Forum Index : Microcontroller and PC projects : PicoM + GFXterm: editor highlighting not correct
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6604 |
You have to set it up for white background as usual then all seems OK A pity it's Windows only. There is a kitty for Linux but very different beast. Jim VK7JH MMedit |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9135 |
Ah, but will it Wine? :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Probably, TeraTerm does. No help for RPi users. Jim VK7JH MMedit |
so it doesn't work out-of-the-box, ie with a black background? many folks would not consider a white background 'normal' or desirable. cheers, rob :-) |
The PicoMite problem seems to have been fixed for both GFXterm and PuTTY in V5.07.00a26; it looks like it is now using the same standard white/green/cyan/magenta palette as the CMM2. Thanks for acting @matherp. Best wishes, Tom Edited 2021-06-18 19:58 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
