Forum Index : Microcontroller and PC projects : PicoMite/PicoMiteVGA V5.07.03 release candidates
that seems to have fixed it, tested on an 82k basic file. the stuttering i was seeing before consisted of random pauses of up to 360ms. with the version you just posted, pauses greater than 10ms are ALL between 37ms and 40ms. there is no longer any visible stuttering for an MX170: pauses greater than 10ms are all between 20ms and 40ms. cheers, rob :-) |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11854 |
Not related to your issue. One possible cause is duplicate function or subroutine names |
| wolfme Regular Member Joined: 26/10/2021 Location: GermanyPosts: 43 |
ok, thanks, i've checked that again. No duplicates. |
Please post your file and I'll try it |
i think i have figured it out: I use more than 255 labels to jump the read command to the correct data line with restore <label> like this: _H01: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H01 _H02: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H02 _H03: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H03 _H04: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H04 _H05: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H05 _H06: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H06 _H07: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H07 _H08: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H08 _H09: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H09 _H0A: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0A _H0B: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0B _H0C: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0C _H0D: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0D _H0E: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0E _H0F: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0F _H10: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H10 _H11: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H11 _H12: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H12 _H13: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H13 _H14: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H14 _H15: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H15 _H16: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H16 _H17: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H17 _H18: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H18 _H19: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H19 _H1A: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H1A _H1B: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H1B _H1C: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H1C _H1D: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H1D _H1E: Data 6, &H0F,&H02,&H94,&HDF,&HB0,&H90 ' &H1E NZ Sign _H1F: Data 6, &H00,&H08,&H9F,&HD1,&HB0,&H90 ' &H1F SZ Sign _H20: Data 4, &H00,&H00,&H00,&H00 ' &H20 space _H21: Data 5, &H00,&H06,&H5F,&H06,&H00 ' &H21 ! _H22: Data 6, &H00,&H07,&H03,&H00,&H07,&H03 ' &H22 " _H23: Data 6, &H00,&H24,&H7E,&H24,&H7E,&H24 ' &H23 # _H24: Data 6, &H00,&H24,&H2B,&H6A,&H12,&H00 ' &H24 $ _H25: Data 6, &H00,&H63,&H13,&H08,&H64,&H63 ' &H25 % _H26: Data 6, &H00,&H36,&H49,&H56,&H20,&H50 ' &H26 & _H27: Data 4, &H00,&H07,&H03,&H00 ' &H27 ' _H28: Data 4, &H00,&H3E,&H41,&H00 ' &H28 ( _H29: Data 4, &H00,&H41,&H3E,&H00 ' &H29 ) _H2A: Data 6, &H00,&H08,&H3E,&H1C,&H3E,&H08 ' &H2A * _H2B: Data 6, &H00,&H08,&H08,&H3E,&H08,&H08 ' &H2B + ... ... _HFF: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &HFF In RC1 this worked, in RC6 not. If i read all this data into an array, then it works. |
reducing labels works... |
I've put labels into a hash table from RC5. Previously they were very inefficient - sequential search through the code. There is now a limit of a total of 192 labels and subroutines/functions. I perhaps should have mentioned this However, Filling the table should not die in such a bad way. Please post your full list of labels and data so I can use it to fix the code to die more gracefully. Thanks |
I've put labels into a hash table from RC5. Previously they were very inefficient - sequential search through the code. There is now a limit of a total of 192 labels and subroutines/functions. I perhaps should have mentioned this However, Filling the table should not die in such a bad way. Please post your full list of labels and data so I can use it to fix the code to die more gracefully. Thanks oh, ok. Here we go : 'June / december solistic 'Sommer- / Wintersonnwende 2020 - 2149 _solistic: Data 2020,20,21,2021,21,21,2022,21,21,2023,21,22,2024,20,21,2025,21,21,2026,21,21,2027,21,22,2028,20,21,2029,21,21 Data 2030,21,21,2031,21,22,2032,20,21,2033,21,21,2034,21,21,2035,21,22,2036,20,21,2037,21,21,2038,21,21,2039,21,22 Data 2040,20,21,2041,21,21,2042,21,21,2043,21,22,2044,20,21,2045,21,21,2046,21,21,2047,21,22,2048,20,21,2049,20,21 Data 2050,21,21,2051,21,21,2052,20,21,2053,20,21,2054,21,21,2055,21,21,2056,20,21,2057,20,21,2058,21,21,2059,21,21 Data 2060,20,21,2061,20,21,2062,21,21,2063,21,21,2064,20,21,2065,20,21,2066,21,21,2067,21,21,2068,20,21,2069,20,21 Data 2070,21,21,2071,21,21,2072,20,21,2073,20,21,2074,21,21,2075,21,21,2076,20,21,2077,20,21,2078,20,21,2079,21,21 Data 2080,20,21,2081,20,21,2082,20,21,2083,21,21,2084,20,20,2085,20,21,2086,20,21,2087,21,21,2088,20,20,2089,20,21 Data 2090,20,21,2091,21,21,2092,20,20,2093,20,21,2094,20,21,2095,21,21,2096,20,20,2097,20,21,2098,20,21,2099,21,21 Data 2100,21,21,2101,21,22,2102,21,22,2103,22,22,2104,21,21,2105,21,22,2106,21,22,2107,22,22,2108,21,21,2109,21,22 Data 2110,21,22,2111,21,22,2112,21,21,2113,21,22,2114,21,22,2115,21,22,2116,21,21,2117,21,22,2118,21,22,2119,21,22 Data 2120,21,21,2121,21,21,2122,21,22,2123,21,22,2124,21,21,2125,21,21,2126,21,22,2127,21,22,2128,21,21,2129,21,21 Data 2130,21,22,2131,21,22,2132,21,21,2133,21,21,2134,21,22,2135,21,22,2136,21,21,2137,21,21,2138,21,22,2139,21,22 Data 2140,20,21,2141,21,21,2142,21,22,2143,21,22,2144,20,21,2145,21,21,2146,21,22,2147,21,22,2148,20,21,2149,21,21 _H01: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H01 _H02: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H02 _H03: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H03 _H04: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H04 _H05: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H05 _H06: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H06 _H07: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H07 _H08: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H08 _H09: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H09 _H0A: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0A _H0B: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0B _H0C: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0C _H0D: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0D _H0E: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0E _H0F: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H0F _H10: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H10 _H11: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H11 _H12: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H12 _H13: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H13 _H14: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H14 _H15: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H15 _H16: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H16 _H17: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H17 _H18: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H18 _H19: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H19 _H1A: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H1A _H1B: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H1B _H1C: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H1C _H1D: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &H1D _H1E: Data 6, &H0F,&H02,&H94,&HDF,&HB0,&H90 ' &H1E NZ Sign _H1F: Data 6, &H00,&H08,&H9F,&HD1,&HB0,&H90 ' &H1F SZ Sign _H20: Data 4, &H00,&H00,&H00,&H00 ' &H20 space _H21: Data 5, &H00,&H06,&H5F,&H06,&H00 ' &H21 ! _H22: Data 6, &H00,&H07,&H03,&H00,&H07,&H03 ' &H22 " _H23: Data 6, &H00,&H24,&H7E,&H24,&H7E,&H24 ' &H23 # _H24: Data 6, &H00,&H24,&H2B,&H6A,&H12,&H00 ' &H24 $ _H25: Data 6, &H00,&H63,&H13,&H08,&H64,&H63 ' &H25 % _H26: Data 6, &H00,&H36,&H49,&H56,&H20,&H50 ' &H26 & _H27: Data 4, &H00,&H07,&H03,&H00 ' &H27 ' _H28: Data 4, &H00,&H3E,&H41,&H00 ' &H28 ( _H29: Data 4, &H00,&H41,&H3E,&H00 ' &H29 ) _H2A: Data 6, &H00,&H08,&H3E,&H1C,&H3E,&H08 ' &H2A * _H2B: Data 6, &H00,&H08,&H08,&H3E,&H08,&H08 ' &H2B + _H2C: Data 4, &H00,&H60,&HE0,&H00 ' &H2C , _H2D: Data 6, &H00,&H08,&H08,&H08,&H08,&H08 ' &H2D - _H2E: Data 4, &H00,&H60,&H60,&H00 ' &H2E . _H2F: Data 6, &H00,&H20,&H10,&H08,&H04,&H02 ' &H2F / _H30: Data 6, &H00,&H3E,&H51,&H49,&H45,&H3E ' &H30 0 _H31: Data 6, &H00,&H00,&H42,&H7F,&H40,&H00 ' &H31 1 _H32: Data 6, &H00,&H62,&H51,&H49,&H49,&H46 ' &H32 2 _H33: Data 6, &H00,&H22,&H49,&H49,&H49,&H36 ' &H33 3 _H34: Data 6, &H00,&H18,&H14,&H12,&H7F,&H10 ' &H34 4 _H35: Data 6, &H00,&H2F,&H49,&H49,&H49,&H31 ' &H35 5 _H36: Data 6, &H00,&H3C,&H4A,&H49,&H49,&H30 ' &H36 6 _H37: Data 6, &H00,&H01,&H71,&H09,&H05,&H03 ' &H37 7 _H38: Data 6, &H00,&H36,&H49,&H49,&H49,&H36 ' &H38 8 _H39: Data 6, &H00,&H06,&H49,&H49,&H29,&H1E ' &H39 9 _H3A: Data 4, &H00,&H6C,&H6C,&H00 ' &H3A : _H3B: Data 4, &H00,&HEC,&H6C,&H00 ' &H3B ; _H3C: Data 6, &H00,&H08,&H14,&H22,&H41,&H00 ' &H3C < _H3D: Data 6, &H00,&H24,&H24,&H24,&H24,&H24 ' &H3D = _H3E: Data 5, &H00,&H41,&H22,&H14,&H08 ' &H3E > _H3F: Data 6, &H00,&H02,&H01,&H59,&H09,&H06 ' &H3F ? _H40: Data 6, &H00,&H3E,&H41,&H5D,&H55,&H1E ' &H40 @ _H41: Data 6, &H00,&H7E,&H11,&H11,&H11,&H7E ' &H41 A _H42: Data 6, &H00,&H7F,&H49,&H49,&H49,&H36 ' &H42 B _H43: Data 6, &H00,&H3E,&H41,&H41,&H41,&H22 ' &H43 C _H44: Data 6, &H00,&H7F,&H41,&H41,&H41,&H3E ' &H44 D _H45: Data 6, &H00,&H7F,&H49,&H49,&H49,&H41 ' &H45 E _H46: Data 6, &H00,&H7F,&H09,&H09,&H09,&H01 ' &H46 F _H47: Data 6, &H00,&H3E,&H41,&H49,&H49,&H7A ' &H47 G _H48: Data 6, &H00,&H7F,&H08,&H08,&H08,&H7F ' &H48 H _H49: Data 5, &H00,&H41,&H7F,&H41,&H00 ' &H49 I _H4A: Data 6, &H00,&H30,&H40,&H40,&H40,&H3F ' &H4A J _H4B: Data 6, &H00,&H7F,&H08,&H14,&H22,&H41 ' &H4B K _H4C: Data 6, &H00,&H7F,&H40,&H40,&H40,&H40 ' &H4C L _H4D: Data 6, &H00,&H7F,&H02,&H04,&H02,&H7F ' &H4D M _H4E: Data 6, &H00,&H7F,&H02,&H04,&H08,&H7F ' &H4E N _H4F: Data 6, &H00,&H3E,&H41,&H41,&H41,&H3E ' &H4F O _H50: Data 6, &H00,&H7F,&H09,&H09,&H09,&H06 ' &H50 P _H51: Data 6, &H00,&H3E,&H41,&H51,&H21,&H5E ' &H51 Q _H52: Data 6, &H00,&H7F,&H09,&H09,&H19,&H66 ' &H52 R _H53: Data 6, &H00,&H26,&H49,&H49,&H49,&H32 ' &H53 S _H54: Data 6, &H00,&H01,&H01,&H7F,&H01,&H01 ' &H54 T _H55: Data 6, &H00,&H3F,&H40,&H40,&H40,&H3F ' &H55 U _H56: Data 6, &H00,&H1F,&H20,&H40,&H20,&H1F ' &H56 V _H57: Data 6, &H00,&H3F,&H40,&H3C,&H40,&H3F ' &H57 W _H58: Data 6, &H00,&H63,&H14,&H08,&H14,&H63 ' &H58 X _H59: Data 6, &H00,&H07,&H08,&H70,&H08,&H07 ' &H59 Y _H5A: Data 6, &H00,&H71,&H49,&H45,&H43,&H00 ' &H5A Z _H5B: Data 5, &H00,&H7F,&H41,&H41,&H00 ' &H5B [ _H5C: Data 6, &H00,&H02,&H04,&H08,&H10,&H20 ' &H5C \ _H5D: Data 5, &H00,&H41,&H41,&H7F,&H00 ' &H5D ] _H5E: Data 6, &H00,&H04,&H02,&H01,&H02,&H04 ' &H5E ^ _H5F: Data 6, &H80,&H80,&H80,&H80,&H80,&H80 ' &H5F _ _H60: Data 4, &H00,&H03,&H07,&H00 ' &H60 ` _H61: Data 6, &H00,&H20,&H54,&H54,&H54,&H78 ' &H61 a _H62: Data 6, &H00,&H7F,&H44,&H44,&H44,&H38 ' &H62 b _H63: Data 6, &H00,&H38,&H44,&H44,&H44,&H28 ' &H63 c _H64: Data 6, &H00,&H38,&H44,&H44,&H44,&H7F ' &H64 d _H65: Data 6, &H00,&H38,&H54,&H54,&H54,&H08 ' &H65 e _H66: Data 6, &H00,&H08,&H7E,&H09,&H09,&H00 ' &H66 f _H67: Data 6, &H00,&H18,&HA4,&HA4,&HA4,&H7C ' &H67 g _H68: Data 6, &H00,&H7F,&H04,&H04,&H78,&H00 ' &H68 h _H69: Data 4, &H00,&H7D,&H40,&H00 ' &H69 i _H6A: Data 6, &H00,&H40,&H80,&H84,&H7D,&H00 ' &H6A j _H6B: Data 6, &H00,&H7F,&H10,&H28,&H44,&H00 ' &H6B k _H6C: Data 5, &H00,&H00,&H7F,&H40,&H00 ' &H6C l _H6D: Data 6, &H00,&H7C,&H04,&H18,&H04,&H78 ' &H6D m _H6E: Data 6, &H00,&H7C,&H04,&H04,&H78,&H00 ' &H6E n _H6F: Data 6, &H00,&H38,&H44,&H44,&H44,&H38 ' &H6F o _H70: Data 6, &H00,&HFC,&H44,&H44,&H44,&H38 ' &H70 p _H71: Data 6, &H00,&H38,&H44,&H44,&H44,&HFC ' &H71 q _H72: Data 6, &H00,&H44,&H78,&H44,&H04,&H08 ' &H72 r _H73: Data 6, &H00,&H08,&H54,&H54,&H54,&H20 ' &H73 s _H74: Data 6, &H00,&H04,&H3E,&H44,&H24,&H00 ' &H74 t _H75: Data 6, &H00,&H3C,&H40,&H20,&H7C,&H00 ' &H75 u _H76: Data 6, &H00,&H1C,&H20,&H40,&H20,&H1C ' &H76 v _H77: Data 6, &H00,&H3C,&H60,&H30,&H60,&H3C ' &H77 w _H78: Data 6, &H00,&H6C,&H10,&H10,&H6C,&H00 ' &H78 x _H79: Data 6, &H00,&H9C,&HA0,&H60,&H3C,&H00 ' &H79 y _H7A: Data 6, &H00,&H64,&H54,&H54,&H4C,&H00 ' &H7A z _H7B: Data 6, &H00,&H08,&H3E,&H41,&H41,&H00 ' &H7B { _H7C: Data 4, &H00,&H00,&H77,&H00 ' &H7C | _H7D: Data 5, &H00,&H41,&H41,&H3E,&H08 ' &H7D } _H7E: Data 6, &H00,&H02,&H01,&H02,&H01,&H00 ' &H7E _H7F: Data 6, &H00,&H3C,&H26,&H23,&H26,&H3C ' &H7F _H80: Data 6, &H00,&H1E,&HA1,&HE1,&H21,&H12 ' &H80 _H81: Data 6, &H00,&H3D,&H40,&H20,&H7D,&H00 ' &H81 _H82: Data 6, &H00,&H38,&H54,&H54,&H55,&H09 ' &H82 _H83: Data 6, &H00,&H20,&H55,&H55,&H55,&H78 ' &H83 _H84: Data 6, &H00,&H20,&H55,&H54,&H55,&H78 ' &H84 _H85: Data 6, &H00,&H20,&H55,&H55,&H54,&H78 ' &H85 _H86: Data 6, &H00,&H20,&H57,&H55,&H57,&H78 ' &H86 _H87: Data 6, &H00,&H1C,&HA2,&HE2,&H22,&H14 ' &H87 _H88: Data 6, &H00,&H38,&H55,&H55,&H55,&H08 ' &H88 _H89: Data 6, &H00,&H38,&H55,&H54,&H55,&H08 ' &H89 _H8A: Data 6, &H00,&H38,&H55,&H55,&H54,&H08 ' &H8A _H8B: Data 5, &H00,&H01,&H7C,&H41,&H00 ' &H8B _H8C: Data 5, &H00,&H01,&H7D,&H41,&H00 ' &H8C _H8D: Data 5, &H00,&H01,&H7C,&H40,&H00 ' &H8D _H8E: Data 6, &H00,&H70,&H29,&H24,&H29,&H70 ' &H8E _H8F: Data 6, &H00,&H78,&H2F,&H25,&H2F,&H78 ' &H8F _H90: Data 6, &H00,&H7C,&H54,&H54,&H55,&H45 ' &H90 _H91: Data 6, &H00,&H34,&H54,&H7C,&H54,&H58 ' &H91 _H92: Data 6, &H00,&H7E,&H09,&H7F,&H49,&H49 ' &H92 _H93: Data 6, &H00,&H38,&H45,&H45,&H39,&H00 ' &H93 _H94: Data 6, &H00,&H38,&H45,&H44,&H39,&H00 ' &H94 _H95: Data 6, &H00,&H39,&H45,&H44,&H38,&H00 ' &H95 _H96: Data 6, &H00,&H3C,&H41,&H21,&H7D,&H00 ' &H96 _H97: Data 6, &H00,&H3D,&H41,&H20,&H7C,&H00 ' &H97 _H98: Data 6, &H00,&H9C,&HA1,&H60,&H3D,&H00 ' &H98 _H99: Data 6, &H00,&H3D,&H42,&H42,&H3D,&H00 ' &H99 _H9A: Data 6, &H00,&H3C,&H41,&H40,&H3D,&H00 ' &H9A _H9B: Data 6, &H80,&H70,&H68,&H58,&H38,&H04 ' &H9B _H9C: Data 6, &H00,&H48,&H3E,&H49,&H49,&H62 ' &H9C _H9D: Data 6, &H00,&H7E,&H61,&H5D,&H43,&H3F ' &H9D _H9E: Data 6, &H00,&H22,&H14,&H08,&H14,&H22 ' &H9E _H9F: Data 6, &H00,&H40,&H88,&H7E,&H09,&H02 ' &H9F _HA0: Data 6, &H00,&H20,&H54,&H55,&H55,&H78 ' &HA0 _HA1: Data 5, &H00,&H00,&H7D,&H41,&H00 ' &HA1 _HA2: Data 6, &H00,&H38,&H44,&H45,&H39,&H00 ' &HA2 _HA3: Data 6, &H00,&H3C,&H40,&H21,&H7D,&H00 ' &HA3 _HA4: Data 6, &H00,&H7A,&H09,&H0A,&H71,&H00 ' &HA4 _HA5: Data 6, &H00,&H7A,&H11,&H22,&H79,&H00 ' &HA5 _HA6: Data 6, &H00,&H08,&H55,&H55,&H55,&H5E ' &HA6 _HA7: Data 6, &H00,&H4E,&H51,&H51,&H4E,&H00 ' &HA7 _HA8: Data 6, &H00,&H30,&H48,&H4D,&H40,&H20 ' &HA8 _HA9: Data 6, &H3E,&H41,&H5D,&H4B,&H55,&H3E ' &HA9 _HAA: Data 6, &H04,&H04,&H04,&H04,&H04,&H1C ' &HAA _HAB: Data 6, &H00,&H17,&H08,&H4C,&H6A,&H50 ' &HAB _HAC: Data 6, &H00,&H17,&H08,&H34,&H2A,&H78 ' &HAC _HAD: Data 5, &H00,&H30,&H7D,&H30,&H00 ' &HAD _HAE: Data 6, &H00,&H08,&H14,&H00,&H08,&H14 ' &HAE _HAF: Data 6, &H00,&H14,&H08,&H00,&H14,&H08 ' &HAF _HB0: Data 6, &H44,&H11,&H44,&H11,&H44,&H11 ' &HB0 _HB1: Data 6, &HAA,&H55,&HAA,&H55,&HAA,&H55 ' &HB1 _HB2: Data 6, &HBB,&HEE,&HBB,&HEE,&HBB,&HEE ' &HB2 _HB3: Data 6, &H00,&H00,&H00,&HFF,&H00,&H00 ' &HB3 _HB4: Data 6, &H08,&H08,&H08,&HFF,&H00,&H00 ' &HB4 _HB5: Data 6, &H00,&H70,&H28,&H25,&H29,&H70 ' &HB5 _HB6: Data 6, &H00,&H70,&H29,&H25,&H29,&H70 ' &HB6 _HB7: Data 6, &H00,&H70,&H29,&H25,&H28,&H70 ' &HB7 _HB8: Data 6, &H3E,&H41,&H5D,&H55,&H41,&H3E ' &HB8 _HB9: Data 6, &H0A,&HFB,&H00,&HFF,&H00,&H00 ' &HB9 _HBA: Data 6, &H00,&HFF,&H00,&HFF,&H00,&H00 ' &HBA _HBB: Data 6, &H0A,&HFA,&H02,&HFE,&H00,&H00 ' &HBB _HBC: Data 6, &H0A,&H0B,&H08,&H0F,&H00,&H00 ' &HBC _HBD: Data 6, &H00,&H18,&H24,&H66,&H24,&H00 ' &HBD _HBE: Data 6, &H00,&H29,&H2A,&H7C,&H2A,&H29 ' &HBE _HBF: Data 6, &H08,&H08,&H08,&HF8,&H00,&H00 ' &HBF _HC0: Data 6, &H00,&H00,&H00,&H0F,&H08,&H08 ' &HC0 _HC1: Data 6, &H08,&H08,&H08,&H0F,&H08,&H08 ' &HC1 _HC2: Data 6, &H08,&H08,&H08,&HF8,&H08,&H08 ' &HC2 _HC3: Data 6, &H00,&H00,&H00,&HFF,&H08,&H08 ' &HC3 _HC4: Data 6, &H08,&H08,&H08,&H08,&H08,&H08 ' &HC4 _HC5: Data 6, &H08,&H08,&H08,&HFF,&H08,&H08 ' &HC5 _HC6: Data 6, &H00,&H20,&H56,&H55,&H56,&H79 ' &HC6 _HC7: Data 6, &H00,&H70,&H2A,&H25,&H2A,&H71 ' &HC7 _HC8: Data 6, &H00,&H0F,&H08,&H0B,&H0A,&H0A ' &HC8 _HC9: Data 6, &H00,&HFE,&H02,&HFA,&H0A,&H0A ' &HC9 _HCA: Data 6, &H0A,&H0B,&H08,&H0B,&H0A,&H0A ' &HCA _HCB: Data 6, &H0A,&HFA,&H02,&HFA,&H0A,&H0A ' &HCB _HCC: Data 6, &H00,&HFF,&H00,&HFB,&H0A,&H0A ' &HCC _HCD: Data 6, &H0A,&H0A,&H0A,&H0A,&H0A,&H0A ' &HCD _HCE: Data 6, &H0A,&HFB,&H00,&HFB,&H0A,&H0A ' &HCE _HCF: Data 6, &H00,&H5D,&H22,&H22,&H22,&H5D ' &HCF _HD0: Data 6, &H00,&H22,&H55,&H59,&H30,&H00 ' &HD0 _HD1: Data 6, &H00,&H08,&H7F,&H49,&H41,&H3E ' &HD1 _HD2: Data 6, &H00,&H7C,&H55,&H55,&H55,&H44 ' &HD2 _HD3: Data 6, &H00,&H7C,&H55,&H54,&H55,&H44 ' &HD3 _HD4: Data 6, &H00,&H7C,&H55,&H55,&H54,&H44 ' &HD4 _HD5: Data 6, &H00,&H00,&H00,&H07,&H00,&H00 ' &HD5 _HD6: Data 6, &H00,&H00,&H44,&H7D,&H45,&H00 ' &HD6 _HD7: Data 6, &H00,&H00,&H45,&H7D,&H45,&H00 ' &HD7 _HD8: Data 6, &H00,&H00,&H45,&H7C,&H45,&H00 ' &HD8 _HD9: Data 6, &H08,&H08,&H08,&H0F,&H00,&H00 ' &HD9 _HDA: Data 6, &H00,&H00,&H00,&HF8,&H08,&H08 ' &HDA _HDB: Data 6, &HFF,&HFF,&HFF,&HFF,&HFF,&HFF ' &HDB _HDC: Data 6, &HF0,&HF0,&HF0,&HF0,&HF0,&HF0 ' &HDC _HDD: Data 6, &H00,&H00,&H00,&H77,&H00,&H00 ' &HDD _HDE: Data 6, &H00,&H00,&H45,&H7D,&H44,&H00 ' &HDE _HDF: Data 6, &H0F,&H0F,&H0F,&H0F,&H0F,&H0F ' &HDF _HE0: Data 6, &H00,&H3C,&H42,&H43,&H3D,&H00 ' &HE0 _HE1: Data 6, &H00,&HFE,&H4A,&H4A,&H34,&H00 ' &HE1 _HE2: Data 6, &H00,&H3C,&H43,&H43,&H3D,&H00 ' &HE2 _HE3: Data 6, &H00,&H3D,&H43,&H42,&H3C,&H00 ' &HE3 _HE4: Data 6, &H00,&H32,&H49,&H4A,&H31,&H00 ' &HE4 _HE5: Data 6, &H00,&H3A,&H45,&H46,&H39,&H00 ' &HE5 _HE6: Data 6, &H00,&HFC,&H20,&H20,&H1C,&H00 ' &HE6 _HE7: Data 6, &H00,&HFE,&HAA,&H28,&H10,&H00 ' &HE7 _HE8: Data 6, &H00,&HFF,&HA5,&H24,&H18,&H00 ' &HE8 _HE9: Data 6, &H00,&H3C,&H40,&H41,&H3D,&H00 ' &HE9 _HEA: Data 6, &H00,&H3C,&H41,&H41,&H3D,&H00 ' &HEA _HEB: Data 6, &H00,&H3D,&H41,&H40,&H3C,&H00 ' &HEB _HEC: Data 6, &H00,&H9C,&HA0,&H61,&H3D,&H00 ' &HEC _HED: Data 6, &H00,&H04,&H08,&H71,&H09,&H04 ' &HED _HEE: Data 6, &H00,&H00,&H02,&H02,&H02,&H00 ' &HEE _HEF: Data 6, &H00,&H00,&H07,&H03,&H00,&H00 ' &HEF _HF0: Data 6, &H00,&H00,&H08,&H08,&H08,&H00 ' &HF0 _HF1: Data 6, &H00,&H00,&H24,&H2E,&H24,&H00 ' &HF1 _HF2: Data 6, &H00,&H24,&H24,&H24,&H24,&H24 ' &HF2 _HF3: Data 6, &H05,&H17,&H0A,&H34,&H2A,&H78 ' &HF3 _HF4: Data 6, &H00,&H06,&H09,&H7F,&H01,&H7F ' &HF4 _HF5: Data 6, &H00,&H22,&H4D,&H55,&H59,&H22 ' &HF5 _HF6: Data 6, &H00,&H08,&H08,&H2A,&H08,&H08 ' &HF6 _HF7: Data 6, &H00,&H00,&H08,&H18,&H18,&H00 ' &HF7 _HF8: Data 6, &H00,&H06,&H09,&H09,&H06,&H00 ' &HF8 _HF9: Data 6, &H00,&H00,&H08,&H00,&H08,&H00 ' &HF9 _HFA: Data 6, &H00,&H00,&H08,&H00,&H00,&H00 ' &HFA _HFB: Data 6, &H00,&H02,&H0F,&H00,&H00,&H00 ' &HFB _HFC: Data 6, &H00,&H09,&H0F,&H05,&H00,&H00 ' &HFC _HFD: Data 6, &H00,&H09,&H0D,&H0A,&H00,&H00 ' &HFD _HFE: Data 6, &H00,&H3C,&H3C,&H3C,&H3C,&H00 ' &HFE _HFF: Data 6, &H00,&H00,&H00,&H00,&H00,&H00 ' &HFF and - of course - many subs and functions... |
| dMajo Newbie Joined: 18/05/2020 Location: ItalyPosts: 29 |
@matherp as I have understood now the VGA version uses the second core for its video output and this perhaps implies that on the non-VGA version the second core is unused. I have one feature request if possible, for the non-VGA version: if the 'comspec$' can change from "COMn: baud, buf, int, int-trigger, EVEN/ODD, S2, 7BIT" to"COMn: baud, buf, int, int-trigger, EVEN/ODD/USR, S2, 7BIT/8BIT, BRI" for both the ports COM1 and COM2The BRI should indicate bridge mode. The COM2 will fire a second CDC virtual serial port bridged to the COM2 pins. The COM1 will do the same over the existing CDC. The physical port should use the comspec$ specified baudrate (and other params) but it should also listen to the CDC baudrate: - if it have for example 1200 baudrate the traffic goes to the console - if it have any other baud setting it goes to the physical COM1 port. This could allow for easy flashing of other sub-modules connected to the picomite (other mcu with serial bootloader, gps/gsm modules, ...) Here there is an 2-port usb2uart bridge example for the RP2040 USR (user defined) parity This is a minor wish. When programming in assembly and thus having full control over the in-built UART it happens to do serial masters on MCUs that do not support 9bit communication for addressing. In this case I do not use fifo and I toggle the parity register on the fly between the transmitted bytes based upon the byte I have to transmit and thus using the parity as the 9th bit. The stripped parity (9th bit in this case) on the master's receiver is not a problem in an single-master bus where only the queried slave is allowed to send traffic. So perhaps: TGLPAR 'toggle parity register or betterPRINT #1, BYTE1 'transmit byte1 PRINT #1, BYTE2 'transmit byte2 TGLPAR 'toggle parity register PRINT #1, BYTE3 'transmit byte3 TGLPAR 'toggle parity register PRINT #1, BYTE4 'transmit byte4 PRINT #1, BYTE5 'transmit byte5 ... PRINTTGL #1, BYTE1 'transmit byte 1 after toggling the Parity This of course implies that the slaves have 9bit support in their UARTs configured without parity.PRINT #1, BYTE2 'no need to toggle PRINTTGL #1, BYTE3 'transmit byte 3 after toggling the Parity PRINTTGL #1, BYTE4 'transmit byte 4 after toggling the Parity PRINT #1, BYTE5 'no need to toggle ... ALLdataEE.com EDU Promos |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10039 |
Can't download any of the latest betas posted by matherp. Anyone else seeing this? Clicking on the link results in nothing happening. Right-clicking/Save linked content as.... results in 100% download, but the download never completes, and I can only pause or cancel. Pause does nothing, cancel deletes the download thus far. Anyone else seeing this? EDIT: The links to Geoff's website are the ones that won't work(for me). There was a ZIP that matherp uploaded to the thread in page two after Rob(robert.rozee) posted some comments - that downloads fine, but any link to Geoff's website fails. Edited 2022-01-04 16:05 by Grogster Smoke makes things work. When the smoke gets out, it stops! |
Anyone else seeing this? No problems here. Firefox complains about not safe but "download anyway" fixes that. (I think that is because it's http instead of https.) Jim VK7JH MMedit |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3379 |
Going to Geoff's website in a new tab and downloading from there always works. |
To do what you want the USB would have to be a CDC host. The code you linked is for a CDC device which wouldn't do the job. The RP2040 H/W does not support 9-bits of data, only 8 bits + specific parity. To do what you want it is trivial to modify the Pico PIO UART example. Check the Pico SDK or Pico RP2040 manual to see how simple this is. |
http://geoffg.net/Downloads/picomite/PicoMite_Beta.zip PicoMite/PicoMiteVGA V5.07.03RC7 New command FLUSH [#]filenumber This causes any outstanding writes to a file to be written to disk or waits for serial output to be complete on an open com port Fixed error handling for too many labels and/or functions and subroutines (max 224) Improved USB console receive algorithm For those having problems with Geoff's site PicoMite_Beta.zip Edited 2022-01-04 19:43 by matherp |
I've just tried another browser that's happy on Geoff's site: Ungoogled Chromium. Google will hate this. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 411 |
With Google Chrome this works for me: 1. copy the address: http://geoffg.net/Downloads/picomite/PicoMite_Beta.zip 2. open a new tab in Crome 3. paste the address and insert an "s": http:// -> https:// 4. enter...and the download starts |
all working well with RC7. spotted one small cosmetic: > > flash save 9 Error : 9 is invalid (valid is 1 to 0) > (at end of error message - should be 7, not 0) cheers, rob :-) addendum: this is with the NON-VGA version Edited 2022-01-04 21:21 by robert.rozee |
Peter When posting the links could you change the http to https please? that will solve everyones issues with various browsers http://geoffg.net/Downloads/picomite/PicoMite_Beta.zip to https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip to https please? that will solve everyones issues with various browsers The issue is some browsers will only allow access/downloads for https You can turn it off in settings, or allow downloads from http as well it actually makes sense to use the https link seeing it works. Edited 2022-01-04 21:49 by lew247 |
| Calli Regular Member Joined: 20/10/2021 Location: GermanyPosts: 74 |
So Mouse fixed! Thanks! I have one thing which bugs me but is maybe a feature request: After an error the cursor is placed at the line where the error occured. Great! Would it be possible to always go to the line where the cursor was when leaving the editor? Be it run or save. That would avoid scrolling too much after a quick change in longer programs. Cheers, Carsten |
Would it be possible to always go to the line where the cursor was when leaving the editor? I'm confused. You like the fact that the cursor is placed on an error... but then you ask for something different! Just to be clear, the behaviour on starting the editor should be: - If an error occurred the cursor is placed on the line with the error. - Otherwise the cursor is placed on the last line edited. - If the editor has not been used since start up, the cursor is placed at the start. Geoff Edited 2022-01-04 23:11 by Geoffg Geoff Graham - http://geoffg.net |
