Local Time 23:57 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/PicoMiteVGA V5.07.05 betas
     Page 3 of 11
led-bloon
Posted: 07:40am 15 Jun 2022
Just finished re-compiling PicoMiteVGA V5.07.05b7 for other hardware
and noticed that the instability of horizontal sync (126 MHz Mode 1)
has been fixed, when compiling with a RaspberryPi
Thanks Peter
Miss you George
Posted: 11:34am 15 Jun 2022
  matherp said  Option display rows,cols
Maximum cols is 240
Thank you. That solves my problem.
Posted: 12:55pm 15 Jun 2022
  Volhout said  Peter,
There is a serious problem with PLAY WAV "filename.wav".
It looks like the audio buffers overlap with the tile memory (colors) in mode 1.
Using 5.07.05b6
The audio sounds okay though. Even if I do a CLS in mode 1.
When I used the switchmode powersupply there was all kinds of noise and even the SD card trafic was audible. Now with the linear regulator all is noice.
The only thing that is audible is a little noise in the silent passages, but it is constant noise, and can very well come from the 11 bit resolution.
Needed to connect my living room audio system to be able to distinguish this noise. On (my) headset it is not audible at all.
Oh, doesn't look good.
Maybe post a short test to show it, so Peter can fix it?
Posted: 01:15pm 15 Jun 2022
PicoMite V5.07.05b8
Fixes crashing bug if edit is used after running a program with IR input
Removes support for the GDEH029A1 display as this controller is now obsolete
Reduces available RAM for VGA version from 108Kb to 104Kb to solve memory corruption issue.
Warning: this version will erase all flash and options - backup saved programs as required
Posted: 08:15am 16 Jun 2022
PicoMite V5.07.05b9
Fixes bug in SDK that caused SPI clock to set to wrong level before first transaction
Improved error checking of SETPIN command to avoid crashes
SETPIN for PWM no longer needs to specify the channel and port e.g. "SETPIN 1,PWM" is now accepted
Posted: 10:22am 17 Jun 2022
Hi Peter,
That solved the problem with the screen corruption. Thanks....
However.. When I am playing a song (it runs in the background) I cannot list a directory at the same time. Is that intentional ?
> play wav "track 1.wav"
> files
Error : Not enough memory
Edited 2022-06-17 20:33 by Volhout
cosmic frog
Posted: 04:50pm 17 Jun 2022
> files
I also have this problem. Sometimes it will actually work but most times says not enough memory.
I thought it maybe limitations of the hardware.
Dave.
Posted: 05:24pm 17 Jun 2022
There will be a buffer in RAM for the WAV data. How big it is I've no idea. I suppose that it might have to be a reasonable size, to read a certain numbers of sectors from the SDcard. The entire WAV file won't be loaded at once unless it's a brief sound effect - most are much bigger than the available RAM as WAV is uncompressed.
Posted: 05:39pm 17 Jun 2022
I am not sure if Peter can make this work at all, hence the question. Maybe it is a matter of RAM allocation, but maybe it is MMBasic trying to access the sd card to get the FAT, and at tje same time the WAV player tries to read new data. And that is quite frequent if you immagine that WAV files can be 50Mbyte for 3 minutes = 180 seconds. That is 300k per second. With RAM buffers sized 60k, that is 5x per second. So very frequent.
Michal
Posted: 08:06am 18 Jun 2022
And can picomite play mp3? For 128kbps it is only 16kB per second from the SD card.
Michal
Posted: 08:23am 18 Jun 2022
No, sorry. It's wav files only on the PicoMite.
Posted: 08:24am 18 Jun 2022
"And can picomite play mp3?"
The manual makes no mention, perhaps it can be done if you write a CSub.
For true retro sound get the background music from a radio-cassette player sitting behind the monitor. ;-)
Michal
Posted: 08:39am 18 Jun 2022
The processor power should be enough:
https://learn.adafruit.com/mp3-playback-rp2040
Michal
Posted: 09:17am 18 Jun 2022
Remember how MP3 works. It's compressed. You don't play the MP3 itself, you decompress it on the fly and play the resulting bit stream. That decompression process needs two things - processor power and RAM. The Pico may well be able to handle the processing, but it may not have enough spare RAM for decompression once things like a display, the user program, variables and MMBasic itself have taken their share. There's only 264K in total.
Posted: 11:19am 18 Jun 2022
The CMM2 has MP3. MMB4W has MP3. If the PicoMite could do it, it would have MP3. It can't. Note I said the. PicoMite not the RP2040
Edited 2022-06-18 21:21 by matherp
Michal
Posted: 12:32pm 18 Jun 2022
Maybe some less memory-hungry compression method and algorithm?
Michal
Edited 2022-06-18 22:41 by Michal
Posted: 01:42pm 18 Jun 2022
Why? You're still extremely limited for RAM. It's pointless decompressing any music files when you can't fit them into RAM. You may as well just stream WAV from a SD card, use less processor power and less RAM and stand a chance of getting get better sound quality too.  :)
Posted: 08:52am 21 Jun 2022
PicoMite V5.07.05b11
Fixes bug when using "ON KEY int" command
Enables operation up to 378MHz
Maximum program sizes now 100Kb(PicoMiteVGA) and 124Kb(PicoMite)
fred777
Posted: 09:34am 21 Jun 2022
I know that linux users will complain but shouldn't those "/" characters shown in CWD$ and FILES really be "\"? I mean its FAT after all...
> files
A:/STUFF
0 directories, 0 files
should be
> files
A:\STUFF
Posted: 11:41am 21 Jun 2022
Peter,
Is there room to discuss the Program/RAM split ? personally I'd rather give up some of the Program RAM in exchange for getting to ~160K of variable RAM.
Also am I correct in believing that processed CSUBs take up space in the variable RAM segment ?
     Page 3 of 11
