Forum Index : Microcontroller and PC projects : Pico Gamer
| SimpleSafeName Guru Joined: 28/07/2019 Location: United StatesPosts: 351 |
So, I printed it out three times (I'm about to print it a fourth time), and here's a photo of the first two top half of the cases: ![]() Neither one of them came out all that great, and they don't remotely approach the quality of Geoff's case. But they appear to be useable. And each one printed in about an hour, for about 25 cents. As for my experiences: So there's something going on with my QIDI X-MAX3. It's putting out crappy prints. I did a bit of maintenance and, meh, I'll have to keep looking for the problem. Specifically it want to print out rough edges as if it were have a Z-banding problem. The face of it is a bit rough, but I am using my PEI sheet (designed for excellent adhesion of the plastic to the bed), so that is to be expected. That part of the print came out perfect. So good that I can see where I scraped the PEI off of the bed in a few places (oops). For those who are curious, here's how I put the lettering on the .STL in OpenSCAD: $fn=64; difference() { translate([0,0,6.5]) import("TopNoLetters.STL"); rotate([180,0,90]) translate([-34,-38,-1]) linear_extrude(4) text("START", font = "Archivo Black", size=4); rotate([180,0,90]) translate([-9.4,-38,-1]) linear_extrude(4) text("SEL", font = "Archivo Black", size=4); rotate([180,0,90]) translate([11,-38,-1]) linear_extrude(4) text("OFF", font = "Archivo Black", size=4); rotate([180,0,90]) translate([26.2,-38,-1]) linear_extrude(4) text("ON", font = "Archivo Black", size=4); rotate([180,0,90]) translate([55.5,26,-1]) linear_extrude(4) text("VOL", font = "Archivo Black", size=4); rotate([180,0,90]) translate([75.0,-2.95,-1]) linear_extrude(4) text("A", font = "Archivo Black", size=6); rotate([180,0,90]) translate([57,-12,-1]) linear_extrude(4) text("B", font = "Archivo Black", size=6); }; And, why yes, that is an E&L MT-80Z trainer from days gone by that I'm using as a backdrop for the photo. :) Edited 2024-03-25 19:22 by SimpleSafeName |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6094 |
That MT-80Z looks a lot like the "Micro Professor" that my nephew owned in the 80's. ![]() Volhout Edited 2024-03-25 22:21 by Volhout PicomiteVGA PETSCII ROBOTS |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1532 |
The filament always needs something to lay on. Due to the curves at the edges, from the front to the sides, you should set the layer height setting to fine. I had a usable result at 0.12 mm layer height with a .6mm Nozzle (estimated 5 hours printing time) Edited 2024-03-25 22:52 by Martin H. 'no comment |
The Keyboard and the ROM are different, other than that I think that they are the same. I bought this particular MT-80Z for the books that came with it. And in the listing the seller mentioned that he had fired it up using the MPF-I power supply, "Since it was the same as the MPF-I". I wondered what he was talking about. I never knew. LOL! Later on, E&L swapped out the MPF stickers with their own. And the complete trainer comes with another larger board (with the breadboard that you see) that has its own Z80. So I was fooled. :) BTW, I have the same book for my MPF-II (I gave my MPF-I away to a YouTuber "The Clueless Engineer" in Australia). Edited 2024-03-26 02:29 by SimpleSafeName |
I used 0.12mm on this print (0.12mm is the best that comes "standard" with the slicer), and it took 2 hours. I'm now seeing "defects" in the print which appear to have come from my "repair" of the board. It looks like my repairs worked, the layer shift appears to have gone away revealing the pattern created by MeshMixer. The only thing that my fixed board has going for it is that it will play nice with OpenSCAD. It would be nice if OpenSCAD ignored minor errors since they apparently are the only ones that care. FWIW, the errors in the Thorn gun caused severe printing problems, so sometimes you have no choice. |
Hi Geoff, Will you be producing new firmware for the Pico Gamer? It occurred to me at this late stage whether the size of flash memory (2,4 or 16 meg) could be specified with an OPTION command and whether that would save you from having to produce new firmware each time there is a change or bug fix? Bill Edit: That could be useful to do away with the SD card in some applications. The battery charging circuit could be ignored (maybe). Edited 2025-01-03 17:04 by Turbo46 Keep safe. Live long and prosper. |
| Geoffg Guru Joined: 06/06/2011 Location: AustraliaPosts: 3366 |
No, I'm not planning to. The only things that need updating are the games which can be easily updated/added to by the user. The flash memory size is a hardware thing (not an MMBasic option). So, no, individual images are required to suit the hardware. Sorry. I don't understand this at all. Geoff Geoff Graham - http://geoffg.net |
@turbo, The picogamer firmware is a uf2 file that contains MMBasic and games and a menu system. This set of programs will still work on the designed hardware. No need to update. The mmbasic in this uf2 will be 5.08.00 or maybe 5.09.00-ish, and the games work fine on that version of mmbasic. The only reason for Geoff change the uf2 image would be if many games would be written for 6.00.01 that would not run on 5.08.00 anymore. Alternatively a backport of the new games to 5.08.00 would be needed for these games. It would be essential though, that the 5.08.00 user manual is available, so games writers can backport the 6.00.01 games. Maybe have the 5.08.00 user manual added to the picogamer web page. Volhout Edited 2025-01-04 02:04 by Volhout PicomiteVGA PETSCII ROBOTS |
I try to keep old versions of the firmware (with manuals) available. They are under the archive link. ![]() Geoff Graham - http://geoffg.net |
I realize that the different flash sizes mean different hardware but I thought, apparently wrongly, that an OPTION command could be used to allow the firmware to know what size flash was available and operate accordingly. I expect that it would require a change to the firmware by Peter to accommodate it but I also though it would avoid the need for multiple versions of MMBasic just for the Pico Gamer. I was trying to suggest that, if more flash was available, that a computer could be built without the need for an SD card. Something like (say) the Design #1 that you presented in Silicon Chip magazine but without the need for an SD card. That was the point of my questions. How could you write and test games or other programs for the Pico Gamer that required new features provided in new versions of MMBasic? I was hoping to avoid any on-going work for Geoff to support any future changes to MMBasic. A uf2 image of the complete package is a nice thing to have but is it really necessary? Bill Keep safe. Live long and prosper. |
I agree and is something that I will fix. Not soon, because I am going away for a few months, but I will do that. Geoff Geoff Graham - http://geoffg.net |
Geoff, Now there is a Waveshare RP2350-plus it looks compatible with the RP2040-plus. Do you think it would be a worthwhile upgrade? Bill Edit: I've bought one anyway. Edited 2026-03-04 16:11 by Turbo46 Keep safe. Live long and prosper. |
I believe that it would work, but I have not tried it, basically because the RP2040-plus did a great job in the first place and all my prototypes have the module firmly soldered in place. Because the games were tested and worked on the RP2040-plus I'm not sure that it would be a worthwhile upgrade. If you decide to use the RP2350-plus I would be interested in your results with it. Geoff Edited 2026-03-04 17:34 by Geoffg Geoff Graham - http://geoffg.net |
Now there is a Waveshare RP2350-plus it looks compatible with the RP2040-plus. Do you think it would be a worthwhile upgrade? Bill Edit: I've bought one anyway. Hi Bill, Please be aware that Geoff released 2 binary images for the PicoGamer that have RP2040 MMBasic binary inside (4Gbyte and 16Gbyte). When you change to a RP2350 the MMBasic binary may not work, and thus the unit may not boot after installing the UF2 file. For Game*Mite there is an alternative install method originated from Tom (thwill). One that I also described in Game*Mite thread for upgrading to newer versions of MMBasic. thread That procedure first describes you install the latest MMBasic version (choose 2040 or 2350) and after that copy all the files to the required locations. This is the method you also should use until Geoff creates 2 new UF2 files for 2350 variants. Since the RP2350 MMBasic has additional functionality (keywords) you may have to adapt some of the MMBasic programs to work around this. But in essence (on Game*Mite with genuine RP modules) the Pico2 (RP2350) works great and gives a speed advantage over Pico (RP2040) in games, so much that in PicoFrog (Frogger) I had to differentiate during run time to keep both play similar. Volhout Edited 2026-03-04 17:46 by Volhout PicomiteVGA PETSCII ROBOTS |
Good point Volhout. I will pull the individual files out so that they can be loaded with any version of MMBasic (ie, not bundled). I will update my website with this and post on this thread. Might take a week or two. Geoff Geoff Graham - http://geoffg.net |
Thanks Volhout, I had forgotten about the memory size. Thanks Geoff, Much appreciated. The board is coming by snail mail so I may it not get it before then anyway. Bill Keep safe. Live long and prosper. |
| PilotPirx Senior Member Joined: 03/11/2020 Location: GermanyPosts: 134 |
Is anyone ordering the circuit boards in Germany? I would be interested in one! |
@Geoffg, I suppose it has been considered whether catering for the extra ram in the Waveshare boards could be done by an OPTION RAM?. That could allow the boards to be used in other projects without special versions of the firmware? Bill Keep safe. Live long and prosper. |
Sorry Bill but you have completely confused me there. There is no OPTION RAM (that I know of), do you mean OPTION PSRAM? But there is no PSRAM on the Waveshare RP2040-Plus. As I said, I'm confused. Geoff Geoff Graham - http://geoffg.net |
Sorry Geoff, What I meant was, could it be added to the firmware as option that would allow you to set how much RAM was available like four or 16 meg. To allow the firmware to cater for those waveshare modules instead of having to build a special firmware for each case. I guess that’s probably one for Peter these days, but I don’t know. Bill Keep safe. Live long and prosper. |
