Local Time 10:28 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maths precedence error in MMBasic? Any maths gurus out there?
     Page 3 of 3
zeitfest
Posted: 01:19am 09 May 2024
  Quote   how many programs genuinely have code that does double consecutive exponentiations (with no parentheses to force the order) and wasn't tested to check it worked as intended?
+1
I agree, although there are "thousands built" and it might be expected that at least the initial testing would find it.
Then again, It's not as if NASA is using this stuff.
NPHighview
Posted: 06:42pm 09 May 2024
Jim - I love that you're quoting "Numerical Recipes in C", one of my favorites. I have a couple of others that you might like:
"Numerical Methods that Usually Work" - Acton (see cover photo - a hoot!)
"Math Toolkit for Realtime Programming" - Crenshaw
...and my favorite, "Mathematical Methods in the Physical Sciences" by Mary Boas (I've worked pretty much every problem in that book, under Boas' stern tutelage)
Live in the Future. It's Just Starting Now!
darthvader
Posted: 03:23pm 12 May 2024
HP Prime G2 give me : 3.00012207031
homa
Posted: 07:44pm 12 May 2024
  Volhout said  P.S. is there a note in the GW_Basic manual for this ? Guess not....
Hi Volhout,
I have consulted my old GW-Basic 3.2 reference manual in printed form (unfortunately in German) :-)
It actually gives some information about this – everything used to be better™!
But see for yourself. It says something about the function hierarchy and the order from left to right, unless brackets are used first.
Matthias
twofingers
Posted: 01:18am 13 May 2024
Thanks Matthias!
The  English version is not quite as clear. But leads to the same result.
Two consecutive operators must be separated by parentheses.
This means that if you follow the instructions you will get correct results.
EDIT
  Quote  3-18              ALLGEMEINE EIGENSCHAFTEN VON GWBASlC
Aufeinanderfolgende Operaloren derselben Hierarchiestufe werden von links nach rechts abgearbeitet. Die Hierarchie kann durch Verwendung von Klammern aufgehoben werden. Geklammerte Ausdrücke werden grundsätzlich zuerst bearbeitet. Bei geschachtelten Klammerausdrücken werden grundsätzlich der innerste Klammerausdruck zuerst bearbeitet.
Translation:
  Quote  3-18 GENERAL CHARACTERISTICS OF GWBASlC
Consecutive operators of the same hierarchy level are processed from left to right. The hierarchy can be broken by using parentheses. Expressions in parentheses are always processed first. For nested parentheses expressions, the innermost parentheses expression is always processed first.
Edited 2024-05-13 11:30 by twofingers
The lone and ...
zeitfest
Posted: 01:56am 13 May 2024
Integer math gives the answer as 3
How is the negation operator processed in MMBasic ?
(ed) To be fair, it is a reasonable thing for Basic to test for repeated exponentiation, and flag it so as to enforce bracketing.
Edited 2024-05-13 12:14 by zeitfest
Posted: 07:02am 13 May 2024
Ah, so the answer is INT(PI). Is that a coincidence?  :)
Nothing wrong with integers. I always use them when counting on my fingers and toes.
Posted: 09:58am 13 May 2024
Hi Mick,
Unfortunately I cannot use integers for fingers. 9.5 is my count. But toes are still integers...
Edited 2024-05-13 19:59 by Volhout
     Page 3 of 3
