Local Time 10:42 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.01.00D release candidates
     Page 3 of 3
EDNEDN
Posted: 02:06pm 20 Nov 2025
  ville56 said  EDNEDN,
many thanks for providing us with an updated version of MMDebug.
I have a question:
got the message "Options were not correctly set for MMDebug. That is fixed now".
You are very welcome.   It was fun to write!
That message is probably not valuable anymore and can be ignored.   I'll double check that it can be removed and get rid of it for the next release.   (And eliminate the confusion it caused.)
That message is only complaining that the screen's (X,Y) dimensions are not big enough to support the debugger taking over the upper right corner of the screen.
The 'D' version of PicoMite_v6.01.00RC??D firmware has the screen size defaulting to (145,45) instead of (80,24).
Obviously, if MMBasic is going to support retro-hardware the (80,24) size used to make a lot of sense.  That is what was mostly available back in the day.   But with today's high resolution screens being used as an ASCII terminal by the user that limitation doesn't have much value anymore.
Perhaps somebody can provide a reason why it still makes sense to have the (80,24) screen size be the default, and if so, the screen size could be adjusted higher (quietly!!!!) if the person invokes the debugger.    If there are reasons to keep the default at (80,24) please explain the thinking!
Edited 2025-11-21 00:11 by EDNEDN
Posted: 03:35pm 20 Nov 2025
On a real VT100 the font is 8x9 pixels, giving a display of 53 lines of 80 characters on a 640x480 pixel screen. It may not be possible to generate this using the timing on the Picomite.
The default of 80x24 was almost certainly chosen as it will display well on a TFT LCD display as well as a VGA monitor. Making the display width wider takes you out of the native width for most LCD displays so the display might be poor. Remember that you can't enter OPTION DISPLAY unless you can read the screen. :)
EDNEDN
Posted: 04:31pm 20 Nov 2025
I was thinking the 80x24 size was chosen because that is what the old 'Glass CRT' screens were.    I think that is what the old VT-52's were???    And of course that carried over into what the LCD panels were developed to handle.
It is easy enough to just quietly set the screen size larger and not issue a caution message.   Probably that is what makes sense.
And RC18 just showed up...   So that will provide an opportunity to resolve this.
Posted: 05:10pm 20 Nov 2025
Strictly speaking the line length was 79 characters followed by a CR character. However, by using them carefully you could display 80. :)
We had no VGA monitor for the Picomite at first. Only LCD. 640x480 became "the high resolution VGA standard" by virtue of the IBM PC, so I suppose it was a good one to copy.
After that you get the characters per line and number of lines decided by what timings you can accommodate. The VT100 used 53 lines of 9 pixel high character cells to get 477 rows of pixels, losing the other 3 rows. The characters were 7 pixels high, plus two rows either blank or for descenders, which touched the row below.
EDNEDN
Posted: 05:47pm 20 Nov 2025
PicoMite V6.01.00RC18D
Built using PicoMite V6.01.00RC18 with the code updated to silently deal with improper screen size options.
PicoMite_v6.01.00RC18D---Documentation.zip
PicoMiteV6.01.00RC18D---Firmware.zip
Edited 2025-11-21 04:01 by EDNEDN
EDNEDN
Posted: 06:05pm 21 Nov 2025
PicoMite V6.01.00RC19D now available.
Built using PicoMite V6.01.00RC19 with the new Regular Expression engine.
PicoMite_v6.01.00RC19D---Documentation.zip
PicoMite_v6.01.00RC19D---Firmware.zip
Edited 2025-11-22 04:06 by EDNEDN
EDNEDN
Posted: 05:03pm 25 Nov 2025
PicoMite V6.01.00RC20D now available.
There are currently no known issues with the debugger.
Built using PicoMite V6.01.00RC20 with the new mid$(), lmid(), instr() and linstr() functions.  And of course, the new array dimensioning capabilities.
PicoMite_v6.01.00RC20D---Documentation.zip
PicoMite_v6.01.00RC20D---Firmware.zip
Posted: 05:30pm 25 Nov 2025
EDNEDN, I've tightened the size of the images back to the minimum. I don't know how much extra code you are adding but you need to make sure the image isn't too big for the size allowed in Configuration.h set by FLASH_TARGET_OFFSET.
I've created a script to tell me the minimum to set that to rounded up to 16K which is the minimum flash erase size. You might want to just check your images. If it is undersized most of MMbasic will still run but the user will see unexplained bugs.
import sys
def parse_hex(filename):
   highest = 0
   ext_addr = 0
   with open(filename, 'r') as f:
       for line in f:
           if not line.startswith(':'):
               continue
           length = int(line[1:3], 16)
           addr = int(line[3:7], 16)
           rectype = int(line[7:9], 16)
           if rectype == 4:  # Extended Linear Address
               ext_addr = int(line[9:13], 16)
           elif rectype == 0:  # Data record
               full_addr = (ext_addr << 16) + addr
               end_addr = full_addr + length
               if end_addr > highest:
                   highest = end_addr
   return highest
def round_up(value, boundary):
   return (value + boundary - 1) // boundary * boundary
if __name__ == "__main__":
   if len(sys.argv) < 2:
       print("Usage: python GetHighestHexAddress.py firmware.hex")
       sys.exit(1)
   filename = sys.argv[1]
   highest = parse_hex(filename)
   # Round up to 16-byte boundary
   safe16 = round_up(highest, 16)
   # Round up to 16KB boundary
   safe16k = round_up(highest, 0x4000)
   # Compute block index relative to flash base
   flash_base = 0x10000000
   blocks = (safe16k - flash_base) // 1024
   print(f"Highest written address: 0x{highest:X}")
   print(f"Rounded up to 16-byte boundary: 0x{safe16:X}")
   print(f"Rounded up to 16KB boundary: 0x{safe16k:X}")
   print(f"Equivalent number of 1KB blocks from flash base: {blocks}")
My current build file runs this automatically but the check is manual
set "fixed_string=V6.01.00RC20"
set "extension=.uf2"
set "directory=../"
ren buildRP2040L build
cd build
cmake -G "NMake Makefiles" -DCOMPILE=PICO ..
nmake
set "filename=PicoMiteRP2040"
if exist "%filename%%fixed_string%%extension%" del "%filename%%fixed_string%%extension%"
copy "PicoMite.uf2" "%directory%%filename%%fixed_string%%extension%"
findstr /B ".heap" PicoMite.elf.map
python ../GetHighestHexAddress.py PicoMite.hex
cmake -G "NMake Makefiles" -DCOMPILE=PICOUSB ..
nmake
set "filename=PicoMiteRP2040USB"
cmake -G "NMake Makefiles" -DCOMPILE=VGA ..
nmake
set "filename=PicoMiteRP2040VGA"
cmake -G "NMake Makefiles" -DCOMPILE=VGAUSB ..
nmake
set "filename=PicoMiteRP2040VGAUSB"
cmake -G "NMake Makefiles" -DCOMPILE=WEB ..
nmake
set "filename=WebMiteRP2040"
cd ..
timeout /t 20 /nobreak
ren build buildRP2040L
ren buildRP2350L build
cd build
cmake -G "NMake Makefiles" -DCOMPILE=WEBRP2350 ..
nmake
set "filename=WebMiteRP2350"
cmake -G "NMake Makefiles" -DCOMPILE=VGARP2350 ..
nmake
set "filename=PicoMiteRP2350VGA"
cmake -G "NMake Makefiles" -DCOMPILE=VGAUSBRP2350 ..
nmake
set "filename=PicoMiteRP2350VGAUSB"
cmake -G "NMake Makefiles" -DCOMPILE=PICORP2350 ..
nmake
set "filename=PicoMiteRP2350"
cmake -G "NMake Makefiles" -DCOMPILE=PICOUSBRP2350 ..
nmake
set "filename=PicoMiteRP2350USB"
cmake -G "NMake Makefiles" -DCOMPILE=HDMI ..
nmake
set "filename=PicoMiteHDMI"
cmake -G "NMake Makefiles" -DCOMPILE=HDMIUSB ..
nmake
set "filename=PicoMiteHDMIUSB"
cd ..
ren build buildRP2350L
Edited 2025-11-26 03:32 by matherp
EDNEDN
Posted: 06:00pm 25 Nov 2025
OK!   I'll check that out for all versions in a few hours.
The Debugger uses about 12Kb of flash memory.   (It varies up and down a little bit depending upon the version of the firmware that is being generated.)
It uses less than zero bytes of SRAM if it is not activated.   If it is activated it grabs 384 bytes of SRAM via a call to GetSystemMemory( sizeof(struct Debugger_Memory));
EDNEDN
Posted: 08:21pm 25 Nov 2025
I checked everything out and I believe all 'D' versions are good.
Originally, I wrote a .cpp program to parse the .map files and tell me where the FLASH_TARGET_OFFSET should be.   Later, the .cpp program was modified to find all Debugger code and variables and report the size of each in all segments.
Lately, I haven't even really been using that program to parse the .map files.
This is for a couple of reasons.   Because the Debugger uses less than zero SRAM I have only needed to be concerned about the FLASH_TARGET_OFFFSET number for a given firmware version.    And assuming your numbers in configuration.c are set to good values I can quickly just bump that number up by 16 Kb.   (In reality, I only need to bump it up by 12 or 13 Kb, but it was safer to go a few Kb more just because the optimization success of the compiler is hard to predict with all the veneer code that gets added depending upon code placement.)
One thing I did notice in the last couple Release Candidates is that the WebMite-RP2040 isn't linking correctly.   Its Ram section is 88 bytes too big.  I had to adjust HEAP_MEMORY_SIZE down by 1kb for it to link successfully.   I don't know yet why that is.
C:/PROGRA~2/ARMGNU~1/133167~1.3RE/bin/../lib/gcc/arm-none-eabi/13.3.1/../../../../arm-none-eabi/bin/ld.exe: PicoMite.elf section `.heap' will not fit in region `RAM'
C:/PROGRA~2/ARMGNU~1/133167~1.3RE/bin/../lib/gcc/arm-none-eabi/13.3.1/../../../../arm-none-eabi/bin/ld.exe: region `RAM' overflowed by 88 bytes
It might be because you are using cmake followed by nmake.   And I'm using only cmake:
cmake -GNinja -DCOMPILE=WEB -S . -B build
cmake --build build --target PicoMite
I'll run down that build difference when I get a chance and figure out why things are different between the build scripts.
EDNEDN
Posted: 01:13am 26 Nov 2025
@matherp
I ran down the difference with the RP2040 WebMite build.   The difference is the compiler puts veneer code in SRAM to make it possible to get to functions that are too far away from the calling code.    And with the extra 12KB of Debugger code inserted in the middle of the .c file list, it was adding a few too many bytes and there wasn't enough SRAM space to do what it was being told to do.
I think I can just move the debugger.c file to a place that doesn't force as many veneer calls and I'll be able to use the exact same configuration.h settings as you have specified.   Probably the first place to try is to move it to very end of the .c file list because there are only two calls into the debugger and they are done from MMBasic.c.
Incidentally...  Building with Cmake followed by nmake produces identical picomite.elf.map files as building with Cmake (generating Ninja code) followed by Cmake.   The only difference is there are some back slashes instead of forward slashes in the file paths.
Posted: 08:32am 26 Nov 2025
  Quote   I had to adjust HEAP_MEMORY_SIZE down by 1kb for it to link successfully.
This is very very bad
Flash memory can only be erased in chunks of 4K. So the HEAP MEMORY SIZE, which also determines the maximum program size and therefore the flash slot size MUST also be in set in 4K increments. Basically, every allocation of flash must be in a minimum of 4K chunks
EDNEDN
Posted: 02:08pm 26 Nov 2025
OK!   I am going to spend some time seeing if I can get things to link with your numbers.   It was only the RP2040 WebMite that had a problem.   And if I can't get that to link with your numbers, I'll adjust by 4KB and not 1KB.
Thanks for the pointer!
EDNEDN
Posted: 05:57pm 28 Nov 2025
PicoMite v6.01.00RC21D
There are no known issues with the debugger at the moment.
PicoMite_v6.01.00RC21D---Documentation.zip
PicoMite_v6.01.00RC21D---Firmware.zip
EDNEDN
Posted: 07:48pm 03 Dec 2025
PicoMite v6.01.00RC22D
I'll be travelling for the next week.   It will be difficult to respond to new PicoMite v6.01.00 Release Candidates during this period.   But if the changes in RC23 are not too complex, it may be possible to respond quickly with a Debugger version while on the road.
PicoMite_v6.01.00RC22D---Documentation.zip
PicoMite_v6.01.00RC22D---Firmware.zip
     Page 3 of 3
