Local Time 13:53 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Left behind ?
     Page 3 of 3
PhenixRising
Posted: 08:10pm 07 Aug 2026
Never left behind. I won't bore the group with yet another story but I just had the opportunity to compare our Picomite with a high end industrial controller (£2500)
The PicoMite smoked it 😂🤣
It's an absolute beast as it stands 👍😎
zeitfest
Posted: 11:12am 11 Aug 2026
The tide is going out I think.
I looked for a very specialised, old physics program on the net. Originally
it had been painfully written and tweaked over some years by a physics research group
and the PhD students, post-docs and academic staff.
The source code was only on paper archives, but Gemini (Google) read the academic papers description and logic and recreated the program in a minute or so... and translated it into some other languages as wanted.
So you could translate your MMBasic into most other languages and probably vice
versa... programming is becoming arbitrary.
Posted: 11:41am 11 Aug 2026
If, as is quite possible based on recent events*, simple access to AI eventually becomes impossible, will the resulting code still be maintainable by humans? Will there still be humans that can program well enough to understand it without AI assistance?
*The apparent ease with which AI systems can break out of their sandbox and run amok.
"... scientists were so preoccupied with whether or not they could that they didn't stop to think if they should." - Jurassic Park
Posted: 12:31pm 11 Aug 2026
Good points Mick.
I guess the instructions you give the AI should be to include detailed comments within the program. Then follow that by getting it to write a detailed account of how the program works overall and for each module within it.
Posted: 12:50pm 11 Aug 2026
  phil99 said  I guess the instructions you give the AI should be to include detailed comments within the program.
All the programs I've had AI write have been amply commented without my asking, and much more helpfully and comprehensively commented than if I had written it all. YMMV.
Martin H.
Posted: 01:08pm 11 Aug 2026
  Mixtel90 said  If, as is quite possible based on recent events*, simple access to AI eventually becomes impossible, will the resulting code still be maintainable by humans? Will there still be humans that can program well enough to understand it without AI assistance?
That’s a very good point.
That’s why I get the AI to explain the procedure or the algorithm to me, so that I understand it. AI doesn’t get annoyed if I ask the same question 20 times. I’ll then write the programme myself. It’s debatable, though, whether I’ll still understand my own source code a year from now.
Edited 2026-08-11 23:10 by Martin H.
'no comment
Posted: 02:17pm 11 Aug 2026
Much human written legacy code is unsupportable once the authors are no longer available. An AI has a much better chance of understanding it than we do. I used to work for a bank whose entire back office was written in Dec Basic. It couldn't safely be touched or maintained so 15 years after being written it was still in use. The only solution was a start-from-scratch rewrite at huge expense
Bryan1
Posted: 09:38pm 11 Aug 2026
One of the best things I thought of with my projects with Claude I simply asked it to make a help page for each page so now got a ? in the top right of the screen with an explanation of the commands on the page.
If you guys want an example of this just have a look at my club.py as when someone else uses the code they are not left in the blue so a good understanding can be had from reading the help file.
Regards Bryan
Posted: 07:43am 12 Aug 2026
That sounds like an excellent idea. If AI is sorting out the code it's only fair that it should do the documentation as it goes along. :)
I know there's a lot of legacy code that is almost impossible to figure out now, but why repeat the same mistake now, when there's no need to? In the past there were sometimes (well, occasionally anyway) times when all comments were omitted or single letter variable names used in interpreters simply to save a bit of speed or some user RAM, but neither of those excuses really works now.
ManiB
Posted: 11:27pm 12 Aug 2026
  Martin H. said  Out of curiosity and because of the Video  from ExplainingComputers,
I just installed LM Studio on my Linux laptop. And I set up the gemma-4-e4b model locally.
What can I say? It basically supports MMBasic, too.
My question was: “I'd like to try the ‘Game of Life’ in MMBasic. Do you have any ideas about that?”
His answer: “Absolutely! Conway's Game of Life is a perfect, classic project for any programming language—and for MMBasic, too.”
That was followed by a presentation several pages long on how the program works and the logic behind it, and then he handed me a finished listing.
Martin
Hi Martin,
I took a look at your AI-generated source code and ported it to my PicoMiteHDMIUSB. Here's what I came up with. If you don't mind, I'd like to include this in my MMBasic tutorial: Mein erstes MMBasic Programm
' Game of Life fuer MMBasic
Option Explicit
Option Default None
Const MAX_X = 50
Const MAX_Y = 30
Const STARTANTEIL = 10       ' Anteil lebender Zellen in Prozent
Dim GridA(MAX_X, MAX_Y) As Integer
Dim GridB(MAX_X, MAX_Y) As Integer
' ======================== Hauptprogramm ========================
MainLoop
End
' ======================== Subs & Functions ========================
Sub MainLoop
 Local iteration As Integer
 iteration = 0
 InitialisiereGitter GridA()
   ZeigeGitter GridA(), iteration
   iteration = iteration + 1
   ' Optional: Animation verlangsamen
   ' Pause 500
   BerechneNaechstesGitter GridA(), GridB()
   UebernehmeGitter GridB(), GridA()
End Sub
' Setzt alle Zellen eines Gitters auf 0.
Sub ClearGrid(Grid() As Integer)
 Local x As Integer, y As Integer
 For y = 1 To MAX_Y
   For x = 1 To MAX_X
     Grid(x, y) = 0
   Next x
 Next y
End Sub
' Erzeugt eine zufaellige Startbelegung.
' Es werden exakt STARTANTEIL Prozent der Zellen gesetzt.
Sub InitialisiereGitter(CurrentGrid() As Integer)
 Local AnzahlZellen As Integer, GesetzteZellen As Integer
 ClearGrid CurrentGrid()
 AnzahlZellen = (MAX_X * MAX_Y * STARTANTEIL) \ 100
 GesetzteZellen = 0
 Do While GesetzteZellen < AnzahlZellen
   x = Int(Rnd * MAX_X) + 1
   y = Int(Rnd * MAX_Y) + 1
   ' Nur neue Zellen zaehlen. Dadurch entstehen exakt
   ' AnzahlZellen unterschiedliche lebende Startzellen.
   If CurrentGrid(x, y) = 0 Then
     CurrentGrid(x, y) = 1
     GesetzteZellen = GesetzteZellen + 1
   End If
End Sub
' Berechnet aus CurrentGrid die naechste Generation in NextGrid.
Sub BerechneNaechstesGitter(CurrentGrid() As Integer, NextGrid() As Integer)
 Local NachbarnCount As Integer
 For y = 1 To MAX_Y
   For x = 1 To MAX_X
     NachbarnCount = ZaehleLebendeNachbarn(CurrentGrid(), x, y)
     If CurrentGrid(x, y) = 1 Then
       ' Lebende Zelle:
       ' Bei 2 oder 3 lebenden Nachbarn ueberlebt sie.
       If NachbarnCount = 2 Or NachbarnCount = 3 Then
         NextGrid(x, y) = 1
       Else
         NextGrid(x, y) = 0
       End If
     Else
       ' Tote Zelle:
       ' Bei genau 3 lebenden Nachbarn wird sie geboren.
       If NachbarnCount = 3 Then
         NextGrid(x, y) = 1
       Else
         NextGrid(x, y) = 0
       End If
     End If
   Next x
 Next y
End Sub
' Zaehlt die lebenden Nachbarn einer Zelle.
' Zellen ausserhalb des Spielfelds gelten als tot.
Function ZaehleLebendeNachbarn(Grid() As Integer, X_Zelle As Integer, Y_Zelle As Integer) As Integer
 Local Count As Integer
 Local dx As Integer, dy As Integer
 Local NeighX As Integer, NeighY As Integer
 Count = 0
 For dy = -1 To 1
   For dx = -1 To 1
     ' Die Zelle selbst darf nicht mitgezaehlt werden.
     If Not (dx = 0 And dy = 0) Then
       NeighX = X_Zelle + dx
       NeighY = Y_Zelle + dy
       If NeighX>=1 And NeighX<=MAX_X And NeighY>=1 And NeighY<=MAX_Y Then
         If Grid(NeighX, NeighY) = 1 Then Count = Count + 1
       End If
     End If
   Next dx
 Next dy
 ZaehleLebendeNachbarn = Count
End Function
' Kopiert das berechnete Gitter in das aktuelle Gitter.
Sub UebernehmeGitter(SourceGrid() As Integer, TargetGrid() As Integer)
 For y = 1 To MAX_Y
   For x = 1 To MAX_X
     TargetGrid(x, y) = SourceGrid(x, y)
   Next x
 Next y
End Sub
' Gibt das Spielfeld und einige Statusinformationen aus.
Sub ZeigeGitter(Grid() As Integer, iteration As Integer)
 Local ZeileStr$ As String
 Local n As Integer, counter As Integer
 counter = 0
 CLS
 ' Ueberschrift auf MAX_X Zeichen zentrieren.
 ZeileStr$ = " Game of Life [" + Str$(iteration) + "] "
 n = MAX_X - Len(ZeileStr$)
 If n > 0 Then
   ZeileStr$ = String$(n \ 2, "-") + ZeileStr$ + String$(n - n \ 2, "-")
 End If
 Print ZeileStr$
 ' Spielfeld ausgeben.
 For y = 1 To MAX_Y
   ZeileStr$ = ""
   For x = 1 To MAX_X
     If Grid(x, y) = 1 Then
       ZeileStr$ = ZeileStr$ + Chr$(219)   ' voller Block
       counter = counter + 1
     Else
       ZeileStr$ = ZeileStr$ + "."
     End If
   Next x
   Print ZeileStr$
 Next y
 ' Anzahl lebender Zellen ausgeben.
 ZeileStr$ = " Living cells [" + Str$(counter) + "] "
 If n > 0 Then
 End If
 Print ZeileStr$
End Sub
Martin H.
Posted: 06:03am 13 Aug 2026
  Quote   If you don't mind, I'd like to include this in my MMBasic tutorial: Mein erstes MMBasic Programm
Of course you can use that.
What I was really interested in was seeing how a large language model, without an internet connection, was able to recognise the correct game from my phrase ‘Game of Life’ and was also capable of generating a Basic programme.
'no comment
     Page 3 of 3
