Local Time 18:32 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Picaxe 28X
     Page 3 of 3
Downwind
Posted: 03:29pm 24 Mar 2013
There is nothing wrong with the Peek and Poke commands and the addresses used are valid for both x1 and x2 chips.
Its not a problem to reprogram a chip over another program as all the previous program is removed in the process and even the eeprom is cleared.
Removing power or reset, will clear all data in variables but not the data stored in eeprom.
It would seem with Version 2, values need to be set in the menu before the program will function correctly, this would be because the menu settings are stored in eeprom and after loading the code into the chip all the eeprom locations will be set to zero untill new data is entered via the menu.
To reverse OP1 i think you should leave the <> unchanged and just change the High / Low commands around.
Pete.
Sometimes it just works
scnarine
Posted: 05:06pm 24 Mar 2013
Thank Pete...that worked.
scnarine
Posted: 04:09pm 12 Apr 2013
This project is coming along great. I will post a picture of the finish product soon. I do have one last question guys....If I used an allegro for the current sensing circuit, would I still need the op amp 741 circuit?
Downwind
Posted: 04:30pm 12 Apr 2013
The short answer is no you dont need the opamp, but perhaps a link to the allegro sensor you intend to use would help with a better answer, as some of the smaller chips do need an opamp but 90% dont.
Pete.
scnarine
Posted: 06:11pm 12 Apr 2013
This is the one I intend to use http://www.allegromicro.com/Products/Current-Sensor-ICs/Fift y-To-Two-Hundred-Amp-Integrated-Conductor-Sensor-ICs/ACS756. aspx
Downwind
Posted: 07:03pm 12 Apr 2013
No opamp required for that allegro,the output can be connected directly the the picaxe ADC input, although some filtering is required for stable readings.
Its best to use the unidirectional sensor as this will give far better resolution, because it will give around zero volts out for zero current and 5 volts out for max current.
The bidirectional sensors read plus and minus amps (which is often not required) and for zero current they output 2.5 volts, with zero volts out for max minus amps and 5 volts out for max plus amps.
Have you seen this page on the forum.
http://www.thebackshed.com/Windmill/articles/Alegro.asp
Pete.
scnarine
Posted: 04:03pm 13 Apr 2013
Would I need to add the offset software:
AmpOffset = 2.5
AmpReading = pin(1) - AmpOffset
if AmpReading > -0.2 and AmpOffset < 0.2 then AmpOffset = 0
or
AmpOffset = pin(2) - 2.5
if AmpReading > -0.1 and AmpOffset < 0.1 then AmpOffset = 0
If I need to add one of the above code where should I put it in the code?
I did connect the allegro ACS756 and I zero the amp setting and it looks great to me. The whole project coming along great so far.....slow but sure, since I started this a few years ago... lol. I got a few BEFW11S4 linksys router for $1.00 each and I am using that as the project case. The LCD fits perfect in the front. I have a friend of mine who is a graphic designer is working on the front panel design.
     Page 3 of 3
