Local Time 23:20 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pickit3 troubles
     Page 3 of 3
Posted: 01:40am 25 Mar 2014
to see the startup message, type in:
WATCHDOG 1
this will cause an immediate reboot of the micromite.
rob :-)
Posted: 04:31am 25 Mar 2014
Nice one Rob
I was looking at it from a hardware point of view simply because I was just working on the type of reset switch for my MicroMite Module.
Your idea is much easier for pal cal to try.
Bryan1
Posted: 10:06am 25 Mar 2014
Hi guys,
Just thinking now this has gone past my troubles this thread has some good info for troubleshooting so a rename of the thread may be a good idea. That if members have a similar problem it will be easier to find. Glenn would have to rename it and maybe 'serial connection problem' may be an option.
Regards bryan
Frank N. Furter
Posted: 08:34pm 25 Mar 2014
Hi!
It's a normally behavior with the startup message.
I can see the message with my µMite with MAX3232 and a separate USB-RS232 converter and powered with battery.
=> COM-Port is open with Teraterm and the message appears...
With my second µMite with PL2303 and powered over USB I can't see any message. I can only open Teraterm after PL2303 has registered by Windows. In that time is the message gone into the binary nirwana...
Reboot with WATCHDOG 1 is a very goog Idea!!!
Frank
     Page 3 of 3
