Local Time 03:04 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Talking to FRAM chips with I2C....
     Page 3 of 4
Lou
Posted: 04:59am 03 Oct 2014
Hey Guys,
Have you looked at the chip Zonker has on his new 28 pin board: FM31256-G (12.99 US$) here .
It has a Real Time Clock with calibration register (should be very accurate) and 32k of FRAM.
It would be nice to get that chip on the LCDuMite processor board.
How about MMBasic code for that one ?? Or is it too specialized ??
Lou
Posted: 06:31am 03 Oct 2014
@Lou,
Even though I've been using FRAM's for some time, I have only started using them for MicroMite projects. Initially for memory only (i.e. data loggers) so other onboard 'features' have not yet been utilised by myself.
More and more FRAM's are just starting to appear with additional 'features' - to use these with the MicroMite will be very easy (just a few lines of MMBasic will get results) - just a matter of someone 'having a go' to produce the code.
My funds are very low at the moment due to a couple of exciting new MicroMite products I am about to release. Therefore to keep buying new components is not realistic for me just now.
If anyone wants to buy a couple of Zonker's FRAM's and have a go at coding them then I will be more than happy to jointly help write some code to get things working (and I'm sure Grogster will chime in to help too).
For anyone interested in FRAMs, a 2kx8 costs from AU$2 + shipping from all major suppliers. Break Out boards are available from Adafruit, but I would strongly recommend you consider Zonker's module as the FRAM is just one small part of a very useful Module . . .
WW
Edited by WhiteWizzard 2014-10-04
jman
Posted: 08:45am 03 Oct 2014
  Lou said   Hey Guys,
Lou
Hi Lou
I have some chips on order when they arrive I will put together some code
to drive them and post it.
BTW Cypress ship via FedEx at no charge
Jman
Posted: 10:47am 03 Oct 2014
Jman - Thanks for letting us know that Cypress (owners of Ramtron) ship free of charge. You persuaded me to spend more money that I don't have
The only downside to their them is that it has just taken me over one hour in trying to place an order for a 31256 (Zonkers chip @ $12.05). Their website is a total pain in the a**e - otherwise a good purchase!
Lets see how long it takes to arrive . . . .
Posted: 12:01pm 03 Oct 2014
Would I be correct in assuming that those FRAM chips with embedded RTC etc, are addressed as two separate devices on the I2C bus?
IE: It's all in the one package, but you address the FRAM part and the RTC part with different addresses.
....I would ASSUME that is the only logical way to do it with multi-function chips....
(but then, assumptions are the mother of all "Expletive deleted!" - up's.)
jman
Posted: 12:13pm 03 Oct 2014
  Grogster said   Would I be correct in assuming that those FRAM chips with embedded RTC etc, are addressed as two separate devices on the I2C bus?
Well your assumption is spot on from the data sheet
"The RTC and processor companion functions are accessed via 25 special function registers, which are mapped to a separate I2C device ID."
Slave Address (Slave ID = 1010b) that operates the same as a stand-alone memory device. The second device is a real-time clock and processor companion which have
a unique Slave Address (Slave ID = 1101b)."
Jman
Lou
Posted: 12:15pm 03 Oct 2014
Thanks jman, Wizz,
I need an accurate RTC for a possible winter project (uMite repeater controller), and other accurate RTC chips seem to be going for near the same price as the Cypress chip. Since I mainly need the RTC, I figure in this case you get the FRAM for free.
Great if you guys can share some code jman, Wizz. Maybe we can get a 'standard' going for the uMite RTC and FRAM.
Lou
Posted: 10:29pm 03 Oct 2014
Just read the data sheet for the FM31256-G FRAM; it looks like a real nice chip with some very useful additional features.
Had an email regarding my order from The Cypress Store; they are shipping on Monday 6th (not sure from which part of the world though). Selected FedEx Priority so hopefully will be with me by end of business Tuesday.
I will create a test PCB in the meantime and hopefully have code posted here by Wednesday evening (UK time).
WW
jman
Posted: 11:09am 04 Oct 2014
Hi
Attached is some sample code to set and read the RTC in the Fram chips
Please note this is untested as the chips have not arrived yet.
If somebody has one maybe they could test it for me and post the result
Jman
2014-10-04_210833_FramRTC.zip
centrex
Posted: 10:23pm 07 Oct 2014
Hullo Grogster, WhiteWizard and Jman and others interested in FRAM.
Has anyone come up with a workable I2C software to use a FRAM chip as a data logger.
I have just received an Adafruit Fram breakout board and would like to get it going.
I see from previous posts there have been a few problems, hopefully you have been able to sort them.
Cliff
Cliff
Posted: 10:53pm 07 Oct 2014
Hi-de-hi.
Reading and writing is no problem at all, so long as you can get the data into the length of a MMBASIC string(256 bytes) for sequential writing, or if you only need to write every now and then with a few bytes, standard writing is no problem at all.
How often do you need to write data, and how many bytes in each write?
centrex
Posted: 11:39pm 07 Oct 2014
Hi Grogster
I want measure two voltages and two current values say 12.8 volts and say 10.5 amps these would be scaled to suit the micromite and read every 10 minutes or so.
I will have to go over your previous posts and give the bits of code a try.
Thanks for your help.
Cliff
Cliff
Posted: 12:09am 08 Oct 2014
Hi there. Try this:
[code]
A=1 'Set A to 1 at start of code
[/code]
SUBROUTINE:
[code]
SUB FRAM (V1,V2,I1,I2)
I2C open 400,100
D$=chr$(A\256) + chr$(A Mod 256) + chr$(V1) + chr$(V2) + chr$(I1) + chr$(I2)
I2C write &B1010000,0,6,D$
A=A+5 'Set A for the next cycle
I2C Close
End Sub
[/code]
This sub will build a string in MMBASIC consisting of the data values of V1,V2,I1 and I2, insert the correct FRAM address as the first two bytes of D$, then write all that to the FRAM starting from decimal address 1. The sub will auto-increment the address by five each time the routine is called.
You need only reset A to 1 at the start of the code, then every time you call the sub, it will write V1,V2,I1 and I2 to incrementing FRAM addresses.
NOT TESTED, but SHOULD work - I will try it tomorrow.....
Edited by Grogster 2014-10-09
Lou
Posted: 07:50am 08 Oct 2014
jman, Wizz,
Please keep us up-to-date on the FramRTC code, especially the RTC and calibration code.
jman, did you start this code back in May ?? I noticed the date in your code.
We are ordering parts while Zonker is finishing up the 170 core 28pin DIP board for a small first time run, I want to test the accuracy of the RTC ASAP. I think I'm going to like this board. Now, if I can find a good voice chip...
Thanks,
Lou
Posted: 07:57am 08 Oct 2014
My 'Zonker spec' FRAM is still en-route to me (currently in Germany).
It is scheduled for delivery tomorrow (UK Thursday) but I am out all day so won't have it until Friday.
I will post code as soon as I have a chance to do so (probably by end of Friday).
WW
jman
Posted: 08:12am 08 Oct 2014
  Lou said   jman, Wizz,
Thanks,
Lou
My chips arrived yesterday so I will test and post the results
This reworked code that I did for the DS3231 back in May
Jman
centrex
Posted: 09:47pm 08 Oct 2014
Thanks Grogster
I will give it a try on the weekend.
Cliff
Cliff
jman
Posted: 10:30pm 08 Oct 2014
Hi
The attached code is now tested and working with the Fram RTC
I will do the calibration next and post it here
Jman
2014-10-09_082917_FramRTC.zip
Posted: 10:45pm 08 Oct 2014
  centrex said   Thanks Grogster
Cliff
Would you like a date and time stamp every time the sub is called?
(assuming that an external RTC has been installed and correctly set)
jman
Posted: 11:50pm 08 Oct 2014
Oh dear I made a mistake in the RTC code
new code attached that actually does work this time :)
Jman
2014-10-09_094947_FramRTC.zip
     Page 3 of 4
