Forum Index : Microcontroller and PC projects : Micromite Library
| halldave Senior Member Joined: 04/05/2014 Location: AustraliaPosts: 121 |
Thanks for the kind words I am rejigging mmreference,com a new look for 2015, so bear with any hideous colours in the transition That said I would like any and all submissions for the CFunctions library, Snippets Library and MMBasic Library for each of these are there any sub categories that would be helpful? It would be great to have these loaded up and organised before Silicon Chip hits the shelves in January |
btw life is back to normal now - I'm busy coding the MuP Security Shield using the Geoff's new Micromite MkII features.. the implementation I worked on didn't scale and when 20 million customers were migrated things went haywire, I had to put my life and hobbies on hold whilst we work through and resolved everything.... Only 11 months until the next one |
| G8JCF Guru Joined: 15/05/2014 Location: United KingdomPosts: 676 |
Library Updated 2014-12-12 23:35 UTC http://www.g8jcf.dyndns.org/MMBasicIILib/ Peter The only Konstant is Change |
Oldbitcollector![]() Senior Member Joined: 16/05/2014 Location: United StatesPosts: 172 |
@halldave, The new website style looks great! Good to see you back! My Propeller/Micromite mini-computer project. |
@G8JCF Peter, I think a link to this should go up now as a sticky on the TBS board. Whether it actually resides there (as per your discussions with Glenn) can be sorted out later. What do you think? Greg |
Hi Greg I'm good with that idea. I think a fresh Sticky Post with the Subject Line Micromite MMBasic Library(s) might do the trick. @Gizmo, how could we go about hosting the site itself on TBS please ? Micromite MMBasic Library(s) 4.6 MKII 4.6 MKII Mirror 4.6 MKII Mirror MMReference (subject to David Hall approval) These links point to web-sites containing MMBasic 4.6 MKII software Libraries/Applications and code snippets. If you have MMBasic 4.6 MKII s/w which you would like to see included in the 4.6 MKII library, then please PM @G8JCF on this Forum. If you would like to provide a mirror for the 4.6MKII library, then please PM @G8JCF on this Forum And, if other people want to mirror the site, I'll add the links to the Mirrors onto the INDEX.HTML page of www.g8jcf.dyndns.org/MMBasicIILib/. I've included @CircuitGizmo's mirror as the first mirror, and I recall @atmega8 also offering to mirror it as well, but I don't have the URL for his mirror Peter The only Konstant is Change |
Hi Peter, That'd be great - I'm not sure if Glenn's read this or not, or whether you had PM'd him so I sent him a PM to see if he's OK with it. Greg |
Thank You Greg The only Konstant is Change |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5198 |
Got the PM How would you guys like it. I can add those links to any/all of these ... 1. the Read Me. Guidelines for this section. sticky. 2. Create a new sticky, call it Micromite MMBasic Library 3. Add it to the main sites Links page http://www.thebackshed.com/windmill/Links.asp Any updates to the links, just PM me and I'll make them. I'm thinking 2. and 3. and just add a note to 1. pointing to 2. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
I reckon that'd be spot on Glenn. Why not add a link to Hugh's Maximite MMBasic library on Geoff's site too Maximite MMBasic library in the same sticky. Then just call the sticky MMBasic Libraries (plural) and put a line for each link there. Greg |
@Gizmo Glenn, Spot on with the Sticky Post - Just the ticket, massive thank you ! @pacemen Greg, Well done, and a huge thank you for sorting all this out ! Peter The only Konstant is Change |
Bryan1![]() Guru Joined: 22/02/2006 Location: AustraliaPosts: 2271 |
G'day Guy's, Ok I have been out of the picture for awhile and my new electronics room in the new shed will be up and going in the new year. Anyway I have been researching and do think a Wiki page could be built and think that would provide a great resource for both the Maximite and uMite. Regards Bryan |
