Forum Index : Microcontroller and PC projects : MM2: 2.4" SPI Colour Touchscreen
Works a treat Peter, thanks again. Another query - how would you recommend to input a string from Graeme's modified code that I posted above in the zip file above, i.e. in 'SUB QwertyTest' down near the bottom.
As I've shown it, it sits in a 'Do Loop' so that you can just keep entering characters but of course if the 'key press' is a bit long you end up with multiples of that character. If you're a bit slow entering characters it'll time-out and drop back to the main program with probably only a part of the string you wanted having been entered. You can also test each character at the end of the routine to catch an 'Enter' (i.e. CR) and then return to the main program but the time-out issue is still there. I guess if you could set the 'T.getxy' function flag back to zero that would be a good way to control it but unfortunately you can only do that within the 'T.getxy' function, not another subroutine or the main program. I'm probably missing something obvious here so be gentle.
Greg |
| centrex Guru Joined: 13/11/2011 Location: AustraliaPosts: 320 |
Hi Matherp I have to agree with all the previous posts the drivers for the tft displays are fabulous. My problem is there are so many variations it is hard to keep track of what is what. Can you put the latest updated version in the MMBasic library. I am using a 2.8tft with BigMick BP170 interface. Thanks Cliff Cliff |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11894 |
This is easy to fix. Just add one line to the top of QwertyTest as follows: DO IF T.getxy(xvalues(0),yvalues(0),1000) AND T.getxy(xvalues(1),yvalues(1),1000) AND T.getxy(xvalues(2),yvalues(2),1000) THEN DO WHILE PIN(T_IRQ)=0:LOOP 'wait for key release before processing |
Nice one again Peter, works brilliantly - love these one-line fixes! Now just one more.
How do I tell the QwertyTest subroutine that T.getxy timed out and therefore it shouldn't do the blanking pstring (2nd pstring from the bottom). I'll have to put the blanking pstring back up in the 'backspace' key (<) test section, but that's OK whereas where it is now the timeout wipes anything previously put on that row before the pad string input is started. I was thinking maybe a new global flag variable would do it, if it was set in T.getxy after a timeout and tested down there at the bottom of QwertyTest. That reduces the 'standalone-ness' of T.getxy though and doesn't seem very elegant. Greg |
Not sure if I'm missing something because T.getxy already returns a 0 if there was a timeout or non-zero if there was a keypress so: IF T.getxy(xvalues(0),yvalues(0),1000) AND T.getxy(xvalues(1),yvalues(1),1000) AND T.getxy(xvalues(2),yvalues(2),1000) THEN ' code handling keypress ELSE ' code handling timeout ENDIF |
It was me missing something Peter - I'd put the pstrings after the final ENDIF instead of the one before and now the 'flash' at the end of each timeout doesn't happen. The blanking still happens but that's as it should be. It works pretty well now - code below: FUNCTION filter(values() AS INTEGER) AS INTEGER
LOCAL INTEGER AB,BC,AC AB=ABS(values(0)-values(1)) BC=ABS(values(1)-values(2)) AC=ABS(values(0)-values(2)) IF AB<=BC AND AB<=AC THEN filter=(values(0)+values(1))\2 IF BC<=AB AND BC<=AC THEN filter=(values(1)+values(2))\2 IF AC<=AB AND AC<=BC THEN filter=(values(0)+values(2))\2 END FUNCTION ' SUB I9341_test 'Graeme Meagers Qwertypad with QwertyTest & using Peter Mathers x,y touch coords routine 'modified Greg Yaxley QwertyPad DO QwertyTest LOOP SUB QwertyPad 'Graeme's routine for a Qwerty pad LOCAL INTEGER J LOCAL STRING Q$ Q$="QWERTYUIOPASDFGHJKL^ZXCVBNM< * .1234567890" I9341.setrot(I9341_rt_left) I9341.fillscreen(black) I9341.drect(0, 0, 320, 240, red) '--------- This section adds a number row FOR J = 1 TO 10 I9341.frndrect((J*32)-30,68,29,29,3,yellow) I9341.pstring((J*32)-22,73,MID$(Q$,J+37,1),3,0,black,yellow) NEXT J '--------- FOR J = 1 TO 10 I9341.frndrect((J*32)-30,100,29,29,3,cyan) I9341.pstring((J*32)-22,105,MID$(Q$,J,1),3,0,black,cyan) NEXT J FOR J = 1 TO 9 I9341.frndrect((J*32)-16,132,29,29,3,cyan) I9341.pstring((J*32)-7,137,MID$(Q$,J+10,1),3,0,black,cyan) NEXT J FOR J = 1 TO 10 I9341.frndrect((J*32)-30,164,29,29,3,cyan) I9341.pstring((J*32)-22,169,MID$(Q$,J+19,1),3,0,black,cyan) NEXT J FOR J = 1 TO 2 I9341.frndrect((J*32)-15,196,30,30,3,cyan) I9341.pstring((J*32)-7,201,MID$(Q$,J+29,1),3,0,black,cyan) NEXT J I9341.pstring(17,210,"Shift",1,0,black,cyan) I9341.frndrect(81,196,160,30,3,cyan) I9341.pstring(125,210,"SPACE",2,0,black,cyan) FOR J = 8 TO 9 I9341.frndrect((J*32)-13,196,30,30,3,cyan) NEXT J I9341.pstring(243,201,".",3,0,black,cyan) I9341.pstring(275,211,"Enter",1,0,black,cyan) I9341.pstring(245,230,"spilcdv2.bas",1,0,green,black) 'I9341.frndrect(10,10,300,80,3,white) I9341.frndrect(10,2,316,44,3,white) I9341.pstring(15,15,"The First Line is Here",2,0,Black,White) I9341.pstring(15,35,"The Second Line is Here",2,0,Black,White) 'I9341.pstring(15,55,"The Third Line is Here",2,0,Black,White) 'I9341.pstring(15,75,"The Fourth Line is Here",2,0,Black,White) END SUB ' -------Test Touch for QwertyPad------- SUB QwertyTest LOCAL INTEGER x0,y0,xvalues(3),yvalues(3) LOCAL INTEGER SHIFT=1 LOCAL STRING L1$="" SETPIN 24,DOUT DO IF T.getxy(xvalues(0),yvalues(0),1000) AND T.getxy(xvalues(1),yvalues(1),1000) AND T.getxy(xvalues(2),yvalues(2),1000) THEN DO WHILE PIN(T_IRQ)=0:LOOP 'wait for key release before processing y0=filter(yvalues()) x0=filter(xvalues()) IF 1400 > x0 AND 1160 < x0 THEN 'Value for number row IF 1850 > y0 AND 1680 < y0 THEN 'Value for Key 1 Beep L1$=L1$+"1" ENDIF IF 1680 > y0 AND 1510 < y0 THEN 'Value for 2 Beep L1$=L1$+"2" ENDIF IF 1510 > y0 AND 1340 < y0 THEN 'Value for 3 Beep L1$=L1$+"3" ENDIF IF 1340 > y0 AND 1170 < y0 THEN 'Value for 4 Beep L1$=L1$+"4" ENDIF IF 1170 > y0 AND 1000 < y0 THEN 'Value for 5 Beep L1$=L1$+"5" ENDIF IF 1000 > y0 AND 830 < y0 THEN 'Value for 6 Beep L1$=L1$+"6" ENDIF IF 830 > y0 AND 660 < y0 THEN 'Value for 7 Beep L1$=L1$+"7" ENDIF IF 660 > y0 AND 490 < y0 THEN 'Value for 8 Beep L1$=L1$+"8" ENDIF IF 490 > y0 AND 320 < y0 THEN 'Value for 9 Beep L1$=L1$+"9" ENDIF IF 320 > y0 AND 150 < y0 THEN 'Value for 0 Beep L1$=L1$+"0" ENDIF ENDIF IF 1160 > x0 AND 920 < x0 THEN 'Value for 1st alphas row IF 1850 > y0 AND 1680 < y0 THEN 'Value for Key Q Beep IF Shift=1 THEN L1$=L1$+"Q" ELSE L1$=L1$+"q" ENDIF IF 1680 > y0 AND 1510 < y0 THEN 'Value for W Beep IF Shift=1 THEN L1$=L1$+"W" ELSE L1$=L1$+"w" ENDIF IF 1510 > y0 AND 1340 < y0 THEN 'Value for E Beep IF Shift=1 THEN L1$=L1$+"E" ELSE L1$=L1$+"e" ENDIF IF 1340 > y0 AND 1170 < y0 THEN 'Value for R Beep IF Shift=1 THEN L1$=L1$+"R" ELSE L1$=L1$+"r" ENDIF IF 1170 > y0 AND 1000 < y0 THEN 'Value for T Beep IF Shift=1 THEN L1$=L1$+"T" ELSE L1$=L1$+"t" ENDIF IF 1000 > y0 AND 830 < y0 THEN 'Value for Y Beep IF Shift=1 THEN L1$=L1$+"Y" ELSE L1$=L1$+"y" ENDIF IF 830 > y0 AND 660 < y0 THEN 'Value for U Beep IF Shift=1 THEN L1$=L1$+"U" ELSE L1$=L1$+"u" ENDIF IF 660 > y0 AND 490 < y0 THEN 'Value for I Beep IF Shift=1 THEN L1$=L1$+"I" ELSE L1$=L1$+"i" ENDIF IF 490 > y0 AND 320 < y0 THEN 'Value for O Beep IF Shift=1 THEN L1$=L1$+"O" ELSE L1$=L1$+"o" ENDIF IF 320 > y0 AND 150 < y0 THEN 'Value for P Beep IF Shift=1 THEN L1$=L1$+"P" ELSE L1$=L1$+"p" ENDIF ENDIF IF 920 > x0 AND 680 < x0 THEN 'Value for 2nd alphas row IF 1760 > y0 AND 1590 < y0 THEN 'Value for Key A Beep IF Shift=1 THEN L1$=L1$+"A" ELSE L1$=L1$+"a" ENDIF IF 1590 > y0 AND 1420 < y0 THEN 'Value for S Beep IF Shift=1 THEN L1$=L1$+"S" ELSE L1$=L1$+"s" ENDIF IF 1420 > y0 AND 1250 < y0 THEN 'Value for D Beep IF Shift=1 THEN L1$=L1$+"D" ELSE L1$=L1$+"d" ENDIF IF 1250 > y0 AND 1080 < y0 THEN 'Value for F Beep IF Shift=1 THEN L1$=L1$+"F" ELSE L1$=L1$+"f" ENDIF IF 1080 > y0 AND 910 < y0 THEN 'Value for G Beep IF Shift=1 THEN L1$=L1$+"G" ELSE L1$=L1$+"g" ENDIF IF 910 > y0 AND 740 < y0 THEN 'Value for H Beep IF Shift=1 THEN L1$=L1$+"H" ELSE L1$=L1$+"h" ENDIF IF 740 > y0 AND 570 < y0 THEN 'Value for J Beep IF Shift=1 THEN L1$=L1$+"J" ELSE L1$=L1$+"j" ENDIF IF 570 > y0 AND 400 < y0 THEN 'Value for K Beep IF Shift=1 THEN L1$=L1$+"K" ELSE L1$=L1$+"k" ENDIF IF 400 > y0 AND 230 < y0 THEN 'Value for L Beep IF Shift=1 THEN L1$=L1$+"L" ELSE L1$=L1$+"l" ENDIF ENDIF IF 680 > x0 AND 440 < x0 THEN 'Value for 3rd row IF 1850 > y0 AND 1680 < y0 THEN 'Value for Key SHIFT Beep Shift= NOT Shift ':QweryPad ENDIF IF 1680 > y0 AND 1510 < y0 THEN 'Value for Z Beep IF Shift=1 THEN L1$=L1$+"Z" ELSE L1$=L1$+"z" ENDIF IF 1510 > y0 AND 1340 < y0 THEN 'Value for X Beep IF Shift=1 THEN L1$=L1$+"X" ELSE L1$=L1$+"x" ENDIF IF 1340 > y0 AND 1170 < y0 THEN 'Value for C Beep IF Shift=1 THEN L1$=L1$+"C" ELSE L1$=L1$+"c" ENDIF IF 1170 > y0 AND 1000 < y0 THEN 'Value for V Beep IF Shift=1 THEN L1$=L1$+"V" ELSE L1$=L1$+"v" ENDIF IF 1000 > y0 AND 830 < y0 THEN 'Value for B Beep IF Shift=1 THEN L1$=L1$+"B" ELSE L1$=L1$+"b" ENDIF IF 830 > y0 AND 660 < y0 THEN 'Value for N Beep IF Shift=1 THEN L1$=L1$+"N" ELSE L1$=L1$+"n" ENDIF IF 660 > y0 AND 490 < y0 THEN 'Value for M Beep IF Shift=1 THEN L1$=L1$+"M" ELSE L1$=L1$+"m" ENDIF IF 490 > y0 AND 320 < y0 THEN 'Value for Backspace Beep IF LEN(L1$) > 0 THEN L1$=LEFT$(L1$,(LEN(L1$)-1)) ENDIF ENDIF ENDIF I9341.pstring(15,15," ",2,0,red,white) I9341.pstring(15,15,L1$,2,0,red,white) ENDIF LOOP SETPIN 24,OFF END SUB ' SUB Beep PIN(24)=1:PAUSE 20:PIN(24)=0 'flash LED END SUB |
Thanks Greg for sharing your final code; glad you (and Peter) got it going - very useful to see it |
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
YES..! More UI Objects... Awesome work Gent's..! |
Mostly thanks to Graeme Meager and Peter Mather actually gents, I didn't do much. The 'backspace' (<) works properly though now and the artefact is fixed. One thing I should have included in the above code is the change Peter suggested to 'pstring', i.e. change Peter's original 'pstring' subroutine to: SUB I9341.pstring(xx0 AS INTEGER, yy0 AS INTEGER, text$, sz AS INTEGER, orientation AS INTEGER, fontcolour AS INTEGER, backgroundcolour AS INTEGER) 'x, y coordinates of top left of first character, text string, size, orientation
IF text$<>"" THEN LOCAL INTEGER i=I9341draw(I9341.fpstring,I9341_AddrOfFont,xx0,yy0,sz,orientation,fontcolour,backgroundcolour,I9341_params(),text$) ENDIF END SUB Greg |
Hi Cliff, Not sure if you've got your 2.8" screen going yet but the following might help. I'm assuming it's the same ILI9341 SPI one that Mick mentioned in this thread (9/4/15 6:51 am). I don't have a 2.8" but Mick said the pinout is the same as the 2.4" version and it's the same 240x320 resolution. There are two connections to each of the MX170's fixed SPIin, SPIout and SPIclk pins (14, 3 and 25 resp.) because of the two controllers (LCD and Touch) on the screen. The other five control lines are shown below on pins 2, 4, 5, 6, and 7, of the 170 but can be assigned to what you want in Peter's code. The connections I'm using are from 'twofingers' post in this thread (16/2/15 11:04pm) as below. This 2015-05-19_115415_QwertyPadTest.zip is the code I'm using. You should be able to see the Qwerty pad if you just run the program but you'll need to calibrate your 2.8" raw touch screen positions (x,y,max,min) using the appropriate program from Peter's first post of this thread first. Next you'll need to change Graeme's ranges for the different row and key positions in the QwertyTest subroutine to match your scaled touch parameters obtained using the calibration program. Once at this point you should be able to see the correct keys you touch print on the first line - they're stored in L1$ and the 'backspace' also works properly. Greg SPI interface: ILI9341S controller MX170 uM2 2.4" Touch LCD 28 Pin Display PCB Pin ---------------------------------- Vcc (3.3v)–––––– 1 VCC (3.3V) GND––––––––––––– 2 GND 2–––T_IRQ––––––– 14 T_IRQ 3–––SPIout–––––– 6 SDI(MOSI) 3–––SPIout-T–––– 12 T-DIN 4–––I9341_CD–––– 5 D/C 5–––I9341_RESET– 4 RESET 6–––I9341_CS–––– 3 CS 7–––T_CS–––––––– 11 T_CS 14––SPIin––––––– 9 SDO(MISO) 14––SPIin-T––––– 13 T-DO 25––SPI CLK––––– 7 SCK 25––SPI CLK-T––– 10 T-CLK 8 LED (direct to 3.3v) --------------------------------------------- T = Touch-screen signal |
Hi paceman I have the display working fine, its just there seems to a lot of changes to the code that are hard to keep up with (all due respect to matherp). Maybe with Ver 4.7 Beta now out it wont be a problem as one would just wait for updates, it appears to use Peters code which works very well. Thanks for your input. regards Cliff Cliff |
Hi paceman, I have been using the touch screen interrupt driven in one on my programs. The main changes are when you set the SETPIN T_IRQ use: SETPIN T_IRQ,INTL,QwertyTest,pullup 'Use interrupt driver touch This will call your QwertyTest whenever a key is pressed. The DO LOOPS that continually call it are then not need. Your program sets up the interrupt and writes the keyboard layout, then does nothing at all until a key is pressed. The advantage is its free to do other stuff if you want, and the key is displayed immediately when pressed but only once unless the press is released and pushed again. As the program is not stuck in the QwertyTest continually, but called new each time, a couple of the local variables need to be made global I have modified it to run interrupt driven. 2015-05-20_123245_QwertyPadTestInterrupt.zip Hope it useful Regards Gerry F4 H7FotSF4xGT |
Thanks Gerry, that sounds very neat. I've just re-programmed my current MX170 setup to V4.7 beta3 to give that a try so I'll need to re-hash things a bit to give yours a try. I'll report back when I've set things up and tried it. Greg |
Hi Cliff, Yes, it's a bit academic now that Geoff's released the V7 betas so I'll just go with them now too. It was getting a bit confusing but I'd been following it pretty closely for a while using a 170 and a 470 so I (mostly) knew where I was at. Peter no doubt would have been working closely with Geoff on it so putting time into documenting all the earlier versions would have been a bit of a waste when he knew V1.7 was imminent. Greg |
| Bizzie Senior Member Joined: 06/07/2014 Location: AustraliaPosts: 194 |
I'll ask my question here as it relates to the 2.4" SPI TFT display. How much current does a typical display draw? Or putting it another way can I power a display and piggy backed 28 pin mite (on BigMicks Backpack 170 board) off the 5v (500mA) supply available from a CGCOLORMAX 2? Rob Rob White |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1773 |
Yes! Edit: With back light (100%) about 150mA. ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
My 2.4" pulled a lot less than that, about 45mA at 3.3v without a limiting resistor. See the posts on this thread on 13 March 2015 at 10:58pm. Greg |
Hi Rob, In my testing for the BackPack170, the backlight drew between 65 to 80mA and the entire board came it at 140-150mA including the backlight drive. That was at a standard 40MHz Well within the capability of a 500mA drive power source. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Thanks all, Will continue my development. Regards Rob Rob White |
Hi to all: Is there a version of QwertyPadTestInterrupt which works on Mick's BackPack170 and MMBasic V5.1? It seems that some things has changed... THANKS! Frank |
