Local Time 17:38 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMflash - Flashing MM’s made easy
     Page 3 of 3
Posted: 10:49pm 27 Jan 2016
That sounds a good idea.
BTW for anyone else who's interested (well, it's possible), I didn't mention the datasheet (now up to rev Q) says that a few parts of the programming operation need longer delays, some a lot longer.
twofingers
Posted: 10:47am 28 Jan 2016
Hi all,
I think it's time to say thanks to all of the involved people (Jim, PeterM, Robert, Jean, ...)!
Today I flashed a MM2 using MBs (Jeans) 16f1455 programmer (I hope he will give it a better name soon ) and Jims MMFlash (Micromite mode).
Perhaps Jim will some days consider his nice program for a genuine 16f1455 mode to expand? One wrapper for all the pic32prog programmers.
Michael
The lone and ...
MicroBlocks
Posted: 07:53pm 28 Jan 2016
It is actually a protocol and i ported it to a PIC16F1455, in Jim's program it would be 'using ASCII ICSP'
It does have a name. :) A 'Microblocks U2SP'. :)
Although the P in the name stand for Power and refers to the module version which has a added voltage regulator. https://www.facebook.com/Microblocks
Still not available as my pcb assembly order did not work out. :(
Chris Roper
Posted: 08:05pm 28 Jan 2016
  twofingers said  ]16f1455 programmer[/URL] (I hope he will give it a better name soon ) and Jims MMFlash (Micromite mode).
As it is the perfect MicroMite companion, for both Console IO and Flashing, I would propose it be called the MiteMate.
Or alternatively to fit with the company name, the MicroMate.
Chris
P.s.
I originally sent this yesterday but it showed up 8 hours late, must be due to the SEACOM Cable outages in Egypt.
Edited by Chris Roper 2016-01-30
http://caroper.blogspot.com/
MicroBlocks
Posted: 08:19pm 28 Jan 2016
It is also a AtmelMate. :) It works great with that too. Got the flashin of a atmel328 working, but that is still in further test/development.
I try to not be micromite specific.
For marketing purposes (keywords) it is best to use 'Microblocks' followed by a productname.
'Microblocks MicroMate' has a nice flow and sounds good. Any royalties for me using it?
Chris Roper
Posted: 08:32pm 28 Jan 2016
  MicroBlocks said  'Microblocks MicroMate' has a nice flow and sounds good. Any royalties for me using it?
Your companionship on the forum and the fact you were willing to share is of way more value than any royalty. I think I and other owe you, not the other way round :)
Chris
MicroBlocks
Posted: 09:02pm 28 Jan 2016
Thanks!
centrex
Posted: 09:51pm 13 Mar 2016
I wanted to reflash a PIC170 using TassyJim and the teams fabulous piece of software for a pic to program a pic.
So I made a dedicated pcb with the 170 a usb to serial module plus a reasonable power supply to power the programmer as well as the target. It is not sub miniature, all through hole except for the Vcap and has all the pic pins brought out to pads so it can be used for other things.
This is it.
The usb to ttl is on the left the multi core on the right is to the icsp connector on the target.
It is not powered by the usb but requires a separate 5V power supply.Edited by centrex 2016-03-15
Cliff
     Page 3 of 3
