Local Time 10:29 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Firmware V5.03
     Page 3 of 3
Phil23
Posted: 12:21pm 01 May 2017
  Geoffg said
  Phil23 said   Just wondering if the SSD not connected issue can be addressed at some point in 5.3.
I cannot reproduce the "bug" that you refer to and there is nothing that I can see in the code that would make the console stop working when a display is removed.
Thanks Geoff,
I'm about to be back playing with my E100's soon.
Will try again to see if I can reproduce the issue again with 100% repeatability & minimum code.
If I can do that on both my E100's I'll post the procedure.
Phil.
(And yes, I'd then consider the issue low priority).
Geoffg
Posted: 06:35pm 01 May 2017
  PicFan said   Hello Geoff !
Please try this !
Thank you !
Wolfgang
I tried it and it worked perfectly!!!
What device were you running on?
Geoff
> print mm.device$, mm.ver
Micromite MkII 5.0302
> list
Option autorun on
Option explicit
Option default integer
Dim test1 = 3
On error skip
RTC gettime
If (MM.Errno <> 0) Then
Print "RTC NICHT VORHANDEN, interne Uhr wird verwendet !"
Print ""
EndIf
Print test1
End
> run
3
Posted: 08:06pm 01 May 2017
No problems on a MMX running Ver 5.0318
and I did remember to unplug the RTC first.
PicFan
Posted: 10:00pm 01 May 2017
Please try this !
Thank you !
Wolfgang
Geoff
> list
Option autorun on
Option explicit
Dim test1 = 3
On error skip
RTC gettime
Print ""
EndIf
Print test1
End
> run
3
I have the board (Exp. 64 MM470) updated today with the last version of your homepage and it works. (Example with "ON ERROR SKIP"). Is it possible that the download with the MAC problems caused?
Thank you and best regards
Wolfgang
CaptainBoing
Posted: 10:52pm 01 May 2017
Hi Wolfgang.
It's unlikely the download platform was responsible (PC/MAC/*nix etc..) more likely it is on-chip corruption. I have not seen any problems with MZ series or indeed any of the "simpler" 12F, 16F, 18F stuff (limit of my usage), but odd things with a 28 pin MX170 and two 44pin MX170s worked fine after re-flashing the firmware.
It's not my first tactic, but I have got into the habit of re-flashing whenever something *really* odd is happening. Going back through this forum you will find recent examples of stuff being fixed with a re-flash or a change of chip and personally I have had three instances of weird stuff happening that was fixed by flashing the firmware.
<speculation> Maybe there is "something" with the MX <\speculation>
PicFan
Posted: 03:09am 02 May 2017
Hello Captain!
Thanks for your quick reply. My problem is as follows:
I have a program which calculates only numbers and requires time and date. The program runs for about 10 days on the same MM-470 board with V5.0302 without error. On Saturday I added only the "ON ERROR SKIP" command (see examble) after the initialization of about 20 variables and "RUN". ERROR, none of the variables was more declared? I remove the command, the Programm runs, i added the command, program fail. ERROR "xyz" not declared.
I have now again version V5.0302 (MAC download) programmed, it also works this version without error?
Many thanks to all and greetings from Austria!
WolfgangEdited by PicFan 2017-05-03
CaptainBoing
Posted: 03:53am 02 May 2017
I have pasted your code into a MX170 beast and removed the RTC to trigger the ON ERROR SKIP
this is at version 5.3
here is the screen dump:
> rtc gettime
RTC not responding
> list
Option autorun on
Option explicit
Dim test1 = 3
On error skip
RTC gettime
Print ""
EndIf
Print test1
End
> run
3
it works no problem. I think you had a corrupt flash and the act of taking it to 5.2 cleaned it up. 5.3 just puts you back where you were.
Edited by CaptainBoing 2017-05-03
MicroBlocks
Posted: 05:21am 02 May 2017
When you suspect a corrupt flash it might be best to read the chip first, then reprogram it and compare the two. MMBasic saves stuff in flash and it there is a small change it might be a bug. If you have the 'corrupted' flash then maybe something can be found.
I used the mx chips extensively (not MMBasic) and never had a corrupt flash before.
CaptainBoing
Posted: 06:15am 02 May 2017
yep - that is a good idea.
sort of a "crash dump". I haven't had a problem for a while but I am going to do this next time (if there is one)
Geoffg
Posted: 11:28am 02 May 2017
I find it hard to envisage a corruption that would just cause a "variable not found" error but otherwise leave the firmware running perfectly. It would require a few bits to be flipped in specific locations but everything else left untouched - the odds against that happening would be astronomical.
But, there is no denying that Wolfgang experienced something like that and I have heard of other cases of where people have corrected weird behavior by reflashing the chip. It might be that reflashing resets everything (program space, options, etc) and that is the fix. Who knows?
Geoff
CaptainBoing
Posted: 09:41pm 02 May 2017
something similar/related
I remember an email exchange where a FOR/NEXT loop wouldn't count backwards with a local integer variable - A re-flash fixed that.
MMBasic is a massive complex beast - there will always be obscure "surprises" in anything this complex. The space shuttle's code was the most tested/debugged code ever written and they were still finding odd things right up to the last.
The pro's far outweigh the odd wrinkle and I know from my job that often the time taken to hunt down a specific cause is not worth the time/spend - especially if you get it for nothing - BTW, hows the paypal donate button coming? (HINT HINT)Edited by CaptainBoing 2017-05-04
piclover
Posted: 02:01pm 03 May 2017
  Geoffg said  I have finally got the time to start on the bug list and this is one of the first that I have found and fixed - the fix will be in the next version.
But I just wanted to say a big thanks for the succinct demo code, it was a huge help in nailing a subtle bug.
Most welcome. As a programmer myself, I always seek/ask for some reproduction procedure whenever people find bugs in my software.
Bug-hunting without a repro can become "painful"...
     Page 3 of 3
