Local Time 15:06 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Updated PicoMite, PicoMite and WebMite Firmware
     Page 4 of 4
Posted: 12:38pm 21 Jul 2023
Peter,
Any reason why audio support for MOD file is not supported ? Is there a conflict with PWM audio ?
Can this be used as a basis (it has PWM support)
pico MOD player
Edited 2023-07-22 00:08 by Volhout
Posted: 08:43pm 25 Jul 2023
@Peter,
Is there a reason why the picomite BLIT WRITE command does not have the "mode" option (mirror image in X or Y direction) where as the picomite VGA SPRITE WRITE command does ?
Is this an omission, or is it simply not possible ?
Thank you in advance for your answer.
P.S. another technical question. In VGA picomite I created sprites. These where saved  as 16 bit BMP's. In MS PAINT I converted them to 24 bit BMP's. These 24 bit BMP's (in MS PAINT) look identical to the 16bit BMP's. However, if I load the 24 bit BMP's into a picomite with ILI9341 LCD, they look as if there are colors missing. Now I seem to remember that the ILI9341 has 16 bit colors. Is it possible that the RGB conversion from 24bit to 16bit is removing essential bits ??
Edited 2023-07-26 06:51 by Volhout
Posted: 10:16am 27 Jul 2023
  Volhout said  @Peter,
hmm, good question!
     Page 4 of 4
