Local Time 14:07 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Fonts for Mites
     Page 4 of 4
Posted: 03:37pm 07 Aug 2026
Hi Martin,
You've probably got better things to do, but if you find yourself at a loose end I wonder if an MMBasic version of the Microserif font https://fontenddev.com/fonts/microserif would be possible ?
Martin H.
Posted: 04:30am 08 Aug 2026
Hi Tom
This Microserif font looks cute
That should be a 6x8-pixel font; I can try to convert it this weekend.
What I can’t do is adjust the kerning*, as the Pico always uses fixed spacing between the letters.
Martin
*Kerning: Adjusting the spacing between exactly two specific characters (e.g. combinations such as ‘A’ and ‘V’ or ‘T’ and ‘o’), where the shape of the letters creates large visual gaps
EDIT
I had to redraw the font because I don’t seem to have a Windows drawing programme that draws the characters without trying to smooth them out.
I’ve created the font, but it’s 8x8, so the spacing is actually too wide. I haven’t yet worked out how to shift the bits for 6-pixel-wide fonts.
microserif.zip
Edited 2026-08-09 01:38 by Martin H.
'no comment
Posted: 07:52pm 09 Aug 2026
Thanks Martin,
I did the prep work to allow me to manipulate the fonts in my adventure game earlier today so I just need to see if Claude can be persuaded to sort out the width issue.
Martin H.
Posted: 08:40pm 09 Aug 2026
Of course, the problem with the width can be solved ‘by hand’
cls
wrt 0,0,"It’s always a brilliant piece of writing",RGB(GREEN)
sub wrt tx,ty,prd$,col
local integer n
for n=1 to len(prd$)
text tx,ty,mid$(prd$,n,1),,9,,col,-1
inc tx,6:next
end sub
I had a look at your Git repository on MMB4W, but couldn’t find the code for the Picomite Font 7 (6x8); otherwise I could have checked how the bits are shifted there.
Edited 2026-08-10 06:40 by Martin H.
'no comment
Posted: 08:45pm 09 Aug 2026
Font 7 is this one, hadn't noticed the name was backwards before: https://github.com/thwill1000/mmb4l/blob/main/src/fonts/Font_8x6.h - not my doing, from the original MMBasic source.
Posted: 08:55pm 09 Aug 2026
Anyway Claude Sonnet 5 (Low effort) succeeded with a bit of kicking and access to the font reading and glyph rendering code from MMBasic:
microserif6x8.zip
Martin H.
Posted: 11:55am 10 Aug 2026
  thwill said  Font 7 is this one, hadn't noticed the name was backwards before: https://github.com/thwill1000/mmb4l/blob/main/src/fonts/Font_8x6.h - not my doing, from the original MMBasic source.
That’s right, it’s 8x6, but we’re looking for 6x8. According to the Picomite manual, Font uses the 6x8 format.
  thwill said  Anyway Claude Sonnet 5 (Low effort) succeeded with a bit of kicking and access to the font reading and glyph rendering code from MMBasic:
microserif6x8.zip
Great, so it worked out in the end after all, and my painting wasn’t quite for nothing
Martin
Edited 2026-08-10 22:12 by Martin H.
'no comment
Posted: 01:13pm 10 Aug 2026
I was referring to the fact that the filename "Font_8x6.h" suggests it contains an 8x6 font whereas it clearly contains a 6x8 font. The same file exists in the PicoMite source repository.
Posted: 01:14pm 10 Aug 2026
  Martin H. said  Great, so it worked out in the end after all, and my painting wasn’t quite for nothing
Yep, thanks for doing it, not sure I'm going to use it as the default font in my adventure game but it is there as an option.
     Page 4 of 4
