Local Time 23:23 25 Oct 2026 Privacy Policy
     Page 4 of 52
homa
Posted: 12:59pm 15 Mar 2025
Oops, ... Mistake?
I've finally got some time again and have been enjoying the whole development. I updated the rp2350 on the reference board to “PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.02RC3”.
It looks good at first. The application “testcard.bas” shows the different graphic modes. Then I have:
> play mp3 “going”
executed. Here the screen reproducibly goes into sleep mode because there is no more graphics output! Was that intended? I find the previous behavior better.
Even a
> load “testcard”
> run
[19] If Instr(MM.DEVICE$, “HDMI”) Then
Error : Expression Syntax
does not help! Now there is even an error message that was not there before.
Only a reset helps.
Here is the option list:
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD GR
OPTION CPUSPEED (KHz) 252000
OPTION RESOLUTION 640x480
OPTION SDCARD GP22, GP26, GP27, GP28
OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  192
OPTION PLATFORM HDMIUSB
Matthias
Posted: 01:24pm 15 Mar 2025
  Quote  If Instr(MM.DEVICE$, “HDMI”) Then
You need to re-download - this is the bug I reported fixed earlier this morning
I'll have a look at the mp3 issue
JanVolk
Posted: 01:45pm 15 Mar 2025
This is with the latest version
PicoMite MMBasic RP2040 Edition V6.00.02RC3
Copyright 2011-2025 Geoff Graham
Copyright 2016-2025 Peter Mather
> option list
OPTION SYSTEM I2C GP4,GP5
OPTION DISPLAY 44, 89
OPTION SDCARD GP17, GP18, GP19, GP16
> list functions
Error: Invalid address - resetting
Greetings,
Jan.
Posted: 02:51pm 15 Mar 2025
V6.00.02RC4 is available on
Fixes MP3 playback on HDMI versions
Fixes LIST FUNCTIONS
Fixes instability in 1280x720 mode 3 HDMI
Fixes graphics commands in 800x600 VGA
Fixes memory issue in WAV playback on RP2040 VGA
Fixes bug in MM.DEVICE$ in USB versions
Posted: 02:53pm 15 Mar 2025
@Peter,
Yes, that later version (I call it "v6.00.02rc3_2" runs all the programs that have caused problems before. We have another winner.
This one is just as good as "v6.00.02b16_2" was...
- logic analyzer: runs
- petscii robots: runs
- as02-5 runs
- rocks: runs
- blocks_sound : runs (played for 20 minutes)
- kong : runs
- chemichaos : runs
- circle : runs
- asciimovie : runs
- flappy : runs
- snake : runs
- gems&rocks: runs
- flow : runs
- 2048 : runs
I still have to test the thermal camera.
javavi
Posted: 04:19pm 15 Mar 2025
PicoMite VGA/HDMI 6.00.02b10
Is it possible to make the MAP(n) function work in MODE 1 to set the color with the COLOR command and other commands ?
For example, something like this:
MODE 1
COLOR MAP(14), MAP(7)
PRINT "COLOUR MAP"
Posted: 05:04pm 15 Mar 2025
No, you can set the tile colours. With HDMI you have a choice of 32768 RGB555 colours in 640x480 and 720x400 and 256 RGB332 colours in other modes. In VGA you kjust have the normal 16 colours
TILE 0,0,RGB(red),rgb(white),MM.HRES\MM.fontwidth,mm.vres\mm.fontheight
Edited 2025-03-16 03:05 by matherp
javavi
Posted: 06:47pm 15 Mar 2025
  matherp said  No,
I recognize the first phase of the already traditional scheme of our communication with you.
Posted: 06:48pm 15 Mar 2025
Not in this case. The release is closed.
homa
Posted: 06:54pm 15 Mar 2025
> play mp3 "going"
> load "spriteDemo"
> run
> mode 1
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.02RC4
OPTION KEYBOARD GR
> ? MM.INFO$(CPUSPEED)
315000000
mp3 works   ==> rejoiced too soon!
> play mp3 "going"
Error : Not enough Heap memory
I miss an output of the CPU speed when it is not on default.
Matthias
Edited 2025-03-16 05:10 by homa
Posted: 07:45pm 15 Mar 2025
  Quote  play mp3 "going"
You don't give me a sequence or what else is loaded and/or has been run. If memory is used for other things you will get this
homa
Posted: 09:05pm 15 Mar 2025
exactly the same sequence as above:
reset
> b:
> play mp3 "going"
> load "spriteDemo"
> run
CTRL+C
> mode 1
> option list
315000000
> play mp3 "going"
Posted: 10:55pm 15 Mar 2025
  matherp said  V6.00.02RC4 is available…
Fixes instability in 1280x720 mode 3…..
Confirming all is good once again.
Thank You for the quick fix; it is very much appreciated.
Posted: 10:56pm 15 Mar 2025
Yes but you don't show how much memory spritedemo is taking. I've checked and playing mp3 doesn't leak memory so it just looks like you are using it all - nothing I can do about that. MP3 playing is very memory hungry
homa
Posted: 11:08pm 15 Mar 2025
  matherp said  Yes but you don't show how much memory spritedemo is taking. I've checked and playing mp3 doesn't leak memory so it just looks like you are using it all - nothing I can do about that. MP3 playing is very memory hungry
spriteDemo is your Code from here: https://www.thebackshed.com/forum/ViewTopic.php?TID=16672&PID=216958#216958#216958
you are right, a “new” helps to free the memory and then “play mp3” works again.
Edited 2025-03-16 09:12 by homa
Posted: 08:59am 16 Mar 2025
  Quote  you are right, a “new” helps to free the memory and then “play mp3” works again.
There does seem to be a bug but it looks like something to do with clean up of sprites rather than anything to do with mp3. Will invesigate further
UPDATE
It's caused by the sprites not being closed with ctrl-C. You can do this manually with SPRITE CLOSE ALL. This is a difficult question. How much do I clear up after ctrl-C and how much to leave? The advantage of leaving things is to allow debugging at the command line. So, at the moment, after exiting I could do type SPRITE SHOW to check something. The disadvantage, as you have found is that it leaves a resource tied up.
Any thoughts from anyone reading this appreciated
Edited 2025-03-16 19:47 by matherp
dddns
Posted: 10:25am 16 Mar 2025
  Quote  The advantage of leaving things is to allow debugging at the command line.
From my point of view please leave it as it is, for debugging it is really useful.
And there are commands like "memory" and "clear", a "new" is not necessary.
bfwolf
Posted: 10:56am 16 Mar 2025
  matherp said  UPDATE
How about adding a non-remanent "DEBUG" option?
For example, "OPTION DEBUG SPRITE KEEP/CLEAR," where "CLEAR" would be the default.
Saving such "OPTION DEBUG" variants together in a bit field in RAM (integer = 64 bits) would also be memory efficient.
This would make it easy to add more "OPTION DEBUG" variants.
But I don't know if that would be easy to do.
Edited 2025-03-16 20:57 by bfwolf
twofingers
Posted: 12:10pm 16 Mar 2025
Hi Peter,
I know it's too late for this release, but maybe an idea for the next one? Is it possible to automatically set the lengths of string constants? This means that MMBasic or the preprocessor limits the memory usage to the value required by the string constant, a kind of automatic "LENGTH" command in the background. I'm currently busy with VT100 escape codes. That can easily amount to more than 20 constants and consume more than 5-10kB of heap memory for constants that should actually only require 100 bytes. I'm not interested in discussing how to work around this, e.g., by inserting the escape sequences directly into the code or something similar.
Perhaps this is something you'd like to add to your to-do list?
Michael
Posted: 12:37pm 16 Mar 2025
Michael,
Print MM.Info(heap)
Dim a$(20) length 10
Print MM.Info(heap)
Shows that 21 strings length 10 characters (210 bytes) consume only 256 bytes heap. Quite efficient.
Saved 51 bytes
130560
130304
Edited 2025-03-16 22:38 by Volhout
     Page 4 of 52
