Forum Index : Microcontroller and PC projects : PicoMite V6.03.02 betas
| terekgabor Senior Member Joined: 02/01/2026 Location: HungaryPosts: 129 |
One more idea: Maybe LIBRARY DELETE can be run from a program. To make flash slot free at the end of the program. G@bor |
Hello Peter again! I tried KEYDOWN on Picocalc. I got value 0 back all the time in any cases. Maybe I missed something? G@bor |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11888 |
What version keyboard firmware are you running? Try the chuckie egg program - works for me. Make sure you use the latest PICORP2350 firmware from the github |
I had the ”old” b5 version - missed the update. Now updated and it is ok. Also thanks for the repair of Library with Definefont! G@bor |
Now available V6.03.02b6 on https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V6.03.02b6 This version adds a new sound sub-system - perfect for sound effects. Try the attached. Full details in the manual or lookup the BBC manual. Available in all builds. Both engines feed the same audio output, so the difference is entirely in how the sound is described. PLAY SOUND is a bank of free-running oscillators that your program drives directly. PLAY BBC is a sequencer with a fixed synthesiser behind it, and the firmware does the timing. PLAY SOUND, the oscillator bank Pros: Rich timbres. Sine, square, triangle, sawtooth, periodic and white noise, plus a user waveform of 4096 points via PLAY LOAD SOUND. Sine is the only clean tone in MMBasic, and only this engine has it. True stereo. Each of the four sounds can go left, right or both, with separate volumes per side, so up to eight oscillators in total. Continuous pitch. Any frequency from 1 Hz to 20 kHz as a float, so smooth sweeps, detuning and exact tuning are all possible. Immediate. A new PLAY SOUND replaces a running sound at once. Volume changes are ramped over about a millisecond to hide clicks. Cons: No timing, no shape. There are no durations, queues or envelopes. Every note-on, note-off and fade is your program's job with PAUSE, SETTICK or a timer interrupt, so a tune is a lot of BASIC and competes with the game loop. Costly. Phase accumulators are floats stepped per sample per oscillator. The manual's own figure is about 23% of the CPU with four sounds on both sides, and the RP2040 has no FPU. Holds the output. Once started, every other PLAY command is blocked until an explicit PLAY STOP. Aliasing on RP2040. The polyBLEP that cleans square and sawtooth edges is RP2350 only. RP2040 keeps the naive edges because the RAM-resident code would not fit. PLAY BBC, the sequencer Pros: Timing is built in. Durations in twentieths of a second, an 8-note queue per channel, sync groups for chords and a flush bit for effects. A tune is a run of statements and the program carries on. Envelopes. Sixteen definable envelopes give ADSR volume and a three-section repeating pitch envelope, stepped at 100 Hz. Lasers, sirens, vibrato and explosions are one line each. Cheap. Integer arithmetic only, band-limited squares on every chip including RP2040. The state is about 470 bytes of heap taken on first use and nothing before that. Releases the output itself. When all queues drain it stops like PLAY TONE, so a following PLAY WAV needs no PLAY STOP. Direct ports. BBC Micro sound code runs with only the PLAY BBC prefix added, which is why Elite and Chuckie Egg now sound like the originals. Cons: Fixed palette. Three square voices and one noise channel, mono, no sine or user waveforms. Coarse pitch. Quarter-semitone steps over roughly 122 Hz to 4.8 kHz. Bass below 122 Hz and smooth sub-quarter-tone sweeps are not available. Coarse time. 50 ms note granularity and 10 ms envelope steps. Blocking on a full queue. The command waits for a slot, and MMBasic interrupts are deferred while it waits. Tick-driven programs must keep queues short or use flush. Higher latency. Its swing buffers are larger, so a note starts a little later after the command. PLAY SOUND PLAY BBC Voices 4 per side, 8 total 3 tone + 1 noise Output stereo mono Waveforms 7 + user table square, LFSR noise Pitch 1 to 20000 Hz, float 0 to 255, quarter-semitones Buffer per swing 704 bytes, about 4 ms 2048 bytes, about 11.6 ms The two cannot run at the same time, so a program picks one. Use PLAY SOUND when the sound itself is the point: sine tones, stereo placement, a sampled waveform, or a frequency you compute. Use PLAY BBC when the sound must run alongside a game loop with no attention from the program, or when porting BBC code. ' Play each of Elite's ten sounds in turn, named, so they can be judged by ' ear. Standalone: it carries its own copy of the SFX table from ' 45_sound.bas and of the four envelopes from the cassette loader's E%. ' ' Nothing here is approximated. Each effect is the four bytes the 6502 ' source holds it as, handed straight to PLAY BBC SOUND, and the envelopes ' are the loader's own numbers. ' ' Needs firmware 6.03.02b6 or above. The explosion's noise is pitch 7, ' which is clocked by channel 1 rather than at a fixed rate, and earlier ' firmware has no tuned noise setting to clock it with - it would come out ' as a flat hiss instead of a crash. ' ' RUN, and press a key between each. ESC stops. OPTION EXPLICIT OPTION DEFAULT NONE CONST TXN = 10 DIM INTEGER txCh(TXN-1), txAmp(TXN-1), txPit(TXN-1), txDur(TXN-1) DIM txNm$(TXN-1) LENGTH 44 DIM INTEGER txI ' envelope, T, three pitch steps, three section lengths, ADSR, two levels PLAY BBC ENVELOPE 1, 1, 0, 111, -8, 4, 1, 8, 8, -2, 0, -1, 112, 44 PLAY BBC ENVELOPE 2, 1, 14, -18, -1, 44, 32, 50, 6, 1, 0, -2, 120, 126 PLAY BBC ENVELOPE 3, 1, 1, -1, -3, 17, 32, 128, 1, 0, 0, -1, 1, 1 PLAY BBC ENVELOPE 4, 1, 4, -8, 44, 4, 6, 8, 22, 0, 0, -127, 126, 0 RESTORE dat_tx FOR txI = 0 TO TXN - 1 READ txNm$(txI), txCh(txI), txAmp(txI), txPit(txI), txDur(txI) NEXT txI CLS PRINT "Elite's sounds - a key plays the next, ESC stops" FOR txI = 0 TO TXN - 1 PRINT txI; " "; txNm$(txI) PLAY BBC SOUND txCh(txI), txAmp(txI), txPit(txI), txDur(txI) IF TxKey() = 27 THEN PLAY STOP : END NEXT txI ' The two halves of a kill are fired together by the game, and they belong ' together: the tone on channel 1 sweeps down under envelope 3 and the noise ' is clocked by it. Heard apart, neither is the sound. PRINT "and the two halves of an explosion together, as the game plays them" PLAY BBC SOUND txCh(3), txAmp(3), txPit(3), txDur(3) PLAY BBC SOUND txCh(2), txAmp(2), txPit(2), txDur(2) IF TxKey() = 27 THEN PLAY STOP : END PLAY STOP PRINT "done" END FUNCTION TxKey() AS INTEGER LOCAL k$ LENGTH 2 DO k$ = INKEY$ LOOP UNTIL k$ <> "" TxKey = ASC(k$) END FUNCTION dat_tx: ' name channel amp pitch duration DATA "our lasers", 18, 1, 0, 16 DATA "being hit by lasers", 18, 2, 44, 8 DATA "explosion, the noise half", 16, -15, 7, 26 DATA "explosion, the tone that sweeps it", 17, 3, 240, 24 DATA "short, high beep", 3, -15, 188, 1 DATA "long, low beep", 19, -12, 12, 8 DATA "missile away, or our own launch", 16, -15, 6, 12 DATA "hyperspace drive", 16, 2, 96, 16 DATA "E.C.M. on, until it is flushed", 19, 4, 194, 255 DATA "E.C.M. off, which is that flush", 19, 0, 0, 0 Edited 2026-09-14 23:13 by matherp |
Wow! SOUNDS fantastic! Thanks Peter! Anyway I have some thousands hours in Elite game, my favourite space sim. |
Perfect, you can find all the bugs for me |
Yeah, there are some bugs in ED, but not so many as in SC(Star Citizen). ED nowadays is a very playable simulator I think. Last surface mining update for example is a very good idea was from Frontier Dev. |
PLAY BBC SOUND is working very good. It remains me when I was young and we are playing and programming Enterprise 128k computer. I will test it whole night |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 693 |
> option list PicoMiteHDMI MMBasic RP2350B Edition V6.03.02b6 OPTION SYSTEM I2C GP20,GP21 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION KEYBOARD GR OPTION PICO OFF OPTION RESOLUTION 640x480 @ 315000KHz OPTION HDMI PINS 1, 3, 5, 7 OPTION SDCARD GP33, GP30, GP31, GP28 OPTION AUDIO I2S GP10,GP22', ON PWM CHANNEL 11 OPTION RTC AUTO ENABLE OPTION COUNT GP34,GP35,GP36,GP37 OPTION MODBUFF ENABLE 512 OPTION PLATFORM PICO COMPUTER 3 OPTION PSRAM PIN GP47 > How do I replace? OPTION KEYBOARD GR, 0, 1, 200, 75 According to the manual: > OPTION KEYBOARD GR Total of 6 Mbytes PSRAM available > OPTION KEYBOARD REPEAT 200, 75 Error : Invalid syntax > OPTION KEYBOARD REPEAT 200,75 Error : Invalid syntax > OPTION REPEAT 200,75 Error : Invalid Option |
Check the manual for a ps2 keyboard Edited 2026-09-15 02:40 by matherp |
My mistake – I ended up with the wrong firmware for the PC3 I was actually referring to the USB keyboard. |
Hi Peter, With the Wi-Fi firmware and the “TELNET CONSOLE ON” option, is there actually a way to check whether the console is in use via Telnet—in other words, whether an active connection exists? Matthias |
Hi Peter, I'm experimenting with `PLAY BBC SOUND` for background music in a game. I understand that each BBC sound channel has an 8-entry queue, but I can't find a way to query how many queue entries are currently free. How do you handle refilling the BBC sound queue in your games without blocking the main game loop? Do you simply keep track of how many notes have been queued, or is there a mechanism I'm missing to detect when the queue has room for more notes? Thanks! Matthias |
| javavi Guru Joined: 01/10/2023 Location: UkrainePosts: 609 |
The fantasy retro-computer TIC-80 features a built-in sound effects editor and a tracker music editor. How to TIC-80 - SFX Editor How to TIC-80 - Music Editor I’m not hinting at anything, but perhaps someday the PicoMite will also get a similar set of tools for playing around with sound. |
It can't do everything and these sound like candidates to write in Basic |
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 612 |
Peter, may have found an issue in FRAMEBUFFER MERGE 0,B running your code from the FUZIX manual on a PicoMite MMBasic RP2350A V6.03.02b6 OPTION SYSTEM SPI GP2,GP3,GP4 OPTION SYSTEM I2C GP0,GP1 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION HEARTBEAT OFF OPTION CPUSPEED (KHz) 200000 OPTION DISPLAY 40, 145 OPTION LCDPANEL ILI9488, LANDSCAPE,GP5,GP6,GP7,GP8,INVERT OPTION TOUCH GP10,GP9 GUI CALIBRATE 0, 3927, 3947, -1282, -792 OPTION GUI CONTROLS 10 OPTION SDCARD GP11 OPTION PLATFORM 480x320-res 'MODE 2 FRAMEBUFFER CREATE FRAMEBUFFER LAYER FRAMEBUFFER WRITE F ' the background, drawn once CLS RGB(BLUE) BOX 20, 20, 120, 80, 2, RGB(WHITE), RGB(RED) 'FRAMEBUFFER WRITE N DO FRAMEBUFFER WRITE L CLS 0 ' 0 is the transparent index CIRCLE x, 120, 30, 2, 1, RGB(YELLOW), RGB(YELLOW) FRAMEBUFFER WRITE N FRAMEBUFFER MERGE 0 x = x + 4 LOOP WHILE INKEY$ = "" runs ok, but changed into FRAMEBUFFER MERGE 0,B results in: [13 FRAMEBUFFER MERGE 0,B Error : CPU2 Stack overflow which IMHO should run as well. Gerald 73 de OE1HGA, Gerald |
Hello Peter! I have a question: I have a program where there are DATA lines in the main program (together with READ) and also there are DATA lines and READ in a function. Like this: DIM D$(2) AS STRING LENGTH 2 DATA “ab”, “cd”, “ef” READ D$() …. FUNCTION MYFUNC LOCAL E$(2) AS STRING LENGTH 2 DATA “ab”, “cd”, “ef” READ E$() … END FUNCTION This is working fine. But if I put the DATA lines (I tried also together with READ) from main program to a LIBRARY I got “String too long” error referred to the data line in the function. Is something normal behavior and I am doing something wrong? Thanks! G@bor |
framebuffer merge bug is fixed and will be in the next beta. Nobody has obviously tried it before with a screen wider than 320 pixels As to the DATA issue...... This is really difficult to explain. DATA has no concept of being in a subroutine it is program wide. When you issue a read statement it will read from the next unread data statement wherever it is. So, if there is data in the main program it will read that and if that doesn't fit the variable in the read then BANG! which is what you are seeing. There is a bug however, To read data from the library currently it has to be found by using RESTORE label before the read. READ will always start looking for data at the top of the main program, it doesn't currently then pass to the library when it exhausts the main program which I think it should. I think this is just a legacy hole from when the library was introduced. |
Thanks Peter! Now I modified my program, take out data lines from function and make one longer string instead locally. All the data line in the main program moved to the library. I will test it afternoon. G@bor |
