Forum Index : Microcontroller and PC projects : Pico Computer 3: Keyboard edition
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9402 |
I would definitely contact JLCPCB just in case it's their cleaner fluid that's attacking plastic in the socket. It may have started to happen when they changed to a different cleaner or started getting sockets from a different source. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6303 |
There is no USB clock. The text is unaltered since the days of the PS2 keyboard. Volhout PicomiteVGA PETSCII ROBOTS |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10157 |
@ Mick: Okey dokey. @ Volhout: You are quite correct! D- and D+ but no clock. Not sure how I missed that! ![]() Perhaps it is both a USB and PS/2 compatible KB. Edited 2026-11-03 10:23 by Grogster Smoke makes things work. When the smoke gets out, it stops! |
Update for everyone: I removed and replaced the uSD card socket with one I have here. It is DEFINITELY the socket that is the problem. The replacement uSD socket that I soldered on works perfectly, as expected. The one I removed, still has the same sticking problem, even once removed from the board. Perhaps JLC got a bad-batch of uSD card sockets? Smoke makes things work. When the smoke gets out, it stops! |
Easy to detect. Is the socket (inside) sticky... then it is flux Is the socket clean, it is mechanical friction, and may be solved by lubricating. The lubrication can be washed out with the manufacturing process. Or the socket itself is bad quality (mechanical tolerances). Volhout PicomiteVGA PETSCII ROBOTS |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3460 |
If the friction is between the metal cover and the top of the card perhaps it can be fixed by stretching the cover up 0.1 to 0.2 mm. Put some masking tape on a card and push it in and out a few times. Remove the tape to see if it is any better. |
I will have a tinker with the old socket and see what can be done. Certainly would be preferable, to find a solution that does not require me to remove it and replace it - not that this is any real hardship, it just sucks up a little of my time. I might try giving the bad socket a quick squirt of WD40. If that works OK, I could try it on one of the actual boards. Smoke makes things work. When the smoke gets out, it stops! |
You could even try washing up liquid solution. Detergent can be pretty good. WD40 is really intended to be a water displacer (Water Displacer 40). It's good for removing sticky residue off scissors though, and as a drilling lubricant for aluminium. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Owwwwwww!!! Never thought of THAT. Once the detergent dries out, wouldn't you have the same problem though? Smoke makes things work. When the smoke gets out, it stops! |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4407 |
I expect the idea is the detergent might shift the sticky stuff, then you wash thoroughly to shift both. John |
Dishwasher.... Then re-lubricate Volhout PicomiteVGA PETSCII ROBOTS |
Some fluxes are water soluble - they are designed to be washed with water. Some miniature relays have a pip on the case that you are supposed to cut off after washing to allow the contacts to vent, not good to wash those obviously. Keyboards work fine after being put in the dishwasher and dried out. It's not that strange really. :) A bit of switch cleaner/lubricant on the socket after and it could be like new. If it works. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| mozzie Guru Joined: 15/06/2020 Location: AustraliaPosts: 524 |
G'day, The SDCard socket on my PC2 was fixed using "brake + carby" cleaner and an old toothbrush, it is bloody hard to remove so maybe the detergent will break it up, next time perhaps. Old toothbrushes are great for this kind of thing, once they are too shaggy for brushing teeth there is still a heap of life left for the workshop Speaking from experience, WD40 is for making LUCAS electrics work when there is any moisture in the atmosphere (long term Mini owner...)Regards, Lyle. |
Ahhhhhh, LUCAS electrics - we meet again..... Thanks for all the other comments, chums, I will let you know how it comes out. I have another batch of CMM2G2's in production, so I will be interested to see how their SD card sockets turn out. It might only be an issue with the micro-SD ones. Smoke makes things work. When the smoke gets out, it stops! |
| calcmandan Newbie Joined: 24/07/2020 Location: United StatesPosts: 25 |
I'm studying the linear power-supply design while reproducing the circuitry in KiCad, and I have a question regarding the 2350b internal voltage regulator. The design uses an external linear regulator for dvdd supply rather than using the internal regulator of the 2350b. The connections confusing me: Pin 63 (VREG_LX): Not connected Pin 64 (VREG_VIN): Supplied from 3.3V via 10ohm resistor and a 2.2 bypass cap Pin 65 (VREG_FB): Not connected Pin 61 (VREG_AVDD): Supplying from the other 3.3v circuit I read part 6.3.7 of the 2350 datasheet, specifically figure 21 covering external core-voltage supplies. It shows the specification of connecting vreg_fb to ground when dvdd is supplied externally. I'm curious whether leaving veg_fb floating in the Pico 3 design is deliberate. If so, what is the rationale. Does the firmware put the internal regulator into high impedance mode? Does this eliminate the need to establish a defined potential on the feedback pin? Or am I overlooking something obvious? I'm interested in understanding the design before proceeding with my schematic. Thank you, calcmandan sysop | air & wave bbs finger | info@bbs.airandwave.net |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12301 |
I missed 6.3.7 when designing the circuit. However, given that the boards work perfectly I decided not to make a change to conform just in case. |
It seems to always be simpler than I thought. Thanks, calcmandan sysop | air & wave bbs finger | info@bbs.airandwave.net |
| ManiB Senior Member Joined: 12/10/2019 Location: GermanyPosts: 197 |
@Peter, I found this keyboard on Amazon; its dimensions are approx. 22 x 11 x 0.7 cm. ![]() What do you think – wouldn’t that be a good candidate for the PC3 Keyboard Edition? |
Hi ManiB, Do you know the story of the smallest skyscraper in the world ? read here the core of the test: ![]() This keyboard is 21.7mmx10.9mm in size....(not cm) Volhout Edited 2026-11-25 18:33 by Volhout PicomiteVGA PETSCII ROBOTS |
| Bleep Guru Joined: 09/01/2022 Location: United KingdomPosts: 889 |
I think the image is wrong, the description says "Mini keyboard: The mini keyboard (217 x 109 x 7 mm) and the 50 cm USB cable. It comes with a plug & play USB interface. It is enough to connect to your computer, regardless of whether it is on or under your desk." |
