Local Time 02:58 29 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Test Version 2.6D
     Page 4 of 4
Greg Fordyce
Posted: 09:39am 11 Oct 2011
Anthony, I saw that last night as well, but it is a different issue than what I found. So it seems two small bugs with LIST, but I can live with them.
Looking at the wish list, color is top of the list (wish 11) and NTSC is number 11 (wish 25). I suppose the votes can speak for themselves. BTW wish 33 is number 2 on the list, it can be removed as it is for the AUTO command.Edited by Greg Fordyce 2011-10-12
CircuitGizmos
Posted: 01:33pm 11 Oct 2011
  donmck said
However in the US, you will have trouble finding a set that is anything but NTSC only.
I have noticed newer ones touting PAL support. But there are still a lot of sets around without it. And frankly a lot of tube TVs that, like the home computer revolution of the 80s, can be pressed into service as a monitor for the MM.
My personal need is because I have a modulator input to my system that is NTSC. This way all of the TVs that I have can be tuned to a channel that displays information from the MM.
If it isn't implemented as a feature of the language, I would be happy just to know what would change in the source code to implement NTSC. Perhaps a compilation option.
Vikingboy
Posted: 05:38pm 11 Oct 2011
Hi,
You can get pal/ntsc encoder chips pretty cheaply and easily, they will take usually an RGB or YUV signal and a timing signal and will output either pal or ntsc as an option, you could easily take the rgb I think from the VGA output and since that is already running at 60Hz it should be fairly easy to encode to NTSC. I did a quick google search and there are a couple of sites with some schematics.
Also you can get really cheap and nasty consumer transcoders these days for not allot of money and considering it is a simple BW low rez image they would probably give quite acceptable output.
rgds,
Andrew
CircuitGizmos
Posted: 05:53pm 11 Oct 2011
  Vikingboy said   Hi,
rgds,
Andrew
I'm sure there are all sorts of hardware solutions. Not what I care for.
wizard
Posted: 06:20pm 11 Oct 2011
Hi,
Kinda silly not to have NTSC params.
There are a LOT of them out there.
Maybe a BASIC command rather than
a hardware pin?
Wiz
p.s.- FWIW my heat gun dependent breadboard was
'fixed' with a short leaded tant. gumdrop cap.
Goodbye heatgun!
donmck
Posted: 07:38pm 11 Oct 2011
Wish 13: Auto Renumber Lines
Wish 33: Auto Line Number Input ie: Auto 100,10 Syntax or default 10,10
Thanks Greg,
I haven't kept right up with things recently.
Does this cover both 13 and 33?
Cheers Don...
https://www.dontronics.com
Greg Fordyce
Posted: 09:20pm 11 Oct 2011
  donmck said
Does this cover both 13 and 33?Cheers Don...
Yes
donmck
Posted: 10:46pm 11 Oct 2011
  Greg Fordyce said
Yes
Thanks, both removed.
Cheers Don...
sparkey
Posted: 04:11pm 23 Oct 2011
geoff how far away is 2 point 7 firm pls..regards sparkey...///...///
donmck
Posted: 08:23pm 23 Oct 2011
  sparkey said   geoff how far away is 2 point 7 firm pls..regards sparkey...///...///
As far as I understand, Geoff is going to release this in conjunction with a Silicon Chip Magazine article.
Cheers Don...
Geoffg
Posted: 09:09pm 23 Oct 2011
Yes, a few days now.
Geoff
VK6MRG
Posted: 10:04am 24 Oct 2011
I have just picked up my November SC mag!
VK6MRG
Posted: 10:07am 24 Oct 2011
Page 34!
All I can say is, well, it's not what I expected!
VK6MRG
Posted: 10:53am 24 Oct 2011
Still reading!
And when it comes to the Version 2.7 of the firmware... WOW!
I can't wait to have a play with that!
VK6MRG
Posted: 12:49pm 24 Oct 2011
I have started a new topic about the new Maximite.
Mini Maximite V2
     Page 4 of 4
