Local Time 18:15 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Firewing or VB.net for PIC24HJ
     Page 4 of 4
vasi
Posted: 12:00pm 07 Jun 2014
  Goeytex said  ...
While I cannot get back to it right away, I suspect that on the WIN7 installation that the configuration was not pointing correctly to one of the MPLAB directories causing the linker not to work.
I've suspected that, especially regarding to LKR folder...
The blue background is kept for historical reasons (it resembles Turbo Pascal 7.0 IDE). I am now in Linux after a fresh install and I don't have WINE installed... but I'm sure you can figure how you change the colors (themes) for the syntax highlighting. Edited by vasi 2014-06-08
Elvish name: Mablung Miriel
Beyound Arduino Lang
Goeytex
Posted: 06:06pm 07 Jun 2014
@Vasi,
On the Win 7 installation the folder settings were correct. I removed MPL8.92 and installed 8.6, then "some" of the example projects would compile. It seems that some of the example code is just bad,untested. or may only work on older versions.
The Pascal language seems convoluted compared to what I am used to, and the included libraries don't seem that good.
I am not going to spend any more time on this. For now, I am going to remove it from my system. Maybe I will try again at another time.
Bill
     Page 4 of 4
