Local Time 15:42 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximites on Windows 10
     Page 4 of 4
Posted: 08:42am 25 Mar 2018
  Quote  When I reset the board via the reset switch, or when I send a 'break' signal from Tera Term, I get the welcome message from the MMX44, but no '>' and no flashing cursor.
This suggests there is a program "autorunning".
Hold down the ! key and press reset on the PCB. You should get a message that the firmware is resetting options and that will clear anything left running. Otherwise it sounds like a USB issue on the PC.
palcal
Posted: 08:45am 25 Mar 2018
Yes there was a program "autorunning". Thanks for that but that does not apply to the MM or MM+ does it?
Paul.
Posted: 09:12am 25 Mar 2018
  Quote  hanks for that but that does not apply to the MM or MM+ does it?
Yes, exactly the same
mschmalenbach
Posted: 02:23pm 25 Mar 2018
  WhiteWizzard said   Hi Martin,
Ensure you power your MMX from the larger, square USB Type-B socket next to the Power Jack. The other USB socket (Type-A in top right corner) is set up for. USB keyboard.
Your MMX44 was left set for a TFT, and possibly with OPTION AUTORUN ON.
As TassyJim mentions above, pressing Ctrl-C on the TeraTerm keyboard will 'break' the auto-running program (assuming it is AUTORUNing).
Let us know if this sorts you out. . .
Phil
Hi Phil
D'Oh!
I'd forgotten the last thing we did was have autorun on!!
I sent a CTRL-C and it's now all peachy over Tera Term on my windows laptop!
I've also gotten my PS2 keyboard recognised.
I just can't get vga to work. When I command "option lcdpanel vga" I get an error saying it's already configured.
I've tried it on 2 different monitors, and neither of them is seeing a VGA signal.
I've also done "option lcdpanel noconsole."
Still no joy.
I know I'm missing something simple, but for the life of me I can't think what!
Martin
mschmalenbach
Posted: 02:33pm 25 Mar 2018
One more thing - I got my xmas pressie to myself, a Rigol 4 channel 100MHz digital storage scope out - I'm not seeing any video signals at all on the VGA connector.
So clearly I'm missing a command somewhere!
Martin
Posted: 02:36pm 25 Mar 2018
  Quote  I just can't get vga to work
Based on Phil's note above
  Quote  Your MMX44 was left set for a TFT
So
OPTION LCDPANEL DISABLE
then
OPTION LCDPANEL VGA
Personally I think it is best to do a full reset as in my post above and start from a clean setup.
Type OPTION LIST
to see what is set at the momentEdited by matherp 2018-03-27
mschmalenbach
Posted: 02:43pm 25 Mar 2018
When checking mm.vres and mm.hres I get 480 and 800 respectively - ideal for one of those bigger lCD panels, but NOT VGA resolution!
mschmalenbach
Posted: 02:45pm 25 Mar 2018
option list gives the following...
OPTION CPU 252
OPTION LCDPANEL SSD1963_5, LANDSCAPE,, 142
OPTION TOUCH 118, 121, 103
OPTION KEYBOARD US
OPTION USBKEYBOARD UK
OPTION SDCARD 93, 94
OPTION RTC 15, 16
OPTION HEARTBEAT ON
mschmalenbach
Posted: 02:56pm 25 Mar 2018
OK - the VGA option is now running after disabling the LCD panel.
My scope shows a reasonable VGA signal now on the VGA connector, but none of the 3 monitors I have will display the VGA image although now they do all recognise there is a signal there - they didn't do that before.
One monitor reports a 640x480 display, tries to auto adjust to display it, but comes up with a blank display. :(
EDIT: this is after a hard reset, which would at least display the (c) message...Edited by mschmalenbach 2018-03-27
mschmalenbach
Posted: 03:04pm 25 Mar 2018
UPDATE
I decided to just run the resident program, which is the spinning cube...
And up came the display - a spinning cube, in green, very smooth!
So, do I just need to enable console output to the VGA?
UPDATE 2:
It's all running fine now. I have console & running display on all 3 monitors in turn, and PS2 keyboard input.
Nice. It's like being back in the 80s with my old BBC or C-64.
But at 252 MHz!!Edited by mschmalenbach 2018-03-27
Posted: 04:17pm 25 Mar 2018
Glad it is all working
Please disable whichever keyboard you are not using. This is WW'S testing configuration and you should have either/or not both. Also if you are using VGA then disable touch.Edited by matherp 2018-03-27
palcal
Posted: 08:45pm 25 Mar 2018
The problem with my 144 pin MMX was that there was a program autorunning BUT it had an error in it, so was stopping with an error message and so CTRL-C would not work.
I don't know what Matherp meant when he said...
  Quote  This suggests there is a program "autorunning".
I have always used CTRL-C to break into an Autorunning program.
Paul.
Posted: 09:42pm 25 Mar 2018
  Quote  The problem with my 144 pin MMX was that there was a program autorunning BUT it had an error in it, so was stopping with an error message and so CTRL-C would not work.
It is impossible to diagnose what if anything is wrong based on the information you are giving. If I create a program with an error in it and "autorun" it, it is comes back to the command prompt exactly as expected. If you create a program that corrupts the MM to the extent that MMBasic fails and then autorun it then it will need a full reset to recover and, as we have seen in other threads, this can sometimes even mean reflashing the chip (MM2 and MM+ as well as MMX)
     Page 4 of 4
