Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10043
Posted: 09:54pm 22 Mar 2018
Lovely, thanks, I will have a play with this over the weekend with any luck. This week has been busy so I have not had as much time to play with things on the bench.Smoke makes things work. When the smoke gets out, it stops!
PeterB Guru Joined: 05/02/2015 Location: AustraliaPosts: 669
Posted: 03:53am 04 Apr 2018
G'Day For what it is worth I have connected up a 4 key/4 relay system that appears to be similar. bit time = 2 msec 1 = hi for 1.6 msec 0 = lo for 0.6 msec gap between blocks = 14 msec gap between noise and first block = 14 msec first block of data appears to be corrupted. Key fob #1 button A is 775D03 B is 775D0C C is 775D30 D is 775DC0 Key fob #2 button A is 115403 B is 11540C C is 115430 D is 1154C0 Each block has a 0 parity stuck on the end and since every group has an odd number of 1s I am not sure if it is parity. It should be easy to decode with two monos (plus a bit of other stuff). :) Peter Edit 0 = hi for 0.6 msec PeterEdited by PeterB 2018-04-05
