Forum Index : Microcontroller and PC projects : Micromite V5.04.09 Beta 19
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2265 |
Still like to know if this is the same in the previous versions, however a short bit of code and I can now set the input limit to anything I want. User can type all day and nothing more is added to the TextBox display once set limit is reached. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1134 |
Guys, I am still struggling with NumberBox. Can someone have a look at the code below to see where I am going off the rails or if there really is a bug there - appreciated any help or advice. Option explicit DIM MyNB = 1 Dim InsideNB DIM ExitNB DIM NBKeyVal ' Carry out initialisation routines here - enable interrupt last StartPoint: CLS Font 3 GUI numberbox MyNB,10,120,180,40,RGB(red),RGB(Black) BackLight 100 GUI interrupt TouchDown,TouchUp ' subroutine to handle touch int Main: Do 'Main program loop, DO while InsideNB = 0 LOOP ' should only get here if touch detected If ExitNB = 1 Then Print "NB exited, NB value returned is ",CtrlVal(MyNB) print "NB key value variable is ",NBKeyVal ExitNB = 0 EndIf Loop ' end of main process loop ' Interrupt handling subroutines Sub TouchDown InsideNB = 1 ' entered numberbox end sub Sub TouchUp ExitNB = 1 ' left the numberbox pressing Ent InsideNB = 0 ' End Sub Sub MM.KEYPRESS ref as Integer, caption as string print "Key pressed had caption ",caption If ref = MyNB AND caption = "Ent" Then print "Inside KP, Ent pressed with key value = ",CtrlVal(ref) ' manual says this will return a string? ' *** this next line fails because CtrlVal(ref) actually returns a Null (I think) which VAL does not like if VAL(CtrlVal(ref)) > 60 then CtrlVal(ref) = "60" ' *** comment out the line above and uncomment the line below ' if CtrlVal(ref) > 60 then CtrlVal(ref) = 60 ' *** the line above does not throw an error but does not work becuase if CtrlVal(ref) returns a NULL ' the > 60 line will always fail. if you enter a number greater than 60 it is not changed NBKeyVal = CtrlVal(ref) ' here I want a global variable to equal the number entered ' but I always end up with NBKeyVal with a value of 0 Endif End Sub According to the manual, the MM.KEYPRESS subroutine should allow checking the value entered. The test code above is as per the manual as far as I can see. Thanks, panky ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Currently you can't read the Keypad from within MM.Keypress, that is one of the problems. You could overcome that by reading the control value outside of MM.Keypress, after the control closes. Just flag when the Ent key is pressed and then read the Control contents in the main program. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Thanks Mike, I had pretty much figured that out - it was the issue with whether the fact that CtrlVal(ref) inside KEYPRESS was a string as indicated in the manual or was something else (it acts like a NULL). In any event, either way there is an error in the manual or a bug within KEYPRESS. Thanks for taking the time to assist. panky ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| Bizzie Senior Member Joined: 06/07/2014 Location: AustraliaPosts: 194 |
I have not used MM.KEYPRESS at all in my code but I regularly get the value from a NUMBERBOX() with NBKeyVal = CtrlVal(LASTREF) after the Touch UP interrupt has been fired (usual method set flag in interrupt routine and process in another sub). Not sure if this helps or not. Rob White |
Hi Rob, That's also how I normally do it - I was just trying to determine if there was a bug in KEYPRESS as a result of earlier dicussion in this thread. Cheers, panky. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
I needed to turn Beta 19 into a final release which I have now done. It can be downloaded from http://geoffg.net/micromite.html (scroll to the bottom of the page). There are a number of features and bugs which have been reported here which did not make it into this release so I plan to start a V5.04.10 beta version in which I will tackle these. This will be out soon and I will start a new thread for it. So, keep your eyes peeled. Geoff Geoff Graham - http://geoffg.net |
Thanks Geoff, I just wanted to say that this is a fabulous piece of software and none of the problems we report are in any way knocking the incredible work effort you have put into bringing this to life over the years. It's so good that I have to constantly remind myself that this is free software. Thanks again * 10000000. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
| OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1051 |
Totally agree. |
Amen from me also. panky ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
