Local Time 16:03 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.07.00b12 - Various fixes
     Page 5 of 9
Posted: 08:29am 08 Apr 2021
V5.07.00b26 now available
GUI BITMAP command restored as per MM2/ArmmiteF4
Posted: 10:46am 08 Apr 2021
ooh! Thanks Peter. I liked that one on the MM2. :)
epsilon
Posted: 08:44am 09 Apr 2021
Is this the best place to flag documentation errors?
In the User Guide, the 'pages available in the various modes' next to the mode command has some errors:
MODE 3,16: 0-25 (doc says 0-26)
MODE 3,12: 0-24 (doc says 0-25)
MODE 3,8: 0-53 (doc says 0-54)
MODE 5,16: 0-30 (doc says 0-31)
MODE 5,12: 0-29 (doc says 0-30)
MODE 5,8: 0-60 (doc says 0-61)
MODE 6,16: 0-26 (doc says 0-27)
MODE 6,12: 0-25 (doc says 0-26)
MODE 6,8: 0-53 (doc says 0-54)
MODE 7,16: 0-19 (doc says 0-21)
MODE 7,12: 0-18 (doc says 0-20)
MODE 7,8: 0-41 (doc says 0-42)
(MODEs 11 and 12 I couldn't verify)
MODE 13,16: 0-11 (doc says 0-12)
MODE 13,12: 0-10 (doc says 0-11)
MODE 13,8: 0-26 (doc says 0-27)
MODE 14 is not documented.
Epsilon CMM2 projects
Posted: 05:52pm 11 Apr 2021
V5.07.00b27 now available
Improves flac and mp3 playback when using image save
The CMM2 now supports the calculation of pitch, roll and yaw angles from accelerometer and magnetometer inputs.
For  information on this technology see https://github.com/kriswiner/MPU-6050/wiki/Affordable-9-DoF-Sensor-Fusion
The MATH SENSORFUSION command supports both the MADGWICK and MAHONY fusion algorithms. The format of the command  is:
MATH SENSORFUSION type ax, ay, az, gx, gy, gz, mx, my, mz,  pitch, roll, yaw [,p1] [,p2]
Type can be MAHONY or MADGWICK
Ax, ay, and az are the accelerations in the three directions and should be specified in units of standard gravitational acceleration.
Gx, gy, and gz are the instantaneous values of  rotational speed which should be specified in radians per second.
Mx, my, and mz are the magnetic fields in the three directions and should be specified in nano-Tesla (nT)
Care must be taken to ensure that the x, y and z components are consistent between the three inputs. So , for example, using the MPU-9250 the correct input will be ax, ay,az, gx, gy, gz, my, mx, -mz based on the reading from the sensor.
Pitch, roll and yaw should be floating point variables and will contain the outputs from the sensor fusion.
The MATH SENSORFUSION routine will automatically measure the time between consecutive calls and will use this in its internal calculations.
The Madwick algorithm takes an optional parameter p1. This is used as beta in the calculation. It defaults to 0.5 if not specified
The Mahony algorithm takes two optional parameters p1, and p2. These are used as Kp and Ki in the calculation. If not specified these default to 10.0 and 0.0 respectively.
A fully worked example of using the code is given below for the GY-91 MCU9250 module
Connect Vin to 5V, GND to GND, SDA to pin 3, SCL to PIN 5 and SDO to 3.3V (selects the alternative I2C address.
The code contains lots of unnecessary optional features for self test and calibration but the required routines are really just the main program loop, the chip initialisation, and the chip read routines.
Link the roll, pitch and yaw outputs to the CMM2 3D routines to control and visualise a 3D object
'  Micromite AHRS using MPU9250
'  Version 2: Sensor fusion converted to MATH SENSORFUSION command
'  Original source code from kriswiner (https://github.com/kriswiner/MPU-9250)
'  and Sebastion Madgwick's Open source IMU and AHRS algorithms
'   MPU9250 connections
'   GND
'   VCC - 3.3V
'   SCL to I2C clock
'   SDA to I2C data
'   NCS to 3.3V (needed to force I2C)
'   INT to intPin
'   SD0 to GND or 3.3V (see address below)
const  screenIO=1 'set to 1 to do fast output on screen, otherwise 0
const MPU9250_ADDRESS =&H69  ' Device address when ADO = 1, must use if RTC also connected to I2C
'const MPU9250_ADDRESS =&H68  ' Device address when ADO = 0
'Magnetometer Registers
const AK8963_ADDRESS   =&H0C
const WHO_AM_I_AK8963  =&H00 ' should return =&H48
const AK8963_ST1       =&H02  ' data ready status bit 0
const AK8963_XOUT_L    =&H03  ' data
const AK8963_CNTL      =&H0A  ' Power down (0000), single-measurement (0001), self-test (1000) and Fuse ROM (1111) modes on bits 3:0
const AK8963_ASAX      =&H10  ' Fuse ROM x-axis sensitivity adjustment value
' Gyro/accelerometer registers
const SELF_TEST_X_GYRO =&H00
const SELF_TEST_Y_GYRO =&H01
const SELF_TEST_Z_GYRO =&H02
const SELF_TEST_X_ACCEL =&H0D
const SELF_TEST_Y_ACCEL =&H0E
const SELF_TEST_Z_ACCEL =&H0F
const XG_OFFSET_H      =&H13  ' User-defined trim values for gyroscope
const XG_OFFSET_L      =&H14
const YG_OFFSET_H      =&H15
const YG_OFFSET_L      =&H16
const ZG_OFFSET_H      =&H17
const ZG_OFFSET_L      =&H18
const SMPLRT_DIV       =&H19
const CONFIG           =&H1A
const GYRO_CONFIG      =&H1B
const ACCEL_CONFIG     =&H1C
const ACCEL_CONFIG2    =&H1D
const FIFO_EN          =&H23
const I2C_MST_CTRL     =&H24
const INT_PIN_CFG      =&H37
const INT_ENABLE       =&H38
const INT_STATUS       =&H3A
const ACCEL_XOUT_H     =&H3B
const TEMP_OUT_H       =&H41
const GYRO_XOUT_H      =&H43
const USER_CTRL        =&H6A  ' Bit 7 enable DMP, bit 3 reset DMP
const PWR_MGMT_1       =&H6B ' Device defaults to the SLEEP mode
const PWR_MGMT_2       =&H6C
const FIFO_COUNTH      =&H72
const FIFO_R_W         =&H74
const WHO_AM_I_MPU9250 =&H75 ' Should return =&H71
const XA_OFFSET_H      =&H77
const XA_OFFSET_L      =&H78
const YA_OFFSET_H      =&H7A
const YA_OFFSET_L      =&H7B
const ZA_OFFSET_H      =&H7D
const ZA_OFFSET_L      =&H7E
const   AFS_2G = 0
const   AFS_4G =1
const   AFS_8G =2
const   AFS_16G =3
const   GFS_250DPS = 0
const   GFS_500DPS =1
const   GFS_1000DPS =2
const   GFS_2000DPS =3
const   MFS_14BITS = 0'  0.6 uT per LSB
const   MFS_16BITS =1' 0.15 uT0.6 per LSB
const outputFreq=50.0   ' output frequency in iterations
const  declination=-0.63 ' local magnetic declination in degrees
' Global Variable definitions
DIM INTEGER Mmode = &H06       ' 1 for single shot, 2 for 8 Hz, 6 for 100 Hz continuous magnetometer data read
DIM INTEGER Gscale = GFS_250DPS
DIM INTEGER Ascale = AFS_4G
DIM INTEGER Mscale = MFS_16BITS ' Choose either 14-bit or 16-bit magnetometer resolution
DIM FLOAT MagCalibration(2), gRes, mRes, aRes
dim float ax, ay, az, gx, gy, gz, mx, my, mz, SelfTest(5), mmult(2)
dim float mxmax=-1000,mxmin=1000,mymax=-1000,mymin=1000,mzmax=-1000,mzmin=1000
dim float pitch,yaw,roll,heading
dim float Kp=10,Ki=0
dim float beta = 0.5 'derived from testing
dim integer gdata(13),mData(6),temp%
DIM INTEGER lastrun
' Calibration parameters for gyro and accelerometer
dim float gyro_Bias(2)=(40,15,100), accel_Bias(2)=(340,55,-390)
' calibration parameters for magnetometer derived from running AK8963calibrate
DIM float magbias(2)=(-20.205,7.035,18.165), magscale(2)=(1,1,1)
'  Setup
i2c open 400,1000
pause 100
writeByte(MPU9250_ADDRESS,PWR_MGMT_1,&H80)
pause 500
initMPU9250
temp%=readByte(MPU9250_ADDRESS,WHO_AM_I_MPU9250)
if temp%<>&H71 then
   Print "MPU9250 not found"
   end
endif
temp%=readByte(AK8963_ADDRESS,WHO_AM_I_AK8963)
if temp%<>&H48 then
   Print "AK8963 not found"
   end
endif
print "Internal temperature is ",readTempData()
if screenIO then cls
initAK8963(MagCalibration())
getAres
getGres
getMres
if screenIO then readMPU9250(0)
' Uncomment this section to run  the self test algorithm of the accelerometer and gyro
' Ensure the module is on a level surface and is completely still
' MPU9250SelfTest(selftest())
' print "Errors in %"
' print "    Gyro    Accel"
' Print "X ",str$(selftest(3),3,3," "),STR$(selftest(0),4,3," ")
' Print "Y ",str$(selftest(4),3,3," "),STR$(selftest(1),4,3," ")
' Print "Z ",str$(selftest(5),3,3," "),STR$(selftest(2),4,3," ")
' end
' Uncomment this section to derive calibration parameters for gyro and accelerometer
' note the parameters and set them to load into the arrays gyroBias and accelBias above
' initMPU9250
' calibrateMPU9250(gyroBias(), accelBias())
' Print "X ",str$(gyroBias(0),3,3," "),STR$(accelbias(0),4,3," ")
' Print "Y ",str$(gyroBias(1),3,3," "),STR$(accelbias(1),4,3," ")
' Print "Z ",str$(gyroBias(2),3,3," "),STR$(accelbias(2),4,3," ")
' end
initMPU9250
loadcalibrations
'Print "AK8963 mag calibration X=",MagCalibration(0),"  Y=",MagCalibration(1),"  Z=",MagCalibration(2)
mmult(0)=mRes*magCalibration(0)/magscale(0)
mmult(1)=mRes*magCalibration(1)/magscale(1)
mmult(2)=mRes*magCalibration(2)/magscale(2)
temp%=0
' Main program
timer=0
do
 readMPU9250(0)
'  SensorFusion Madgwick ax, ay, az, gx, gy, gz, mx, my, mz, pitch, roll, yaw', beta
math  SensorFusion Mahony ax, ay, az, gx, gy, gz, mx, my, mz,  pitch, roll, yaw', Kp, Ki
 heading   = ((720.0-yaw*180/PI)- declination)
 heading = heading mod 360.0
 if (temp% mod outputFreq) = 0 then
   Print @(0,4*mm.info(fontheight))"Heading = "+str$(heading,3,1," ")
 endif
 temp%=temp%+1
 if screenIO then text 0,100,"pitch="+str$(pitch*180/PI,3,2," ")+"  roll="+str$(roll*180/PI,3,2," ")+"  yaw="+str$(yaw*180/PI,3,2," ")
loop
end
sub readMPU9250(offset%)
 local integer i
 local float j
   do
   i=readByte(MPU9250_ADDRESS, INT_STATUS) and readByte(AK8963_ADDRESS, AK8963_ST1) and 1
 loop until i=1
 readBytes(MPU9250_ADDRESS, ACCEL_XOUT_H, 14, gData()) 'read in the gyro and accelerometer data
 readBytes(AK8963_ADDRESS, AK8963_XOUT_L, 7, mData())' Read the six raw data and ST2 registers sequentially into data array
 if((mData(6) AND &H08)=0) THEN ' Check if magnetic sensor overflow set, if not then report data
   i=(mData(1) << 8) OR mData(0):IF i AND &H8000 then i=i OR &HFFFFFFFFFFFF0000
   my = i
   my = my * mmult(0) + magbias(0)' Turn the MSB and LSB into a signed 16-bit value
   i=(mData(3) << 8) OR mData(2):IF i AND &H8000 then i=i OR &HFFFFFFFFFFFF0000
   mx = i
   mx=mx * mmult(1) + magbias(1) ' Data stored as little Endian
   i=(mData(5) << 8) OR mData(4):IF i AND &H8000 then i=i OR &HFFFFFFFFFFFF0000
   mz = i
   mz=-(mz * mmult(2) + magbias(2))
'    if mx>mxmax then mxmax=mx
'    if my>mymax then mymax=my
'    if mz>mzmax then mzmax=mz
'    if mx<mxmin then mxmin=mx
'    if my<mymin then mymin=my
'    if mz<mzmin then mzmin=mz
 endif
' Now we'll calculate the acceleration value into actual g's
' this depends on scale being set
   i=(gData(0) << 8) OR gData(1):IF i AND &H8000 then i=i OR &HFFFFFFFFFFFF0000
   ax = i
   ax=ax*aRes ' Turn the MSB and LSB into a signed 16-bit value
   i=(gData(2) << 8) OR gData(3):IF i AND &H8000 then i=i OR &HFFFFFFFFFFFF0000
   ay = i
   ay=ay*aRes
   i=(gData(4) << 8) OR gData(5):IF i AND &H8000 then i=i OR &HFFFFFFFFFFFF0000
   az = i
   az=az*aRes
 ' Calculate the gyro value into actual radians per second
   i=(gData(8) << 8) OR gData(9):IF i AND &H8000 then i=i OR &HFFFFFFFFFFFF0000
   j=i
   gx = RAD(j* gRes) 'Turn the MSB and LSB into a signed 16-bit value
   i=(gData(10) << 8) OR gData(11):IF i AND &H8000 then i=i OR &HFFFFFFFFFFFF0000
   j=i
   gy = RAD(j* gRes)
   i=(gData(12) << 8) OR gData(13):IF i AND &H8000 then i=i OR &HFFFFFFFFFFFF0000
   j=i
   gz = RAD(j* gRes)
   if screenIO then text 0,0+offset%,"Acc X="+str$(ax,3,2," ")+"  Y="+str$(ay,3,2," ")+"  Z="+str$(az,3,2," ")
   if screenIO then text 0,13+offset%,"Rot X="+str$(gx,3,2," ")+"  Y="+str$(gy,3,2," ")+"  Z="+str$(gz,3,2," ")
   if screenIO then text 0,26+offset%,"Mag X="+str$(mx,3,2," ")+"  Y="+str$(my,3,2," ")+"  Z="+str$(mz,3,2," ")
'    if screenIO then text 0,39+offset%,"Max X="+str$(mxmax,3,2," ")+"  Y="+str$(mymax,3,2," ")+"  Z="+str$(mzmax,3,2," ")
'    if screenIO then text 0,52+offset%,"Min X="+str$(mxmin,3,2," ")+"  Y="+str$(mymin,3,2," ")+"  Z="+str$(mzmin,3,2," ")
end sub
sub initMPU9250
 LOCAL INTEGER c
' wake up device
 writeByte(MPU9250_ADDRESS, PWR_MGMT_1, &H80) ' Reset
 pause 100 ' Wait for all registers to reset
 writeByte(MPU9250_ADDRESS, PWR_MGMT_1, &H00) ' Clear sleep mode bit (6), enable all sensors
' get stable time source
 writeByte(MPU9250_ADDRESS, PWR_MGMT_1, &H01)  ' Auto select clock source to be PLL gyroscope reference if ready else
 pause 200
' Configure Gyro and Thermometer
' Disable FSYNC and set thermometer and gyro bandwidth to 41 and 42 Hz, respectively
' minimum delay time for this setting is 5.9 ms, which means sensor fusion update rates cannot
' be higher than 1 / 0.0059 = 170 Hz
' DLPF_CFG = bits 2:0 = 011 this limits the sample rate to 1000 Hz for both
' With the MPU9250, it is possible to get gyro sample rates of 32 kHz (!), 8 kHz, or 1 kHz
 writeByte(MPU9250_ADDRESS, CONFIG, &H03)
' Set sample rate = gyroscope output rate/(1 + SMPLRT_DIV)
 writeByte(MPU9250_ADDRESS, SMPLRT_DIV, &H04)  ' Use a 200 Hz rate a rate consistent with the filter update rate
' Set gyroscope full scale range
' Range selects FS_SEL and AFS_SEL are 0 - 3, so 2-bit values are left-shifted into positions 4:3
 c = readByte(MPU9250_ADDRESS, GYRO_CONFIG)
 c=c AND &B11100100
 c = c OR (Gscale << 3) ' Set full scale range for the gyro
 writeByte(MPU9250_ADDRESS, GYRO_CONFIG, c ) ' Write new GYRO_CONFIG value to register
' Set accelerometer full-scale range configuration
 c = readByte(MPU9250_ADDRESS, ACCEL_CONFIG)
 c=c AND &B11100111
 c =  c OR (Ascale << 3) ' Set full scale range for the accelerometer
 writeByte(MPU9250_ADDRESS, ACCEL_CONFIG, c) ' Write new ACCEL_CONFIG register value
' Set accelerometer sample rate configuration
' It is possible to get a 4 kHz sample rate from the accelerometer by choosing 1 for
' accel_fchoice_b bit (3) in this case the bandwidth is 1.13 kHz
 c = readByte(MPU9250_ADDRESS, ACCEL_CONFIG2)
 c = c AND &B11110000
 c = c OR &H03  ' Set accelerometer rate to 1 kHz and bandwidth to 41 Hz
 writeByte(MPU9250_ADDRESS, ACCEL_CONFIG2, c) ' Write new ACCEL_CONFIG2 register value
' The accelerometer, gyro, and thermometer are set to 1 kHz sample rates,
' but all these rates are further reduced by a factor of 5 to 200 Hz because of the SMPLRT_DIV setting
' Configure Interrupts and Bypass Enable
' Set interrupt pin active high, push-pull, hold interrupt pin level HIGH until interrupt cleared,
' clear on read of INT_STATUS, and enable I2C_BYPASS_EN so additional chips
' can join the I2C bus and all can be controlled by the Arduino as master
  writeByte(MPU9250_ADDRESS, INT_PIN_CFG, &H32)
  writeByte(MPU9250_ADDRESS, INT_ENABLE, &H01)  ' Enable data ready (bit 0) interrupt
  writeByte(MPU9250_ADDRESS, USER_CTRL, &H05)
  pause 100
end sub
sub initAK8963(destination() as float)
' First extract the factory calibration for each magnetometer axis
 local integer rawData(2); ' x/y/z gyro calibration data stored here
 writeByte(AK8963_ADDRESS, AK8963_CNTL, &H00); ' Power down magnetometer
 Pause 10
 writeByte(AK8963_ADDRESS, AK8963_CNTL, &H0F); ' Enter Fuse ROM access mode
 readBytes(AK8963_ADDRESS, AK8963_ASAX, 3, rawData());  ' Read the x-, y-, and z-axis calibration values
 destination(0) =  (rawData(0) - 128)/256 + 1   ' Return x-axis sensitivity adjustment values, etc.
 destination(1) =  (rawData(1) - 128)/256 + 1
 destination(2) =  (rawData(2) - 128)/256 + 1
 Pause 10
' Configure the magnetometer for continuous read and highest resolution
' set Mscale bit 4 to 1 (0) to enable 16 (14) bit resolution in CNTL register,
' and enable continuous mode data acquisition Mmode (bits [3:0]), 0010 for 8 Hz and 0110 for 100 Hz sample rates
 writeByte(AK8963_ADDRESS, AK8963_CNTL, (Mscale << 4) OR Mmode) 'Set magnetometer data resolution and sample ODR
 Pause 10
end sub
sub writeByte(address%,reg%,value%)
 i2c write address%,0,2,reg%,value%
end sub
function readByte(address%,reg%) as integer
 i2c write address%,1,1,reg%
 i2c read address%,0,1,readByte
end function
sub readBytes(address%,reg%,n%,a%()) as integer
 i2c read address%,0,n%,a%()
end sub
sub getMres
 select case Mscale
 ' Possible magnetometer scales (and their register bit settings) are:
' 14 bit resolution (0) and 16 bit resolution (1)
   case MFS_14BITS
         mRes = 0.6 ' Proper scale to return milliGauss
   case MFS_16BITS
         mRes = 0.15 ' Proper scale to return milliGauss
 end select
end sub
sub getGres
 select case Gscale
 ' Possible gyro scales (and their register bit settings) are:
'250 DPS (00), 500 DPS (01), 1000 DPS (10), and 2000 DPS  (11).
       // Here's a bit of an algorith to calculate DPS/(ADC tick) based on that 2-bit value:
   case GFS_250DPS
         gRes = 250.0/32768.0
   case GFS_500DPS
         gRes = 500.0/32768.0
   case GFS_1000DPS
         gRes = 1000.0/32768.0
   case GFS_2000DPS
         gRes = 2000.0/32768.0
 end select
end sub
sub getAres
 select case Ascale
 ' Possible accelerometer scales (and their register bit settings) are:
' 2 Gs (00), 4 Gs (01), 8 Gs (10), and 16 Gs  (11).
   case AFS_2G
         aRes = 2.0/32768.0
   case AFS_4G
         aRes = 4.0/32768.0
   case AFS_8G
         aRes = 8.0/32768.0
   case AFS_16G:
         aRes = 16.0/32768.0
 end select
end sub
function readTempData() as float
 local integer rawData(1)  ' x/y/z gyro register data stored here
 readBytes(MPU9250_ADDRESS, TEMP_OUT_H, 2, rawData()) ' Read the two raw data registers sequentially into data array
 readTempData=sint16((rawData(0) << 8) OR rawData(1)) / 333.87 + 21.0 '
end function
FUNCTION sint16(x as integer) as float ' convert to signed 16 bit number
 local a%=x
 IF a% AND &H8000 then a%=a% OR &HFFFFFFFFFFFF0000
 sint16 = a%
END FUNCTION
FUNCTION iint16(x as integer) as integer ' convert to signed 16 bit number
 local a%=x
 iint16 = a%
END FUNCTION
FUNCTION iint15(x as integer) as integer ' convert to signed 16 bit number
 local a%=x
 IF a% AND &H4000 then a%=a% OR &HFFFFFFFFFFFF8000
 iint15 = a%
END FUNCTION
sub MPU9250SelfTest(destination() as float) ' Should return percent deviation from factory trim values, +/- 14 or less deviation is a pass
 local integer rawData(5) = (0, 0, 0, 0, 0, 0)
 local integer selfTest(5)
 local integer gAvg(2)=(0,0,0), aAvg(2)=(0,0,0), aSTAvg(2)=(0,0,0), gSTAvg(2)=(0,0,0)
 local float factoryTrim(5)
 local integer FS = 0,ii
 writeByte(MPU9250_ADDRESS, SMPLRT_DIV, &H00)    ' Set gyro sample rate to 1 kHz
 writeByte(MPU9250_ADDRESS, CONFIG, &H02)        ' Set gyro sample rate to 1 kHz and DLPF to 92 Hz
 writeByte(MPU9250_ADDRESS, GYRO_CONFIG, (1<<FS))  ' Set full scale range for the gyro to 250 dps
 writeByte(MPU9250_ADDRESS, ACCEL_CONFIG2, &H02) ' Set accelerometer rate to 1 kHz and bandwidth to 92 Hz
 writeByte(MPU9250_ADDRESS, ACCEL_CONFIG, (1<<FS)) ' Set full scale range for the accelerometer to 2 g
 for ii = 0 to 199  ' get average current values of gyro and acclerometer
   readBytes(MPU9250_ADDRESS, ACCEL_XOUT_H, 6, rawData())        ' Read the six raw data registers into data array
   aAvg(0) = aAvg(0) + iint16((rawData(0) << 8) OR rawData(1))   ' Turn the MSB and LSB into a signed 16-bit value
   aAvg(1) = aAvg(1) + iint16((rawData(2) << 8) OR rawData(3))
   aAvg(2) = aAvg(2) + iint16((rawData(4) << 8) OR rawData(5))
   readBytes(MPU9250_ADDRESS, GYRO_XOUT_H, 6, rawData())       ' Read the six raw data registers sequentially into data array
   gAvg(0) = gAvg(0) + iint16((rawData(0) << 8) OR rawData(1))   ' Turn the MSB and LSB into a signed 16-bit value
   gAvg(1) = gAvg(1) + iint16((rawData(2) << 8) OR rawData(3))
   gAvg(2) = gAvg(2) + iint16((rawData(4) << 8) OR rawData(5))
next ii
 for ii =0 to 2 ' Get average of 200 values and store as average current readings
   aAvg(ii) = aAvg(ii)/ 200
   gAvg(ii) = gAvg(ii)/ 200
 next ii
' Configure the accelerometer for self-test
 writeByte(MPU9250_ADDRESS, ACCEL_CONFIG, &HE0) ' Enable self test on all three axes and set accelerometer range to +/- 2 g
 writeByte(MPU9250_ADDRESS, GYRO_CONFIG,  &HE0) ' Enable self test on all three axes and set gyro range to +/- 250 degrees/s
 pause 25  ' Delay a while to let the device stabilize
 for ii = 0 to 199   ' get average self-test values of gyro and acclerometer
   aSTAvg(0) = aSTAvg(0) + iint16((rawData(0) << 8) OR rawData(1))   ' Turn the MSB and LSB into a signed 16-bit value
   aSTAvg(1) = aSTAvg(1) + iint16((rawData(2) << 8) OR rawData(3))
   aSTAvg(2) = aSTAvg(2) + iint16((rawData(4) << 8) OR rawData(5))
   gSTAvg(0) = gSTAvg(0) + iint16((rawData(0) << 8) OR rawData(1))  ' Turn the MSB and LSB into a signed 16-bit value
   gSTAvg(1) = gSTAvg(1) + iint16((rawData(2) << 8) OR rawData(3))
   gSTAvg(2) = gSTAvg(2) + iint16((rawData(4) << 8) OR rawData(5))
next ii
   aSTAvg(ii) =aSTAvg(ii)/200
   gSTAvg(ii) =gSTAvg(ii)/200
next ii
' Configure the gyro and accelerometer for normal operation
 writeByte(MPU9250_ADDRESS, ACCEL_CONFIG, &H00)
 writeByte(MPU9250_ADDRESS, GYRO_CONFIG,  &H00)
' Retrieve accelerometer and gyro factory Self-Test Code from USR_Reg
 selfTest(0) = (readByte(MPU9250_ADDRESS, SELF_TEST_X_ACCEL)) ' X-axis accel self-test results
 selfTest(1) = (readByte(MPU9250_ADDRESS, SELF_TEST_Y_ACCEL)) ' Y-axis accel self-test results
 selfTest(2) = (readByte(MPU9250_ADDRESS, SELF_TEST_Z_ACCEL)) ' Z-axis accel self-test results
 selfTest(3) = (readByte(MPU9250_ADDRESS, SELF_TEST_X_GYRO) ) ' X-axis gyro self-test results
 selfTest(4) = (readByte(MPU9250_ADDRESS, SELF_TEST_Y_GYRO) ) ' Y-axis gyro self-test results
 selfTest(5) = (readByte(MPU9250_ADDRESS, SELF_TEST_Z_GYRO) ) ' Z-axis gyro self-test results
' Retrieve factory self-test value from self-test code reads
 factoryTrim(0) = (2620/(1<<FS))*(( 1.01 ^ (selfTest(0) - 1.0) )) ' FT(Xa) factory trim calculation
 factoryTrim(1) = (2620/(1<<FS))*(( 1.01 ^ (selfTest(1) - 1.0) )) ' FT(Ya) factory trim calculation
 factoryTrim(2) = (2620/(1<<FS))*(( 1.01 ^ (selfTest(2) - 1.0) )) ' FT(Za) factory trim calculation
 factoryTrim(3) = (2620/(1<<FS))*(( 1.01 ^ (selfTest(3) - 1.0) )) ' FT(Xg) factory trim calculation
 factoryTrim(4) = (2620/(1<<FS))*(( 1.01 ^ (selfTest(4) - 1.0) )) ' FT(Yg) factory trim calculation
 factoryTrim(5) = (2620/(1<<FS))*(( 1.01 ^ (selfTest(5) - 1.0) )) ' FT(Zg) factory trim calculation
' Report results as a ratio of (STR - FT)/FT the change from Factory Trim of the Self-Test Response
' To get percent, must multiply by 100
 for ii=0 to 2
   destination(ii)   = (aAvg(ii)-aSTAvg(ii)+factoryTrim(ii)) / factoryTrim(ii)*100   ' Report percent differences
   destination(ii+3) = (gAvg(ii)-gSTAvg(ii)+factoryTrim(ii+3)) / factoryTrim(ii+3)*100 ' Report percent differences
 next ii
end sub
sub calibrateMPU9250(dest1() as float, dest2() as float)
 LOCAL INTEGER rData(11) ' data array to hold accelerometer and gyro x, y, z, data
 LOCAL INTEGER ii, jj, packet_count, fifo_count
 LOCAL INTEGER gyro_bias(2)  = (0, 0, 0), accel_bias(2) = (0, 0, 0),accel_temp(2),gyro_temp(2)
 LOCAL INTEGER accel_bias_reg(2) = (0, 0, 0)' A place to hold the factory accelerometer trim biases
 LOCAL INTEGER mask_bit(2) = (0, 0, 0) ' Define array to hold mask bit for each accelerometer bias axis
 LOCAL INTEGER  accelsensitivity = 16384  ' = 16384 LSB/g
' reset device
 writeByte(MPU9250_ADDRESS, PWR_MGMT_1, &H80) ' Write a one to bit 7 reset bit toggle reset device
 pause 100
' get stable time source Auto select clock source to be PLL gyroscope reference if ready
' else use the internal oscillator, bits 2:0 = 001
 writeByte(MPU9250_ADDRESS, PWR_MGMT_2, &H00)
 pause 200
' Configure device for bias calculation
 writeByte(MPU9250_ADDRESS, INT_ENABLE, &H00)   ' Disable all interrupts
 writeByte(MPU9250_ADDRESS, FIFO_EN, &H00)      ' Disable FIFO
 writeByte(MPU9250_ADDRESS, PWR_MGMT_1, &H00)   ' Turn on internal clock source
 writeByte(MPU9250_ADDRESS, I2C_MST_CTRL, &H00) ' Disable I2C master
 writeByte(MPU9250_ADDRESS, USER_CTRL, &H00)    ' Disable FIFO and I2C master modes
 writeByte(MPU9250_ADDRESS, USER_CTRL, &H0C)    ' Reset FIFO and DMP
 pause 15
' Configure MPU6050 gyro and accelerometer for bias calculation
 writeByte(MPU9250_ADDRESS, CONFIG, &H01)      ' Set low-pass filter to 188 Hz
 writeByte(MPU9250_ADDRESS, SMPLRT_DIV, &H00)  ' Set sample rate to 1 kHz
 writeByte(MPU9250_ADDRESS, GYRO_CONFIG, &H00)  ' Set gyro full-scale to 250 degrees per second, maximum sensitivity
 writeByte(MPU9250_ADDRESS, ACCEL_CONFIG, &H00) ' Set accelerometer full-scale to 2 g, maximum sensitivity
' Configure FIFO to capture accelerometer and gyro data for bias calculation
 writeByte(MPU9250_ADDRESS, USER_CTRL, &H40)   ' Enable FIFO
 writeByte(MPU9250_ADDRESS, FIFO_EN, &H78)     ' Enable gyro and accelerometer sensors for FIFO  (max size 512 bytes in MPU-9150)
 pause 40 ' accumulate 40 samples in 40 milliseconds = 480 bytes
' At end of sample accumulation, turn off FIFO sensor read
 writeByte(MPU9250_ADDRESS, FIFO_EN, &H00)        ' Disable gyro and accelerometer sensors for FIFO
 readBytes(MPU9250_ADDRESS, FIFO_COUNTH, 2, rData()) ' read FIFO sample count
 fifo_count = ((rData(0) << 8) OR rData(1))
 packet_count = fifo_count/12' How many sets of full gyro and accelerometer data for averaging
 for ii=0 to packet_count-1
   for jj=0 to 2
     accel_temp(jj)=0
     gyro_temp(jj)=0
   next jj
   readBytes(MPU9250_ADDRESS, FIFO_R_W, 12, rData()) ' read data for averaging
   accel_temp(0) =  iint16((rData(0) << 8) OR rData(1)  )   ' Form signed 16-bit integer for each sample in FIFO
   accel_temp(1) =  iint16((rData(2) << 8) OR rData(3)  )
   accel_temp(2) =  iint16((rData(4) << 8) OR rData(5)  )
   gyro_temp(0)  =  iint16((rData(6) << 8) OR rData(7)  )
   gyro_temp(1)  =  iint16((rData(8) << 8) OR rData(9)  )
   gyro_temp(2)  =  iint16((rData(10) << 8) OR rData(11))
   accel_bias(0) = accel_bias(0)+ accel_temp(0) ' Sum individual signed 16-bit biases to get accumulated signed 32-bit biases
   accel_bias(1) = accel_bias(1)+ accel_temp(1)
   accel_bias(2) = accel_bias(2)+ accel_temp(2)
   gyro_bias(0) = gyro_bias(0)+ gyro_temp(0)
   gyro_bias(1) = gyro_bias(1)+ gyro_temp(1)
   gyro_bias(2) = gyro_bias(2)+ gyro_temp(2)
next ii
 accel_bias(0) = accel_bias(0)/ packet_count ' Normalize sums to get average count biases
 accel_bias(1) = accel_bias(1)/ packet_count
 accel_bias(2) = accel_bias(2)/ packet_count
 gyro_bias(0) = gyro_bias(0)/ packet_count
 gyro_bias(1) = gyro_bias(1)/ packet_count
 gyro_bias(2) = gyro_bias(2)/ packet_count
if(accel_bias(2) > 0) THEN
 accel_bias(2) = accel_bias(2) - accelsensitivity  ' Remove gravity from the z-axis accelerometer bias calculation
else
 accel_bias(2) = accel_bias(2) + accelsensitivity
endif
 gyro_bias(0)=gyro_bias(0)/-4
 gyro_bias(1)=gyro_bias(1)/-4
 gyro_bias(2)=gyro_bias(2)/-4
' Construct the gyro biases for push to the hardware gyro bias registers, which are reset to zero upon device startup
 rData(0) = (gyro_bias(0)>>8) AND &HFF ' Divide by 4 to get 32.9 LSB per deg/s to conform to expected bias input format
 rData(1) = gyro_bias(0)      AND &HFF ' Biases are additive, so change sign on calculated average gyro biases
 rData(2) = (gyro_bias(1)>>8) AND &HFF
 rData(3) = gyro_bias(1)     AND &HFF
 rData(4) = (gyro_bias(2)>>8) AND &HFF
 rData(5) = gyro_bias(2)      AND &HFF
' Push gyro biases to hardware registers
 writeByte(MPU9250_ADDRESS, XG_OFFSET_H, rData(0))
 writeByte(MPU9250_ADDRESS, XG_OFFSET_L, rData(1))
 writeByte(MPU9250_ADDRESS, YG_OFFSET_H, rData(2))
 writeByte(MPU9250_ADDRESS, YG_OFFSET_L, rData(3))
 writeByte(MPU9250_ADDRESS, ZG_OFFSET_H, rData(4))
 writeByte(MPU9250_ADDRESS, ZG_OFFSET_L, rData(5))
' Output scaled gyro biases for display in the main program
 dest1(0) = gyro_bias(0)
 dest1(1) = gyro_bias(1)
 dest1(2) = gyro_bias(2)
' Construct the accelerometer biases for push to the hardware accelerometer bias registers. These registers contain
' factory trim values which must be added to the calculated accelerometer biases on boot up these registers will hold
' non-zero values. In addition, bit 0 of the lower byte must be preserved since it is used for temperature
' compensation calculations. Accelerometer bias registers expect bias input as 2048 LSB per g, so that
' the accelerometer biases calculated above must be divided by 8.
 readBytes(MPU9250_ADDRESS, XA_OFFSET_H, 2, rData()) ' Read factory accelerometer trim values
 accel_bias_reg(0) =  iint15((rData(0) << 7) OR ((rData(1) and &HFE)>>1))
 if rData(1) and &H1 then mask_bit(0)=&H1
 readBytes(MPU9250_ADDRESS, YA_OFFSET_H, 2, rData())
 accel_bias_reg(1) =  iint15((rData(0) << 7) OR ((rData(1) and &HFE)>>1))
 if rData(1) and &H1 then mask_bit(1)=&H1
 readBytes(MPU9250_ADDRESS, ZA_OFFSET_H, 2, rData())
 accel_bias_reg(2) =  iint15((rData(0) << 7) OR ((rData(1) and &HFE)>>1))
 if rData(1) and &H1 then mask_bit(2)=&H1
' Construct total accelerometer bias, including calculated average accelerometer bias from above
 accel_bias_reg(0) = accel_bias_reg(0) - (accel_bias(0)\16) ' Subtract calculated averaged accelerometer bias scaled to 2048 LSB/g (16 g full scale)
 accel_bias_reg(1) = accel_bias_reg(1) - (accel_bias(1)\16)
 accel_bias_reg(2) = accel_bias_reg(2) - (accel_bias(2)\16)
 rData(0) = (accel_bias_reg(0) \ 128) AND &HFF
 rData(1) = ((accel_bias_reg(0))<<1 )     AND &HFE
 rData(1) = rData(1) OR mask_bit(0) ' preserve temperature compensation bit when writing back to accelerometer bias registers
 rData(2) = (accel_bias_reg(1) \ 128) AND &HFF
 rData(3) = ((accel_bias_reg(1)) <<1)     AND &HFE
 rData(3) = rData(3) OR mask_bit(1) ' preserve temperature compensation bit when writing back to accelerometer bias registers
 rData(4) = (accel_bias_reg(2) \ 128) AND &HFF
 rData(5) = ((accel_bias_reg(2))<<1)      AND &HFE
 rData(5) = rData(5) OR mask_bit(2) ' preserve temperature compensation bit when writing back to accelerometer bias registers
' Push accelerometer biases to hardware registers
 writeByte(MPU9250_ADDRESS, XA_OFFSET_H, rData(0))
 writeByte(MPU9250_ADDRESS, XA_OFFSET_L, rData(1))
 writeByte(MPU9250_ADDRESS, YA_OFFSET_H, rData(2))
 writeByte(MPU9250_ADDRESS, YA_OFFSET_L, rData(3))
 writeByte(MPU9250_ADDRESS, ZA_OFFSET_H, rData(4))
 writeByte(MPU9250_ADDRESS, ZA_OFFSET_L, rData(5))
' Output scaled accelerometer biases for display in the main program
  dest2(0) = accel_bias(0)
  dest2(1) = accel_bias(1)
  dest2(2) = accel_bias(2)
  print "calibration done"
end sub
sub loadcalibrations
end sub
Edited 2021-04-12 03:57 by matherp
retepsnikrep
Posted: 06:38pm 11 Apr 2021
My brain has yawed off to the left and right before exploding with that latest post.
Incredible work..
Gen1 Honda Insights.
epsilon
Posted: 08:34pm 11 Apr 2021
Apologies for messing up the thread, but this thread is probably still the best place to flag issues.
I noticed that the COMMENT directive doesn't work when put inside a .INC:
      SUB foo
        PRINT "In foo"
      #COMMENT START
        PRINT "In foo comment"
      #COMMENT END
      END SUB
      In foo
      Error in test.inc line 4: Invalid character: #
  matherp said  V5.07.00b21 now available
New directive to allow multi-line comments. The commands must be in capitals. Any lines between the two commands are completely ignored and not loaded into memory
#COMMENT START
#COMMENT END
Posted: 09:43pm 11 Apr 2021
  Quote  I noticed that the COMMENT directive doesn't work when put inside a .INC:
Cut and paste error - I'll fix in the next beta
epsilon
Posted: 06:59am 12 Apr 2021
Perfect. Thank you!
epsilon
Posted: 03:28pm 12 Apr 2021
I'm seeing an issue reading back the MAP after installing a custom palette.
At the prompt:
> MAP(0) = &H808080
> MAP SET
(observe background color change)
> PRINT MAP(0)
0
I'm using firmware version 5.07.00b23.
Posted: 04:46pm 12 Apr 2021
  Quote  I'm seeing an issue reading back the MAP after installing a custom palette.
The map function gives the RGB332 colour that is used internally to map to the CLUT. So map(255) always gives &He0e0c0 which the firmware then converts to 255. It is just a way of allowing you to select the normal colour that will find the place in the CLUT you want. It is not a window into the CLUT
epsilon
Posted: 05:05pm 12 Apr 2021
Thanks. That makes sense. This should probably be corrected in the Graphics Programming Guide pdf which has this example:
MAP(134)=RGB(149,73,66)
MAP SET
TEXT MM.HRES\2, MM.VRES\2,"Hello",CM,,5,map(134)
It also would be good to add MAP in the User Guide to the list of functions, with the description you outlined.
Posted: 05:11pm 12 Apr 2021
The example is correct. map(134) is used to output the text in the colour rgb(149,73,66) which has been loaded into clut slot 134 which is found by map(134) returning &H802080 which the firmware converts to &B10000110 which = 134
epsilon
Posted: 07:58pm 12 Apr 2021
  matherp said  The example is correct. map(134) is used to output the text in the colour rgb(149,73,66) which has been loaded into clut slot 134 which is found by map(134) returning &H802080 which the firmware converts to &B10000110 which = 134
You're right of course. I should have thought that through before responding. This is almost identical to the discussion about the color map in the Mapster thread.
The caveat being that despite the assignment on line 1, MAP(134) <> RGB(149,74,66), but the example never claimed it would be so.
frnno967
Posted: 01:23am 13 Apr 2021
Peter, I believe the new GUI CURSOR capability may have a bug. When the coordinates are being updated rapidly the sprite flickers. In maxiterm I'm using the GUI CURSOR SHOW and HIDE commands to show an "underline" sprite and flash it on and off. In the main loop of the program the coordinates are updated rapidly every cycle as the loop runs. The show and hide are operating correctly but there's a noticeable flicker in the sprite as it's coordinates are updated.
You can see a video of it in action via this link.
It's not just a refresh issue with my monitor that I can tell, and only started flickering after I changed the code to take advantage of the SHOW and HIDE functionality of the latest beta firmware (b26).
If you want to test it for yourself, just run maxiterm and hit ALT-U after the initial prompts:
maxiterm 1.9.5 revised.zip
Thank you.
Edited 2021-04-13 11:32 by frnno967
Jay Crutti: Ham Radio Operator, K5JCJ. Computer Enthusiast. Musician. Engineer.
Posted: 07:05am 13 Apr 2021
  Quote  When the coordinates are being updated rapidly the sprite flickers.
Of course, the update hides and then re-shows so if you sit in a tight loop it will flicker. Use any of the normal graphic techniques (page copy, getscanline etc.) to mitigate this or just slow down the update rate
Edited 2021-04-13 17:10 by matherp
frnno967
Posted: 12:31am 14 Apr 2021
  matherp said  Of course, the update hides and then re-shows so if you sit in a tight loop it will flicker. Use any of the normal graphic techniques (page copy, getscanline etc.) to mitigate this or just slow down the update rate
Got it. Didn't realize the firmware was hiding then reshowing every time the coordinates updated. Applied rate limiting and that fixed it, thanks!
JoOngle
Posted: 02:24pm 14 Apr 2021
Just want to chime in and say I appreciate the work you do @matherp
Posted: 03:08am 20 Apr 2021
Bug in HEX$()
If you try and use a calculation contained within brackets for the value, an error is raised.
PRINT HEX$(55,2)
x = 33+22
PRINT HEX$(x,2)
PRINT HEX$(33+22,2)
PRINT HEX$((33+22),2) ' this one causes an error
37
37
37
Error in line 5: HEX is not declared
Turbo46
Posted: 03:22am 20 Apr 2021
  Quote  Bug in HEX$()
Interesting, it runs OK on a Micromite and DOS?
Bill
Posted: 08:02am 20 Apr 2021
  Quote  Bug in HEX$()
Fixed in b28 just posted
This also introduces a new function BASE$
BASE$( base, number [, chars])
Returns a string giving the base value for the 'number'.
'chars' is optional and specifies the number of characters in the string with zero as the leading padding character(s). base can be between 2 and 36. Numbers >9 are represented by a letter as per hex.
i.e.
? base$(36,35) gives the answer "Z"
BIN$, OCT$, and HEX$ are internally converted to calls to BASE. This saves 2 function slots for future expansion
     Page 5 of 9
