Local Time 21:08 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteWeb lessons
     Page 5 of 5
Posted: 10:15am 18 May 2023
I am missing a way to get  values from pc to webmite. Also Some info on
This is now well covered in the latest version of the WebMite manual - page 29
LucV
Posted: 02:25pm 18 May 2023
@matherp
Peter,
The manual shows how to use radiobuttons. But they have predefined values.
I think Volhout wants an input field in which he can put any value he wants from his keyboard.
I am working on it.
Luc's tech Blog
Posted: 04:44pm 18 May 2023
  LucV said  I think Volhout wants an input field in which he can put any value he wants from his keyboard.
That is what I illustrated above using Peter's THERMO code.
Posted: 05:56pm 18 May 2023
I think I can achieve what I want with the html input form type=NUMBER, and in other fields with input form type=TIME.
In basic I can extract the value from the return string.
Now I have to design the whole html page first... as a table...
P.s. lizby, your example uses type=text. That will also work, but when using type=number, you can easy check for wrong entries..
Edited 2023-05-19 04:00 by Volhout
LucV
Posted: 07:51pm 20 May 2023
Ok guys,
Anybody still interested (after the above) in me making lessons about
an input field in which you can put any value you like and send it to the Pico,
and a slider with which you can set a value in a pre-defined range.
It's a lot of work and maybe no longer needed after lizby's and volhouts posts.
Luc
Luc's tech Blog
Posted: 09:34pm 20 May 2023
Luc -- slider and check box examples would be good. Thanks for your work in formal documentation.
     Page 5 of 5
