Local Time 14:42 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.03.00 Release
     Page 5 of 5
EDNEDN
Posted: 02:44pm 23 Jul 2026
I think I might have stumbled onto a LongString bug in PicoMite V6.03.00 Release.
Depending on how 'Option Base' is set, lgetbyte() returns different values.
With 'Option Base 0' the position information given by linstr() does not align with the information returned by lgetbyte().
I understand this could be argued either way.   But it would seem to me that lgetbyte() should be consistent with the offsets returned by linstr() and used by lgetstr$().
If you flip the 'Option Base' to 1 you get different results than with it at 0.
If the answer is this is not a bug, this deviant behavior of lgetbyte() should be documented as dependent on 'Option Base'.    And so far I can't find any documentation that it is dependent on 'Option Base'.   Below is a program that demonstrates the inconsistency:
option base 0
dim integer b(1024)
longstring clear b()
j$ = chr$(13)+chr$(10)+"--------------some junk text---------------"
longstring append b(), j$
longstring append b(), chr$(13)+chr$(10)+"Hello world."+chr$(13)+chr$(10)
print "b() is currently set to:"
longstring print b()
print
p = linstr( b(), "Hello ")
print "Hello found at offset ";p
print
for a = p-5 to p+10
t = lgetbyte( b(), a)
       tt = t
if t < 32 then tt = asc("?")
print "Offset ";a;" using lgetbyte() has "; chr$(tt); "  (";t;")  "
next a
print
e$ = lgetstr$( b(), p, 12)
print "lgetstr$() correctly returning "; e$;" at offset ";p
print
Edited 2026-07-24 00:46 by EDNEDN
Posted: 03:08pm 23 Jul 2026
The difference is deliberate. lgetbyte is intended to treat the longstring as a byte array which you would therefore expect to honour Option Base.
It's not safe to change this behaviour as this would almost certainly break existing programs
I'll add additional clarification to the user manual to make this clear.
Edited 2026-07-24 01:10 by matherp
toml_12953
Posted: 07:39am 25 Jul 2026
Update: I fixed the following by disabling the PSRAM and reenabling it.
When I try to run the program below, I get Not enough PSRAM memory in line 21 (DIM c AS POINT). It doesn't seem like it should take very much, though.
'   "Center.zen" solves for the center and radius
'   of a circle
'   Sample program for the Zeno Interpreter by:
'   Stephen R. Schmitt
'   962 Depot Road
'   Boxborough, MA 01719
OPTION base 1
TYPE POINT
 x AS float
 y AS float
END TYPE
' program
DIM r AS float
DIM c AS POINT
DIM p(3) AS POINT
p(1).x = 7
p(1).y = 7
p(2).x = 0
p(2).y = 8
p(3).x = 0
p(3).y = 0
PRINT "points: ";
PRINT "("; p(1).x; ","; p(1).y; "), ";
PRINT "("; p(2).x; ","; p(2).y; "), ";
PRINT "("; p(3).x; ","; p(3).y; ") "
r = circ( c, p() )
IF r > 0 THEN
 PRINT "Circle: ("; c.x; ","; c.y; "),"; r
ELSE
 PRINT "Not a circle!"
END IF
END
'  Calculate center and radius of
'  circle given three points
FUNCTION circ( c AS POINT, p() AS point) AS float
 LOCAL i AS integer
 LOCAL float r, m11, m12, m13, m14
 LOCAL a(3,3) AS float
 FOR i = 1 TO 3         ' find minor 11
   a(i,1) = p(i).x
   a(i,2) = p(i).y
   a(i,3) = 1
 NEXT i
 m11 = DET(a())
 FOR i = 1 TO 3         ' find minor 12
   a(i,1) = p(i).x^2 + p(i).y^2
   a(i,2) = p(i).y
   a(i,3) = 1
 NEXT i
 m12 = DET(a())
 FOR i = 1 TO 3         ' find minor 13
   a(i,2) = p(i).x
   a(i,3) = 1
 NEXT i
 m13 = DET(a())
 FOR i = 1 TO 3         ' find minor 14
   a(i,2) = p(i).x
   a(i,3) = p(i).y
 NEXT i
 m14 = DET(a())
 IF m11 = 0 THEN
   r = 0                ' not a circle
 ELSE
   c.x =  0.5 * m12 / m11 ' center of circle
   c.y = -0.5 * m13 / m11
   r   = SQR( c.x^2 + c.y^2 + m14/m11 )
 END IF
 circ = r               ' the radius
END FUNCTION
Option List:
PicoMite MMBasic RP2350B V6.03.00
OPTION SERIAL CONSOLE COM1,GP0,GP1,BOTH
OPTION LCD SPI GP10,GP11,GP12
OPTION SYSTEM I2C GP6,GP7, SLOW
OPTION BAUDRATE 19200
OPTION FLASH SIZE 16777216
OPTION LIBRARY_FLASH_SIZE  4B000
OPTION COLOURCODE ON
OPTION CASE UPPER
OPTION TAB 8
OPTION DEFAULT COLOURS GREEN, BLACK
OPTION KEYBOARD PICOCALC
OPTION PICO OFF
OPTION CPUSPEED (KHz) 384000
OPTION LCDPANEL CONSOLE ,, FF00
OPTION DISPLAY 26, 40
OPTION LCDPANEL ST7365P, PORTRAIT,GP14,GP15,GP13
OPTION BACKLIGHT LCD 80
OPTION GUI CONTROLS 50
OPTION SDCARD GP17, GP18, GP19, GP16
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  192
OPTION PLATFORM PicoCalc
OPTION PSRAM PIN GP47
Edited 2026-07-25 17:48 by toml_12953
ville56
Posted: 07:50am 25 Jul 2026
Running the prog above on an PicoMite MMBasic RP2350B V6.03.00 with or without PSRAM enabled, I get an error at
> run
[62] m11 = DET(a())
Error : Dimensions
but no complaints about DIM c AS POINT ....
73 de OE1HGA, Gerald
Posted: 08:12am 25 Jul 2026
There is no function DET or array DET so like ville56, unable to test further
toml_12953
Posted: 09:03am 25 Jul 2026
  ville56 said  Running the prog above on an PicoMite MMBasic RP2350B V6.03.00 with or without PSRAM enabled, I get an error at
> run
[62] m11 = DET(a())
Error : Dimensions
Oops! I defined DET(n() in the library as
FUNCTION DET(n())
 DET=MATH(m_determinant n())
END FUNCTION
to help writing more standard BASIC code. I just wish MMBasic could have a function return an array. Then I could write even more MAT functions to match standard BASIC. Something like this:
a()=INV(b())  ' Like MAT A = INV(B) in standard BASIC
c()=TRN(r())  ' Like MAT C = TRN(R) in standard BASIC
FUNCTION INV(n())
 LOCAL m(BOUND(n(),1), BOUND(n(),2))
 MATH M_INVERSE n(), m()
 INV=m()
END FUNCTION
FUNCTION TRN(n())
 MATH M_TRANSPOSE n(), m()
 TRN=m()
END FUNCTION
Edited 2026-07-25 19:21 by toml_12953
Posted: 09:21am 25 Jul 2026
> RUN
Circle: ( 3, 4), 5
Supertech
Posted: 02:09am 27 Jul 2026
I upgraded to V6.03.00 on all my Webmites including
OPTION WIFI ssid$, password$, hostname$, ipaddress$, mask$, gateway$, country$
with working stable. Thank you.
However,
option list
WebMite MMBasic RP2350A Edition V6.03.00
OPTION SYSTEM I2C GP10,GP11
OPTION AUTORUN  ON
OPTION FLASH SIZE 4194304
OPTION CPUSPEED (KHz) 200000
OPTION LCDPANEL ILI9488, LANDSCAPE,GP14,GP13,GP12
OPTION TOUCH GP15,GP17
GUI CALIBRATE 0, 3931, 3887, -1307, -880
OPTION WIFI 228766427-2.4G, **************************, BP Proto, 10.0.1.35, 255.255.255.000, 10.0.1.1
OPTION TCP SERVER PORT 80
OPTION TELNET CONSOLE ON
OPTION GUI CONTROLS 20
OPTION SDCARD GP21
OPTION AUDIO GP8,GP9', ON PWM CHANNEL 4
> list pins
[LIBRARY] If MM.ADDRESS$ Then CLS
Error : Expected a number
> ? MM.SUPPLY
Error : MM.SUPPLY is not declared
when I type these, I get?
> list pins
> ? MM.SUPPLY
Regards.
BarryH
Posted: 03:50am 27 Jul 2026
MM.SUPPLY is only designed to work for standard Pico/Pico2 boards - ie NOT Wifi, as GP25 (which is not exposed on board pins) is used by the wireless module.
BarryH
ville56
Posted: 05:45am 27 Jul 2026
LIST PINS works for me ...
OPTION SYSTEM SPI GP2,GP3,GP4
OPTION SYSTEM I2C GP8,GP9
OPTION AUTORUN  ON
OPTION HEARTBEAT OFF
OPTION CPUSPEED (KHz) 252000
OPTION DISPLAY 40, 145
OPTION LCDPANEL ST7789_320, PORTRAIT,GP14,GP13,GP15,GP16
OPTION WIFI JN88fg, *********, Nixie, AT
OPTION SDCARD GP17
Clock> list pins
Clock> GP0      1      OFF
GP1     2      OFF
GP2     4      Boot Reserved : SPI SYSTEM CLK
GP3     5      Boot Reserved : SPI SYSTEM MOSI
GP4     6      Boot Reserved : SPI SYSTEM MISO
GP5     7      DOUT
GP6     9      DOUT
GP7     10     DOUT
GP8     11     Boot Reserved : SYSTEM I2C SDA
maybe you should nuke the Pico first, there seems to be some old data left over.
Gerald
some_rando
Posted: 01:33am 31 Jul 2026
I have long been a fan of Geoff Graham's ASCII Video Terminal https://geoffg.net/terminal.html, also published July 2014 in Silicon Chip. Although there were some incompatibilities with the VT100 "standard", I was able to get MMBasic variants starting at about 5.3 through 6.00.03 to talk seamlessly to the AVT with console on GP1/GP0. I also toyed with Fuzix, Micropython, Nuttx, Pi3A+ Linux builds with this architecture. The big advantages of the AVT were that it nominally drew 50mA from the 5V supply, used legacy VGA and PS/2 hardware, and could be turned off to save power, then turned back on - even while inside the MMBasic editor - resuming an editing session.
 Sadly, I just tried the latest MMBasic 6.03 variant which introduced changes to the editor code, and presumably the VT100 commands sent from the inbuilt editor. I now find that the editor gets to line 20, and then fails to scroll the upper portion of the screen. No doubt 6.03 was tested relentlessly with TerraTerm, and performs flawlessly. But without some serious work the AVT is no longer compatible. I can't even say this is a bug. The fact that the AVT had a common heritage with Micromite, and then Picomite (and others) was serendipity. The world moves on, and regardless, we must have a display in some form : VGA is legacy, and DVI/HDMI is now the standard.
 Given that the Pico's have two cores, and the newly discovered ability for one core to generate a VGA/HDMI display, it is a natural progression to have "boot-to" style versions of micropython, fuzix et al. (This idea may be shaken a bit when the next versions of the Pico family have four or more cores).
 My personal opinion is that this could all have gone in a different direction, downwards to the roots of home computing, and followed the earlier evolution towards native-code generating compilers like the Borland Turbo family. Why head in the contemporary direction to self-contained "boot-to" machines which generate a HDMI terminal using overclocking, when there is a market saturated with cheap high end machines which faultlessly run Linux, and every programming language ever invented?
 Finally, Fuzix has been running on RP2040 since mid 2021. You guys are just rediscovering it now because a core can be handed over to HDMI to create a terminal. Fuzix, Nuttx and the like have interpreters. No native compilers. Geoff Nutt wrote a Pascal compiler, but it compiles to an abstract P-machine.
 My money is on PShell, which has a RP2040/RP2350 native code compiler, Vi, and LittleFS file system. Last night I swapped-in my last running version from 2023, which still works perfectly. Today I'll look at the latest version. I am hoping there has been some progress. Unfortunately as goes with these things, PShell is held together by a lone author (Lurk101) who values anonymity, and has little time for lesser fools like me.
Footnote added 2026-08-01 15:58 by some_rando
Wow, I'm about a month late with Pico3, and language developments over there. I eat my hat. Not necessarily the AVT part. :-)
Posted: 07:42am 31 Jul 2026
The incompatibility with AVT surprises me a little. I would have thought that that part of the code was solid by now.
VGA and HDMI have always been *additional* to the serial terminal capability AFAIK - you don't need to have either. You can, of course, run a version of the firmware with neither VGA nor HDMI. You should be able to define the serial terminal pins (GP8 and GP9 by default) in this instead of or in addition to using the USB serial port.
I suspect that the direction of the evolution of the PicoMite has been at least partially set by the RAM and ROM capabilities of the original Pico.
An interpreter is very efficient as a lot of it can remain in ROM, only requiring some workspace in the RAM area. The user program can be tokenized to reduce the RAM required before it is run.
A compiler usually needs the source code, then an intermediate code as the linker operates then the final code. That can be quite some RAM footprint in total. It can also, depending on the target, be a very complex process. Remember, you have no disk drives or OS to help out. The RP2350 now has twice the RAM of the RP2040, a lot more flash and some memory management.
If you simply want native code then you may as well use an Arduino or some other compiler on a PC, where you can have a nice IDE. Having everything, including keyboard and display handling, in one place is a much neater and more portable solution  IMHO.  :)
     Page 5 of 5
