Forum Index : Microcontroller and PC projects : Group order for the new Pico Computer 3 in Germany?
| v.lenzer Senior Member Joined: 04/05/2024 Location: GermanyPosts: 156 |
Great - I can hardly wait. Looks really good with the bezels!! Best wishes! Joachim |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6151 |
Be carefull not to tighten this screw too much. You may cut the copper trace. ![]() PicomiteVGA PETSCII ROBOTS |
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 624 |
You may use an isolating washer as well. They have been used for PC motherboards some time ago for the same reason. I should still possess plenty of them somewhere... 73 de OE1HGA, Gerald |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 697 |
Update ![]() ![]() ![]() So finally, about 5 hours later... all the boards have been tested and are working perfectly! Inserted the CR2032 battery, set the RTC, screwed them into the case, flashed PicoMiteHDMIWEBV6.03.02b1.uf2, and then ran the hardware profiler program. All tests completed, including Wi-Fi. https://www.thebackshed.com/forum/ViewTopic.php?TID=19034&PID=258001#258001#258001 You’ll find the log on drive A:. I also stuck the chip’s unique ID under the case. That way, you can tell them apart. I’m not going to test all the VGA adapters right now. Tomorrow I’ll start packing the packages and printing the shipping labels. They might go out as early as Saturday, otherwise on Monday! So everything is going according to plan. Matthias ------------------------------------------------------------- Update: So endlich, ca. 5h später ... alle Boards sind getestet und funktionieren einwandfrei! CR2032 eingelegt, RTC gestellt, ins Gehäuse geschraubt, aufgespielt wurde PicoMiteHDMIWEBV6.03.02b1.uf2 und dann das hardware profiler Program laufen lassen. Alle Tests absolviert, incl. WLAN. https://www.thebackshed.com/forum/ViewTopic.php?TID=19034&PID=258001#258001#258001 Auf dem Laufwerk a: findet ihr das LOG. Ich habe auch die Chip unique ID unter das Gehäuse geklebt. So kann man die auseinanderhalten. Die VGA-Adapter teste ich jetzt nicht alle. Morgen geht es an das Pakete packen und die Versandetiketten. Evtl. gehen die Samstag schon raus, sonst am Montag! Läuft also nach Plan. Matthias |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1154 |
SUPER!!! Thank you very, very much!!! Frank |
Ja is denn heit scho Weihnacht'n? (Zitat Beckenbauer) Dass du dir so viel Mühe machst ist nicht selbstverständlich. Man weiß jetzt schon, dass man nur auspacken und loslegen kann. Darum jetzt schon mal meinen herzlichsten Dank. It's not self-evident that you put in so much effort. You already know that all you can do is unpack and get started. So now I would like to thank you very much. Best wishes! Joachim |
Matthias, many thanks for all the effort you did and still do put into that order for us. I wouldn't have expected you to act as the incoming QC department, but you do and you do it painstakingly.Many thanks again, Gerald 73 de OE1HGA, Gerald |
| Arne Regular Member Joined: 05/01/2025 Location: GermanyPosts: 64 |
Super service Matthias, many, many thanks for your effort. I’m already looking forward to next week… All the best, Arne |
| ManiB Senior Member Joined: 12/10/2019 Location: GermanyPosts: 182 |
Hello Volhout, I'm planning to organize a group order after thoroughly testing the Pico Computer 3 and finding it to be a good product. If you're interested, please leave a comment here. I'll add you to the list. https://mikrocontroller.bplaced.net/wordpress/sammelbestellung-fuer-den-neuen-pico-computer-3/ Best regards, ManiB |
Hi Matthias, I’d like to thank you very much for your efforts. I really appreciate it. Unfortunately, the five sets I ordered have already all been sold, but I’m planning to organize my own group order. https://mikrocontroller.bplaced.net/wordpress/sammelbestellung-fuer-den-neuen-pico-computer-3/ Best regards, ManiB |
UPDATE ![]() Die Pakete sind gepackt, es fehlt nur noch das Füllmaterial, dann können sie morgen auf die Reise gehen! Bis auf ein paar Kleinigkeiten hat alles geklappt. Auch die Vorbestellung des Speichers und des WLAN-Moduls hat funktioniert. Ein kleines Problem habe ich aber noch. Neben kleineren Nebenkosten wie der Auslandsgebühr bei der Kreditkarte oder dem PayPal-Zuschlag – alles Lerngeld, dafür gab es vereinzelt auch Trinkgeld. Danke dafür! Die CR2032-Batterie geht daher auf mich! Doch bei dem HDMI2VGA-Adapter habe ich mich verkalkuliert. JLCPCB hat auch einen kräftigen Nachschlag gefordert. Am Ende komme ich jetzt auf den doppelten Preis. Anstatt 4,30 Euro sind es 8,60 Euro (MwSt. nicht vergessen). Da 4,30 Euro x 19 Stück aber 81,70 Euro ergeben, würde ich mich über eine Nachzahlung von den betroffenen Personen freuen. Vielen Dank! The packages are packed; all that’s missing is the packing material, and then they can be shipped tomorrow! Except for a few minor issues, everything went smoothly. Pre-ordering the storage device and the Wi-Fi module also worked out. I do still have one small problem, though. Aside from minor additional costs like the international credit card fee or the PayPal surcharge—all part of the learning process—I also received a few tips here and there. Thanks for those! So I’ll cover the cost of the CR2032 battery! But I miscalculated the cost of the HDMI-to-VGA adapter. JLCPCB also charged a hefty surcharge. In the end, the total cost has doubled. Instead of 4.30 euros, it’s now 8.60 euros (Don't forget the sales tax). Since 4.30 euros × 19 units equals 81.70 euros, I’d appreciate it if the people affected could cover the difference. Thank you very much! ![]() Ganz zum Schluß noch ein Angebot für die Bastler. ACHTUNG ich habe aber nur 7 Sets zum abgeben und es sind noch nicht alle Teile eingetroffen! Daher hier schnell schreiben wer ein Selbstbau-Set für ein Breadboard Breakout Adapter in das Paket haben möchte, aber es geht dann später in den Versand. Ich hoffe die kommen am Samstag, laut Ankündigung. Ich habe einmal einen Vergleichsadapter mit 40 Pin neben den benötigten 30 Pin für den PC3 gelegt. Die Stecker sind echt schwer zu bekommen. IDE hatte glaube ich 32 PIN, die gibt es wie Sand am Meer. Selbstbau-Setpreis 5,- EUR One last thing for the DIYers. PLEASE NOTE: I only have 7 sets to give away, and not all the parts have arrived yet! So if you’d like a DIY kit for a breadboard breakout adapter included in your package, let me know here quickly, but it will be shipped later. I’ve included a 40-pin adapter next to the required 30-pin one for the PC3 for comparison. The connectors are really hard to find. I think IDE had 32 pins—those are a dime a dozen. DIY kit price: 5.00 EUR ![]() Viel Spaß! Matthias |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1560 |
Hallo Matthias super Neuigkeiten, vielen Dank für deinen Einsatz. Ich freu mich schon. Gruß Martin Hi Matthias, Great news – thank you very much for all your hard work. I’m really looking forward to it. Best regards, Martin 'no comment |
Hallo Matthias, ich habe dir gerade 25,-EUR für meine fünf HDMI/VGA Adapter nachgezahlt ;) LG, Manfred |
| karlelch Guru Joined: 30/10/2014 Location: GermanyPosts: 359 |
Hi Matthias Vielen lieben Dank für all die Mühe!! Herzliche Grüße Thomas |
@homa: Hi Matthias, was bin ich Dir noch schuldig? Ich würde gerne so ein Selbstbau-Set von Dir abnehmen. what do I still owe you? I'd love to buy one of those DIY kits from you. Frank |
| tom_g Newbie Joined: 21/02/2023 Location: SwitzerlandPosts: 31 |
Dear Matthias, professional service, thank you so much ! I am anticipating the parcel and with no hesitating charge Fuzix from incredible Peter ! Best regards from the beautiful holiday site Ohrid in North Macedonia Thomas Edited 2026-09-05 18:03 by tom_g |
Matthias, you have a PM. Ville56 (Gerald) has sent the money for the adapter and advanced money for the postage to AT via PayPal (pls see PM). thanks again, Gerald 73 de OE1HGA, Gerald |
![]() Project complete! Versand erfolgt - jetzt wünsche ich euch viel Freude. Die Sendungsnummern sende ich euch per PM. Für die mit dem Adapter, alle Teile bis auf 2x15 Pin-Header da. Ich habe dafür 1er dabei getan. Geht auch und dafür sind die Pakete jetzt unterwegs. The parcels have been dispatched – I hope you enjoy them. I’ll send you the tracking numbers via PM. For those with the adapter, all parts are included except for the 2x15-pin headers. I’ve included 1-pin headers instead. That works just as well, and the parcels are now on their way. Matthias |
![]() Der Adapter passt nur wenn der Stecker auf der Seite vom HDMI Stecker beschnitten wird! ![]() Ich habe ein scharfes Teppichmesser benutzt. Das Kabel hält auch ohne den Bügel der Zugentlastung und der Verriegelungsnase. Die Beschriftung stimmt, bis auf J1 mit 1,2,29,30 Dafür aber an den PINs und das ist viel wichtiger! The adapter will only fit if the plug is trimmed on the side with the HDMI connector! ![]() I used a sharp carpet knife. The cable stays in place even without the strain relief clip and the locking tab. The labelling is correct, apart from J1, which is labelled 1,2,29,30 But the pin numbers are correct, and that’s much more important! Matthias Edited 2026-09-06 04:33 by homa |
Hi Matthias! My three PC3s arrived safe and sound. You could really see the effort you put into them only after opening the package. My heartfelt thanks for that. Now I need to read up on the subject. I’ve managed to run the profiler, but I haven’t yet succeeded in establishing a connection via the PC COM port. I also still need to get a USB mouse. Hallo Matthias! Meine drei PC3 sind wohlbehalten angekommen. Welche Mühe du dir damit gemacht hast, konnte man erst erkennen, wenn man das Paket geöffnet hat. Nochmals meinen allergrößten Dank dafür. Jetzt muss ich mich in die Thematik einlesen. Ich konnte zwar schon den Profiler laufen lassen, habe es aber noch nicht geschafft, eine Verbindung über den PC-Com-Port herzustellen. Ausserdem muss ich mir noch eine USB-Maus besorgen. Best wishes! Joachim |
