Local Time 03:43 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Killed microprosessor
     Page 5 of 5
Posted: 09:22pm 14 Aug 2017
Sorry about the missing link
http://www.thebackshed.com/forum/forum_posts.asp?TID=9676&KW=vt100
plover
Posted: 03:12am 15 Aug 2017
The link explains what you were trying to tell me. I could not help having a go, though a little bit premature for me to jump into Function at this stage.
[code]
Function at$(x,y)
[/code]
Above seemed perfect so I added this to my little program
Function at$(x,y)
at$=Chr$(27)+"["+Str$(Y)+";"+Str$(X)+"H"
End Function
Timer = 0
p=1
DO WHILE Timer < 4000
PRINT at$(10,10) "Hello ", p
p=p+1
pause 200
LOOP
First I used following robert.rozee program it works fine in MME VT. I copied and pasted from the link referred above into MME and loaded into Micro. Then took just the at$(x,y) function and added to my code.
Originally I added the function at the bottom of my code but I had made a mistake and got an error when running. Thinking I perhaps should have added function first, as above, but still got the error when running.
Soon after I spotted the error and made correction and my program worked as I was looking for, Counting "on the spot"
clrscr
For X = 1 To 10
For Y = 1 To 5
Print at$((X*5)+10,(Y*2)+2) X*Y
Next Y
Next X
Print at$(1, 20) "press enter to exit ";
Line Input S$
End
Function at$(x,y)
End Function
Sub clrscr
Print Chr$(27)+"[2J";
End Sub
One more little bit learned.Edited by plover 2017-08-16
     Page 5 of 5
