Local Time 01:57 23 Oct 2026 Privacy Policy
Forum Index : Electronics : Controlling a GTI into the ozinverter
     Page 5 of 6
yahoo2
Posted: 08:00pm 08 Sep 2017
  Madness said   Just been looking at the best way to establish communication between multiple charge controllers. It seems power line communication is not readily available for the Arduino. However, Ethernet is cheap and readily available, this would then allow connection by cable, wireless or if powerline is the best option use powerline ethernet adaptors.
Ethernet Shields are around $6.50 AUD just slightly more than Arduino itself.
Impressive stuff Madness! Trying it on a 5kw HF inverter is certainly jumping in the deep end, if any inverter is going to play up it will be one of them. I am excited to see this, its been on my Christmas wish list for a while.
I have been looking into the wireless side of things, the ESP8266 has some quirks and workarounds that I am struggling to get my brain across. In theory it should not only be able to do the wireless link but replace the arduino uno as well. in practice it is OK for some things and a real pain for others.
However the ESP32 has some of these kinks sorted out and a lot more pins available. The downside is that it is so new there is not much code/library adapted for it yet. Give it a few months and it should be possible to easily run oztules program directly on the ESP32.
There will be a lot shields and adapter boards around soon and it is possible to configure them to do over the air changes and updates.
oztules
Posted: 08:40pm 08 Sep 2017
I am thinking of a more mundane robust solution... perhaps as simple as a voltage controlled oscillator, transformer coupled to the home "mains"via a capacitor.
This would impress a simple frequency onto the power lines, and require only a receiver to convert the frequency to a voltage at the other end. It would be universal, and stupidly simple and robust. The little isolation transformer will have a capacitor in series with the hv side to keep the 50 hz heavily attenuated before we even get going.
So a VCO and receiver should solve the problem simply and elegantly.... unless I'm missing something.
........oztules
Madness
Posted: 08:55pm 08 Sep 2017
Arduino I can work with and there is unlimited options and it is a proven platform. I can't see myself trying to learn something else at this stage that may or may not do the job.
As for VCO solutions, I will leave that in your capable hands Oz. If you can get a signal with a 5V range then you won't even need any different code, just connect it to pin 6 of your existing design and nothing else needs to be changed.
Arduino I can do with modules beyond that I am in the dark.
I did try it on an Aerosharp first in case something was wrong, the 5KW Zeversolar Inverter has not put a foot wrong, it gave an error 30 at first when the MOSFETs were not completely isolated. Once I made it completely Isolated the GTI just did what it is supposed to do.Edited by Madness 2017-09-10
yahoo2
Posted: 10:05pm 08 Sep 2017
  Madness said   Arduino I can work with and there is unlimited options and it is a proven platform.
That the beauty of it, the arduino core for these chips can be added to the IDE. Once it is set up the process of compiling and downloading is exactly the same.
Anyway, we can look at all that later.
Clockmanfr
Posted: 10:25pm 08 Sep 2017
  oztules said   I am thinking of a more mundane robust solution... perhaps as simple as a voltage controlled oscillator, transformer coupled to the home "mains"via a capacitor.
........oztules
Sounds good.
Saves installing 1km of data cables. (the other half would not be happy)
As I am simple minded chap there are a couple of things that give me concern.
Frequency would have to be very small power but vey high, off beat so to speak, to avoid resonance HZ frequency's with my GTI wanting it within parameters, and the OZInverter Mini grid HZ not being interfered with especially when backcharging.
But yes, sounds elegant and simple.
oztules
Posted: 11:02pm 08 Sep 2017
In reality, we can get by perfectly well with a single tone for a 1 and no tone for a 0. 1 represents too much, and zero represents not enough.... which is essentially what happens now.... we fuzzy dance around the set point, we never actually stay still.
This would emulate the same thing with very small change to code for the absorb voltage.... but the same thing applies to the float voltage. The receiving computer does not know why we are sending a tone or not, it just obeys, so the transmitter set point just changes when the tone will apply... that should do it...... so the tone function of the sending nano will be enough to get it to work I think... say 15khz, this should be so high away from the 50 hz carrier, that the attenuation will be huge.
Now that is simple as.
We will need a few watts to make this happen, but the tone is only on the line when we have too much power anyway, not enough voltage will be represented by a silence in the 15khz range.... so no power then.
May look into this sooner rather than later perhaps.... although I don't need it myself.
........oztules
Madness
Posted: 01:26am 09 Sep 2017
Is the distance really 1 KM?
Clockmanfr
Posted: 02:50am 09 Sep 2017
Line of site, well up and over a slight hill/rise is just 500m.
The OzInverter mini grid 230vac cable then Zig Zags to each buildings.
I have already put in 220m of cat cable, but digging again is something I am not fond of.
Madness
Posted: 11:21am 09 Sep 2017
So it could easily be done wirelessly for very minimal cost if needed, however, I am sure Oz will come through his option.
If you do need to do another run of cable for any reason it can be done with a repurposed wireless router instead.
RFburns
Posted: 12:14pm 09 Sep 2017
Clockman maybe if you needed full Ethernet you could have used a pair of these
adaptor
and the description Oz gives is the way tariff 33 is controlled so tried and proven
the link here may be of interestpower comms .This uses FSK but the filtering may be of interest. RF Edited by RFburns 2017-09-10
Strong like horse smart like tractor!
oztules
Posted: 04:20pm 09 Sep 2017
Thanks RF, the filters are about what I hoped for... goody
......oztules
Clockmanfr
Posted: 12:09am 10 Sep 2017
Hi Madness,
Yes wireless tech works great, and I have used a simple system, but the things get problematic with more than 2 GTI's at different locations. ......
1. Biggest problem over time is reliability, offset against cost and ease of use.
2. I have to install, especially with that hill in the way, good TX & RX aerial adapters for that 1/2km distances, so more complications.
3. Ruggedness of the wireless system. Some of my installations get hammered by the rain/humidity, so a lot of conformal coating and waterproofing required, again adding to the cost and complexity.
4. With the wireless system, in the end, I operated a dead man handle type, ie, with out a valid signal the GTI,s would not switch on, don't want to cook my batteries. But then dreaded reliability again.
5. Interferences ... around our property here its small milking cow herds country, and every farmer has old mains voltage fed electric fences, and boy do they bleed interference. one fence is shorting out closer to my TX than my RX. We also get constant thunder storms and that certainly stops things.
So I have stopped using the wireless system and fine tuned my GTI's to shut down at a 245vac voltage rise and 1vac differences.
Sorry for writing the above in this simplistic form, I am surprised at how many folk study this particular topic.
Clockmanfr
Posted: 12:30am 10 Sep 2017
Thanks 'Rfburns' nice article/thesis link.
I can even understand some of it.
Made me smile when I saw that SPICE test program still exists, (memories of inserting a floppy and trying to get it to work in the Mid 1980's).
And yep those filters sure are helpful.
Clockmanfr
Posted: 12:47am 10 Sep 2017
Oztules, Yesterday my 14 year old managed to get our new internet/phone/4g mobile hub extender/tele, etc, etc, up and working. Taken 15 years but finally entered the modern world with good speeds.
So I can actually look at stuff rather than enter a page and go have a cuppa while the page loads.
Bit of a shock for this old fellow going from Sat system at 500k up, on a good day before 08.00hrs, to 50mb at any time of day.
We are 2 hours from Paris but finally the French Regional Government paid, been trenching 60km & taken 3 years, to have Fibre Optic cabinet/installation/back up UPS etc, installed at 600 meters away and switched on last week.
Upshot is ........ I can do some serious research now!
It would be neat to add another supplement to the OzInverter Book, about a simple controlling system for the GTI's that are on the OzInverter created 230vac mini grid.
Madness
Posted: 09:24pm 12 Sep 2017
The controller has been working perfectly over the last week, with a couple tweaks to the settings it is working alongside my current commercial MPPT charge controllers. I have been able to adjust times and voltages so they all share the load and switch to float within 15 minutes of each other.
Once I am happy with the design I will get PCB's made of the bigger version I am working on that will be able to control all my panels both GTI and dc - dc all off the one Arduino.
yahoo2
Posted: 03:08pm 13 Sep 2017
If you have to do a order of ten, I would buy some of your spares Madness.
I know I should do it myself but I have been feeling decidedly unmotivated lately.
Madness
Posted: 04:00pm 13 Sep 2017
Hi Yahoo,
Yes I can help with extras, the price of 5 is very little less than 10. I am keeping the PCB to 100 X 100MM to keep the cost down. Is there anything that you would like to see on the board?
yahoo2
Posted: 07:21pm 13 Sep 2017
  Madness said   Is there anything that you would like to see on the board?
No , dont think so, most of my DC stuff is pretty simple and modular now-days.
As long as there is power I can convert to 3.3 volts for a wireless module I should be fine.
Mulver
Posted: 10:28pm 13 Sep 2017
I'd happily chip in for a couple if it's an option Madness!
I'm not yet at making pcb status.
FYI
I bought myself an Arduino starter kits for fathers day and have been working on an automatic ssr dump load controller based on oztules code. This will be used to consume power to control the back charging before needing to throttle back the grid tie.
Based on this code Variablessr
As soon as it's cleaned up I'll post it here.
Madness
Posted: 10:42pm 13 Sep 2017
Hi Mulver
I will be doing the same also, the new version of the PCB I am working on will require an Arduino Uno. This gives a lot more flexibility to add shields for networking, data logging. I have used code similar to that before but it can play havoc with your inverter, I now turn the SSR on when at full battery voltage and off again if it drops too far.
Other things I will add is temperature compensation to the battery charging algorithm, I will also be using the temperature to control an SSR for air conditioning to keep everything cool, last summer my batteries were getting up to 40 degrees.
Learning to write code for the Arduino opens so many doors to solve problems, whether it is water the garden to a robot the possibilities have no limit.
Anyone wanting boards can you PM with numbers please and I will let you know cost etc.Edited by Madness 2017-09-15
     Page 5 of 6
