Local Time 01:05 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA: Framework for ray casting using the DDA method
     Page 6 of 6
Martin H.
Posted: 10:20pm 05 Mar 2026
Hi Kevin
Quite possible. I haven't looked at Peters new routines yet, except for the video. Consider it ‘sporting ambition’ on my part. I read up on it and started implementing it in Basic on the Pico at a usable speed (see the first post). Once the function was in place, I optimised the routines for speed as far as possible. Regardless of the fact that there is now an ‘out of the box’ version for it.
The last posted Version was a a first attempt. I have already added the adjustment for CMM2/MMB4W; the version will be available tomorrow.
Hope that made some sense.
Martin
'no comment
Bleep
Posted: 08:17am 06 Mar 2026
Hi Martin,
No I absolutely understand, it's the challenge of trying to wring the best performance our of what you have. I do it myself all the time, obsessively ;-) I'll give your latest version a spin when you publish it.
Regards Kevin.
Martin H.
Posted: 09:37am 06 Mar 2026
added different textures
added the Image RESIZE_FAST command for Win/CMM2
re-added View-Bobbing,
ccast091.zip
Have Fun
Martin
Edited 2026-03-06 19:42 by Martin H.
'no comment
Bleep
Posted: 01:10pm 06 Mar 2026
Hi Martin, yes that's working fine, it's slightly slower than the previous version, About 15 to 16fps at 320x240 and about 8fps at 480x320.
On a HDMI 640x480 @378Mhz about 14fps
Or a HDMI 640x320 @252Mhz about 9 to 10fps
Or a HDMI 1024 (actually 512) @375Mhz 20 to 21fps
Regards Kevin.
Posted: 01:47pm 06 Mar 2026
Hi Martin,
on RP2040 VGA @252MHz it is 4FPS. Quite nice...
Volhout.
Martin H.
Posted: 01:50pm 06 Mar 2026
Hi Kevin,
To speed up image rendering, you can set the variable resStep from 2 to 4. This will make the changes more angular, but only half as many scans will be performed per frame.
' --- Grafik Setup ---
Dim integer resStep = 4' Wich...
'no comment
Posted: 01:54pm 06 Mar 2026
@Martin,
With reStep=4 and 6 I get a Blit-RESIZE error "number out of bounds". Line 114
Same when I run with line 115 after commenting out line 114.
Edited 2026-03-06 23:55 by Volhout
led-bloon
Posted: 11:57pm 06 Mar 2026
Thanks gentlemen for some very interesting code!
I have added some trivial changes to the code for aesthetics.
Some of it may be of interest.
Tested on PicoMite HDMI only.
1. I have added a text line for angleIndex (simple) although a
  small "North-Up display" would be better (beyond my pay-grade)
2. I have added a small replica of the map (plus user current position)
  under the text info.
3. I have moved the displayed Frame buffer, both X & Y, by a fixed
  offset (ScrnOff).
4. Removed UCASE$ on keyboard input, checking for "asdw" now and also
  added arrow keys for movement (Chr$(x) -> 128,129,130,131)
  Added CASE ELSE at bottom: screenRedraw = 0 (for any non-movement keys)
5. Played a little with the wall texture BMPs.
6. Some other minor changes ... can't remember all of them, but minimal.
led
ccast1b2.zip
Edited 2026-03-07 09:58 by led-bloon
Miss you George
Martin H.
Posted: 09:08am 07 Mar 2026
Hi led-bloon
  Quote  3. I have moved the displayed Frame buffer, both X & Y, by a fixed
 offset (ScrnOff).
So did I in the last release
  Quote  4. Removed UCASE$ on keyboard input, checking for "asdw" now and also
the use of  UCASE$ avoids me having to query letters in both states, e.g. ‘a’ or ‘A’, thus saving another operation. Checking the cursor keys makes sense, I just hadn't implemented it yet, thank you.
  Quote  5. Played a little with the wall texture BMPs
I'll take a look at that. I'm also considering whether I should create 32x32 and 16x16 versions to prevent pixelation caused by excessive reduction (just a thought, as you have more control over this in the drawing programme).
Thank you, I'll test your version on the Pico later.
 Martin
Edited 2026-03-07 22:51 by Martin H.
'no comment
Posted: 12:06pm 15 Mar 2026
Thanks Martin, I've updated my development version of MMB4L to support BLIT RESIZE and it all looks very impressive.
     Page 6 of 6
