Local Time 08:04 28 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PACMAN for Maximite
     Page 6 of 8
Nick
Posted: 09:26pm 03 Apr 2012
Wow!
Genius? Legendary?
I only gave you 50 bucks djuqa!
Thanks. Edited by Nick 2012-04-05
djuqa
Posted: 10:30pm 03 Apr 2012
No Don't say that. I did it because It is Genius and legendary.
VK4MU MicroController Units
Bill.b
Posted: 10:53pm 03 Apr 2012
Hi Nick
still have problems with activatin key board control
ver 1.0 worked OK
bill
ajkw
Posted: 11:54pm 03 Apr 2012
  Bill.b said   Hi Nick
ver 1.0 worked OK
bill
I had trouble with the first version with keyboard control also, I think that when there is nothing connected to the pins 11-14 then value of them floats causing erractic control that overrode the keyboard during gameplay. I had to make a small program change to get the keyboard to work. The details are at home, I can advise tonght if required.
I will obviously be trying out version 1.1 tonight also :-)
Cheers,
Anthony.
Nick
Posted: 01:25am 04 Apr 2012
Interesting these keyboard problems. Are these Maximites or one of the "clones".
I don't do anything special for keyboard control. I'm just using INKEY$ and it works normally on my genuine Maximite.
I do activate Atari joystick (pins 11-14 as digital inputs) even during "No Joystick" control. Maybe I need to make "No Joystick" really be "No Joystick"?
Nick
elchucko
Posted: 02:28am 04 Apr 2012
I can't get Maxman to run on my Maximite sm1 with 3.1 release (or the previous release). I do note that I key in "run" D5 the red LED comes on. The screen shows "coin" and a few random characters. Ideas? I am running my Maximite via the usb port to my PC using W7 and Tera Term. The only connection I'm using to the Maximite is the usb port. Ideas?
djuqa
Posted: 02:33am 04 Apr 2012
Elchucko It NEEDS the VGA/Composite Output for display.
The TeraTerm USB connection (which is really only a serial TEXT CONNECTION) is not suitable for the GRAPHICS.
Edited by djuqa 2012-04-05
elchucko
Posted: 02:36am 04 Apr 2012
OK. Thanks
elchucko
Posted: 02:56am 04 Apr 2012
I switched to VGA and it runs. Wow, excellent! Can't say more!
djuqa
Posted: 03:02am 04 Apr 2012
Great , Enjoy it.
Seems to be too much dependence on USB connected Tera Term by a LOT of MM & DM users.
Those VGA and KB Sockets are there for good reason (For enjoying Great GAME Graphics).
ajkw
Posted: 04:38am 04 Apr 2012
  Nick said   Interesting these keyboard problems. Are these Maximites or one of the "clones".
Nick
Nick,
Mine is a genuine Maximite with 3.1. The changes I made to the program was to elimate checking the state of the pins and only respond to the keyboard. I think with a joystick attached with pull ups the pins are high but with nothing connected they float or are low.
I'll double check this tonight.
Cheers,
Anthony.
Bill.b
Posted: 06:13am 04 Apr 2012
Hi Nick
Mine is an original Altronics maximite running 3.1
Bill
Nick
Posted: 08:28am 04 Apr 2012
  Bill.b said   Hi Nick
Bill
Strange. Let me try some things. Namely, to totally disable Joystick control when selecting "No Joystick".
I'll post the modified MMBasic lines here for you to try and see if that fixes things.
Nick
VK5EX
Posted: 08:31am 04 Apr 2012
Hi Nick,
Congrats on an excellent repo of Pacman. I must admit that I'm a bit hooked. I have it running here all the time , even have the autorun set to autostart the game !! .. Talk about obsessive !! Anyway I notice that we get one extra life at the first 10000. Is the game supposed to give any extra lives at each 10000 ? I cant remember what the original game play is.
Regards .. Andrew
Nick
Posted: 08:50am 04 Apr 2012
Yes VK5EX, I extra at 10000... and no more!
The original machine did too, only one at 10000.
Glad you like the game.
Sorry about the addiction.
Nick
Posted: 08:56am 04 Apr 2012
---> BILL.B:
Try deleting line 53.
This prevents the intialization of pins 11-15 as digital inputs.
Then run the game choosing "No Joystick".
ajkw
Posted: 09:15am 04 Apr 2012
then you get an error at 96 "input mode not implemented"
try
line 96: if wii>0 and pin(15)=0 then v=1: goto GO
works for me
Anthony.Edited by ajkw 2012-04-05
Nick
Posted: 09:18am 04 Apr 2012
Anthony.
Good call Anthony. Bill... does Anthony's suggestion work?
Nick
Bill.b
Posted: 10:40am 04 Apr 2012
Nick
Removing line 96 'If Pin(15)=0 then v=1:Goto G0'
fixed my keyboard problem and now I can play the
game OK Thank a lot.
Bill
darthmite
Posted: 12:25pm 04 Apr 2012
I finally found what you forget to implement in the game
Please add the 'Don't play' option !!
Because when i try to go on the ON/OFF button from my UBW32 or if
i try to press 'CTRL + C' , i don't know why ... my finger go away
Very addictive , something like stop to smoke cigarettes ... he he he.
The Load of the level as font is now light fast compared to before.
Now it's like the original game
Congratz Nick !
Cheers.
     Page 6 of 8
