Local Time 13:30 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Alpha Firmware - a27 onwards - starting on displays
     Page 7 of 14
Posted: 02:15pm 25 Jun 2021
I found this:
https://github.com/Bodmer/TFT_eSPI/discussions/898
It *might* be possible to make the MISO signal work correctly by shorting out a diode. I've never tried this, just did a search.
Posted: 02:29pm 25 Jun 2021
  Quote  Regarding the ILI9488, is there any reason not to simply cut off the MISO pin on the LCD module?
I just removed the pin from the display - same effect
  Quote  https://github.com/Bodmer/TFT_eSPI/discussions/898
Different display, the ILI9488 doesn't have the diode it is the controller itself that is faulty
Posted: 03:12pm 25 Jun 2021
I'm having trouble with GUI CALIBRATE on my setup. I get the target, but no response to touching it. Here's my option setup.
PicoMite MMBasic Version 5.07.00a37
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
>option list
OPTION SDCARD GP5, 10
OPTION SYSTEM SPI GP2,GP3,GP4
OPTION SYSTEM I2C GP10,GP11
OPTION LCDPANEL ILI9341, LANDSCAPE,GP20,GP19,GP18
OPTION RTC AUTO ENABLED
OPTION GUI CONTROLS 59
OPTION MEMORY 60160, 100608
OPTION TOUCH GP22,GP21
I also tried with a ILI9488, MISO pin snipped from the LCD.
I triple-checked the wires, re-touched with the soldering iron, and finally checked for continuity with the Pico plugged in (I know there's a risk) not powered, and I have continuity between Pico pin 29, GP22 and T_IRQ, and between Pico pin 27, GP21 and T_CS.
Checked again for pin to pin continuity with the LCD plugged in--both good.
I also checked for continuity between pins adjacent to T_IRQ and T_CS on both the LDC header and the PicoMite header--no unwanted connection there.
What else should I check for?
Edited 2021-06-26 01:16 by lizby
Posted: 03:32pm 25 Jun 2021
OOPS! Sorry if I raised hopes...  :(
Just going to install a37. It appears to be a thing of beauty. :)
Posted: 04:05pm 25 Jun 2021
a38
PicomiteV5.07.00a38.zip
This now supports setpin n, FIN, PIN, and CIN
To use these you need to set up the pins that will be used for counting
OPTION COUNT pin1, pin2, pin3, pin4
After an option reset or on a new Picomite these will be set to GP6, GP7, GP8, and GP9
If you load A38 to an existing PicoMite you will need to execute the option command
So you can now have up to 4 counting pins and an IR pin with complete flexibility of pin usage
In addition a38 now supports VAR SAVE, VAR RESTORE and VAR CLEAR. The area available for variable storage is 16Kbytes
With a38 most of the key functionality is now implemented other than things I've forgotten. I haven't implemented the keypad or the character LCD commands as these are easy to do in Basic. Any thoughts on this? I'm trying to save command and function slots for future expansion. There is no limit on firmware flash usage at the moment
Posted: 05:21pm 25 Jun 2021
Hmmm...
a37 and ILI9341
Can't get the thing to play now. If I try GUI CALIBRATE I get the screen, but on the first touch I get multiple "ERROR: Touch not calibrated" messages. Also, it's killing SD card access. If I disable Touch by disconnecting T_CS and fitting a pullup resistor then everything is fine. If I try to disable it with OPTION TOUCH DISABLE it doesn't help.
I'm still experimenting as this is on a breadboard - checking wiring. I had it working last night with a36 though. I've just tested the display with a Micromite backpack and it's still working ok with touch.
Posted: 05:27pm 25 Jun 2021
  Quote  Can't get the thing to play now.
Start with OPTION RESET and FLASH ERASE ALL then set up afresh
Posted: 05:41pm 25 Jun 2021
Did that & VAR CLEAR then a power cycle.
> option system spi 4,5,1
> option sdcard 2,15
> files
Error : SD Card not found
Tried a power cycle, same result.
Disabled touch with 10k pullup & files works.
Re-enabled Touch and SD card is dead again. :(
I've not attempted to set up either the LCD or Touch at this point, merely connect the T_CS pin.
If I initialise the display I can print to it, so that's working. SD card is still working.
Edited 2021-06-26 03:46 by Mixtel90
Posted: 06:12pm 25 Jun 2021
  matherp said  Any thoughts on this?
I'd still like to see FLASH WRITE # "filename.bas" for programmatically moving programs from SD card to flash.
It looks as if with OPTION SYSTEM I2C #,# "I2C" and "I2C1" are the valid I2C commands. Since I2C1 was not valid on other platforms, would it be possible for I2C2 to be an alias for I2C1 (perhaps with preprocessing so as not to take up a token slot)?
Can BLIT buffers be cleared on program startup? Also, BLIT LOAD # "file.bmp" would allow tile images to be moved into the BLIT buffers on the ILI9488.
If "There is no limit on firmware flash usage at the moment", would it be possible to add in the keyboard code and (asking a lot here, I know), OPTION LCDPANEL CONSOLE. Since the PicoMite is in many ways a more capable MM+, having this functionality would be consistent with past usage. The 480x320 ILI9488 would provide a decent screen, even if scrolling would be slow over SPI. This could make a quite inexpensive standalone Basic computer.
Posted: 07:11pm 25 Jun 2021
  lizby said  I'd still like to see FLASH WRITE # "filename.bas" for programmatically moving programs from SD card to flash.
If that is something we can have then could you please support the filename being provided from a string variable and not just a hard-coded string.
Any chance of an OPTION F11|F12 so that with one keystroke we can jump to a menu or shell program from the BASIC command-line ?
Edited 2021-06-26 05:13 by thwill
Posted: 07:16pm 25 Jun 2021
Touch not working, maybe try sd card and spi lower speed. It is possible the touch controller cannot keep up with the clock, even when not selected.
Posted: 07:32pm 25 Jun 2021
The annoying thing is that it was working last night! I ran a little LCD/Touch test program on it that I wrote on the Micromite.
I've just rewired the display module to tidy up the wiring a lot. Having Touch connected isn't preventing the SD card from working now. Calibrate is still failing with multiple "ERROR: Touch not calibrated" messages on the first touch though.
> option list
OPTION CPUSPEED (KHz) 250000
OPTION SDCARD GP1, 15
OPTION SYSTEM SPI GP2,GP3,GP0
OPTION SYSTEM I2C GP20,GP21
OPTION LCDPANEL ILI9341, RLANDSCAPE,GP15,GP14,GP13
OPTION TOUCH GP12,GP11
> gui calibrate
Error : Touch not calibrated
It's certainly detecting the touch, but it's not doing the right thing with it by the looks of things. I'll dig a cap out for the 5v rail and see if that helps.
Edited 2021-06-26 05:34 by Mixtel90
Plasmamac
Posted: 07:54pm 25 Jun 2021
hi;
iam totaly confused atm .
can anyone schow me how to wire an ili9341 to the pico and a small demo ?
thx
Plasma
atmega8
Posted: 07:58pm 25 Jun 2021
Hello,
what is the max Baudrate for the Terminal?
Is there autobaud mechanism?
How to import code in the editor?
Cut and paste doesn't work with teraterm.
THX
Plasmamac
Posted: 08:04pm 25 Jun 2021
paste works in teraterm , change the serial port transmit delay
several baud rate are ok so i guess its autobaud
Plasma
TrevorC
Posted: 08:20pm 25 Jun 2021
Hi,
  I am also having problems with gui calibrate with picomite a37 and a38. I get the screen, but on the first touch I get multiple "ERROR: Touch not calibrated"
There is no problem with a36.
Posted: 08:32pm 25 Jun 2021
@Plasmamac
Even more confusing because there's no one "right" way. :)
I'd recommend that you have a look on Geoff's site to get some information (manuals) on the MicroMite+ and have a read. In function it's quite similar.
https://geoffg.net/MicromiteMX470.html
Also look at the circuit of the Micromite LCD Backpack - link on the same page. The manuals and this circuit detail how the display is connected.
OPTION LCDPANEL defines which pins will be used for the display.
OPTION TOUCH defines the pins used for the touch screen function.
These are documented in the manuals and briefly in the PicoMite.docs file that I keep updating.
Eventually there'll probably be a specific PicoMite manual, but not until it's out of alpha.
@atmega8
My PicoMites default to 230400,8,N,1 with no flow control.
Posted: 08:52pm 25 Jun 2021
  atmega8 said  How to import code in the editor?
Copy and then right click works to paste. Alt+V also works to paste.
In TeraTerm, after mouse-sweeping to select, Alt+C works to copy without the effects of Ctrl+C.
Posted: 08:57pm 25 Jun 2021
  TrevorC said  Hi,
Sounds similar. I've not tried a38 yet so I don't know what effect that would have. Now I've rewired I'll put a36 back on.
Posted: 08:58pm 25 Jun 2021
How are people wiring the LED (backlight) pin on their ili9341s?
     Page 7 of 14
