Local Time 02:39 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite - STM32H7: Developments
     Page 8 of 11
Posted: 08:33am 27 Jul 2018
I can confirm you need pullups (nominally 10K) on all data lines + CMD and CLK. This is part of the electrical specification for 4-bit parallel operation of SD cards
  Quote  or the Hc12 module with FU4 mode i need 1200 baud on serial. is this supportet?
Not at the moment - slowest is 2400. This is because the divider of the system clock is only 16-bits and the clock runs at 200MHz
gadgetjack
Posted: 03:14pm 27 Jul 2018
I tied the pullups on the board , both caps on power lines and still the same failure. I am using the waveshare board which now is a bit funky with extra parts.
I am off to the store to get a different brand of card to try. Not sure what else to do. Also tied 3 different versions of software but all gave the same response. I might have a bad board? That would be bad as it took so long to get this one. Testers keep testing....it is still fun.
gadgetjack
Posted: 05:44pm 27 Jul 2018
Ok, progress. I tried a new brand of card and it shows what is on the card. Still seems a bit picky trying to save and reload. Will load the newest version and try again. Baby steps.
Posted: 11:12pm 27 Jul 2018
My SDcard reading is also iffy so you are not alone.
I have one card that works reliably and half a dozen of various specifications that don't work at all.
I am using the waveshare module which already has 10k pullups on all data lines and I added the 2.2ohm/10uF filtering on the 3.3V supply.
I also made a small adapter to use instead of flying leads.
I have another brand module to try but so far no success.
I will try with all pullups removed next.
Posted: 02:52pm 31 Jul 2018
The STM SD card driver seems to be giving too many problems and performance isn't even that good so I have scrapped the 4-bit parallel approach and re-written the SPI version of the driver. In addition I've made some other performance improvements as reported here and updated to the latest 1.3 HAL library
Version 5.04.26
The SDcard should now be wired as per a normal SPI device
PF7 to SD_CLK
PF8 to SD_MISO
PF9 to SD_MOSI
SD_CS can be wired to any available pin as can (optionally) SD_CD and SD_WR. Use the standard MM+ syntax for setting up the SDcard.
OPTION SDCARD cs_pin [,cd_pin] [,wr_pin]
The driver can detect card removal and replacement without needing SD_CD connected. It has been tested using the card socket on an ILI9341 display and is completely compatible with driving the display and touch over the same SPI channel.
The original pins connecting the SDcard are now available for general use.
Pin-98 = PC8
Pin-99 = PC9
Pin-111 = PC10
Pin-112 = PC11
Pin-113 = PC12
Pin-116 = PD2
Pin-87 = PG2
SPI speed is set to 19.2MHz which should be compatible with most cards but in the event there are still problems I'll add an additional speed parameter.
Edited by matherp 2018-08-02
gadgetjack
Posted: 08:40pm 31 Jul 2018
That did it! Now it works perfectly. Gotta find a case for it now.
Thank you for all your great work!!!!
Posted: 03:51am 01 Aug 2018
Sounds good and I have a pile of cards to test.
But where is the link to the download gone?
Posted: 07:14am 01 Aug 2018
  Quote  But where is the link to the download gone?
2018-08-01_171419_Armmite1.3.zip
Posted: 08:12am 01 Aug 2018
Thanks Peter,
I do have a problem
  Quote  ARMmite MMBasic Version 5.04.26
Copyright 2011-2018 Geoff Graham
Copyright 2016-2018 Peter Mather
> files
Error: A hard error occurred in the low level disk I/O layer
> option list
OPTION FLASHPAGES 1
OPTION SDCARD 114, 56
I tried with and without the CD pin connected.
Same error with no card inserted
Posted: 08:29am 01 Aug 2018
Another problem.
My SSD1306 test program doesn't talk to the display.
The program runs without any errors but no life on the display.
Are there any changes to I2C in this latest build?
Posted: 09:05am 01 Aug 2018
This should fix i2c. The change to the updated HAL library somehow changed the pinout
2018-08-01_190416_Armmite1.3.zip
Please try the SD card using the slot on a ILI9341 or similar. There seems to be an issue with the Waveshare card when using SPI (works with pullup resistors removed)Edited by matherp 2018-08-02
Posted: 02:43am 02 Aug 2018
I2C now working.
I tried a different SDCard module and all cards except a Sandisk extreme worked OK
I then tried an module without any pullups and the extreme card works.
Very happy.
One issue. When attempting to use the card with non present, an error is produced.
  Quote  > files
R:/
18688 analogclock.bas
18432 ARLECSwitch.BAS
0 directories, 2 files
> files
> files
R:/
Reinserting the card and it works again.
Normally, I would not be reading the drive without a card present.
Edit. No pullup on the CD line!
I will fit one and try again.
No. that didn't help.Edited by TassyJim 2018-08-03
Posted: 08:08am 02 Aug 2018
  Quote  When attempting to use the card with non present, an error is produced.
The error is correct just the message is a bit (OK a lot) obscure.
Try this version
2018-08-02_180814_Armmite1.3.zip
Posted: 08:52am 06 Aug 2018
Version 5.04.27
2018-08-06_234227_Armmite1.3.zip
This has been tested with the new daughter board and all display and other peripheral support now seems solid. This release supports SDcards over SPI so the SDcard on the daughter board V1.0 is not supported and the SDcard slot on a display should be used instead or a separate SDcard module can be used but should not have pullups.Edited by matherp 2018-08-07
TrevorH
Posted: 08:05pm 09 Aug 2018
Hi Peter,
the backpack seems so far to work OK for me, my displays all use the LED-A pin
to light the backlight, so strapped pin 37 on TFT connector to +3.3v.
I have 2 tiny problems, 1 is SD card not present on ILI9341 display, 2 SD card on
both SSD1963 display work OK BUT instead of loadimage doing so it displays a patch
of garbage.
Any ideas???
Still waiting for RTC batt holder to arrive.
Still haven't tried touch yet.
I am using 5.04.27
Just tried touch, works 100% fine on ILI9431, but still giving same errors as before on SSD1963 displays.
Trevor.Edited by TrevorH 2018-08-11
Posted: 06:58am 10 Aug 2018
  Quote  1 is SD card not present on ILI9341 display,
The 4-pin connector for the ILI9341 SDcard I/F is directly wired to the same pins on the SSD1963 so there is no difference as far as the H/W or S/W is concerned. Can't explain this - check soldering etc.
  Quote  SD card on
of garbage.
Can't replicate. Check soldering of the morpho pins. I had an initial problem and found one unsoldered - there are so many of them it is easy to miss one. Does load image work OK on ILI9341?
  Quote  Just tried touch, works 100% fine on ILI9431, but still giving same errors as before on SSD1963 displays.
Same code so difficult to understand but try this version which slows Touch SPI speed a bit and see if it helps
2018-08-10_165734_Armmite1.3.zip
Edited by matherp 2018-08-11
TrevorH
Posted: 08:16am 10 Aug 2018
Hi Peter,
Just tried SD card again on ILI9431 and is now OK(maybe contact probs with SD socket?!).
LoadImage gives same result as other displays(looks like not decoding BMP properly)
will check all conns with scope!
Trevor.
Posted: 08:26am 10 Aug 2018
  Quote  LoadImage gives same result as other displays(looks like not decoding BMP properly)
Check the image(s) on a PC. I had an image with strange artifacts and couldn't find the problem and then put the card into a PC and they were there on that as well. Some corruption on the card. Also try different cards, The SDcard SPI is running as fast as I could get it while still being reliable. Tassyjim is getting even better results with fast cards but slow cards sometimes give issues even though directory list works.
Let me know and if no joy I'll post another version with slower SDcard SPI
TrevorH
Posted: 09:07am 10 Aug 2018
I am getting confused, I have a 800x480 BMP picture and it looks like it's putting on screen as a 320x240 size in portrait mode (maybe the 320x240 is wrong but similar in size), which would screw up the formatting I guess.
btw am using SanDisk Ultra 32GB class 10 (new) card and all pictures are perfect on PC, also worked perfectly on old setup before daughter board arrived.
ps If I set tft to portrait mode, picture seems to be in landscape on screen????
Trevor.
Posted: 09:40am 10 Aug 2018
I would say you definitely have a short or a bad connection on one of the data pins. Probably 6 or 7. Try using the 8-bit driver and play with different colours to see if there is anything strange. Does text appear where you expect?
     Page 8 of 11
