Forum Index : Microcontroller and PC projects : PicoMite V6.01.00 betas
Don't you have to put gui controls in a program? cls 'define touch areas gui area 1,0,199,80,40 ':line 0,239,80,239,rgb(blue)'left button gui area 2,140,199,80,40 ':line 140,239,220,239,rgb(blue)'right button gui area 3,279,40,40,80 ':line 319,40,319,120,rgb(blue)'up button gui area 4,279,159,40,80 ':line 319,179,319,239,rgb(blue)'down button |
At Ville56, Confirmed. OPTION GUI CONTROLS X kills MMBasic V6.01.00b9. Volhout Edited 2025-08-22 01:26 by Volhout PicomiteVGA PETSCII ROBOTS |
Confirmed. OPTION GUI CONTROLS 4 kills MMBasic V6.01.00b8. as well rpi 2350A had to flash clear_flash to flash b7 until it's fixed. found flash_nuke.. what's that? Edited 2025-08-22 03:32 by stanleyella |
Should be fixed PicoMiteV6.01.00b10.zip |
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 646 |
Thanks Peter, it works now as expected. 73 de OE1HGA, Gerald |
It accepts option gui controls n now. thanks, what/when it happened? PicoMite MMBasic USB RP2350A Edition V6.01.00b10 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION SYSTEM SPI GP18,GP19,GP16 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION KEYBOARD UK OPTION CPUSPEED (KHz) 378000 OPTION LCDPANEL CONSOLE OPTION DISPLAY 20, 40 OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13 OPTION GUI CONTROLS 4 OPTION TOUCH GP12,GP11 GUI CALIBRATE 0, 3900, 3816, -886, -658 OPTION SDCARD GP22 OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0 Edited 2025-08-22 05:22 by stanleyella |
A simple tron game for ili9341 using screen area for left,right,up,down but the box draw to show where the button areas were is commented out because the touch stopped working?? 'option gui control 4 is needed in option list OPTION EXPLICIT OPTION DEFAULT NONE OPTION DEFAULT INTEGER OPTION BASE 1 'arrays start at 1 option autorun on dim px,py,pdx,pdy dim cx(3),cy(3),cdx(3),cdy(3),cpa(3) dim ts,tr,csc=0,psc=0,cm cls 'define touch areas gui area 1,0,199,80,40 ':line 0,239,80,239,rgb(blue)'left button gui area 2,140,199,80,40 ':line 140,239,220,239,rgb(blue)'right button gui area 3,279,40,40,80 ':line 319,40,319,120,rgb(blue)'up button gui area 4,279,159,40,80 ':line 319,179,319,239,rgb(blue)'down button 'draw direction buttons... stops touch working 'box 0,199,80,40,3,rgb(white),rgb(blue)'left button 'box 140,199,80,40,3,rgb(white),rgb(blue)'right button 'box 279,40,40,80,3,rgb(white),rgb(blue) 'up button 'box 279,159,40,80,3,rgb(white),rgb(blue)'down button 'do 'tr=TOUCH(REF) 'loop until tr>0 'pause 5000 'cls do 'init players start positions px=260:py=rnd*120+60:pdx=-1:pdy=0 cx(1)=rnd*100+80:cy(1)=50:cdx(1)=0:cdy(1)=1:cpa(1)=1 cx(2)=rnd*100+80:cy(2)=190:cdx(2)=0:cdy(2)=-1:cpa(2)=1 cx(3)=rnd*50+50:cy(3)=rnd*80+80:cdx(3)=1:cdy(3)=0:cpa(3)=1 'draw play area & 4 random triangles on border box 0,0,319,239,1,rgb(white),rgb(black) ts=rnd*160+40 triangle 0,ts,12,ts+8,0,ts+16,rgb(White) ts=rnd*160+40 triangle 319,ts,307,ts+8,319,ts+16,rgb(White) ts=rnd*240+40 triangle ts,0,ts+8,10,ts+16,0,rgb(White) ts=rnd*240+40 triangle ts,239,ts+8,228,ts+16,239,rgb(White) line 0,239,80,239,1,rgb(blue)'left button line 140,239,220,239,1,rgb(blue)'right button line 319,40,319,120,1,rgb(blue)'up button line 319,179,319,239,1,rgb(blue)'down button 'main do 'check user button pressed tr=TOUCH(REF) if tr>0 then select case tr case 1 'left pressed if pdx=0 then pdy=0:pdx=-1 case 2 'right pressed if pdx=0 then pdy=0:pdx=1 case 3 'up pressed if pdy=0 then pdx=0:pdy=-1 case 4 'down pressed if pdy=0 then pdx=0:pdy=1 end select end if px=px+pdx:py=py+pdy 'has player crashed if pixel (px,py) >0 then 'player crashed box 0,0,319,239,1,rgb(white),rgb(black) text 60,100,"You Lost",l,5:pause 5000:exit do end if pixel px,py,rgb(magenta) 'computer move for cm=1 to 3 if cpa(cm)=1 then if cdx(cm)<>0 then if pixel (cx(cm)+cdx(cm),cy(cm)) >0 then cdx(cm)=0:cdy(cm)=(py>cy(cm))-(py<cy(cm)) end if else if pixel (cx(cm),cy(cm)+cdy(cm)) >0 then cdy(cm)=0:cdx(cm)=(px>cx(cm))-(px<cx(cm)) end if end if cx(cm)=cx(cm)+cdx(cm):cy(cm)=cy(cm)+cdy(cm) 'has computer player crashed if pixel (cx(cm),cy(cm)) >0 then cpa(cm)=0'computer crashed if cpa(1)+cpa(2)+cpa(3)=0 then 'all crashed box 0,0,319,239,1,rgb(white),rgb(black) text 70,100,"You Won",l,5:pause 5000:exit do end if end if pixel cx(cm),cy(cm),rgb(yellow) end if next cm pause 50 loop loop |
I don't know why drawing over gui area stops touch working as above tron |
@Peter, There is no RP2040 non VGA non USB version in this b10 zip (used in Game*Mite). In the b9 zip there was no 2040+VGA+USB version included. This is purely based on the filenames... Volhout Edited 2025-08-22 17:36 by Volhout PicomiteVGA PETSCII ROBOTS |
Oops PicoMiteV6.01.00b10.zip |
@stanleyella: I think it has nothing to do with the BOX statements ... the following code (the first part of your code) runs and touch reacts and has the BOX enabled. Just added the print and pause to see what happens. The problem must be somwhere else .... OPTION EXPLICIT OPTION DEFAULT NONE OPTION DEFAULT INTEGER OPTION BASE 1 'arrays start at 1 option autorun on dim px,py,pdx,pdy dim cx(3),cy(3),cdx(3),cdy(3),cpa(3) dim ts,tr,csc=0,psc=0,cm cls 'define touch areas gui area 1,0,199,80,40 ':line 0,239,80,239,rgb(blue)'left button gui area 2,140,199,80,40 ':line 140,239,220,239,rgb(blue)'right button gui area 3,279,40,40,80 ':line 319,40,319,120,rgb(blue)'up button gui area 4,279,159,40,80 ':line 319,179,319,239,rgb(blue)'down button 'draw direction buttons... stops touch working box 0,199,80,40,3,rgb(white),rgb(blue)'left button box 140,199,80,40,3,rgb(white),rgb(blue)'right button box 279,40,40,80,3,rgb(white),rgb(blue) 'up button box 279,159,40,80,3,rgb(white),rgb(blue)'down button do tr=TOUCH(REF) if tr>0 then print tr pause 100 loop 'until tr>0 'pause 5000 'cls 73 de OE1HGA, Gerald |
@ville56 I know do tr=TOUCH(REF) loop until tr>0 works after drawing boxes. touch any and game starts but touch doesn't work. no boxes and game works with touch. strange. regards stan |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9240 |
try TOUCH(X) or TOUCH(Y) instead of TOUCH(REF) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Mick there's touch last x and touch last y but no good for testing a control touched. it's got me baffled |
Stan, I've played around a bit and found out that the CLS may be the showstopper .... try the following code OPTION EXPLICIT OPTION DEFAULT none dim integer ts,tr,csc=0,psc=0,cm cls 'define touch areas gui area 1,0,199,80,40 ':line 0,239,80,239,rgb(blue)'left button gui area 2,140,199,80,40 ':line 140,239,220,239,rgb(blue)'right button gui area 3,279,40,40,80 ':line 319,40,319,120,rgb(blue)'up button gui area 4,279,159,40,80 ':line 319,179,319,239,rgb(blue)'down button 'draw direction buttons... stops touch working box 0,199,80,40,3,rgb(white),rgb(blue)'left button box 140,199,80,40,3,rgb(white),rgb(blue)'right button box 279,40,40,80,3,rgb(white),rgb(blue) 'up button box 279,159,40,80,3,rgb(white),rgb(blue)'down button do tr=TOUCH(REF) if tr>0 then print tr pause 100 end if loop until tr>0 cls do tr=TOUCH(REF) print tr pause 100 loop If you comment out the red CLS, touch(ref) will work, if CLS is included touch(ref) will produce no return value >0 if box is touched. I do have a slightly different setup (dsiplay), but running the same version of firmware and I suppose the issue (whatever it is) will be in all relevant variants. Gerald 73 de OE1HGA, Gerald |
Hi Gerald, thanks for replying. I mentioned it cos it's a "problem" and indeed I thought the CLS position was a factor. using the advanced graphics pdf for info but cls having effects not mentioned. this draws boxes, waits for touch then starts game but touch not working gui area 1,0,199,80,40 ':line 0,239,80,239,rgb(blue)'left button gui area 2,140,199,80,40 ':line 140,239,220,239,rgb(blue)'right button gui area 3,279,40,40,80 ':line 319,40,319,120,rgb(blue)'up button gui area 4,279,159,40,80 ':line 319,179,319,239,rgb(blue)'down button 'cls 'draw direction buttons box 0,199,80,40,3,rgb(white),rgb(blue)'left button box 140,199,80,40,3,rgb(white),rgb(blue)'right button box 279,40,40,80,3,rgb(white),rgb(blue) 'up button box 279,159,40,80,3,rgb(white),rgb(blue)'down button do tr=TOUCH(REF) loop until tr>0 cls do 'init players start positions The idea was show buttons then erase as game uses areas not marked Edited 2025-08-23 04:04 by stanleyella |
I understand ... well, a GUI SHOW ALL after CLS makes it react again. I didn't look into the advanced graphics manual upfront .... so it seems that the effect is documented, but as we know, males do not read manuals Gerald 73 de OE1HGA, Gerald |
According to the manual there's TOUCH(REF) which returns the number of the control currently being touched and TOUCH(LASTREF) which returns the number of the control last touched. There's no LAST X or LAST Y. I suggested TOUCH(X) or TOUCH(Y) to make sure that touch is working and that your loop is working. They have nothing to do with GUI controls so aren't affected by it. Test from the bottom up. :) . Edited 2025-08-23 05:09 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Why not just draw buttons? Mick Zilog Inside! nascom.info for Nascom & Gemini |
see CLS info... the answer? Using Basic Drawing Commands There are two types of objects that can be on the screen. These are the GUI controls and the basic drawing objects (PIXEL, LINE, TEXT, etc). Mixing the two on the screen is not a good idea because MMBasic does not track the position of the basic drawing objects and they can clash with the GUI controls. As a result, unless you are prepared to do some extra programming, you should use either the GUI controls or the basic drawing objects – but you should not use both. So, for example, do not use TEXT but use GUI CAPTION instead. If you only use GUI controls MMBasic will manage the screen for you including erasing and redrawing it as required, for example when a virtual keyboard is displayed. PicoMite Advanced Graphics Page 15 Note that the CLS command (used to clear the screen) will automatically set any GUI controls on the screen to hidden (i.e. it does a GUI HIDE ALL before clearing the screen). |
