Local Time 20:58 14 Dec 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoGAME LCD: Handheld videogame
     Page 3 of 4
Posted: 02:49pm 08 Jun 2023
  Volhout said  The sound suffers from PRINT statements ...
Thanks. I hadn't noticed but then again with the exception of my Text Adventures I don't use PRINT when I'm writing games.
stanleyella
Posted: 02:57pm 08 Jun 2023
  Mixtel90 said  I've just had a 1.80UKP analogue joystick working today. Not too bad at all, scaling the axis from 0-100 with 50 at midpoint or using it as a digital joystick. It's very promising.
The 5 button pad with 1 analogue out works well. 5 buttons/1 pin.
A switch joystick with resistors would be similar.
Posted: 04:00pm 08 Jun 2023
My idea, as I've said elsewhere, is to make I2C controllers. Two pins would give me several controllers (up to seven if the I2C connection isn't loaded down by too much cable capacitance. More likely to only be two), each with a programmable analogue/digital joystick and two or three buttons.
This is still early days yet, but I've got the joystick working acceptably well in both digital and analogue modes. I need to sort out the I2C now. Somehow. Sometimes you could really do with two monitors and twice as much bench space. :(
My VGA-RJ45 adapters have turned up too. More to play with. :)
ice2642
Posted: 04:42pm 08 Jun 2023
  Volhout said  Tom,
I have been playing with sound on the VGA picomite, and have oe observation I would like ot share.
The sound suffers from PRINT statements.
Te print statements go to the USB interface (console), and I think that USB stack has impact on audio. Only after I removed the last PRINT statement (change to a TEXT statement) the audio was flawless on 126MHz CPU.
Sorry to join the conversation,
It's an interesting observation for me.
I'm doing some tests with tone and the sound is coming out bad, although I connected an amplifier directly to the GP0 and GP1 outputs, without the low filter. The print in program, it just tells you which keys to press to make a certain sound.
Edited 2023-06-09 02:43 by ice2642
MMBasic 5.0707 on PicoMite VGA
stanleyella
Posted: 04:52pm 08 Jun 2023
  Mixtel90 said  My idea, as I've said elsewhere, is to make I2C controllers. Two pins would give me several controllers (up to seven if the I2C connection isn't loaded down by too much cable capacitance. More likely to only be two), each with a programmable analogue/digital joystick and two or three buttons.
I got some i2c 16 port expander chips which work with mmbasic (with help from the forum, thank you). Could also be another option for a control panel.
Posted: 04:55pm 08 Jun 2023
In MMBasic the PLAY sounds are generated by PWM. You *need* a filter or all you get is a modulated 44kHz square wave. You are lucky to be hearing anything at all. :) A simple RC filter will get the audio out of the carrier, but it won't get rid of the 44kHz carrier. That's not good for amplifiers and speakers. This is why Volhout has produced some more complex filters.
IIRC Tom's case is a bit special. The tiny speaker acts as a mechanical filter to reduce the 44kH. It can't simply be substituted by an amplifier input.
You get better quality with less filtering by using a DAC.
Edited 2023-06-09 02:59 by Mixtel90
Posted: 05:06pm 08 Jun 2023
  ice2642 said
  Volhout said  Tom,
You are new to the forum, and there have been megabytes of discussions on audio the last year. To summarize: pwm audio needs a filter, and the picomite powersupply causes noise. Simplest is to use a linear regulator for 3.3V.
Sasquatch
Posted: 05:25pm 08 Jun 2023
Hi Tom,
The PicoGAME PCB looks great!  It looks like the schematic and KiCad files on the Github repository are outdated.  Can we expect Gerber files for the new PCB soon?  If you do another revision of the PCB you might think about adding mounting holes for the LCD module on standoffs.  I can see that the LCD is supported by pin headers on both ends, but a more solid mount might be nice.
-Carl
ice2642
Posted: 05:41pm 08 Jun 2023
  Mixtel90 said  In MMBasic the PLAY sounds are generated by PWM. You *need* a filter or all you get is a modulated 44kHz square wave. You are lucky to be hearing anything at all. :) A simple RC filter will get the audio out of the carrier, but it won't get rid of the 44kHz carrier. That's not good for amplifiers and speakers. This is why Volhout has produced some more complex filters.
Can you sugest a good DAC for use with PicoMite in Aliexpress?
I am looking this models in the attached image.
PCM5102 the first 2 and UDA1334a
  Volhout said
  ice2642 said
  Volhout said  Tom,
Good tip, I'll give a search in the old threads on the subject.
Best Regards,
Posted: 05:43pm 08 Jun 2023
  Sasquatch said  The PicoGAME PCB looks great!  It looks like the schematic and KiCad files on the Github repository are outdated.  Can we expect Gerber files for the new PCB soon?  If you do another revision of the PCB you might think about adding mounting holes for the LCD module on standoffs.  I can see that the LCD is supported by pin headers on both ends, but a more solid mount might be nice.
Thanks Carl.
Yes, everything on GitHub is out of date. Updated schematic and Gerber (courtesy of @bigmik) will be posted once we've ironed out some cosmetic issues and done another round with the audio - it looks like the previous prototype which I based the final decisions around may have had a faulty PAM8302 module on it .
Regarding mounting points for the LCD that may prove a little tricky* and I'm not convinced it is necessary, uncased this is never going to be a particularly robust device. I'll see what @bigmik thinks.
* At least one of them would conflict with the mounting points between the PCB and its baseplate (another unpopulated copy of the same PCB to which the battery and speaker are stuck).
Edited 2023-06-09 04:18 by thwill
Posted: 05:46pm 08 Jun 2023
Hey guys, I'm usually pretty "live and let live" about thread hijacking, but it's getting a bit much. Could I point you at:
   PicoMite: Controllers ... again ;-)
and
   PicoMite: driving a small speaker
Edited 2023-06-09 03:49 by thwill
Posted: 06:10pm 08 Jun 2023
Ice:
The PicoMite supports the MCP4822 DAC chip (and other members of that family). I got some through-hole ones from AliExpress.
Sasquatch
Posted: 08:05pm 08 Jun 2023
Thwill said:
  Quote  uncased this is never going to be a particularly robust device
I have started 3D printing "Trays" for my "Uncased" PCB's  The "trays" cover the back of the PCB and prevent shorting out the solder joints.  The "trays" also give some stability when sitting on the bench or table.
Here are some photos of a tray I printed for a similar project.  The project is an Apple//e emulator using a Teensy 4.1 (on GitHub as Aiie by JorjBauer.)  The main PCB is screwed firmly to the tray and the tray encloses the LiPo battery and charging/boost module.  You can also see the custom printed standoffs supporting the LCD module (in this case the LCD is only supported by pin-headers on one side.)  I used lower profile machine pin headers for the Teensy module and raised the LCD headers slightly to allow clearance under the LCD module.  You can see the micro USB charge port on the top edge of the tray.  This tray has rounded edges and fits nicely in the hand.  I considered adding a top to the tray kind of clam-shell style but I think leaving it open gives the project a nice retro look.
-Carl
stanleyella
Posted: 08:30pm 08 Jun 2023
Wow! I like the mini key board! You guys
vegipete
Posted: 09:24pm 08 Jun 2023
  Sasquatch said  The project is an Apple//e emulator using a Teensy 4.1 (on GitHub as Aiie by JorjBauer.)
How do you (effectively) play Sabotage without a paddle?
I've ported it to the CMM2, steerable shells and all. Works very well - with a potentiometer providing an analog input. I re-wired a standard Apple paddle with a 4 conductor cable. Retro...
Turbo46
Posted: 09:25pm 08 Jun 2023
  Tom said  Hey guys, I'm usually pretty "live and let live" about thread hijacking
Sorry Tom but I would like to point out for the purists that the PAM8302A is a DIGITAL AMPLIFIER.
  Adafruit said  The output is a high frequency 250KHz square wave PWM that is then 'averaged out' by the speaker coil - the high frequencies are not heard.
There is no filter between the amplifier's digital output and the speaker.
Bill
Sasquatch
Posted: 09:56pm 08 Jun 2023
  vegipete said  How do you (effectively) play Sabotage without a paddle?
The large knob is actually an analog joystick so it works quite well for left/right control.  As you may be aware the joystick for apple][ was actually wired the same as two paddles for X and Y.  Sabotage is playable on apple][ keyboard (using "D" and "F" for left/right) although not nearly as nice as a paddle or joystick!
Sabotage might be a good candidate for the PicoGAME LCD using the gamepad controls or a potentiometer as a paddle.
Sabotage was one of the iconic games I remember from the '80s I was wondering who would recognize it. I'd love to play Sabotage on my CMM2, did you ever upload it to the forum?  Let's start a new thread for Sabotage if you want to discuss further!
Edited 2023-06-09 07:58 by Sasquatch
-Carl
Posted: 10:03pm 08 Jun 2023
That's the same sort of joystick I've been playing with. :)
Turbo46
Posted: 10:08pm 08 Jun 2023
  Quote  Let's start a new thread for Sabotage if you want to discuss further!
Please do. Maybe suitable for a Nunchuk?
Bill
Posted: 10:13am 09 Jun 2023
Hi Carl,
  Sasquatch said  I have started 3D printing "Trays" for my "Uncased" PCB's  The "trays" cover the back of the PCB and prevent shorting out the solder joints.  The "trays" also give some stability when sitting on the bench or table.
Very, very nice.
Whilst not as pretty I've found the Bintendo's two PCB sandwich provides similar stability and a level of protection against shorting. The Bintendo suprisingly has reasonable weight and ergonomics, especially for the minimal effort it requires (I've made a deliberate decision to have nothing to do with 3D printing or CNC at least until I retire; there aren't enough hours in the day as it is.)
The final hardware will be licensed under CC BY 4.0 so perhaps someone else might choose to take it further, I know @bigmik has some ideas about squeezing this all into the existing enclosure from one of those cheap Chinese "NES on a chip" handhelds.
Thanks for your interest,
Edited 2023-06-09 20:46 by thwill
     Page 3 of 4
© JAQ Software 2025
