Local Time 04:39 13 Jul 2026 Privacy Policy
     Page 33 of 35
jakesea
Posted: 06:05pm 02 May 2026
  wiseguy said
  jakesea said   Once again, thank you for your design and pcb boards and if you come to the UK I wouldn't mind buying you a drink or two... (I hope you don't drink drinks from high glass with straw, parasol and pineapple pieces in them...)
Aw crap - is there another type of drink ? wait - yes I remember room temperature beer lol.  Ok just a bit of ribbing the local beers are rather palatable.  I will look up where Tredegar is, currently I have no idea how close we would be during our visit.
Yep, room temperature beer - I wouldn't have it any other way...😋
@KeepIS, thank you very much, Mike - the kilovac on the way and the choke cores already at home. Getting closer
mab1
Posted: 06:11pm 02 May 2026
  wiseguy said
  mab1 said  Hi Jakesea,
Good to hear of  another of these great inverters being built in Wales (i'm in Carmarthenshire). Mine is not yet finished: still running on the temporary transformer, but i'll finish it one day.
I have a spare TLS76L1 that Mike generously provided with my boards. I could pop it in the post to you if you like?
Mab I expect to be visiting UK again, hopefully within 6 months so I will put half a dozen in my pocket to post to you when I arrive, for you to keep/distribute at your discretion. If anyone I know visits sooner I will ask them to post to you locally.
that's fine by me.
KeepIS
Posted: 11:35pm 11 May 2026
Some interesting observations with regard to Load switching and currents.
With fast transfer, in this case < 20ms.  Mains AC to Inverter AC switching under any load is basically the load current, with no abnormal phase difference spikes, even 40ms seems to make little difference.
It's interesting that we have have discussed the possible need for syncing when switching between Mains and Inverter under load, but in my real world testing, the real problem is when switching cold loads, either to Mains or Inverter.
This became even more apparent when I reverted back to a Manual Mains - Generator switch. There are a few reasons I did this, but that's for another post if anyone is interested, the Auto switch is great, but without Street power it won't be needed, and the Auto switch needs a separate housing as they are about 5mm deeper than standard DIN rail RCBOs and AC breakers etc, the manual switch is a perfect fit, and looks almost like 4 AC breakers, same size, unobtrusive and very neat in the din rail cover housing.
These Manual switches usually have a centre off position, the one recommended and supplied by the Sparky is the a HAGER SF263, apparently this seems to be the favourite when installing an Emergency Generator backup facility, which I'm informed, is happening quite a lot lately.
The SF263 is rated at 63A, Sparky had the data sheet and it's very good, especially the build quality when compared to the lower cost unit he had, and the cost itself is quite reasonable. The Fuse box Main AC breaker/disconnect is a 100A unit, so the SF263 as per the data, should have a 63A-C breaker between Mains and the SF263, and the same for the GEN Input, or lower depending on the Gen output and wiring. The easiest generator input is an isolated output type, which the Inverter Toroid transformer is, that means everything back from the GEN AC output is also isolated from the House AC Supply.
The SF263 data sheet and typical install labels for changeover switches indicate that the loads should be removed before switching. Loads then switched back on, usually via the circuit breakers in the Fuse box for the loads required, since this is obviously where the changeover switch is located, it only takes a few seconds.
I monitored the loads as the circuits were switched, and there are up to 400A peak DC inputs on the Inverter when switching circuits that have Inverter supplies, like Fridge and Freezers, SMPT devices like Computer and screen Plug packs, TV and other device standby loads, I would imagine a large number of incandescent lights and older fluros would also present high initial cold surge currents.
So dumping the lot at one go can see a peak DC input of around 580A, in my case that's less than half of the Inverters capability. But why stress it when it's easy to just switch the load circuits one at a time, worst case is then around 300A, which happens to be what two LCD monitors and a NUC-PC plug pack can draw on cold power on.
BTW a 2.7kW restive load powered first can reduces these SMPT cold start currents by around 30% to 50%.
Edited 2026-05-14 10:42 by KeepIS
NANO:Inverter V 8.2ksLinux AvrDude GUI script V4.1
KeepIS
Posted: 02:02am 14 May 2026
I've finally got some accurate power readings for the Inverter conversion efficiency, this is the efficiency to convert DC input power to AC output power and does not include Inverter idle power.
The efficiency is very high, with a prominently resistive AC load and a PF of 0.98, the conversion efficiency is close to 98% to 99% @ loads around 1.8kW and above, I have not measured much above 5kW, where wiring losses will lower it slightly.
Below 900 Watts, the AC load PF is incorrect, the HOIKI Power Analyzer won't calculate PF or power below 900W, and Standard AC power meters suddenly show a PF dropping down to 0.54 as power starts falling below 900 Watts, I could be wrong, but AC power may be incorrect, as I don't know if the calculation is based on an incorrect PF of 0.54.
Obviously the overall efficiency "with Idle power" is less at lower power, however at higher power the efficiency still gets up to 98.3%.
On Another subject, I've touched on this before with battery technology comparisons, and it seems to be continually ignored, one major advantage of LiFePO4 is the power Input/Output efficiency.
The efficiency for the amount of power needed to replace the power used in LiFePO4 is above 95%, and translates to less Solar power and shorter recharge times, which really becomes apparent in poor solar conditions.
Another forgotten parameter is the voltage drop with current and State of Charge, the lower the voltage drops, the more current is required to generate 230Vac, things start to sag fast, LiFePO4 after charging finishes (no solar), runs at around 53.4V under load, and drops 400mv overnight to 53v under low loads, and 600mv at 52.8V under a few kW at an SOC of 52%, depending on battery size and build quality.
BTW, some of my LiFePO4 batteries are almost 6 years old now.
I'm now currently running 11kW of panels as two arrays are off line while changes are slowly being made, getting old sucks, two of the "Poidas and wiseguy and others" Solar Charger design and PCB's, are being made, with another four to be made for future spares.
FYI: I made the mistake of looking at some AU forums discussing commercial installations and new rules and ripoffs, and there seems to be a religious belief that you cannot fully run "off the grid solar" on a 600sq block as there is no room for required panels, especially if the Home is all electric, as it could only last a few days, irrespective of where you live, they get quite agitated if you dare even suggest otherwise, "their calculations cannot be challenged."
Perhaps they also believe that panels only work if facing the correct direction and angle, I guess they also believe that Flat or East and South facing panels (roof slope) can't possible be of any real world use.
It's a clown world
Edited 2026-05-14 12:21 by KeepIS
Posted: 03:24am 14 May 2026
  Quote  there seems to be a religious belief that you cannot fully run "off the grid solar" on a 600sq block as there is no room for required panels
Have seen that too. A blanket statement like that does not account for the wide variety of circumstances.
On a block covered in trees (like mine) it holds up but for others without trees and with a large garage or shed enough panels can be installed. And they don't all have to face the sun as in overcast conditions (which is when you need the extra input) almost any direction will do.
Another point is the definition of "fully run off the grid solar". Just as the grid uses gas fired generators to plug occasional gaps in renewable energy supply, a small generator to top up the batteries occasionally does not invalidate the idea of off grid solar.
KeepIS
Posted: 04:13am 14 May 2026
Yes agree totally, you likely know my solar situation, one tree on the east side, but makes very little difference, 30% of the arrays are south facing, 30% flat, 30% north and the rest face West, in the future, another 6kW West facing will be added.
Two big advantage with 48V systems, just two panel series strings, and many sets of 4 panel arrays, with 2 series strings paralleled per array, and one 4 panel array per 60A Solar regulator.
Seven low cost Solar regulators, each panel array is only running at a maximum of 60% of the Solar Regulator capacity for a 4 panels array. The result is low stress and zero failures with lots of redundancy, and this panel configuration is also incredibly resistant to partial array shading and individual panel drop off, especially when compared to HV strings with many series panels.
This also allows instant indication if any panel in an array is under-preforming. We have been running 100% electrically off grid for over a year, and previously 80% off grid for a few years. Never once needed mains in any weather, including many days of rain and gloom, and that's while still using off grid AC like it was Mains AC.
I really feel for anyone confronted with trees and/or two story buildings around them.
I must stop posting long winded replies
Edited 2026-05-14 18:38 by KeepIS
Posted: 09:30am 14 May 2026
From Other Thread
  Quote  I occasionally test them with a "simulated person," a box containing two resistors, a 30mA or 50mA select switch, push test button, and an earth probe.
I have the Digitech powerpoint Earth leakage tester QP-2000, Its been a great tool for checking power points, found one with a missing earth.
  Quote  The simple "Inbuilt RCBO" test switch is OK, but it's not a real test of the circuit IMHO.
Exactly, I find that testing the entire circuit to see if it is actually wired correctly instead of been misled into thinking its all good, tested my friends setup, he said the safety switch works pressed the button yeah see it trips, I said plug this in and try again....no way the switch would trip even at 100ma, I asked where was the neutral bond? blank face....I guess I shouldn't have asked that.
I did find one safety switch on the house wouldn't trip either, had that sorted since.
Perhaps one of these should be in everyone's tool kit , I don't get nuisance trips anymore like when it was connected to the grid  except for the odd gecko triggering them.
  Quote  These Manual switches usually have a centre off position, the one recommended and supplied by the Sparky is the a HAGER SF263
Thats much better than the old Rotary Cam switch I have, its obsolete now as it only switched the 2 active's from grid power and linked the 2 together on the gen side to run the 2 lines on the house and shed.
I'm sure my friend will be getting a switch like the HAGER SF263 one posted above, though I couldn't see any way to turn the power off after or before the Meters...the sparky will charge more to pull the fuse at the street pole I guess.
My first LiFePO4 batteries build (manufacture) date are 7/2019. powered up to use on 1/2021
  Quote  BTW a 2.7kW restive load powered first can reduces these SMPT cold start currents by around 30% to 50%.
Interesting, didn't know it would have that much affect, I have quite a few of those little SMPS.
Edited 2026-05-14 19:35 by Revlac
Cheers Aaron
Off The Grid
KeepIS
Posted: 11:20pm 14 May 2026
Some of the small SMPS supplies are ok, I find the larger LCD monitor adaptors and Laptop / Mini PC adaptors have the highest cold inrush currents, likely larger cap values and lower circuit impedance, the largest cold inrush is from big SMPS Chargers and Bench supplies.
With the manual GEN-Mains switch, the centre OFF position, even though it has a very positive centre Hold Indent, is clearly stated as to not be used as a Safety OFF or Isolation position. Sparky said the specs require a breaker for Mains and GEN inputs before the Changeover switch Active terminals, with both located in the Fuse box with the Changeover switch. With breaker values at or below the 63A rating of the changeover switch, and obviously the GEN breaker lower to match the Generator rated capacity and the GEN cable rating, which in my case, the cable run calls for a 63A breaker, but we decided on a 45A-C for the Inverter output, although I think I could go lower. I've had a 25A-C in the shed for years and only tripped it once on startup current, and that was with a really Big VARIC. I'm sure you know the deal with Trip Time graphs for load and temperature trip conditions for those.
Besides the AC or DC Over-Current sensors in the Inverter always trip before any of the mechanical breakers
I finally found some metal 16 Cell battery boxes at a reasonable price, I only have to pick them up and then get down to transferring the Cells and BMSs etc, should look really neat when all done.
Edited 2026-05-15 11:11 by KeepIS
KeepIS
Posted: 05:20am 20 May 2026
Interesting few days of crazy weather and solar conditions.
Sunday afternoon 17th May: only 3.00pm, full charge but no solar.
No attempt to limit off grid power usage over the next 3 nights.
Monday morning: 64% SOC.
Monday added 5% charge to 69% SOC when solar output dropped to zero. Day started out full overcast and rain, but some solar, turned into dark gloomy and rain, no solar.
Tuesday morning: 33% SOC.
Tuesday evening: Day added 3% Charge, now at 36% SOC - very dark, gloomy and rain never stopped.
Wednesday morning 27% SOC:
Inverter DC input, no solar.
51.9V with 400W load
51.3V with 3.8kW load.
The weather was so bleak and dark that we had almost no solar output. A friend on a very large block a few miles away with 38kW of solar had to run the generator.
This is very abnormal for this location to have "ALMOST" a total loss of Solar energy reaching the panels.
We had a 110mm in the rain gauge here.
Wednesday now sunny, solar running between 140A and 160A @ 54.4V, I use a low bulk charge to limit charge current and, SOC is never near 100%, I carry out a top charge every year.
The interesting thing is the way the batteries behave at low capacity, three of the four 51.3V battery banks are around 6 years old, and they are fake EVE cells, they appear to have lost a little high SOC capacity (they were abused back then), but when they get down to around 68% SOC, they really start to power and hold voltage and SOC for much much longer, they would have gone another day and nigh with a little watchful reduction of unnecessary power usage under no, or little solar.
Edited 2026-05-20 15:24 by KeepIS
Posted: 12:18am 22 May 2026
I have about 9.5Kw of solar panels running across 3 charge controllers at the house, and still do see next to no output on some occasions with really dark weather usually worst just before rain, I had 7kw of panels before and had the same thing happen.
I will say the benefit of more panels comes into play when the cloud cover thins abit between rain and dark and now its almost enough to at least power the house with the occasional battery charge coming in, so yep a few more panels to be installed one day even if only switched on when weather is bad.
Oh before anyone gets up and says panels doing nothing is wasted power .....its not its just not collected like the water tank overflowing or the damns are full etc.
Perhaps another 4kw of solar if I find the space, and I agree with battery SOC and voltage reading, having seen this here as well.
Cheers Aaron
Off The Grid
KeepIS
Posted: 02:14am 22 May 2026
I have room for another 6 to 8kW of panels when the old solar in-feed system finally craps itself, 16 years and still going, inverter was mounted in full Western sun, LCD burnt out, but I can still see the green LED , and power to grid is still climbing each day. I'm sure it will last until the rebates are finally stopped in 2028, or we ask them to disconnect us from the grid, while the corporations still allow it .
In my case, I've never had this kind of low solar energy availability every day, almost all day, and for a few days in a row, well not over the past 6 years at least.
BTW I picked up the 51.2V battery cases, I also got a spare, now I can add another battery if / when some low cost 280A to 380A LiFePO4 cells appear, and the battery housings will all match.
jakesea
Posted: 05:44pm 25 May 2026
I thought, I would update you about my progress.
So far, everything works as expected on the bench. I followed the whole test procedure as described by Wiseguy and then setting up as described by KeepIS. All worked ok (nice, stable 232V sine wave) so I have tested it from my power supply that goes up to 53V 20A and then I connected a heating gun as the load. The fan of the gun was still working fine but when I increased  temperature the voltage on the output started cycling up and down and eventually the inverter turned off due to low battery. As I understand it, my power supply was not able to provide sufficient power to the inverter.
In short, it all looks great so far but I don't want to celebrate too early yet. I need to put it in a cabinet now and connect real power and real load to it.
I still have a few little questions on the back of my head.
When idle, the power consumption (read on the power supply) was going cca 3W up down from 27W to 30W; is it normal/typical? I used two chinese 10000uF 100V caps on each side; could they cause this? (I have already bought 10 new caps from DigiKey (6800uF 100V) and I will install them instead).
And then the chokes again. I use 6 cores of Magnetics 0077192A7   for each and I wound 5 turns of 10 strands of enamelled wire (cca 30mm2 in total). The strange thing is that the measurments range from 8 to 12uH but most of the times they read 9uH. In any case, the value is lower that I expected. Based on your earlier discussions in this forum I thought that it should be around 20uH. Could it be a crap DM (ZOYI ZT-102L ) that makes these measurments so inconsistent?
No blown fets yet so very happy so far
KeepIS
Posted: 10:14pm 25 May 2026
Great news it sound like everything is fine:
Most heat guns over here have a series diode for low heat setting, a really nasty load, some use PWM control but these are low cost and can still create bad loads for inverters, depends on unit, but they won't cause this inverter any problems except for a bit of toroid noise, and I'd expect the 20A supply to have problems, 2 x 10000uF caps are enough, it's possible that a quality cap might have a lower ESR and preform a little better, I'd doubt you will notice much difference though.
The inductance can read low on a standard meter, it's likely around 18uH to 19uH. ZIYO stuff I've tested are usually quite good, but again likely not with this lowish inductance.
A slight cycling variation in the idle current is common on the units I've built, but the idle is normally be around 23 Watts or less, and it depends on Transformer and choke inductance.
What is the %PWM at idle.
Edited 2026-05-26 08:17 by KeepIS
jakesea
Posted: 10:10am 26 May 2026
I have it running right now and PWM at idle is 75.5%.
53VDC in, 231VAC out, using 28W-30W.
4.7uF cap on the output and running through kilovac.
My transformer: secondary 118 turns of 4 in hand (dia 1.8mm; 10mm2 in total) and primary 15 turns of 50mm2 welding cable. Toroid core: OD 190mm x ID 100mm x H 120mm
I wonder why it's using so much more power that you say it should.
wiseguy
Posted: 11:08am 26 May 2026
And then the chokes again. I use 6 cores of Magnetics 0077192A7   for each and I wound 5 turns of 10 strands of enamelled wire (cca 30mm2 in total). The strange thing is that the measurments range from 8 to 12uH but most of the times they read 9uH. In any case, the value is lower that I expected. Based on your earlier discussions in this forum I thought that it should be around 20uH. Could it be a crap DM ([/QUOTE" target=_blank>nd 12 or 13 turns each on one core only. ie 2 toroidal chokes of 1 core ea with 12-13 turns and check idling power. You should be able to check up to ~ 400W without issues and check idling power and efficiency of at least a 250W load.
I lost some of my text. From a quick calculation with those cores you need around 12.5T for 22uH? Do you have 2 spare cores? Wind 12 or 13 turns each on one core only. ie 2 toroidal chokes of 1 core ea with 12-13 turns and check idling power. You should be able to check up to ~ 400W without issues and check idling power and efficiency with at least a 250W load.
I havent been following your build (sorry) is your toroid stacked too and how many cores in total ? Each reasonably sized Toroid will contribute ~ 8-10W of idling for each stacked core. I doubt if the capacitors are causing your issues just one loaded on each side of the inverter of the digikey caps would prove that.
The wandering up and down of the power value on idle is weird but not unusual - it does it on mine too and every one I have ever built. I wondered if it was a slight mains ripple bleed through from the Power Supply and as they are running asynchronously they drift in and out of sync. I never built a version capable of being synced & with sync software to test the theory.
Edited 2026-05-26 21:20 by wiseguy
Cheers Mike
jakesea
Posted: 11:27am 26 May 2026
Hi Mike, thanks for your input.
  Quote  is your toroid stacked too and how many cores in total ?
No, it is a single core I ordered directly from a manufacturer.
I gather you agree that the idle power usage should be lower, don't you?
Edited 2026-05-26 21:33 by jakesea
wiseguy
Posted: 11:37am 26 May 2026
Yes it should be lower - that was why I suggested using the 2 single core chokes with 12 or 13 turns to test if its the chokes causing it.  Also try a 2u2 on the output instead of 4u7 - I don't think it will make a heap of difference to the DC idle power but is does lower the 50Hz circulating currents in the Toroid - only whilst playing with the single core chokes - sounds weird but trust me.
Did you give the manufacturer all the winding details or just wattage and input/output voltage details?  Unless they are are told you are chasing lowish magnetising currents and efficiency they don't always give the most efficient design - in my experience.
Edited 2026-05-26 21:40 by wiseguy
Cheers Mike
jakesea
Posted: 11:52am 26 May 2026
I will do that although the idea of unwinding these chokes breaks my heart - they look so pretty
No, I didn't give them any details. I just ordered by the size that was suggested in the Ozinverter manual when I originaly built it.
Edited 2026-05-26 21:55 by jakesea
wiseguy
Posted: 11:56am 26 May 2026
  jakesea said  I will do that although the idea of unwinding these chokes breaks my heart - they look so pretty
If you dont have a couple of spare cores to try this just get one or two strands of copper wire even PVC coated wire and add the extra 8 turns to the existing 5 - hopefully you have a little space left for a few turns and try it, before you unwind what you have already - what if I am wrong lol.
We just want to get the idle power down - it may not look pretty for a rough trial but it should tell us if we are on the right track.
Edited 2026-05-26 21:59 by wiseguy
Cheers Mike
jakesea
Posted: 12:06pm 26 May 2026
I am tweaking with the caps at the moment and if this doesn't help I will do what you suggest - thank you for the advice.
Interestingly, I have swapped 4u7 cap with 4uF and it appears that the power went down by cca 0.5W
I will try a smaller one now
     Page 33 of 35
