Local Time 09:07 14 Apr 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mmedit for linux cinnamon
     Page 4 of 5
stanleyella
Posted: 04:09pm 01 Mar 2026
  TassyJim said
  Bryan1 said  So after my first failed attempt with MMEdit I deleted everything and re extracted the folder in /home/Bryan/mmedit5. Now trying to get MMedit to load an error comes up and fails to start.
I am working on a version for RPi without the need for webkit stuff.
Just waiting to create another clean image for the RPi.
If that works satisfactorily, I will do the same for other Linux.
You might still have difficulties with qt5. More recent distributions have gone to qt6 and removed it from their repositories.
"If that works satisfactorily, I will do the same for other Linux.". NO!!! mmedit on linux mint works great as is.
"If you want desktop shortcuts, run dtopscuts.sh.". shortcuts to mmedit and mmcc appear but just open files in file manager.
Thanks for your persistence sorting rpi mmedit... rpi programming rpi :)
stan
stanleyella
Posted: 04:33pm 01 Mar 2026
@Jim. Brill! latest zip tar version WORKS! ... extracting was confusing, just zip was easier. Try flashing code next. Thanks again. regards stan
edit, just flashed the lissajours code and it works. got to remember groups dialup usb for it to use usb to ttl
Edited 2026-03-02 04:08 by stanleyella
stanleyella
Posted: 07:06pm 01 Mar 2026
Tried a few other flash progs and rpi mmedit working so far.
dddns
Posted: 08:45pm 01 Mar 2026
Nice :)
@Jim
just a thought: could it be possible to directly call the system default web browser with the help html instead of a GTK window?
edit: I don't own a RPI so could not test
Edited 2026-03-02 06:46 by dddns
Posted: 09:21pm 01 Mar 2026
  dddns said  @Jim
Yes but in my experience it has been difficult to come up with a method that works for all incarnations of Linux.
I am working on it.
Posted: 05:19am 03 Mar 2026
Fascinating thread.
@ Stan: Well done on keeping on with your tinkering.  MANY people just give up on Linux, if it does not work right away, and the rest of them tend to give up if you DARE to mention the terminal!
I speak from experience - I was one of those a few years ago!
I will continue to watch this thread with interest.
Posted: 08:16am 03 Mar 2026
  TassyJim said  Yes but in my experience it has been difficult to come up with a method that works for all incarnations of Linux.
Maybe something like
system("xdg-open filepath.html");
You may want to close stdout & stderr (if they're open to anywhere the user can see) to suppress unwanted output.
You may be best using a full path to the file.
Edited 2026-03-03 18:17 by JohnS
Posted: 08:48am 03 Mar 2026
Yes John, xdg-open seems to be the best contender.
I need to do some more testing but so far...
stanleyella
Posted: 03:39pm 03 Mar 2026
  Grogster said  Fascinating thread.
Trixie os linux can be frustrating for example the config.txt file has moved from /boot/config.txt to /boot/terminal/config.txt and is now "read only"!
I used chmod a+w /boot/terminal/config.txt in the terminal and ok. then right clicked config.txt and properties and it's accessible but when I edit it and try to save it says this file is read only.
The Trixie OS is on a 120G usb3 ssd and I used to plug into win pc to edit config.txt but that pc win 11 went tits up so it's linux mint and the config.txt shows as empty file. it's easy to get frustrated, well for me it is:)
Posted: 04:04pm 03 Mar 2026
To be fair, that DOES sound frustrating.
(And puzzling)
dddns
Posted: 04:59pm 03 Mar 2026
@Stan
Look at the file permissions in /boot/terminal:
ls -la /boot/terminal
I guess it's all root/root
In your filemanager right click and choose "open as administrator" and then edit it or use sudo in the terminal like
sudo xed /boot/terminal/config.txt
Edit:
Debian seems to use as default the text editor gedit so:
sudo gedit /boot/terminal/config.txt
Edited 2026-03-04 03:27 by dddns
Posted: 08:16pm 03 Mar 2026
sudo nano /boot/firmware/config.txt
also works if you prefer nano.
stanleyella
Posted: 08:35pm 03 Mar 2026
No, says read only, had tried that first option, thanks.
read it was the ssd failing but tried flash sd card and still new version is read only
stanleyella
Posted: 08:41pm 03 Mar 2026
  dddns said  @Stan
Edit:
stan@raspberrypi:~ $ sudo gedit /boot/terminal/config.txt
sudo: gedit: command not found
stanleyella
Posted: 09:18pm 03 Mar 2026
I haven't got admin access yet on rpi. seems a secret and why is config.txt now read only... stop people overclocking?
a search and others have tried to make config.txt writable with all methods and failed. weird. I'm not the only one. I'm using fresh images from rpi imager.
Jim's file zip/tar was lots of bother to extract. I tried newish Twister os 64bit on rpi but it couldn't extract mmedit.. gave up on it when it crashed.
Edited 2026-03-04 07:34 by stanleyella
dddns
Posted: 09:20pm 03 Mar 2026
Stan,
I don't have an arm64 platform so I installed Trixie for amd64 with cinnamon in a VM in order to help here.
In this version gedit is the default text editor.
Possible solutions:
Please find out by looking in accessories which editor is installed on your machine and replace gedit with yours in the command line.
The ASCII based editor "nano" should be installed, you could try
sudo nano /boot/terminal/config.txt
Good luck!
p.s. of cause there is vi/vim but that's a pain to use and to explain
dddns
Posted: 09:27pm 03 Mar 2026
  stanleyella said  I haven't got admin access yet on rpi. seems a secret and why is config.txt now read only... stop people overclocking?
I think it is owned by root and others like your user have only read access. You can open it but not change it.
Did you try? In your filemanager right click and choose "open as administrator" and then edit it
dddns
Posted: 09:35pm 03 Mar 2026
I almost can't believe that overclocking is configured in this text file. I'm interested, please post the content
Posted: 09:59pm 03 Mar 2026
# For more options and information see
# http://rptl.io/configtxt
# Some settings may impact device functionality. See link above for details
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Automatically load initramfs files, if found
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
[all]
stan,
at a command prompt
I was able to edit and save the file without any issues
dddns
Posted: 10:10pm 03 Mar 2026
Many thanks Jim!
     Page 4 of 5
