Local Time 11:43 21 Jul 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic ANSI - MMBasic on Mac/Windows/Linux in a terminal
     Page 4 of 6
ville56
Posted: 05:04pm 09 Jun 2026
Use the image from the link above with 40MHz psram clock. Did cure it for me.
73 de OE1HGA, Gerald
jvanderberg
Posted: 05:35pm 09 Jun 2026
I just pushed a release build that sets things to a default of 40MHz as that seems generally safe and really isn't going to impact performance much.  If somebody wants extreme mmbasic performance, they can tweak the build themselves :)
     https://github.com/jvanderberg/PicoMiteAllVersions/releases/download/latest/MMBasic-Anywhere-esp32-s3-octal-merged.bin
Edited 2026-06-10 06:22 by jvanderberg
gadgetjack
Posted: 01:39am 10 Jun 2026
I got a little time to play with my board tonight. Got the sd card option set no problem. When I tried the vga option , it goes into a re-boot loop you can not get out of. I reloaded I think about 9 times and tried different pins , 3bit option, full vga option , but get the same re-boot loop. Am I missing something or am I using the wrong bin file? I used the octal for my type board. Kind of lost at this point. Any help would be great!
Jack
jvanderberg
Posted: 03:22am 10 Jun 2026
I've changed a lot recently and haven't run my VGA setup to smoke test, it shouldn't crash, at the worst it just won't work - so that suggests maybe there's a memory issue.  Memory is oddly tight on these boards.
ville56
Posted: 05:11am 10 Jun 2026
  jvanderberg said  I just pushed a release build that sets things to a default of 40MHz as that seems generally safe and really isn't going to impact performance much.  If somebody wants extreme mmbasic performance, they can tweak the build themselves :)
just flashed that version and the psram bug seems to be back. I've attached the boot-logs
1) log for crash-reboot with active wifi option
crash-wifi-2.zip
2) log for normal boot with no wifi option set
no-crash-no-wifi-2.zip
jvanderberg
Posted: 06:43am 10 Jun 2026
crash-wifi-2.zip
That appeared to have been a different issue related to WPA3 - I've pushed a fix.
The VGA boot loop is also fixed.
And wifi should now support TLS for web connect and MQTT
ville56
Posted: 09:15am 10 Jun 2026
the fix is not working, can't connect to wifi. Please see log
wifi-fail-octal.zip
Also tried with quad version. This version doesn't find psram, which is expected, but also fails with a buffer allocation on wifi connect.
Doktorn
Posted: 10:13am 10 Jun 2026
WaveShare ESP32-S3-PICO with MMBasic-Anywhere-esp32-s3-quad-merged.bin
MMBasic Anywhere (esp32-s3) 1.1.1
MMBasic Anywhere - Copyright 2025-2026 Josh Vanderberg
Bytecode VM, HAL refactor, host/WASM/stdio ports
ESP32-S3 REPL.
Profile: GENERIC
option wifi "dd-wrt","********"
I (28287) mm_options: saved options to raw mmslots sector
ESP32-F81004 connecting to WiFi...
W (28307) wifi:malloc buffer fail
E (28307) wifi:Expected to init 6 rx buffer, actual is 5
W (28317) wifi_init: Failed to unregister Rx callbacks
E (28317) wifi_init: Failed to deinit Wi-Fi driver (0x3001)
E (28317) wifi_init: Failed to deinit Wi-Fi (0x3001)
failed to connect.
jvanderberg
Posted: 05:31pm 10 Jun 2026
Ok, the memory issues should be fixed with the latest release
They've been test on two my boards locally and pass my networking smoke tests.
VGA should be working, though I'd call it more a WIP. It works but tends to glitch a bit when the CPU bogs down. Still very usable.
The LCD panel support is now more standardized and re-uses the pico panel drivers (as they are the same hardware), so if you have a panel attached, and it's one of the existing supported panels, it *should* work with the proper 'options' settings.
ville56
Posted: 06:31pm 10 Jun 2026
Connects now reliably to wifi, thanks!
but, compared with the runtime for sieve.bas for the version tested before (see my post from 08:23am 09 Jun 2026) the current version is about 10 times (!!!) slower now.
  ville56 said
Sieve(6000) in  875.956        ms
Sieve(6000) in  755.13 ms
Sieve(6000) in  1135.285       ms
Sieve(6000) in  2314.811       ms
Sieve(6000) in  1084.235       ms
Sieve(6000) in  907.463        ms
Sieve(6000) in  799.189        ms
Sieve(6000) in  724.963        ms
Sieve(6000) in  2404.137       ms
Sieve(6000) in  1571.621       ms
Sieve(6000) in  1132.949       ms
Sieve(6000) in  946.375        ms
Sieve(6000) in  813.296        ms
current values with the same hardware are
Sieve(6000) in  9891.012       ms
Sieve(6000) in  10135.867      ms
Sieve(6000) in  9780.164       ms
Sieve(6000) in  10076.767      ms
Sieve(6000) in  10024.839      ms
Sieve(6000) in  9973.238       ms
Sieve(6000) in  9842.318       ms
Sieve(6000) in  10031.271      ms
Sieve(6000) in  9616.662       ms
Sieve(6000) in  9923.624       ms
Sieve(6000) in  10074.079      ms
Sieve(6000) in  9763.779       ms
Sieve(6000) in  10168.916      ms
Sieve(6000) in  9672.678       ms
Sieve(6000) in  10051.345      ms
Sieve(6000) in  9628.35        ms
just for comparison ... running that on a RP2350B at 240 MHz gives 283 ms.
Edited 2026-06-11 04:35 by ville56
jvanderberg
Posted: 07:02pm 10 Jun 2026
I think there's some excess polling of the network stack going on.  I think turning off the wifi stack should fix it, but I'll push a fix in a bit.
ville56
Posted: 07:56pm 10 Jun 2026
true, without wifi connection it is
Sieve(6000) in  1033.489       ms
Sieve(6000) in  3543.409       ms
Sieve(6000) in  1642.319       ms
Sieve(6000) in  1162.7 ms
Sieve(6000) in  2522.896       ms
Sieve(6000) in  1707.49        ms
Sieve(6000) in  1461.504       ms
Doktorn
Posted: 08:11pm 10 Jun 2026
Latest version, no errors on startup. Wifi OK, TLS OK. Running "server.bas"
for half an hour with no issues. One thing, I have setup quite large
longstring buff%(16384/8) but it will only fill to about 4k. no errors though.
/Lasse
gadgetjack
Posted: 08:34pm 10 Jun 2026
I got some free time today and tested the latest bin file on my board. VGA came up first try !! No loop ! Now I have a lot of playing to do with this board. Big thanks for all of your help on this. I had almost gave up using those esp32s3 boards.
Jack
jvanderberg
Posted: 08:39pm 10 Jun 2026
I just pushed a patch to decrease the wifi polling overhead.  Give it a few minutes to deploy.
I think most of the moles have been whacked. If I knew how hard this would be I don't think I would have tried it :). Lots of complexity in this little platform.  But hopefully all this makes it a lot easier for other people to make new ports.
The amount of shared code between the esp32-s3 platform and the original PicoMite source is quite large.
gadgetjack
Posted: 08:46pm 10 Jun 2026
I am amazed at the code that comes out of these 3 smart men. Some great fun for all of us on the sweat of these guys and their code. I tip my hat to all three of you.
Jack
jvanderberg
Posted: 08:48pm 10 Jun 2026
Glad somebody else got VGA working.  I am working on some VGA improvements, including driving the VGA signaling at 320x240 for better performance.
I've got it working on my 15 year old Dell 30" monitor, so it should be pretty compatible.
gadgetjack
Posted: 09:48pm 10 Jun 2026
I have that same monitor on my shelf. I use it a lot for testing.
ville56
Posted: 06:50am 11 Jun 2026
  jvanderberg said  I just pushed a patch to decrease the wifi polling overhead.  Give it a few minutes to deploy.
the latest octal s3 build runs fine now. The only issue I still find is the big variation in runtime. Running the sieve in a loop it varies in the order of 1:5 (~600 ms to ~3000 ms)
Thanks anyway, great work.
gadgetjack
Posted: 06:00pm 11 Jun 2026
I have tried several usb keyboards but keep getting a "usb keyboard not enumerated yet" error. Is it not ready yet? Or do i just have the wrong keyboard to use.
     Page 4 of 6
