Posted: 12:14am 19 Mar 2026 Copy link to clipboard
Godoh Guru
I have just bought a new log splitter. It has a 2kw motor with a hydraulic pump attached. My inverters won't start the motor, so I am wondering if anyone here has experience with using soft starters on single phase motors. The motor is a capacitor motor so i am wondering if a soft starter will work on it. I have tried a 3kw Latronics inverter on it and it just goes out on overload straight away. My home made inverter with a 5kw board and home made transformer tries to start it but it will not get up to speed.It goes out on overcurrent too before the motor gets to full speed So I am thinking that a soft starter may help it get running. Or alternately maybe some sort of off loader valve on the hydraulic pump, if there is such a thing. Any help appreciated Pete
Posted: 12:33am 19 Mar 2026 Copy link to clipboard
Revlac Guru
Hi Pete, I haven't tried any of those cheap sort start modules myself, I had thought someone would have by now, be interesting to find out as its not that much to them. Would like to convert my block splitter to electric as well this like most others open-center systems always have oil flow so no much point adding any unloader valve. Closed-center systems are always under pressure, but oil does not flow until you activate a lever asking the system to perform, I have this on one tractor and in a PITA, when other parts of the tractor are open center valve.
Posted: 01:22am 19 Mar 2026 Copy link to clipboard
Godoh Guru
Hi Aaron, thanks for the reply. I have ordered a cheap soft starter to see it that will work. I will see how that goes. My inverter has no problems with my air compressor but it is only 1600 watts from memory. So if the soft starter doesn't work I may have to go to a smaller motor. Cheers Pete
Posted: 03:33am 19 Mar 2026 Copy link to clipboard
KeepIS Guru
On the home made inverter, how did you calibrate over current trip?
Is it possible that you may have OC set a tad low. Depending on the design and DC operating voltage, a 5kW inverter with transformer output should start a 2kW motor.
Posted: 05:21am 19 Mar 2026 Copy link to clipboard
Godoh Guru
Hi KeepIS. The home made inverter has an aliexpress board, there is a current adjustment but it is one of those multi turn pots. It has no instructions on how to calibrate it at all. I have set the voltage settings by adjusting the pots while using a benchtop power supply, so the high and low voltage settings work fine. But current adjustment doesn't really seem to do much. The aliexpress board is a 5kw board, it runs my other stuff fine. But with the new splitter it just spits the dummy. Honestly I have no ideas on how to load the inverter up to set current settings, I don't have a big enough dummy load to use. My battery bank is a 24 volt 660 ampere hour VRLA bank. Pete
Posted: 06:33am 19 Mar 2026 Copy link to clipboard
KeepIS Guru
The current settings don't appear to do much because of the limited adjustment range some of these inverters have, it mainly changes the upper trip limit.
Running at 24 volts DC places a higher limit on how much short-term peak current the FETS can handle, so in this case, I think it best to just let sleeping dogs lie. It was just a thought, wish I could be of more help.
Mike.
Posted: 07:07am 19 Mar 2026 Copy link to clipboard
phil99 Guru
If the soft-starter is a 2 wire type it is best to wire it in series with the motor main winding only. You want full volts across the start winding and its series capacitor to get enough phase shift for the required starting torque. The capacitor limits the start current in that winding to little more than its normal running current.
If the soft-starter is only wired in the supply to the motor there may not be enough starting torque to turn it at all.
Posted: 07:21am 19 Mar 2026 Copy link to clipboard
Bryan1 Guru
G'Day Pete I do have a couple of soft starters here and below is a picture of one
Regards Bryan
Posted: 08:01am 19 Mar 2026 Copy link to clipboard
Godoh Guru
Thanks phil, I will have a look at the motor tomorrow. I think it only has one capacitor, so it must stay in circuit all the time. Sounds like a good plan to put the starter only in with the run winding.
Bryan have you tried using one of those starters you have? That looks like it is for an air conditioner. I can't quite figure out what they are doing with that starter, but it looks like they are switching the start winding out of circuit after it starts. Doesn't quite make sense to call the capacitor the run capacitor in that case. Most motors with only one capacitor and no starting switch just leave the cap and start winding in circuit all the time.
Thanks for the input Mike. I have ordered a two wire soft starter, and will give it a try wired into the run winding only.
I did think that I may be able to use a drill and run the motor up to speed a bit then hit the start button. I may try that tomorrow. Once it gets going the inverter should have no problems, I hope.
Thanks Pete
Posted: 09:15am 19 Mar 2026 Copy link to clipboard
Revlac Guru
A changed the air compressor over too electric a month or 2 a go, it had a 8Hp ICE on it now 2Hp Electric motor 1400RPM and it has centrifugal start and 1 capacitor, with the start switch its 36A starting, when the switch failed and rotor locked I measured about 30A, the inverter in the shed starts this motor on the Air compressor quite well, even turned it off just before full pressure then back on again, it will pull a lot from the 48v battery banks, (a few old 4WD FLA batts and some old (secondhand) used and abused 200Ah LiFePO4)
The other motor I might use for the block splitter is 2.2Kw 2900Rpm (capacitor start no centrifugal switch) but much easier to start, compared to the lower power motor on the compressor.
Pete, Do you have a clamp meter with inrush measurement? It would be nice to find how much difference it makes using a soft starter, on the other hand if the motor starts and runs after putting in the soft starter, well that's good enough.
Yep done that a few times with some rewired 3phase motors. Edited 2026-03-19 19:23 by Revlac
Posted: 08:23pm 19 Mar 2026 Copy link to clipboard
Godoh Guru
Hi Aaron, I have a clamp meter, I don't think it does instantaneous measurements, but I do have an old analog one that I can check the inrush current with. I will have a look at what the motor is drawing. Good to know that you have used the drill method, I also have an air gun that I could use, so may try that as it has heaps more torque. The motor on the splitter is a 2 pole jobby too, 2800rpm. I have to go to town today but will play about this afternoon and see if I can get some measurements. cheers Pete
Posted: 11:17pm 20 Mar 2026 Copy link to clipboard
Godoh Guru
I tried using my air rattle gun today to start the wood splitter motor, and I am happy to say that it worked great. The motor started well and continued to run no problems on the inverter. It doesn't look like it needed much help to get it up and running. So when the soft starter turns up I will connect it to the run winding and see how it goes. I am thinking if the soft starter doesn't do the job then I may try adding a Start capacitor into the circuit and use an electronic starter switch. I may experiment with a start capacitor first with just a toggle switch first to see if it works. But the good point is that with a bit of mechanical assistance from the air gun it starts well and runs great. Thanks for the inputs and help Pete
Posted: 01:03am 21 Mar 2026 Copy link to clipboard
phil99 Guru
Something I forgot to mention, if the motor isn't new measure the value of the start capacitor. A few times I have encountered motors where the measured capacitance was much less than the marked value. Worth testing.
The reduced starting torque results in a slower start at full mains volts but if the voltage sags with the high inrush it may not start at all. Eg. on a long extension lead it may just sit and hum till the overload trips. Or in your case the inverter shuts down.
Cutting open those caps. open found they had 2 or 3 smaller caps inside, with one or two open circuit.
Posted: 03:19am 21 Mar 2026 Copy link to clipboard
Godoh Guru
Hi Phil, it is a new motor. I will try it with a larger capacitor added as a starting cap and see how that goes. If that works then I will get an electronic starting switch for it. For now it is working with the air gun spinning it up a bit then hitting the starter. Once I start it it runs great. The capacitor on it at the moment is 50 uf , I think I have a much larger motor start cap in the shed so will dig it out and see how that goes. I know it only needs to be in for a second or two, so will just experiment and see. I have a short 15amp lead that I am using for it, so no long leads. I have seen many air compressors killed by long leads. Cheers Pete
Posted: 01:08am 01 Apr 2026 Copy link to clipboard
Godoh Guru
Just to report back, I tried a bigger capacitor as a starting cap but it did not help at all. The soft starter module turned up yesterday and it is also a failure. I tried it just connected to the run winding, but no go I also tried it connected to both windings but still no go. So I am back to spinning the motor up to speed by the air rattle gun and hitting the starter. As that works and i will only be using the splitter at the shed then that is the way I have to go. Pete
Posted: 12:25am 02 Apr 2026 Copy link to clipboard
Solar Mike Guru
We have a similar problem at our off grid site, the under ground septic tank has a pump in it that grinds + pumps sewerage from the tank to council system across and under the road.
The pump won't start off our 6KVA low frequency inverter, but runs off the diesel generator; real pain having to start the generator several times a week just to run the pump. Was thinking of making a physically small but high power 48dc-230vac inverter, that was phase locked to the main inverter; start the pump on that and switch over to the main inverter after 3-4 seconds. Have a small toroidal core approx 1.5KW continuous rating, it may run at > 8KVA for a minute or so before it heated up too much.
Could replace the pump for a lower powered one, but they are very expensive, similar could replace the main inverter with a larger one, again expensive.
Mike Edited 2026-04-02 10:25 by Solar Mike
Posted: 12:30am 02 Apr 2026 Copy link to clipboard
Godoh Guru
Hi Mike, I don't know if you know this or not. I was given a Selectronics Pro 3kw inverter. It has inputs for generators on it. I am wondering if I can do similar to you and connect another inverter to the generator input and use them both in parallel?
I am thinking that if the inverter has the ability to synchronise with a generator then it should be able to synchonise with my 4kw battery inverter. Obviously I don't want to blow the inverters up, but if they can work together then that would be great.
( it says that if the load is larger than the gen set then the inverter can supply the required power needed to run the load)
Posted: 03:05am 02 Apr 2026 Copy link to clipboard
Bryan1 Guru
Congrats on the Selectronic inverter score Pete We have a Selectronic SA32 inverter on the house array that has been going since 12/04 and not missed a beat.
If you don't have the manual for the inverter you should be able to scroll thru the menu list to enable/disable features.
