Forum Index : Electronics : Transformer core flux offset problem - continued.
   Page 6 of 6
Posted: 05:49pm
15 Nov 2026
analog8484
  poida said  516 was chosen as a starting point when I first did some testing. I found it near enough. Over time I think the zero point changed a little.
The LEM current sensors do drift, mainly after copping a large current pulse
which then alters the zero point in a sort of permanent way.
Interesting.  I didn't know the LEM sensors can be permanently affected like that.
  poida said
In my view now is not the time to worry about this sort of thing since
I am not presenting a completed project with parts list.
I am showing results of experimentation and a simple to use sensor is ideal
for my needs.
Totally agree it's not time yet to focus on such things.  Just curious if it's something to keep in mind as potential cause of odd behavior.
  poida said
I wonder if there could be a self zeroing primary current signal design
that might be used when we build inverters incorporating this control?
Maybe using sample and hold function, a differential amp, a common signal source,etc.
that does have a zero offset but it is subtracted out to nil from the diff amp.
I had thought about such self calibration that the inverter could do periodically or during startup.  I think it would probably require more switches/relays (e.g. disconnect the output, connect the sensor inputs to ground, etc.).
Posted: 06:14pm
15 Nov 2026
analog8484
  poida said
with diode in circuit:
V1 445, V2 500 and about 580W DC input
it looks like this:
Congrats on a great milestone.  Great to see it working with the dreaded hair drier load.  The waveform is much nicer than what Keepis posted for his hair drier IIRC.  Perhaps Keepis could test soon.
I believe the control enhancement for unbalanced loads is now better than what's available in many commercial LF inverters including Victron and Schneider.  Assuming the required add-on HW components are cheap enough at scale, I would not be surprised if it shows up in Chinese LF inverters in the near future
Edited 2026-11-16 04:16 by analog8484
Posted: 10:42pm
15 Nov 2026
Re the current sensor zero offset.
A partial solution may be at power-up, before driving the MOSFETs, measure and save the current sensor output.
This wont fix drift that occurs while running, so not much help for an inverter that is running all the time as the high peak current of motor starts will likely cause a change in offset, but for a standby inverter may be of some value.
An a place to start experimenting for a fix while running might be to compare the positive and negative peaks. When they are "almost" the same assume they are actually exactly the same and set the zero current point halfway between. Defining "almost" may be tricky.
  Quote  For some reason the hair drier applies a variable load, pulling differing amount of current from cycle to cycle.
A possible explanation may be turbulence in the airflow combined with a significant temperature coefficient of the resistance wire in the element.
Fluctuations in the airflow will vary the rate of cooling of the wire causing the resistance to vary.
Nickel and chromium are getting expensive so perhaps cheaper alloys are being used in consumer products. For it's intended purpose such fluctuations don't matter.
Posted: 06:14am
16 Nov 2026
poida
Phill99:
I like that idea (before AC PWM, get primary winding current sensor zero)
everyone:
the last test was with a a hair drier but this one does not use
diodes to reduce power at full power setting. I had to simulate this
by using the switched inline diode when running it at FUL POWA!
It was nice to see this idea scale from 100W to 400W to 1000W+
   Page 6 of 6
