JAQForum Ver 26.09
   Page 19 of 28
Posted: 05:04am
07 Mar 2026
tinyt
  Bryan1 said
  tinyt said
  Bryan1 said  TinyT the resistor bank is out of circuit and on turn the current charging the caps is only 50mA
Picoverter on/off switch is at off I assume? yes when Vbat matchs the PSU I turn on the nano
If off what is the current when you switch it on?
50 mA
Put back resistor bank and ribbon cable and repeat.
Also measure voltage across the 120 ohms resistor.
Edited 2026-03-07 15:06 by tinyt
Posted: 05:14am
07 Mar 2026
Bryan1
Ok the resistor bank voltage matched BV and settled 4 volts below the PSU voltage, now when the nano is turned the voltage quickly drops to 10 volts with a 200mA current draw. So turned it off
Posted: 05:28am
07 Mar 2026
tinyt
  Bryan1 said  Ok the resistor bank voltage matched BV and settled 4 volts below the PSU voltage, now when the nano is turned the voltage quickly drops to 10 volts with a 200mA current draw. So turned it off
So looks like when the TIP41/TIP42's are driven by the nano, is when voltage (24-10 = 14) drops in the resistor bank, the way I understand it.
The TIP41/TIP42's drive the mosfet gates which are high impedance unless some are leaking/shorted.
I don't want to say this and I could be wrong, but looks like the power board needs some serious troubleshooting.
Posted: 06:10am
07 Mar 2026
Bryan1
Just did some resistance measurements now with nano off the tip31 pins are 17 Vbat 17.7 volts now when the nano is turned on the voltage dropped to 10 volts 3.9 4.4 3.8 volts across the tip31
TIP42 on the right side of the board
pin 1 (outside pin) to pin 2 (centre pin) 9.9K
pin 1 (outside pin) to pin 3 ( inside pin) 11.8K
pin 2 to pin 3 1.94K
TIP41
pin 1 to pin 2 11.6K
pin 1 to pin 3 11.8K
pin 2 to pin 3 259K
TIP42 on the left side of the board
pin 1 to pin 2 9.9K
pin 1 to pin 3 11.9K
pin 2 to pin 3 1.9K
TIP41
pin 1 to pin 2 650K
pin 2 to pin 3 350K
Posted: 08:39am
07 Mar 2026
KeepIS
  Quote  the resistor bank voltage matched BV and settled 4 volts below the PSU voltage, now when the nano is turned the voltage quickly drops to 10 volts with a 200mA current draw. So turned it off
You have 60,000uF of capacitance across those FETS, you have at least a 2000 amperes discharge surge available from those caps.
If you charge the power board, "And THEN enable the Nano controller", you will destroy things if those FETS switch hard on from a fault in the controller or power board.
Apology if I misunderstand what you are writing, I won't mention this again!
Posted: 10:43am
07 Mar 2026
mab1
  tinyt said
  Bryan1 said
  tinyt said
  Bryan1 said  3.44 volts measured on the left pin.
That is too low, maybe your zener diode is not 18 volts. Measure the other two pins of the TIP31.
And put back wires 1 and 2.
OK took the ribbon out and tested the zener diode and 17.7 volts so the zener diode is correct mate.
If your battery voltage is 24v-28v, that 120 ohms 5 watts resistor should be lower in value, maybe close to 60 ohms.
Edit: But if your final battery voltage is 48-56 volts, then you have to restore it to 120 ohms.
That's a very good point: at Vbat= 24v and R64=120ohms you're going to have less than 50mA drive current for all four totem pole drivers. 18 or 22ohms might be better for R64. R54 (r54 on the schematic, but looks like r64 on tinyt's pcb drawing) should be lower too: maybe 1k instead of 10K to provide enough base current for tip35.
But i'm thinking it may be better if the powerboard was returned to the test bench, for better access for testing; once it's outputting 13v ac between vs1 and vs2 on the bench, it may be ready to go back in the cabinet with the big torroid.
Edit again:
Even if the above resistors are part if the problem, there has to be another issue causing the excessive current draw.
Edited 2026-03-07 20:59 by mab1
Posted: 11:13am
07 Mar 2026
tinyt
I think that 120 ohms 5 watts is there for a 48 volts battery to spread the heat between it and the TIP31/TIP35 used as a linear regulator.
Here is an idea, only for your 24 volts psu with bank resistor testing:
Temporarily jumper with a wire across the 120 ohms 5 watts resistor and re-do your testing.
Edit: You might also need to change r64 from 10k to 1k per mab1's suggestion.
Edited 2026-03-07 21:33 by tinyt
Posted: 11:12pm
07 Mar 2026
Bryan1
Ok put a wire in across that 120 ohm 5 watt resistor and when the nano was turned on dropped to 10 volts again with a 204mA current draw,
Now measuring the TIP31 wires
pin 1 switching and 9 volts the highest
pin 2 10 volts (VBat)
pin 3 switching and 10 volts the highest
18 volt zener diode 10 volts (VBat)
So that is an improvement on yesterday and changing R64 to 1K is the next job so once again the power board needs to come out.
Edited 2026-03-08 09:13 by Bryan1
Posted: 12:34am
08 Mar 2026
Is the 200Ω/3 cap charge resistor getting bypassed when the capacitors have charged up?
If it is and the power supply current is below your set limit something else in series must be dropping the volts.
A high resistance join  or a burnt track? Test everything between the power supply and the MOSFETs.
Posted: 01:02am
08 Mar 2026
Bryan1
Phill I just measured the resistance of the resistor bank and with 67 ohms if I'm right that will allow 358mA of current thru the resistor. Now when it does drop down in voltage I'm seeing 200mA which is within the available current.
So no the resistors aren't get bypassed.
Now I am on setting the power board up externally and I have connected some joining cable so the chokes and toroid are online for testing.
Posted: 01:39am
08 Mar 2026
tinyt
Another thing to try:
This is assuming your test power supply can be current limited to around 300mA.
Transfer the resistor bank to be in series with the choke-transformer-choke circuit.
So, it will be VS1-resistorbank-Choke1-transformer-Choke2-VS2
This way the resistor bank will limit current going between VS1 and VS2.
Then you can measure/scope AC voltages across:
VS1 - VS2
Resistor bank
Transformer
If using the scope, make sure your scope has its probe ground isolated from mains ground. Use only one CH1 probe. Connection of probe pin and ground should be the same is if you are using a DMM.
Edited 2026-03-08 11:41 by tinyt
Posted: 02:32am
08 Mar 2026
Bryan1
Well got every setup the way it was before
Now I have changed out R54 for 1K and soldered in a short for the 120 ohm resistor so those changes have happened.
Posted: 02:47am
08 Mar 2026
V = I * R = 200mA * 67Ω = 13.4 Volts drop across the resistors. Measure it if you want to be sure.
28V - 13.4V = 14.6 Volts. That is all your inverter has to work with. You are getting all it can give.
You need to bypass the cap. charging resistor after the caps are charged and before starting the inverter.
Posted: 03:28am
08 Mar 2026
Bryan1
Well just tried it out and I made an inline switch to supply VBat, so once the BV got to the voltage of the psu I closed the switch then turned on the nano.
It dropped to 10 volts with only 1.7 AC volts at VS1 and VS2
Now measured those fast diodes when was running now the one where the arrows pointed on the left was 17 volts and the other one 7 volts.
Now the TIP31 pins were 8 volts 9 volts 8 volts
I did do a test with the choke cables left off and the result was the same 1.7 AC volts so yes the problem looks to be in the power board.
Edited 2026-03-08 13:36 by Bryan1
Posted: 03:43am
08 Mar 2026
tinyt
Verify that D1, D7, D18, and D19 are at the corners of the PCB.
If they are, use your scope CH1 probe and do the following VERY CAREFULLY:
1. probe GND to power board ground probe tip to D1. capture and post scope screen.
2. probe GND to power board ground probe tip to D7. capture and post scope screen.
3. probe GND to power board VS1 probe tip to D18. capture and post scope screen.
4. probe GND to power board VS2 probe tip to D19. capture and post scope screen.
Posted: 04:06am
08 Mar 2026
Bryan1
Ok got some scope pic's but it does help to read properly as I probed D1,D7,D18,D19 with gnd going to vbat ground
D1
D7
D18
D19
Now I will go and 3 and 4 like I should of.
Posted: 04:20am
08 Mar 2026
Bryan1
4.
Posted: 04:34am
08 Mar 2026
tinyt
With the board un-powered, measure the resistance of R1, R26, R27, and R52.
They are close to the TIP41/TIP42 pairs and all should measure around 20 ohms.
Posted: 04:47am
08 Mar 2026
Bryan1
OK got some scope pic's of the gate on each leg
Gate of Q3
Gate of Q14
Gate of Q25
Gate of Q19
R1, R26, R27 and R52 all measure 20 ohms
Posted: 05:02am
08 Mar 2026
tinyt
Looks like Q3 - Q8 mosfets are receiving the right gate signals.
Remove Q16, Q17, Q32 and verify that they are TIP41. Remove Q15, Q18, Q32 and verify that they are TIP42.
Measure resistance between gate and source/drain of Q14, Q19, and Q25.
   Page 19 of 28
