JAQForum Ver 19.10.27
Forum Index : Microcontroller and PC projects : MMBasic for Windows - betas
   Page 27 of 30
Posted: 06:44pm
02 Nov 2023
Martin H.
last version was b 19
if I type blind Mode 1
I get it to work ..
Where do I find the Options file?
It always sets it back to mode 9 and stays black
Posted: 09:59pm
02 Nov 2023
Turbo46
  Quote  Where do I find the Options file?
Mine is in the 'documents' folder and is called '.options'.
Bill
Posted: 10:30pm
02 Nov 2023
Turbo46
Sorry posted in error.
This seems to have fixed the bugs that I was interested in.
Bill
Edited 2023-11-03 08:42 by Turbo46
Posted: 10:55pm
21 Nov 2023
Goksteroo
Matherp.... can you have a look at this post... MMB4W - blit, programming or hardware error - help There is an issue when PAGE WRITE and PAGE RESIZE are used together, at least with MMB4W - mot sure on other versions.
Thanks,
Geoff
Posted: 07:59am
22 Nov 2023
Sorry, not something I can look at in the near future - no dev environment where currently located
Posted: 10:14am
22 Nov 2023
  Goksteroo said  Matherp.... can you have a look at this post... MMB4W - blit, programming or hardware error - help There is an issue when PAGE WRITE and PAGE RESIZE are used together, at least with MMB4W - mot sure on other versions.
Hi Geoff,
If Peter and/or A.N.Other haven't looked at this by the New Year then please drop me a PM and I'll see if I can do anything, but not before then, too much else to do.
Posted: 01:16pm
23 Nov 2023
Goksteroo
Thanks for the offer Tom.
I'm not so concerned now as I thought it might have been something in my code that was causing the problem and now it appears to be a non-fatal bug. I'm sure it will be dealt with in the near future.
In the mean time I can continue with my project knowing that my little bit of code was not the actual cause of the graphic artifacts. They will hopefully disappear when MMB4W is next updated.
Geoff
Posted: 03:04am
24 Nov 2023
mclout999
EDIT OK, sorry I got confused going back and forth to the search and the listing and posted this on the wrong thread. That being said I still can't find the last posting on the Betas for the CMM2s so I still need some help.  thank.
Hi all.  I have not seen anything on this subject for a while and I was trying to do a search on the forum for a subject started about having to use a VGA to HDMI dongle with the CMM2 where Matherp added a new offset command to adjust the screen positioning that worked pretty damn well and I lost my notes on how to set the setting.  I would also like to ask Matherp if the offsetting command was in the newest version and if not could they be added in.  If I flash a new version without them I go back to not being able to use my CMM2s.  I am wondering why I can't seem to find anything with the search system.  I tried limiting to my own user name and it still would not show me anything on the subject.  Thank you for any help you can give.
Edited 2023-11-24 13:08 by mclout999
Posted: 03:12am
24 Nov 2023
In your Browser search bar try:-
site: thebackshed.com "your search terms go here"
Posted: 06:34am
24 Nov 2023
mclout999
  phil99 said  In your Browser search bar try:-
Thanks but I did do that but auto-fill on Chrome filled in a wrong user name and it did not find it.  When I fixed that it came up.  https://www.thebackshed.com/forum/ViewTopic.php?TID=15805&P=1
Matherp posted a version here and the command syntax. It makes using a VGA to HDMI adapter very functional and as it is an option that is non-volital after you monkey around and get it as best you can it sticks for every mode you set.   Only a few modes are not perfect but He indicated many had those modes that did not work on certain monitors. I hope he maintains this option in future updates.
  Quote  matherp
Posted: 04:39am 16 Apr 2023
mclout999
Try this
CMM2V1.5.zip
Load the new firmware, you may get a garbled screen so before anything else note your current options (OPTION LIST) and then type
OPTION RESET
Then you can use a new command
OPTION HORIZONTAL OFFSET mode, offset
mode is the screen mode you want to tune (1 to 18)
offset is the offset in pixels to move the display horizontally (-128 to 127)
Once again thanks.
Edited 2023-11-24 16:36 by mclout999
Posted: 05:51pm
20 Dec 2023
5.07.03b21
MMBasic.zip
Contains everything needed to run PETSCII in the same way as the latest CMM2 beta
Edited 2023-12-21 03:53 by matherp
Posted: 07:04pm
20 Dec 2023
LeoNicolas
Has it support for gamepads?
Posted: 07:16pm
20 Dec 2023
No
Posted: 10:33pm
20 Dec 2023
For many months now across at least three versions of MMB4W, I get just a blank screen, like this:
I don't have a ">" prompt, and no matter how many times I hit <Enter>, I never get one. CLS RGB(RED) has no result. The window closes if I type "quit" and <Enter>.
I've deleted the .options file in MyDocuments without any change in behavior (it's recreated when I run MMBasic).
I'm running Win10. MMB4W worked for me for a long time after it was introduced. I have no idea what changed to cause this current behavior, and no exact memory of when it started.
Any ideas about how I may fix this?
EDIT: I've just found that if I type MODE 2, I get a prompt, and CLS RGB(red) and CLS work.
EDIT2: And now, everything runs. What weird state was I in that was fixed by entering MODE 2?
Edited 2023-12-21 08:44 by lizby
Posted: 10:44pm
20 Dec 2023
Press Auto on the monitor
Posted: 10:51pm
20 Dec 2023
  matherp said  Press Auto on the monitor
This is a laptop.
Posted: 04:37am
21 Dec 2023
Turbo46
I have been testing the INPUT command and the INPUT$ function after results from another post. I have an MM2 which is connected to COM3 and it is running the program:
DO
PRINT "Hello I'm the MM2"
PAUSE(10)
LOOP
I have verified the output using Teraterm
Using MMB4W running this program:
OPEN "com3: 38400" AS #2
test$ = INPUT$(20,#2)
PRINT test$
CLOSE #2
I get this result:
If I run this program:
input #2, test$
print test$
CLOSE #2
MMB4W opens and crashes and I see nothing
Both programs work as expected (by me) in MMBasic for DOS. Sometimes the result is garbled until it is synchronised by the PAUSE in the MM2 but that is not surprising.
I believe this is a bug or 2 unless I am doing something stupid.
Bill
Edit: Forgot to mention that TassyJim found this but it seemed to go unnoticed.
Edited 2023-12-21 15:25 by Turbo46
Posted: 06:03am
21 Dec 2023
Sending data out the com ports is working.
Just not receiving.
Tested with picomites and cmm2 (CH340)
Posted: 08:07am
21 Dec 2023
Try this. Definitely works for me talking to the console of a CMM2
MMBasic.zip
Posted: 09:12am
21 Dec 2023
Turbo46
Works the same as the previous one for me. Did you send the new version? It's the same size as before.
Bill
   Page 27 of 30
© JAQ Software 2025
