Posted: 06:01am 22 Dec 2023 Copy link to clipboard
TassyJim Guru
Every time you open a com port that has random data streaming in, It is worth flushing the buffer. A large buffer may take a few loops to clear it all.
do junk$ - input$(255,#3) loop until loc(#3) = 0
Posted: 06:20am 22 Dec 2023 Copy link to clipboard
disco4now Guru
TEST maybe in the source as a command. LIST FUNCTIONS works OK. LIST COMMANDS does not come back.
Posted: 08:18am 22 Dec 2023 Copy link to clipboard
Posted: 03:10am 23 Dec 2023 Copy link to clipboard
Turbo46 Guru
Thank you Peter.
That did fix the Test problem and the LIST COMMANDS.
I still have the problems with the MM2 connected and spitting out messages 19 to the dozen presumably the coms buffer is full when I run MMB4W:
This program still crashes MMB4W.
OPEN "com3: 38400" AS #2 input #2, test$ print test$ CLOSE #2
This program now prints nothing as if test$ is empty.
OPEN "com3: 38400" AS #2 test$ = INPUT$(20,#2) PRINT test$ CLOSE #2
Both programs work as expected in MMBasic DOS.
I tried a more realistic test and connected a CMM2 (changing the com port and the baud rate) and both of the above programs worked as expected when characters were printed. MMB4W did crash once while running the second program but I was unable to repeat it.
Bill
Posted: 03:31am 23 Dec 2023 Copy link to clipboard
phil99 Guru
I gave up on INPUT$(), INPUT works ok. Yes, it is very easy to make MMB4W crash.
'test 2.bas clear dim integer characters = 4, joystick 'data from controller/joystck dim integer flag, trigger = characters - 1 dim a$ open "com7:460800" as #3 'purge buffer (thanks Jim) pause 1 do: a$ = input$(255,#3) loop until loc(#3) = 0 close #3 pause 1
open "com7:460800,, buffer, trigger" as #3 pause 1
do If flag then if len(a$)=characters then joystick = val("&H"+a$) ? a$, bin$(joystick,characters*4) flag = 0 endif loop
sub buffer 'read buffer input #3, a$ inc flag end sub
' Program running on PicoMiteVGA ' 'dim integer m,n 'm=2^16 'do ' inc n ' n=n mod m ' pause 50 'loop
Edit. Data is received at 50mS intervals. Will see if it can go faster.
Edit 2. Seems ok at 5mS intervals, some errors at 1mS. (change Pause 50 in the VGA program)
Edit 3. Correction, on closer inspection there are occasional missing packets below 30mS. Edited 2023-12-23 14:19 by phil99
Posted: 04:30am 23 Dec 2023 Copy link to clipboard
panky Guru
Hi Bill, A couple of observations:-
In your first program example I never get a failure - works every time however test$ is alway empty. This is because the time taken to create and OPEN a receive buffer and the command to read the buffer with the INPUT statement is too short for any characters to be received. If you put a PAUSE 100 between OPEN and INPUT it correctly displays characters that have had time to get into the buffer.
The same is true for your second program - no time between OPEN and INPUT$ to allow characters to arrive in the buffer. Again a PAUSE 100 between the two will show received characters.
In all my testing, I have not had any crashes of MMB4W (b23). The only issues I have had are where there are more than 256 characters in the receive buffer without any CR LF in there - this results in a 'string too long error' as expected.
Purely as an observation, if you have an unknown length of data to be received at intermittent intervals, you may choose to insert a specific header byte in the data stream. You can then read and throw away bytes 1 at a time until your wanted message block occurs. You can then read in the required number of bytes (remembering the string length limit of 255).
Regards, Doug.
Posted: 04:48am 23 Dec 2023 Copy link to clipboard
phil99 Guru
Instead of a pause you can trigger an interrupt on the second last character for maximum speed. By the time the Sub starts the last character has arrived.
Posted: 06:07am 23 Dec 2023 Copy link to clipboard
Turbo46 Guru
Thanks Doug,
The PAUSE does work for both programs. Without it the first program DOES still crash MMB4W though and I don't think it should.
I have just tried a program with a lot of file I/O and that worked perfectly. I was worried that a PAUSE may be needed for that. But no.
While I understand your explanation and reasoning it is confusing that both programs work well in MMBasic DOS without a pause. A normal INPUT from the keyboard will wait until you type in something and hit <enter> and I realize that INPUT #nbr is normally for file I/O, it just doesn't seem to me as though it should need a PAUSE for it to work properly in this situation.
Bill
Edit: Thinking more about it, INPUT from a com port is more like a keyboard input and probably be treated the same way. My opinion for what it's worth. Edited 2023-12-23 16:42 by Turbo46
Posted: 07:11am 23 Dec 2023 Copy link to clipboard
TassyJim Guru
I think that having characters in the rec buffer when you open it can cause grief. I would definitely flush using INPUT$(255,$n) for reliable startup. I can't make it crash is the input chain is empty on startup.
It might depend on the make of USB TTL converter, just to make life interesting.
Another thing to remember, if you are using INPUT, it is looking for a LF not CR as the end of line. CRs are simply dropped.
Posted: 08:43am 23 Dec 2023 Copy link to clipboard
TassyJim Guru
The strange thing I found. At first, I could repeat Bill's error but when I went back to the original program after some experiments, nothing could make them fail...
Jim Edited 2023-12-23 18:44 by TassyJim
Posted: 08:46am 23 Dec 2023 Copy link to clipboard
Chopperp Guru
Hi
I can't get mode 16 to work. Nothing on the screen. Mode -16 & rest seem OK. Am I missing something?
Brian
Posted: 09:28am 23 Dec 2023 Copy link to clipboard
phil99 Guru
That may be the case. Sending from a MM2 via Geoff's ASCII Terminal to my program on MMB4W works perfectly but using a CH340 causes a "line too long" error. Appending Chr$(10) or Chr$(13) to each packet doesn't help. TeraTerm has no trouble reading it properly so maybe MMB4W is a bit more fussy.
Edit. Adding both CR and LF worked briefly then stopped and I can't get it to run again. Puzzling.
Edit 2. Returning to Geoff's ASCII Terminal and away MMB4W goes, streaming the 16 bit packets at 30mS intervals. Edited 2023-12-23 20:02 by phil99
Posted: 09:53am 23 Dec 2023 Copy link to clipboard
Turbo46 Guru
This is what I am sending to the coms port from an MM2. There is a 10mS PAUSE between each message. It makes MMB4W crash every time when it is running this program:
Trying other things may well produce other results but this particular sequence will crash MMB4W every time.
Bill
Posted: 10:02am 23 Dec 2023 Copy link to clipboard
matherp Guru
You are sending a continuous datastream at high speed and only doing a single read. With respect, this is a totally artificial situation which MMB4W doesn't handle - so be it.
Posted: 10:15am 23 Dec 2023 Copy link to clipboard
JohnS Guru
Change test$ to (say) a$ - does it still crash?
Posted: 10:22am 23 Dec 2023 Copy link to clipboard
phil99 Guru
Sending this from the MM2.
do:? "Hello from the MM2":pause 30:loop
to MMB4W works if via the ASCII terminal but not if sent via a CH340. In both cases TeraTerm receives the stream correctly.
Posted: 10:29am 23 Dec 2023 Copy link to clipboard
Turbo46 Guru
Yes John, I tried that when the 'test' problem was found. It also works with a PAUSE 100 after the OPEN command - go figure?
It looks like this particular subject is closed now.
Thanks everyone for your interest and have a MERRY CHRISTMAS.
Bill
Posted: 10:45am 23 Dec 2023 Copy link to clipboard
Turbo46 Guru
As my Irish friend would say "Well oil beef hooked".
I changed the delay from 10 to 30 and IT WORKS! At least from my MM2 with a Microbridge.
Thanks Phil.
Bill
Posted: 12:42pm 23 Dec 2023 Copy link to clipboard
JohnS Guru
Looks like a bug, though.
I feel it should work (as in: not crash MMB4W) no matter how fast chars are sent to MMB4W and whether the receiving program can keep up or not.
Posted: 11:12pm 23 Dec 2023 Copy link to clipboard
Turbo46 Guru
It is.
Bill
Page 29 of 30
