JAQForum Ver 26.09
Forum Index : Microcontroller and PC projects : PicoMite V7.00.00b8 and release candidates
   Page 3 of 13
Posted: 04:51pm
13 Oct 2026
Lyle
Try this PC3 build. You should be able to issue two separate connection commands:
bluetooth connect serial "rn52-98f5"
bluetooth connect speaker "rn52-98f5"
to get both up without having to enable/disable the broadcasts
Let me know if it works and I'll include it properly
PicoMitePC3V7.00.00RC1.zip
Posted: 05:21pm
13 Oct 2026
mozzie
Peter,
Tested and working, survives both PC3 and RN52 power cycles.
A couple of other minor ones found while testing:
Option Mouse Sensitivity doesn't seem to be restored on Option Disk Load (or not saved)
In the PC3 thread it mentions the "help" file being on the system, is this meant to be loaded as part of the firmware or simply that it can be loaded via Xmodem / Zmodem?
I'll see if I can figure out if the HM10 modules are genuine or not.
Regards, Lyle.
Posted: 09:31am
14 Oct 2026
mozzie
G'day Peter,
Some further testing of Bluetooth serial and both HM10 modules are working after AT+RENEW to reset factory settings.
This has also reminded me of a feature request I hope you would consider:
The original MicroMite allowed the COMn interrupt to be fired on the receipt of a specific char by using =n (=13 for CR) in the OPEN command parameter list. This was not AFAIK carried over to the PicoMite.
Is it possible to add this functionality, as it would make parsing variable length input from serial devices far more streamlined.
I get the feeling the PIC32 hardware may have made this simpler.
HM10 Modules:
I am reasonably certain these where purchased at the same time from the same shop, however it is also possible there are more here that have been mixed in and muddied the water...
Upper module in Pics:
HM10 - 1 Possibly genuine?
Chip marking - CC2540
AT+VERS? = HMSOFT V610
Most AT commands work
Lower module in Pics:
HM10 - 2 Possible fake?
Chip marking - CC2541
AT+VERS? = HMSoft V203
Few AT commands work but this is a very early version if VERS? is correct.
Also another couple of "rainy day" ideas:
Access to the A2DP "Remote Control" commands send from an BT Audio device so a program can act on them.
The ability to select multiple audio files to play in FM, so far I haven't found a way to do this. (Prompted by Grogsters post)
Once again, these are just food for thought, pretty stoked with what we have already.
Regards, Lyle.
Posted: 02:27pm
14 Oct 2026
toml_12953
If you're looking for idas for additions to MMBasic, how about a user-defined coordinate system? This would allow a program to run unchanged no matter what display is used. Example:
WINDOW 0,500,0,500 ' Define X-Axis as 0-500 and Y-Axis as 0-500 as well.
PIXEL 250,250,2
will print a dot in the center of the screen no matter what type of display is used.
For a Sine wave you could do this:
WINDOW 0,2*PI,-1,1 ' Domain: 0 to 2*PI, Range: -1 to 1
FOR I=0 to 2*PI STEP .05
PIXEL I,SIN(I),2
NEXT I
Without the WINDOW statement, PIXEL would act just as it does now so older programs would need no change.
Edited 2026-10-15 00:41 by toml_12953
Posted: 06:40pm
14 Oct 2026
terekgabor
Hello Peter!
In RC1 when I tried to use OPTION PICO PLUS 2 ON I got Error: Pin GP25 is in use.
Webmite 2350 build with Pimoroni Pico Plus 2.
In PIN LIST GP25 is boot reserved for CYW_43 WL_CS.
Error didn’t come in previous versions.
(Maybe something is related to OPTION CYW43 command?)
G@bor
Posted: 06:47pm
14 Oct 2026
There was a bug in previous versions GP25 is used for the cyw43 so can't be used for anything else. This was missed previously
Posted: 06:50pm
14 Oct 2026
terekgabor
Thanks! Does it mean OPTION PICO PLUS 2 ON will never work on W version of Pimoroni PP 2?
Edited 2026-10-15 05:16 by terekgabor
Posted: 09:57pm
14 Oct 2026
There is no such command - where did you get that from?
Posted: 01:12am
15 Oct 2026
Briano
From the User Manual for RC1 Page 131
  Quote  OPTION PICO PLUS 2 ON
or
OPTION PICO PLUS 2 OFF
RP2350B VERSIONS ONLY
Configures the firmware for the Pimoroni Pico Plus 2 board with a
single command. ON sets the heartbeat to the board’s LED pin and
enables the PSRAM fitted to the board (chip select GP47), then saves the
options and restarts. OFF disables the heartbeat and the PSRAM.
This command will generate an error on RP2350A based boards (eg, the
Raspberry Pi Pico 2).
Posted: 06:52am
15 Oct 2026
OK, sorry, forgot all about that. It only applies to the non-wifi version.
Posted: 06:55am
15 Oct 2026
terekgabor
Ok! Thank you Peter, I will use it for the non-W version.
G@bor
Posted: 07:10am
15 Oct 2026
I'll fix it in the next release so it works for both variants
Posted: 07:21am
15 Oct 2026
terekgabor
Thank you!
Posted: 01:19am
16 Oct 2026
Briano
Hi Peter.
I reported a problem in v6.04 of a buffer overrun when a TCP communication timed out. It was fixed in v7.0 Beta1,
but I discovered the problem has returned in both beta 8 and RC1.
I have not tested other betas between these. Can you check to make sure the fix is in 7.0 RCx?
Thank you.....Brian
  Briano said  Hi Peter,
Thank you for continuing to support MMBasic, particularly for PicoCalc.
I've been playing with getting Weather from OpenWeatherMap. I noticed when my WiFi signal is weak, and the connection time's out, my Basic program exits with an error message, then a few seconds later I see a register dump and the CPU restarts.
All works fine if there is no timeout.
I was wondering if PicoMite might be receiving the data late, trying to store the data into my buffer, but since the program crashed, maybe the buffer is gone.
Whatever the problem, is this something which can be fixed? (besides me getting a stronger WiFi signal)
thanks .....Brian
Posted: 07:47am
16 Oct 2026
Brian
The bug fix is definitely in RC1 and I am unable to reproduce. If you can post a test program that demoes the issue I can look at it further
Posted: 01:18pm
16 Oct 2026
V7.00.00RC2 is posted at
https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V7.00.00RC2
Release candidate 2 (V7.00.00RC2). RC2 is RC1 with the reports of the last three days answered.
New since RC1:
The file manager plays a track list: mark audio files with the space bar and press ENTER, step through them with . and , and it shows a cursor at its text prompts
On the Bluetooth host builds BLUETOOTH CONNECT SPEAKER | SERIAL | KEYBOARD says what a device is when its Class of Device does not
OPTION PICO PLUS 2 ON works on the Pimoroni Pico Plus 2 W.
Fixed since RC1
OPTION DISK SAVE omissions
PicoMiteRP2040MIN's I2C OLED,
structure, tokeniser, MATH, DIM, JSON$ and PRINT #GPS faults
PLAY on a directory from another drive,
PSRAM part larger than 8 MB, is now safely used as 8 MB.
MM.VER reads 7.000052.
Posted: 09:19pm
16 Oct 2026
homa
V7.00.00RC2 PicoCalc ST7365P: PIXEL() / BLIT READ wrong colours
> option list
PicoMite MMBasic RP2350A V7.00.00RC2
OPTION LCD SPI GP10,GP11,GP12
OPTION SYSTEM I2C GP6,GP7, SLOW
OPTION FLASH SIZE 4194304
OPTION LIBRARY_FLASH_SIZE  34000
OPTION COLOURCODE ON
OPTION DEFAULT COLOURS GREEN, BLACK
OPTION KEYBOARD PICOCALC
OPTION CPUSPEED (KHz) 252000
OPTION LCDPANEL CONSOLE ,, FF00
OPTION DISPLAY 26, 40
OPTION LCDPANEL ST7365P, PORTRAIT,GP14,GP15,GP13
OPTION BACKLIGHT KBD 32
OPTION BACKLIGHT LCD 48
OPTION SDCARD GP17, GP18, GP19, GP16
OPTION COMPILE ON
OPTION MODBUFF ENABLE  192
OPTION PLATFORM PicoCalc
DIM INTEGER c(4) = (&HFF0000, &HC0392B, &H1F4D2B, &H8A3B1F, &HC9A66B)
DIM INTEGER i, k
FOR i = 0 TO 4
 BOX 100, 100, 40, 40, 0, c(i), c(i)
 PRINT HEX$(c(i), 6); "  read "; HEX$(PIXEL(110, 110), 6);
 FOR k = 1 TO 4
   BLIT READ #1, 100, 100, 20, 20
   BLIT WRITE #1, 100, 100
   BLIT CLOSE #1
   PRINT " > "; HEX$(PIXEL(110, 110), 6);
 NEXT k
 PRINT
NEXT i
FF0000  read FC0000 > FC0000 > FC0000 > FC0000 > FC0000
C0392B  read E01C14 > F00C08 > F80404 > FC0000 > FC0000
1F4D2B  read 0C2414 > 041008 > 000804 > 000400 > 000000
8A3B1F  read C41C0C > E00C04 > F00400 > F80000 > FC0000
C9A66B  read E4D034 > F0E818 > F8F40C > FCF804 > FCFC00
Each 6-bit channel is read back as b5 b5 b4 b3 b2 b1 instead of b5 b4 b3 b2 b1 b0, so every READ/WRITE cycle shifts the channel one more bit. It looks like the read is sampled one bit late.
SPI-LCD.c ReadBufferSPISCR() lines 2051/2067/2086 (also ReadBufferSPI() line 1963): ST7365P is read at SPIReadSpeed (12 MHz). ILI9488/ILI9488P/ST7789B/ILI9481IPS use ST7789RSpeed (6 MHz). Maybe ST7365P needs the slow read too?
Matthias
Edited 2026-10-17 07:20 by homa
Posted: 09:51pm
16 Oct 2026
homa
V7.00.00RC1/RC2 – mounting the SD card also closes open files on A:
Hi Peter,
while testing on V7.00.00RC1 (PC3, OPTION LIST below) I found this: a RANDOM file opened on A: (#7) was closed when a file on B: (#9) was opened afterwards – next SEEK #7 gave Error : File number.
I think the reason is in InitSDCard() (misc/FileIO.c, same in RC2):
for (i = 0; i < MAXOPENFILES; i++)
   if (FileTable[i].com > MAXCOMPORTS)
       if (FileTable[i].fptr != NULL)
           ForceFileClose(i);
FileTable[] is a union of com/fptr/lfsptr, so this also hits LittleFS files on A:. Any (re)mount of B: (first access, or after an SD error) closes open A: files too.
Could InitSDCard()/InitUSBDrive() close only their own files (e.g. check filesource[i] == FATFSFILE)? Side note: this loop runs 0..MAXOPENFILES-1, CloseAllFiles() 1..MAXOPENFILES.
I will catch the error and reopen the file for now.
Regards, Matthias
PicoMitePC3 MMBasic USB RP2350B Edition V7.00.00RC1
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 16777216
OPTION KEYBOARD GR, 0, 1, 200, 75
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION RESOLUTION 640x480 @ 315000KHz
OPTION HDMI PINS  1, 3, 5, 7
OPTION WIFI behofam, *****************, Pico3, DE
OPTION TELNET CONSOLE ON
OPTION SDCARD GP33, GP30, GP31, GP28
OPTION KEYBOARD REPEAT 200,75
OPTION AUDIO I2S GP10,GP22', ON PWM CHANNEL 11
OPTION RTC AUTO ENABLE
OPTION COUNT GP34,GP35,GP36,GP37
OPTION COMPILE ON
OPTION PLATFORM PICO COMPUTER 3
OPTION PSRAM PIN GP47
Posted: 10:41pm
16 Oct 2026
Briano
  matherp said  Brian
Thanks Peter. I loaded RC2 and so far no crashes. It it re-appears I will post here with test code.
Thank you.....Brian
Posted: 07:52am
17 Oct 2026
Mattias
On the pixel read issue, try using the ILI9488P driver instead of the ST7365P. We don't really know what display the Picocalc actually uses and in fact different ones may be used in different devices
I'll look at the mount issue.
UPDATE:
Both issues found and fixed will be in the next release
Edited 2026-10-17 18:41 by matherp
   Page 3 of 13
