JAQForum Ver 26.09
Forum Index : Microcontroller and PC projects : Pico Computer 3 - One board to rule them all
   Page 5 of 11
Posted: 07:20am
30 Jul 2026
The inner tracks are usually half the weight of the outer ones, so if you are using 1oz copper board the inner layers will be 1/2oz.
I'd check your soldering *very* closely with magnification rather than blame the inner layers first. It's possible to get "whiskers" that are barely visible between close pads.
Posted: 07:22am
30 Jul 2026
It's a two layer board - there are no inner tracks
Posted: 07:45am
30 Jul 2026
Bryan1
That next batch of boards will be here next week so I will call in and say hello to Roger and ask if he do the smd soldering for me also find out whats going on with my board.
Not worth taking the risk with more boards until I can learn how to solder smd properly where watching Roger do it should give me the right idea.
Posted: 08:29am
30 Jul 2026
dddns
A question: I'm still looking for a permanent solution for the 3V3 power supply on my setup. I have a CH340 module with a voltage regulator, but it only supplies 250mA. Have you measured the current draw on VCC in your setup, or rather, would you say 250mA is enough (for the SD card, etc.)? I want to power the external connector separately using an AMS1117.
Posted: 08:56am
30 Jul 2026
Bryan1
Looking at the schematic the Vin for the wifi is next to the Gnd pin so whats the bet  there is a solder bridge across those pins, also on a closer look R91 and C124 got sucked up when I used my snapon solder sucker, now trying to solder those small chips back on is a challenge not for the faint hearted.
Posted: 09:02am
30 Jul 2026
R91 is essential. C124 probably not
Posted: 02:50pm
30 Jul 2026
LeoNicolas
Hi Peter
Is it feasible to create a new graphics mode? 320 4bpp where I can use the palette to fulfill the 16 colors?
This can speed up a lot the process to transfer the Another World framebuffer using the blit command. Currently I'm looping through all framebuffer memory positions, extraction each nibble, and calling pixel to set the pixel color.
I'm working on another game port. This new mode will be very useful for this new one as well
Edited 2026-07-31 07:56 by LeoNicolas
Posted: 02:31am
31 Jul 2026
Bryan1
Well I texted Roger this morning and as I was leaving got a txt message saying I had a package and low and behold my second batch of boards turned up
Roger desoldered the wifi chip and soldered it back on and he had some fun fitting the resistor back on as it was bigger. Now as there were no 10K resistors Roger did have 8.8K which should be close enough.
Just setup the repaired board and it booted straight into V0.12 so glad it's all fixed   Also now got a second board and with both having the chips added the fun can start with Claude where I want to get the 2 of them talking to each other.
regards Bryan
Posted: 06:56am
31 Jul 2026
Bryan1
Well it has been an interesting day   got both board talking with each other in the way sending files via the wifi.
First I tried using my mobile as the hotspot and got both connected and working then Claude said lets have a go with just the wifi and no phone
After my typos and copy/paste fun got the wifi between the boards going and just ping ponged a file back and forth   to make it was working.
So this is a good thought for my car club project as a few terminals will be made no wifi or cables needed as they just talk with other.
Posted: 07:12am
31 Jul 2026
  Quote  Is it feasible to create a new graphics mode? 320 4bpp where I can use the palette to fulfill the 16 colors?
What version of code are you talking about? MMbasic already does this (MODE 2 + MAP command/function)
Posted: 10:35am
31 Jul 2026
LeoNicolas
For the micropython version Peter
Posted: 08:59am
01 Aug 2026
Bryan1
Here is one thing that gets me when I had my pico2 setup playing mp.3's was a simple case of bringing FM up and clicking on the song. But since I have gone to micropyhon all I get when I click on the Music folder is
Music  <dir>
Traceback (most recent call last):
 File "<stdin>", line 1, in <module>
 File "pcfm.py", line 624, in fm
 File "pcfm.py", line 589, in loop
 File "pcfm.py", line 315, in open_sel
 File "pcfm.py", line 117, in set_path
 File "pcfm.py", line 123, in load
UnicodeError:
Now this is what Claude said
[CODEwell when I mentioned pico2 it was running mmbasic
That changes the comparison — MMBasic doesn't decode filenames as UTF-8 at all. It treats them as bytes and prints whatever's there, so a CP1252 accent shows as a garbled character but nothing breaks. MicroPython insists on decoding, and throws when it can't.
So it isn't a regression in this firmware, it's a difference between the two languages' handling of filenames. Less compelling as a bug report, though still worth raising — MicroPython on other ports generally copes with this, and the fix is the same either way.
The practical upshot is unchanged: rename the offending files to plain ASCII on your PC, or accept that /sd/Music can't be listed from Python. Playback by exact path should still work.]
So we need to work out why this won't work.
Regards Bryan
Posted: 10:11am
01 Aug 2026
Bryan1
To further on
[The real bug is the one underneath: os.listdir("/sd/Music") raising UnicodeError. That's genuine and worth reporting./CODE]
Posted: 10:48am
01 Aug 2026
LeoNicolas
Peter
For the micropython, I was thinking something similar to hdmi.RGB640_4, but with 320x240 resolution, something like hdmi.RGB320_4 with 16 colours indexed by the palette.
This will be useful for Another World and other games I want to port to the Pico 3 with micropython.
Posted: 10:50am
01 Aug 2026
LeoNicolas
[duplicated]
Edited 2026-08-01 20:51 by LeoNicolas
Posted: 10:54am
01 Aug 2026
Any chance of everyone raising MMbasic/Micropython/Fuzix issues on the relevant threads rather than this one?
Posted: 11:20am
01 Aug 2026
LeoNicolas
Sorry
I will repost it on the correct thread
Edited 2026-08-01 21:31 by LeoNicolas
Posted: 11:33am
01 Aug 2026
Micropython issues and questions
Fuzix issues and questions
MMBasic 6.03.00 issues and questions
Pico Computer 3 PCB issues and questions - HERE
Edited 2026-08-01 21:34 by matherp
Posted: 10:00am
03 Aug 2026
Anyone in the UK selling/ordering built Pico Computer 3 boards?
Posted: 11:41am
03 Aug 2026
romba6
  JohnS said  Anyone in the UK selling/ordering built Pico Computer 3 boards?
I was thinking of it and went to JLPCB to place an order this a.m and got as far as the BoM and they are showing no stock for the raspberry IC and one other component. I gave up as with my eyes and hands I wouldn't be able to fit my own.
   Page 5 of 11
