JAQForum Ver 26.09
Forum Index : Microcontroller and PC projects : PicoMiteVGA DEMO
   Page 7 of 14
Posted: 01:23am
14 Dec 2024
Turbo46
@ Stan,
You have found Tassy Jim's MMBasic help file. Here is the document referred to:
The CMM2 3D engine.zip please refer to that before asking any questions.
Bill
Posted: 04:14pm
24 Dec 2024
javavi
Xmas Tree
MODE 2
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE F
S=320
CLS :t=t+1
For i=155 To 165
 Line 160,40,i,230,,RGB(brown)
Next i
For i=0 To 900 Step 2
 Pixel i*5+Sin(i)*20,(t+i*40)Mod 136
 a=Pi*2/60*(i+t/3)
 z=Cos(a)*i/10+550
 x=Sin(a)*i/6*S/z+160
 y=(i/3-150)*S/z+120
 C=Rnd*&HFFFFFF
 Circle 160,26,3,,,,C
 If z<550 Then
   Circle x,y,1+i/300,,,C,C
 Else
   Pixel x,y,C
 EndIf
Next i
FRAMEBUFFER COPY F,N,B
Posted: 04:34pm
27 Dec 2024
javavi
Merry Christmas & Happy New Year!
MODE 2
FRAMEBUFFER create
FRAMEBUFFER write f
T$="Merry Christmas & Happy New Year!"
x=700:h=160
CLS
If x<-350 Then x=700
Text x,5*Sin(x)+10,T$,C,5
C=Rnd*&HFFFFFF:x=x-1
Text x,5*Sin(x)+10,T$,C,5,,C
C=RGB(BROWN)
Box 140,220,40,20,1,C,C
C=RGB(GREEN)
For i=10 To 110 Step 5
 Triangle h,i,h-i,i+i,h+i,i+i,C,C
Next i
For i=4 To 43 Step .1
 p=i+Timer\100
 If Cos(p)<0 Then
   C=Rnd*&HFFFFFF
   Circle h+2.5*i*Sin(p),i*5,2,,,C,C
 EndIf
Next i
For i=0 To h
 Pixel i+i,Rnd*240
Next i
FRAMEBUFFER copy F,N,B
Posted: 09:28pm
28 Dec 2024
javavi
Christmas Tree
https://github.com/anvaka/atree
MODE 2
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE F
max = 19
xScale = 6
zScale = 2.5
yScale = 11.5
dz = 640
phase=0
Dim redSpiral(2)=(RGB(Red),RGB(Myrtle),1)
Dim cyanSpiral(2)=(RGB(Cyan),RGB(Myrtle),0)
CLS
For i= -startFrom To max Step 0.08
 If (i<0) Or (i>max) Then Continue For
 createSpiral(redSpiral())
 createSpiral(cyanSpiral())
Next
Inc phase,0.1: If phase>6.28 then phase=0
Sub createSpiral(config())
sign = Choice(config(2),-1,1)
If config(2) Then
 foreground = config(0)
 background = config(1)
Else
 foreground = config(1)
 background = config(0)
EndIf
zoff = i*Sin(i+phase)
z = dz/(dz-sign*zoff*zScale)
x = sign*i*Cos(i+phase)*z*xScale+160
y = i*z*yScale+2
If zoff+sign*Pi/4 < 0 Then
 Colour (foreground)
Else
 Colour (background)
EndIf
Pixel x,y
End Sub
Edited 2024-12-29 19:01 by javavi
Posted: 08:45pm
16 Jan 2025
javavi
Lissaju 2   PicoMiteVGA/HDMI MMBasic V6.00.02
MODE 1
Option ANGLE DEGREES
FRAMEBUFFER CREATE
FRAMEBUFFER LAYER
RX=MM.HRes:RY=MM.VRes:CX=RX\2:CY=RY\2
Scale=0.95: AX=CY*Scale: AY=CY*Scale
a=1: b=0: p=0: f=0: c=0
CLS RGB(BLUE)
RBox 0,0,RX,RY
For y=80 To RY Step 80
For x= 8 To RX Step  8
Pixel x,y
Next x:Next y
For x=80 To RX Step 80
For y= 8 To RY Step  8
Pixel x,y
Next y:Next x
For y=0 To RY Step 8
Line CX+1,y,CX-1,y
If Not (y Mod 40) Then Line CX+2,y,CX-2,y
If Not (y Mod 80) Then Line CX+3,y,CX-3,y
Next y
For x=0 To RX Step 8
Line x,CY+1,x,CY-1
If Not (x Mod 40) Then Line x,CY+2,x,CY-2
If Not (x Mod 80) Then Line x,CY+3,x,CY-3
Next x
Triangle CX,0,CX-3,8,CX+3,8,,1
Triangle RX,CY,RX-8,CY-3,RX-8,CY+3,,1
Print @(CX-14,3) "Y"
Print @(RX-12,CY-16) "X"
FRAMEBUFFER WRITE F
 If p>360 Then p=0: EndIf
 If b>6   Then a=a+1: b=0: c=0: EndIf
 If a>5   Then a=1:   b=0: c=0: EndIf
 If c=50  Then
   f=1
   If a=Fix(b) Then f=0: c=0: EndIf
 EndIf
 If c=130 Then f=0: c=0: EndIf
 CLS 0 : Colour RGB(WHITE),RGB(BLUE)
 Print : Print " A="a: Print " B="b: Print " P="p
     sx= AX * Sin(p) + CX
     sy= AY * Sin(p) + CY
 For i= 0 To 360
     x = AX * Sin(a*i + p) + CX
     y = AY * Sin(b*i + p) + CY
     Line sx,sy,x,y
     sx=x: sy=y
 Next i
 FRAMEBUFFER COPY F,L,B
 Inc p: Inc c
 If  f=0 Then b=b+.02
Loop Until Asc(Inkey$)
Posted: 05:26pm
17 Jan 2025
stanleyella
I get a graticule and scrolling values in terminal but no Lissaju
stan
Posted: 05:41pm
17 Jan 2025
  Quote  I get a graticule and scrolling values in terminal but no Lissaju
You need to be running 6.00.02b0 and if running on a VGA version the CPU speed muust be >=252000
Posted: 05:58pm
17 Jan 2025
stanleyella
@matherp sir. is vga also hdmi. the layers like FRAMEBUFFER COPY F,L,B seem different and FRAMEBUFFER CREATE
FRAMEBUFFER LAYER.
I got vga and hdmi to test. it's in the manual?
amazing the improvements to mmb especially pico 2. best wishes, stan
I'll load te beta
Posted: 06:38pm
17 Jan 2025
stanleyella
loaded the beta and got Lissajous. interesting code and nice vga demo.
nice one @javavi
thanks @matherp sir
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.02b0
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD UK, 0, 0, 600, 150
OPTION CPUSPEED (KHz) 315000
OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0
works nice in mode 2 but not mode 3, not enough heap mem
really is a nice program... we should all know trig
Edited 2025-01-18 04:55 by stanleyella
Posted: 07:01pm
17 Jan 2025
stanleyella
my efforts with Lissajous was a sine on audio left right but delay one so out of phase then put sound int 2 a-d channels but back shelf
Posted: 07:47pm
08 Feb 2025
javavi
Punched tape chart recorder
c0=RGB(rust):c1=RGB(green):c2=RGB(white):c3=RGB(blue)
CX=MM.HRes\2
MODE 2: CLS
FRAMEBUFFER LAYER
Text 160,200,"- PicoMite -","CM",1,3,RGB(myrtle)
FRAMEBUFFER WRITE L
Blit 0,0,0,1,MM.HRes,MM.VRes-1
Line 0,0,MM.HRes,0,,0
If t=0  Then For i=10 To MM.HRes-10 Step 2:Pixel i,1,c0:Next
Inc t: If t>20 Then t=0
If t0=0 Then For i=10 To MM.HRes-10 Step 20:Pixel i,1,c0:Next
Inc t0: If t0>2 Then t0=0
If t1=0 Then Line 0,2,6,2,4,c0:Line MM.HRes-6,2,MM.HRes,2,4,c0
Inc t1: If t1>10 Then t1=0
Pixel 140*Sin(d1)+CX,0,c1
d1=d1+1: If d1>360 Then d1=0
Pixel 100*Cos(d2+p2)+CX,0,c2
Pixel  20*Sin(d3)+CX,0,c3
d2=d2+3: If d2>360 Then d2=0: Inc p2,5
d3=d3+10: If d3>360 Then d3=0
Pause 10
Loop While Inkey$=""
Posted: 10:39pm
08 Feb 2025
stanleyella
only half waveform
Posted: 05:44pm
09 Feb 2025
Martin H.
I found a beauty small C64 program on Facebook  and translated it to MMBASIC.
Mode 2
for i=1 to 8000
S=-log(.1+RND)
t=s*200:U=S*20*SIN(t):V=S*25*COS(t):P=S*3
C=COS(P):S=SIN(P)
X=U*C+V*S:Y=-U*S+V*C:R=X*X+Y*Y*Y
Z=40*EXP(-R/1000)*(RND-.5)
X=X*1.4+y*.6:Y=x*.2+y*.8
if ABS(x)<127 AND abs(Y)<=87 THEN PIXEL 160+x,120+y
NEXT
Posted: 07:24am
10 Feb 2025
  javavi said  Punched tape chart recorder
CX=MM.HRes\2
MODE 2: CLS
FRAMEBUFFER LAYER
FRAMEBUFFER WRITE L
Pause 10
Maybe you should first choose the mode, and then after that decide what CX should be set to, since MM.Hres is different when in mode 1.
Posted: 05:19pm
10 Feb 2025
javavi
  Volhout said  Maybe you should first choose the mode, and then after that decide what CX should be set to, since MM.Hres is different when in mode 1.
Yes, that's right.
MODE 2: CLS
CX=MM.HRes\2
FRAMEBUFFER LAYER
FRAMEBUFFER WRITE L
Pause 10
Posted: 06:57pm
17 Feb 2025
javavi
Punched tape recorder with instrument scale
Option DEFAULT INTEGER
MODE 2: CLS
c0=RGB(myrtle):c1=RGB(green):c2=RGB(white):c3=RGB(cyan)
c4=RGB(yellow):c5=RGB(midgreen)
CX=MM.HRes\2:Am=150:St=1:Clr=RGB(white)
FRAMEBUFFER LAYER
Box 0,0,MM.HRes,20,,c4:Box 0,22,MM.HRes,MM.VRes,,c5
For i=10 To MM.HRes-10 Step 5: Line i,8,i,12,,c4:Next
For i=10 To MM.HRes-10 Step 10:Line i,6,i,14,,c4:Next
FRAMEBUFFER WRITE L
Blit 0,10,0,11,MM.HRes,MM.VRes-11
Line 0,0,MM.HRes,0,12,0
If t=0  Then For i=10 To MM.HRes-10 Step 2:Pixel i,16,c0:Next
If t0=0 Then For i=10 To MM.HRes-10 Step 20:Pixel i,16,c0:Next
If t1=0 Then Line 3,21,8,21,4,c0:Line MM.HRes-8,21,MM.HRes-4,21,4,c0
X0=Am*Sin(d1)+CX
Triangle X0,10,X0-4,1,X0+4,1,c3,c2
Line X0,12,X1,13,,Clr
X1=X0
d1=d1+St
If d1>360 Then d1=0:Am=150*Rnd:St=10*Rnd+1:Clr=&HFFFFFF*Rnd
Pause 10
Edited 2025-02-18 04:59 by javavi
Posted: 09:39am
16 Mar 2025
javavi
Square Art   black and white, but also in color
 M=Int(2*Rnd)
 If M Then MODE 1 Else MODE 2
 XR=MM.HRES
 YR=MM.VRES
 For I=0 To 1000
   X=Int(XR*Rnd)
   Y=Int(YR*Rnd)
   W=Int(100*Rnd+4)
   H=Int(100*Rnd+4)
   C=Int(&HFFFF00*Rnd+255)
   F=Int(2*Rnd)
   If F Then Box X,Y,W,H,,C Else Box X,Y,W,H,,C,F
   Box X+1,Y+1,W-2,H-2,,0
   Box X-1,Y-1,W+2,H+2,,0
 Next
 Pause 2000
Posted: 11:06am
17 Mar 2025
Hi Vadim,
I thought this would be a boring one, but it turns out as one of the more interesting demo's. Especially the switching between mode 1 and mode 2 makes it interesting.
Tested on v6.00.02rc5 on RP2040 VGA.
Posted: 06:35pm
23 Mar 2025
javavi
  Martin H. said  I found a beauty small C64 program on Facebook  and translated it to MMBASIC.
Galactica B/W & Colour
Dim CM(6)=(0,8,10,12,14,13,15)
Colour Map CM(),CM()
If Cint(Rnd) Then MODE 1 Else MODE 2
XC=MM.HRES\2:YC=MM.VRES\2
r1=200:r2=250
t1=200:t2=3
For N=1 To 5
 For I=0 To 10000
   L=-Log(Rnd)
   T=L*t1
   U=L*r1*Sin(T)
   V=L*r2*Cos(T)
   P=L*t2
   c=Cos(P)
   s=Sin(P)
   X=U*c+V*s
   Y=-U*s+V*c
   R=X*X+Y*Y
   Z=400*Exp(-R/100000)
   Z=Z*(Rnd -.5)
   Y=Y+Z+Rnd*50
   X=X-Z+Rnd*50
   xp=XC+X*.21+Y*.09
   yp=YC-X*.03-Y*.12
   If Pixel(xp,yp) Then
     Pixel xp,yp,CM(N+1)
   Else
     Pixel xp,yp,CM(N)
   EndIf
 Next
Next
Posted: 11:58am
02 Apr 2025
javavi
Vertical Scrolling Clock
Const Mode.N=2
Const Font.N=1
Const T.Scale=4
Const T.Size=Len(Time$)
MODE  Mode.N
Const X.Res=MM.HRES,Y.Res=MM.VRES
Font  Font.N
Const X.FSize=MM.Info(FONTWIDTH)
Const Y.FSize=MM.Info(FONTHEIGHT)
Const X.Offset=X.FSize*T.Scale*T.Size\2
Const Y.Offset=Y.FSize*T.Scale\2
Dim integer X.Dir=1,Y.Dir=1
Dim integer X.Pos=MM.HRES\2,Y.Pos=MM.VRES\2
Dim Clr(15)=(0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15)
Colour Map Clr(),Clr()
FRAMEBUFFER LAYER 0
FRAMEBUFFER WRITE L
Font 9
Print @(0,0);
For n=1 To (X.Res\8)*(Y.Res\8)
 Print Chr$(32+Int(Rnd*3));
Next
Blit READ  1, 0,0,MM.HRES,1
Blit 0,1,0,0,MM.HRES,MM.VRES-1
Blit Write 1, 0,MM.VRES-1
Blit Close 1
Pause 20
FRAMEBUFFER WRITE N
If C=0 Then C=Int(Rnd*15)+1
Text X.Pos,Y.Pos,Time$,"CM",Font.N,T.Scale,Clr(C)
Inc X.Pos,X.Dir:Inc Y.Pos,Y.Dir
If X.Pos-X.Offset<0 Then X.Dir=1
If X.Pos+X.Offset>MM.HRES Then X.Dir=-1
If Y.Pos-Y.Offset<0 Then Y.Dir=1:C=0
If Y.Pos+Y.Offset>MM.VRES Then Y.Dir=-1:C=0
FRAMEBUFFER WRITE L
DefineFont 9
04200808
80402010 08040201
01020408 10204080
08080808 08080808
End DefineFont
   Page 7 of 14
