Forum Index : Microcontroller and PC projects : galilean moons
| RicM Regular Member Joined: 05/02/2022 Location: AustraliaPosts: 56 |
Dear Members, Dose anyone have a program that calculates the position of the 4 main moons of Jupiter for either the CMM or the CMM2. Kind Regards, RicM |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1153 |
Here you can find a "appJupiter.ino". He also ported it to BASIC - but I can't find the source code anywhere... Frank |
| cdeagle Senior Member Joined: 22/06/2014 Location: United StatesPosts: 269 |
Attached is a QuickBasic program that performs these calculations. I've also included the issue of Celestial Computing in which it was published. The port to MMBASIC should be straight forward except for the graphics. Needs double precision MMBASIC. ccv1n4.pdf galilean.zip |
| retepsnikrep Senior Member Joined: 31/12/2007 Location: United KingdomPosts: 134 |
Very interesting Celestial Computing pdf.. Clever cookies... Gen1 Honda Insights. |
