Local Time 09:31 22 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA DEMO
     Page 14 of 14
Bleep
Posted: 07:03pm 10 Nov 2026
Here is a CSub version.
This gets it down to 35mS, to be honest you might as well stick with your original and replace the 'Sprite' For 'Blit' which gives 45mS all in standard Basic.
Option Default None
Option Explicit
MODE 2 'MODE 7 for MMB4W
Randomize (Timer)
CLS
Dim Integer tt,f,fire(160,20),fire2(160,20),ranr(2048)
Dim Integer rp,y,y1,yy,xx,ff(160),aa(160),bb(160)
For f=0 To 2047:ranr(f)=Int(Rnd*4):Next
'Prepare source
Dither 0,RGB(RED):Box 8,0,8,2,,RGB(RED)
Dither 8,RGB(255,64,0):Box 16,0,8,2,,RGB(255,64,0)
Dither 16,RGB(255,128,0):Box 24,0,8,2,,RGB(255,128,0)
Dither 24,RGB(yellow):Box 32,0,8,2,,RGB(yellow)
Dither 32,RGB(White):Box 40,0,2,2,,RGB(White)
For f=0 To 20:Blit read f+1,f*2,0,2,2:Next
CLS 0
Box 0,238,320,2,,RGB(white)
For f=0 To 160:fire(f,20)=20:Next
tt=Timer
rp=Int(Rnd*2048)
For y=0 To 19
 y1=y+1
 yy=198+(y<<1)
 xx=0
 animate
 For f=0 To 159
  If ff(f) Then Blit Write ff(f),aa(f),bb(f),0
 Next
Next
Print @(0,0);Timer-tt;"     "
'Pause 20' for MMB4W
' --- mmb2csub: animate replaced by a CSUB; original follows
Sub animate
Local Integer f,r,x,xr,fr
 For x=0 To 159
   r=ranr(rp)
   xr=(x+(r)) Mod 160
   fr=fire(xr,y1)-r:If fr <0 Then fr=0
   ff(x)=0:If fire2(x,y)<> fr Then  fire(x,y)=fr:fire2(x,y)=fr:ff(x)=fr+1:aa(x)=xx:bb(x)=yy
   Inc xx,2:Inc rp: If rp>2047 Then rp=0
 Next
End Sub
Sub dither x As Integer,col As Integer
 Pixel x+2,0,col:Pixel x+4,0,col:Pixel x+6,0,col
 Pixel x+7,0,col:Pixel x+5,1,col:Pixel x+7,1,col
End Sub
' --- mmb2csub: generated code for animate
' The wrapper keeps the original name, so call sites are unchanged.
Sub animate
 Local Integer __gt(10)
 __gt(0) = Peek(VARADDR aa%())
 __gt(1) = Peek(VARADDR bb%())
 __gt(2) = Peek(VARADDR ff%())
 __gt(3) = Peek(VARADDR fire%())
 __gt(4) = Peek(VARADDR fire2%())
 __gt(5) = Peek(VARADDR ranr%())
 __gt(6) = Peek(VARADDR rp%)
 __gt(7) = Peek(VARADDR xx%)
 __gt(8) = Peek(VARADDR y%)
 __gt(9) = Peek(VARADDR y1%)
 __gt(10) = Peek(VARADDR yy%)
 animateK __gt()
End Sub
CSUB animateK INTEGER
00000000
'animateK
4646B5F0 465746DE 4D7E2200 682BB5C0 69DBB08A 6FDB6801 601A605A 69DA682B
6FD46B03 60E1469A 61216881 61616901 61A16981 61E16A01 62636A81 62216B83
469B62A3 62E36C03 6C834698 63239307 6D036826 63639308 D1002E00 6863E0BB
23009309 92002200 46539301 46C24F65 E0499303 18EB9D04 9B059304 9B0400DD
C303195B 681B4653 009B4698 015B4443 00DB4443 197618F6 2501C603 46632600
41711940 465BC303 9B06CB03 191B68DB 9B08C303 6853CB03 C303191B 21002002
CB0C465B 414B1812 20014659 2100C10C CB0C9B03 414B1812 DC042B00 2180D105
428A0109 2200D301 99032300 C10C2400 9A019900 18C92301 683B4162 92019100
6FDC69DB D05929A0 330168A3 059B60A3 683BD103 6A9B69DB 683B4798 69DA9903
6FD36809 6A1B00C9 CB18185B 99019800 18C00026 24A44161 59140064 22A0001D
47A02300 9907683B 680969DB 008B6FDA 9206185B 6994015B 00DB185B 00C018E3
CB03181B 002B9404 1AC00034 320C41A1 DA012900 21002000 25009B00 689300DC
469C2600 466344A4 4653C360 9D00681B 009B4698 015B4443 69164443 950500DB
46A818F5 464544A0 4285682D E761D000 686D4645 D000428D E77FE75C 2B009B01
2000D1A2 9B092100 B00A6063 46BBBCE0 46A846B2 2780BDF0 6B13017F 47980038
6020682B 6FDB69DB 682B605E 6FDC69DB 93096863 D80042BB 6066E733 69DB682B
E72C6FDC E000ED08
End CSUB
Edited 2026-11-11 05:54 by Bleep
Martin H.
Posted: 12:22pm 11 Nov 2026
Thank you for your support Kevin...
Up until now, I've equated Sprite and Blit in my mind
Exchanging the "SPRITE" with "BLIT" speed up from ~80 mS to ~50mS
Using your CSUB Version speeds up  ~50mS to ~29mS = 34FpS
So you can really call it an animation
'no comment
Posted: 03:28pm 11 Nov 2026
Hi Kevin, Martin,
Since RP2040 VGA does not provide COMPILE, and mine runs at 252MHz, there is a large difference between the normal version and the CSUB version.
Normal with Sprite : 580ms
Normal with Blit   : 520ms
CSUB version       : 200ms
Martin H.
Posted: 05:19pm 11 Nov 2026
  Volhout said  Hi Kevin, Martin,
Currently, the program calculates using 160x20, or 3,200 cells per frame.
The sprites are 2x2-pixel blocks. If the sprites were enlarged to 4x4, only 800 calculations per frame would be needed. While this would lower the resolution, it should quadruple the speed.
'no comment
Posted: 09:00am 13 Nov 2026
Javavi,
I have been obcessed with the maze program you posted few posts back.
It is a very nide "screen saver" with nicely balanced PAUSE statements, so it is entertaining to watch. Not to fast, not to slow. And the slightly offset green line once a solution is found is also giving a feeling of depth.
Graphically very nice.
But what intrigues me is the algorithm use. The maze is generated using Wilsons algorithm (randomly removing walls until a loop is detected, then closing the loop, and starting a new path at random -not visited- location. This creates a so called "perfect maze". A maze where any location has a path to any other location.
So a maze is generated from random numbers.
Then there is the solver. The solver walks a path until hits a crossing (a "choice") and at that crossing it takes a randomly chosen direction. Until it hits a dead end. Then it walks back until the last crossing, and takes another direction.
A simple algorithm, and essentially you only need to remember the "choices" that where  the last ones taken.
But maze creation is random, and solving is random. So it is very unpredictable what will happen. Below are some of the extreme runs.
This is a maze with many crossings, and in solving it the solver took 101 (out of 106) wrong choices.
This is a maze that has only few crossings in the shortest path, and the solver took 4 out of 4 choices immediately correct (that is statistically not special).
Edited 2026-11-13 19:02 by Volhout
Bleep
Posted: 06:11pm 14 Nov 2026
Hi Martin,
Attached is the flame demo, again, which I have managed to squeeze a bit more speed out of, now about 26.5mS on a 2350 @ 378Mhz. Presumably will also speed up the 2040 as well.
Regards Kevin
flamedemoc.zip
javavi
Posted: 06:30pm 18 Nov 2026
Stellar Steam
MODE 1
Color RGB(Cyan)
CLS
Type star_t
 x As Integer
 y As Integer
 z As Integer
End Type
Dim astar(300) As star_t
Dim oldstar(300) As star_t
For i=0 To 300
 astar(i).x = Rnd * MM.HRES
 astar(i).y = Rnd * MM.VRES
 astar(i).z = Rnd * MM.HRES\2
Next
 For i=0 To 300
 If astar(i).z<1 Then astar(i).z=300 Else astar(i).z=astar(i).z-1
 For p%=0 To oldstar(i).z
   Circle oldstar(i).x, oldstar(i).y, p%,,,0,0
   If astar(i).z<>300 Then
     x0=Int(2*astar(i).z+astar(i).x/(1+astar(i).z/30))
     y0=Int(astar(i).z+astar(i).y/(1+astar(i).z/30))
     Circle x0, y0, p%
   EndIf
 Next
 oldstar(i).x = x0
 oldstar(i).y = y0
 oldstar(i).z = 5/(1+astar(i).z/20)
 Next
Loop While Inkey$=""
Edited 2026-11-19 04:31 by javavi
javavi
Posted: 04:07pm 20 Nov 2026
"Spiderweb" screensaver
MODE 1
Color RGB(Cyan):CLS
Dim Integer radius=MM.VRES\2
Dim Integer x_center=MM.HRES\2
Dim Integer half_line_number=MM.VRES\5
Dim Integer line_count=half_line_number*2
Dim Integer start_x(line_count)
Dim Integer start_y(line_count)
Dim Float base_angle_step = Pi / half_line_number
Dim Float anim_angle_step=base_angle_step/5000
Dim Integer current_counter=Int(Rnd*100000)
Dim Integer i
Dim Integer end_x, end_y
Dim Float angle
For i=1 To line_count
 angle=i*base_angle_step
 start_x(i)=x_center+Cint(radius*Cos(angle))
 start_y(i)=radius+Cint(radius*Sin(angle))
Next i
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE F
 CLS
   angle=(i*anim_angle_step)*current_counter
   end_x=x_center+Cint(radius*Cos(angle))
   end_y=radius+Cint(radius*Sin(angle))
   Line start_x(i), start_y(i), end_x, end_y
 Next
 Inc current_counter,15
 FRAMEBUFFER COPY F,N,B
Wölfi
Posted: 05:54pm 20 Nov 2026
So amazing!
     Page 14 of 14
